Povratak   PC Ekspert Forum > PC Ekspert > Novosti
Staro 13.03.2012., 22:38   #31
sultz34
uglymadafaka
sultz34's Avatar
Lokacija: eternalrecession
Postovi: 478
đžizus, slijep kod zdravih ociju, svaka ti dala zzzz ...
Neću žvaku, 'oću kusur.
sultz34 je offline   Reply With Quote
Staro 14.03.2012., 14:06   #32
lolofuxy
lolofuxy's Avatar
Datum registracije: Jun 2010
Postovi: 3,319
A da ovo mod rađe pobriše da nebi bilo , iako su šanse za osvajanje 1:100000000000 al za svaki slučaj.
You guys are doing awesome on finding the images! We have a lot of entries already and many of you have quite a few bonus entries from your friends entering the sweepstakes.
Just a reminder: We want to keep this contest fair and reward those that went through the challenge of finding the images. Therefor ANYONE FOUND TO BE SHARING THE IMAGE NUMBERS OR LOCATIONS/URLs WILL BE AUTOMATICALLY DISQUALIFIED FROM THE SWEEPSTAKES LETS KEEP IT FAIR AND HONEST
Keep on crushing this sweepstakes, you guys are rockin on this one!
lolofuxy je offline   Reply With Quote
Staro 14.03.2012., 14:25   #33
syss
syss's Avatar
Postovi: 10,805
Autor lolofuxy Pregled postova
1:100000000000...
su šanse da će oni pratiti ovu temu na pce u hrvacka, balkan, skoro evropa
Staro 10.05.2012., 22:31   #34
Postovi: 8,202
Fractal najavio novi fan kontroler. Sumnjam da će se ikad pojaviti kod nas, ali držim fige, možda nam se i smiluju. Uglavnom, sviđa mi se, a i 36W po kanalu nije malo.
http://www.pohrani.com/f/25/IU/MDwmt...2338500154.jpg
Autor Fractal
Announcing the new Adjust 108 Fan controller!
"The new Adjust 108 fan controller from Fractal Design offers a simple and effective option to adjust the speed of your case
fans. With a brushed aluminum front panel and smoothly moving sliders it not only emanates quality but also robustness and precision.
The Adjust 108 Fan Controller manages a total of six fans with a maximum of 36W per channel, the sliders are grouped in two banks of three for ease of use. With a bi-color LED beneath each of the six sliders the controller indicates the speed
of the fan not only by the slider itself but also the color of the LED, where white describes a low RPM and Blue a high RPM"
EDIT:
Što to ni [img] neradi u ovom podforumu? čemu
Staro 10.05.2012., 22:33   #35
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Baš sam ga maloprije snimio na techpowerup-u, lijepo izgleda, još i da ima pokoji display...
C L O W N I N G A R O U N D
Staro 10.05.2012., 22:44   #36
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
i ja ga vidjeh maloprije na overclock.net, bas sam trazio tak nes ovih dana i ovo narucujem s eBaya, ak nebu kod nas bilo. super izgleda, nije prenakiceno sa nepotrebnim stvarima i uklapa se u Arc Mini.
Shockre je offline   Reply With Quote
Staro 11.06.2012., 20:54   #37
Postovi: 8,202
Za sve Fractaloljupce,
Fractal je predstavio 2 nova kućišta, iz isto tako nove serije, pod imenom Node. Kućišta su u HTPC/desktop izvedbi, ali zadržavaju klasičan Fractal izgled i jednostavnost. Konkretno, radi se o
Fractal Node 304
Mini ITX, DTX motherboard compatibility
2 expansion slots
6 – supports either 3.5" or 2.5" HHD / SSD
ATX PSUs, up to 160mm in length (To fit in combination with a long graphics card, PSUs with modular connectors on the back typically need to be shorter than 160 mm)
Graphics cards, up to 310mm in length, when 2 HDD brackets are removed (Graphics cards longer than 170 mm will conflict with PSUs longer than 160mm)
Tower CPU coolers, up to 165 mm tall
Case dimensions: 250 x 210 x 374 mm
Case volume: 19,5 Liters
Net weight: 4,9 kg
te
Fractal Node 605
ATX, microATX, Mini ITX, DTX motherboard compatibility
7 expansion slots
4 - supports either 2.5" or 3.5" HDD / SSD
1 slim-line (only supported with mATX or smaller motherboards)
PSU compatibility: 180 mm (including any modular connectors) with both hard drive cages mounted or 190 mm (excluding cables and any modular connectors) with one hard drive cage mounted
CPU cooler compatibility: 135 mm with side-mounted fans - For coolers with top-mounted fans, Fractal Design recommends that you add at least 30 mm clearance for decent airflow
Case dimensions: 445 x 164 x 349 mm (excluding front panel - 440 x 162 x 341 mm)
Net weight: 6,0 kg
Node 304 kućište je zaista malo no opet dovoljno veliko da stane dobar HTPC unutra, ali zato je u Node 605 moguće ugurati i dosta jači komp, sastavljen od komponenti standardne veličine.
Šta reći, nego da Node 304 ozbiljno pikiram i nadam se da će se uskoro pojaviti kod nas u trgovinama.
Staro 11.06.2012., 21:08   #38
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
Definitivno Node 304 za jedan HTPC.
Staro 11.06.2012., 21:41   #39
syss
syss's Avatar
Postovi: 10,805
dobar 605 do-ba-r!
Staro 12.06.2012., 11:45   #40
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,253
Pupo, ako se ne varam ti si prodao svog Arc Midi? Smije se znat razlog?
Meni danas treba stić iz ADM-a..
EDIT: a može bit da sam se i zeznuo, izgleda da nisi ništa prodao
Zadnje izmijenjeno od: Omerta. 12.06.2012. u 12:41.
Staro 12.06.2012., 12:25   #41
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,717
Autor syss Pregled postova
dobar 605 do-ba-r!
Jaaaaooooo, predobar je!!
Zna li se možda cijena?
Ivo_Strojnica je online   Reply With Quote
Staro 12.06.2012., 13:02   #42
Postovi: 8,202
Suggested price za Node 304 je 90$, odnