Staro 01.04.2012., 20:10   #1
marcozu
Datum registracije: Mar 2012
Lokacija: Županja
Postovi: 7
Evo ovako,svako malo mi se pojavi blue screen ,poslije dizanja sustava dobijem ovu poruku:
Prva:Files that help describe the problem:
C:\Windows\Minidump\040112-16520-01.dmp
C:\Users\Marco\AppData\Local\Temp\WER-29000-0.sysdata.xml
ili
Druga:Files that help describe the problem:
C:\Windows\Minidump\032512-15678-01.dmp
C:\Users\Marco\AppData\Local\Temp\WER-28080-0.sysdata.xml
Inace u pitanju je laptop Lenovo z575,AMD A6 Quad core 3400M,8gb ram,SATA 750gb,AMD Radeon™ HD 6650M 2GB dual graphics.
Imam jos uvijek garanciju,nadam se da netko ima nekakvu ideju.Veliki pozdrav.
Izvinjavam se, još da navedem OS Windows 7 Ultimate sp1 64bit...
Zadnje izmijenjeno od: nino. 01.04.2012. u 20:43.
marcozu je offline   Reply With Quote
Staro 01.04.2012., 20:41   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Iskljuci automatically restart da vidis sto kaze bsod kad ga dobijes, ili pregledaj dump file sa nekim od alata.
How to read the small memory dump files that Windows creates for debugging
IE6
Linux is Not Windows
Staro 01.04.2012., 22:35   #3
marcozu
Lokacija: Županja
Postovi: 7
Evo odrađena analiza s Whocrashed professional edition 3.01,evo rezultata:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Sun 1.4.2012. 13:57:29 GMT your computer crashed
crash dump file: C:\Windows\Minidump\040112-16520-01.dmp
uptime: 01:53:39
This was probably caused by the following module: ntoskrnl.exe (nt+0x80640)
Bugcheck code: 0x101 (0x31, 0x0, 0xFFFFF88002FD5180, 0x3)
Error: CLOCK_WATCHDOG_TIMEOUT
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
uptime: 01:53:39
This was probably caused by the following module: hal.dll (hal!HalReturnToFirmware+0xB2D)
file path: C:\Windows\system32\hal.dll
description: Hardware Abstraction Layer DLL
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Tue 27.3.2012. 22:01:35 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032812-15350-01.dmp
uptime: 03:48:11
Bugcheck code: 0x101 (0x31, 0x0, 0xFFFFF880009E7180, 0x1)
On Mon 26.3.2012. 17:52:23 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032612-16068-01.dmp
uptime: 02:43:36
On Sun 25.3.2012. 13:19:26 GMT your computer crashed
crash dump file: C:\Windows\Minidump\032512-15678-01.dmp
uptime: 03:00:04
On Fri 9.3.2012. 23:38:38 GMT your computer crashed
crash dump file: C:\Windows\Minidump\031012-16582-01.dmp
uptime: 00:00:17
Bugcheck code: 0x50 (0xFFFFF8A002537000, 0x0, 0xFFFFF880041706C4, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Bug check description: This indicates that invalid system memory has been referenced.
Po ovome je problem u pregrijavanju,da li netko zna možda dobar software za provjeru procesora?Ili neki prijedlog u vezi ovoga.Veliki pozdrav.
Staro 01.04.2012., 22:37   #4
nino
nino's Avatar
Postovi: 12,597
Staro 02.04.2012., 00:33   #5
Joke
N00B
Joke's Avatar
Postovi: 3,886
Potpisujem link od kolege Nino, ali pogledaj tu ovaj http://www.sevenforums.com/crash-lockup-debug-how/63501-stop-0x101 -clock_watchdog_timeout-troubleshtg.html"]link da znas sto ti je radit.
IE6
Zadnje izmijenjeno od: Joke. 02.04.2012. u 02:03.
