Staro 21.03.2012., 08:56   #301
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
GK110 Specifications Approximated
Even as launch of the GK104-based GeForce GTX 680 nears, it's clear that it is emerging that it is not the fastest graphics processor in the GeForce Kepler family, if you sift through the specifications of the GK110 (yes, 110, not 100). Apparently, since GK104 meets or even exceeds the performance expectations of NVIDIA, the large-monolithic chip planned for this series, is likely codenamed GK110, and it's possible that it could get a GeForce GTX 700 series label.
3DCenter.org approximated the die size of the GK110 to be around 550 mm², 87% larger than that of the GK104. Since the chip is based on the 28 nm fab process, this also translates to a large increment in transistor count, up to 6 billion. The shader compute power is up by just around 30%, because the CUDA core count isn't a large increment (2000~2500 cores). The SMX (streaming multiprocessor 10) design could also face some changes. NVIDIA could prioritize beefing up other components than the CUDA cores, which could result in things such as a 512-bit wide GDDR5 memory interface. The maximum power consumption is estimated to be around 250~300 Watts. Its launch cannot be expected before August, 2012.
http://www.techpowerup.com/162765/GK...roximated.html
C L O W N I N G A R O U N D
Staro 21.03.2012., 09:04   #302
sapunko_HR
Datum registracije: Oct 2011
Lokacija: _
Postovi: 277
Koliko je jača gtx 680 od 7970 to je nevjerojatno
Trebao sam čekat
sapunko_HR je offline   Reply With Quote
Staro 21.03.2012., 12:15   #303
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,552
Autor sapunko_HR Pregled postova
Trebao sam čekat
Pa nije toliko, ovi leakani benchevi su jako nvidia-centric a na vecim rezama 7970 dostize 680. A na eyefinity rezama ce se tek primjetiti sto je manji framebuffer.
Staro 21.03.2012., 12:44   #304
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Autor the_ghost Pregled postova
To je nebitno jer ni jedna od njih nece imat dovoljo sirove snage za zahtjevnije igre u tak visokim rezolucijama sa max detaljima i aa. MSAA i supersampeling aa doslovno prozdiru memoriju i potrosnja skace za skoro duplo. Bez toga to nije neki problem i 2gb tu nebu premalo. Slozio sa Eyefinity jos sa 2 x 5870 1gb i bez beda igrao sve bez aa..
Staro 21.03.2012., 13:51   #305
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,552
Ljudi igraju BF3 sa jednom 7970 u eyefinity rezama, npr: http://hardforum.com/showpost.php?p=...6&postcount=11
Staro 21.03.2012., 14:00   #306
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Na HardOCPovom forumu nije nista cudno. Sigurno da ga igraju ali ne sa sa aa a onda vise ne treba triliun gb vrama. Pola te price je cisti marketing. Sa dve grafe jos to mogu probavit ali sa jednom je 2gb taman sa ovakvim igrama i grafama.
Staro 21.03.2012., 14:38   #307
rockodaddy
rockodaddy's Avatar
Datum registracije: Aug 2010
Postovi: 207
Mišljenja sam da gtx680 nije mogao oprati hd7970 da bi gk110 već bio tu.
Uvidjevši da nema potrebe za tim odgoda gk110 je najnormalnija stvar koja je mogla usljediti.Smatram da nas tek čeka savršenstvo od čipa jer Nvidia sada ima stvarno vremena da ga doradi do bola.
Learn to listen carefully to others' opinions about controversial things, or things they know about and you do not
rockodaddy je offline   Reply With Quote
Staro 21.03.2012., 18:15   #308
seno
seno's Avatar
Datum registracije: Dec 2009
Lokacija: Bosna
Postovi: 762
Jasta "uvidjeli" haha, da su imali spreman bacili bi oni njega kao meso vukovima. "Do bola" i nije bas nesto 40% brza od dk104 / amd next generation 25-30% brza od svoje 7970 i opet isto. Naravno to je samo moje misljenje kao nekog ko igra samo jednu igricu , ali dosadi ljudima citati "gk110 will be able to run whole world as single chip". Isjecite to dodajte realnosti i idemo opet na standard sematiku grafickih.
seno je offline   Reply With Quote
Staro 21.03.2012., 18:31   #309
pci_e3x
Premium spammer
pci_e3x's Avatar
Lokacija: D.Zagora
Postovi: 776
Staro 21.03.2012., 19:46   #310
Ordem
Datum registracije: Sep 2010
Lokacija: Vk
Postovi: 572
Autor MAGARAC Pregled postova
koliki je aliasing pri eyefinity rezolucijama (cak i na 2560x1600)? mislim jel doista potreban AA sa tolikim pixel countom?
Autor rockodaddy Pregled postova
cim je dual gpu automatski znaci da ne moze biti savrsenstvo
srot driveri (i kod amda i nvidije) + velicina kartice + potencijalno pregrijavanje + buka
Ordem je offline   Reply With Quote
Staro 21.03.2012., 20:30   #311
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,544
Staro 22.03.2012., 00:18   #312
rockodaddy
rockodaddy's Avatar
Postovi: 207
srot driveri (i kod amda i nvidije) + velicina kartice + potencijalno pregrijavanje + buka [/QUOTE]
GK110 nije dual kepler već single gpu kartica koja bi se trebala zvati gtx685.Pa klaun je to postao na početku stanice i kolega u postu poviše tvoga,ali tebi se to ne čita.
Staro 22.03.2012., 00:42   #313
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Autor Ordem Pregled postova
Isto ti je jer ionak uglavnom buljis u srednji monitor i 1080p rezoluciju koju on prikazuje. Ovo ostalo je periferno i ne tak bitno da se vide takvi detalji. Nisam dugo igral nista na tri monitora ali neke igre su trebale malo aa. Ja se rade odreknem detalja nego aa ali opet netko drugi ne..
Kad ce te recezije vise? Opet je AMerika centar svijeta..
Zadnje izmijenjeno od: MAGARAC. 22.03.2012. u 01:57.
Staro 22.03.2012., 01:13   #314
KorisNick
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
Autor Pupo Pregled postova
De molim te, ovaj put mi stvarno reci u kojoj trgovini ti kupiš televizor vrhunskih dimenzija za 2000kn? Aj nemoj ko prošli put što nisi htio reći di uzimaš top procesore tak jeftino!
Nema potrebe da se hvatate svega doslovno, govorim "od oka", dakle možda fulam 500-600 kuna u cijeni al otprilike točno govorim, npr meni brat kupio Grundig televizor 82 inca za 2200kn. Odličan televizor, ono švabo napravio ko za njega. No nije to bitno, bitno je da su oni ipak malo previše omastili brkove, mislim na Nvidiju i AMD-R, a upravo preko naših leđa. No da ne davim više s time, nije mi namjera bila pokretat neke kilometarske rasprave, već samo djelomično ukazat da ipak malo previše zarađuju na našim leđima. Ovako nam režu meso s leđa, radikalno da ne može radikalnije. Još kad se nadovežu naši političari, eto ti dobitne kombinacije za bankrot.
dobrodosao u kapitalizam.
naravno da nabijaju cijene svijesno i nenormalno posto:
1) unatoc takvim cijenama uspiju prodati sve (zakon ponude i potraznje - sto veca potraznja za necim, to veca i cijena proizvoda)
2) nemaju trenutno konkurencije i mogu odredjivati cijene novog hardwera
doista ne vidim sta je tebi tu sporno
takva praksa postoji vec duze od stoljeca.
sigurno se nece odmah u startu prilagodi tebi koji si mozes priustit samo jeftini/srednji segment grafickih pa ponudit 680 za max 2000kn
nema veze sto mogu prodat sve sto proizvedu za duplo vise.
doista ne vidim u cemu je problem
ako si ne mozes priustiti high end kupi si middle/low end
ti bi i ovce i novce, tj sve najbolje komponente po pristupacnoj cijeni
nvidia, ati, intel i ostali sigurno sa dobrim razlogom naplacuju toliko high end komponente
da znas koliko im dodje R&D za svaki od tih cipova (i to pogotovo kad se prelazi na nizi proizvodni proces)...moraju nekako pokriti te troskove.
konkurencija je itekako zdrava sto se tice low enda (ponajvise zahvaljujuci intelu)
a i middle enda posto se te graficke dobro prodaju
a šta ti misliš, da ja siromah ne bi volio sebi priuštit 680tku? pa baš zato i plačem, što nemam dovoljno love za nju.
Nemam ni ja Todorica, fala boga da nemam takvog starog ( jer bi vjerojatno vozio neki Mercedes SL i trosio tisuce eura po cajkama na sponzoruse i vjerojatno zavrsio na Karibima na odikavanju od neceg) i imam placu u toj kat a zadnjih 10 godina i vise stalno imam love za gluposti. Prije sam si mogo uzet neki Autic od te lova a danas se zadovoljim komadom boljeg HWa. Ne sjedim doma i placem nego iskoristim svaku priliku da uzemem sto sastrane i trudim se da sto manje gubim kad vec kupujem i prodajem.
AMD je zajedo ovaj put jer su stavili previsoku cijenu sa 7970. Mogli su komotno ic sa 100$ nize pa bi i 680 bila jeftinija a druga stvar je 28nm koji jos nije uhodan. Da je Nvidia prva izasla mislim da bi i oni napucali takvu cijenu. Moglo bi bit svega uskoro jer lufta za spustanje ima puno kod oba tabora..
Evo Afterburner vec radi. Voltaza i sve bez kemijanja ili cekanja. Vjerojatno su i driveri vec dobri.
http://www.techpowerup.com/162719/MS...-Tweaking.html
a šta da vam kažem, jednostavno prilike su takve, da ću se načekat dok kupim neku pravu zvijerku. iako ne bunim se ni sa ovim srednjim slojem. trenutno sam na Gforce 560Ti, i zadovoljan sam, al naravno uvijek težim boljem a kad vidim kakve su cijene novih modela mrak mi padne na oči.
Zadnje izmijenjeno od: KorisNick. 22.03.2012. u 01:22.
KorisNick je offline   Reply With Quote
Staro 22.03.2012., 01:17   #315
KorisNick
Postovi: 260
mod briši dupli.
Staro 22.03.2012., 08:18   #316
Ordem
Lokacija: Vk
Postovi: 572
a vise ne mogu visit na forumu svaki dan (napokon dobio posao bogu hvala ), tak da samo letimicno prelijetam preko postova
ugl mislio sam da je gk104 single chip rijesenje a gk110 dual gpu posto su vec performanse gtx680 kartice iznad 7970
tj da je gtx680 nvidia single chip high end a da ce gk110 biti dual gpu odgovor na buduci ati 7990
lol pa ako nvidia izda jos gk110 koji je ohoho brzi od 7970 i onda jos dual gpu rijesenje ati nece imati nikakav odgovor na to..
Staro 22.03.2012., 10:56   #317
sapunko_HR
Lokacija: _
Postovi: 277
Još mi samo preostaje da nvidia stavi manju cijenu od HD 7970nevjerojatno koliko je GTX680 jača od HD7970 a pogotovo HD 7950
Nadam se samo da će cijena bit visoka,sukladno i performansama
Staro 22.03.2012., 11:32   #318
the_ghost
lar~
the_ghost's Avatar
Postovi: 1,552
That is my EXACT current setup. A single 7970 and 3 24" screens. I get 45-65 FPS in BF3 on Ultra Textures AA High everything else on medium and SSAO. Game looks and plays fantastic. Every other game I can max out besides Metro of course.
Posto ne igram BF3 ne znam sto je tocno AA high ali ocigledno mu je ukljucen.
Staro 24.03.2012., 23:25   #319
KorisNick
Postovi: 260
Meni je iskreno čudno da je Nvidia izbacila opet jače grafulje, iako sam za zeleni tabor, kad sam vidio stavke AMD-R i Nvidije bio sam uvjeren da će ih AMD-R ovaj put poderat. Sve je upućivalo, da će blaga dominacija zelenih ostat prošlost, kad opet iznenađenje na moje oduševljenje.
Samo glupo mi je da se toliko recenzija izbacuje za 680tku, a za 660tku na koju ja ciljam i za koju imam para se praktički ništa ne priča. Zanimaju me stavke za ostale modele, i naravno cijene da mogu točno odredit koja mi je najisplativija solucija. No za to ću se, kako stvari stoje još neko vrijeme morat strpit.
Staro 25.03.2012., 00:01   #320
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Igra medium sa FXAA na high bez MSAA. Trebao je napisat FXAA high. U igri ima FXAA i MSAA x2 i x4 kao i u jos dosta njih a sad ce bit i ovaj treci.
FXAA je bolje nego nista ali ne pegla neke linije kao MSAA i vidi se razlika sa i bez.
Staro 25.03.2012., 09:19   #321
sapunko_HR
Lokacija: _
Postovi: 277
Došla POV GTX680 u MagazinRS
Staro 25.03.2012., 23:42   #322
KorisNick
Postovi: 260
Prejebeno izgleda, blago onima koji imaju para za tu ljepoticu.
Jel se zna otprilike kad dolazi model 660Ti, ili kako će se već zvati?
Staro 26.03.2012., 15:09   #323
Doink the Clown
Postovi: 6,214
Staro 27.03.2012., 11:14   #324
nexusone
Datum registracije: Apr 2008
Postovi: 139
nexusone je offline   Reply With Quote
Staro 27.03.2012., 11:53   #325
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
GK106 se nigdje ne spominje. Da li je moguće da će od GK104 napraviti 4 SKU-a, svaki sa jednim SMX blokom manje? Ili će čekati kraj godina pa upotpuniti ponudu sa GK110 i GK1x6 i nazvati je serijom 7xx? Do tada Fermi popunjava ponudu.
cccp je offline   Reply With Quote
Staro 28.03.2012., 10:15   #326
nexusone
Postovi: 139
GEFORCE GTX 670TI and GTX670 to hit late-April, or early-May
EDIT:
Kepler keeps on giving: GK106 specifications leaked
To bi trebala biti GTX660/Ti:
28nm TSMC lithography based on Kepler
210mm2 die size
Two GPC
Four SMX
768 CUDA cores
64 texture units
24 ROPs
1.5/2GB RAM
192-bit memory interface
No frequencies have been specified
Zadnje izmijenjeno od: nexusone. 30.03.2012. u 13:07.
Staro 03.04.2012., 17:40   #327
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,227
http://videocardz.com/31650/geforce-...-512bit-memory
GeForce GTX 685 (GK110) Features 4GB 512-bit Memory, 25% Faster than GTX 680
Staro 03.04.2012., 20:36   #328
Doink the Clown
Postovi: 6,214
Uh uh, ovo je sve zanimljivije, posebno mi se sviđa ovih 25%
Staro 03.04.2012., 20:40   #329
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Opa ovo se isplati cekat
Staro 03.04.2012., 20:43   #330
cccp
cccp's Avatar
Postovi: 1,030
Ne isplati se jer je pitanje da li ćeš je dočekati
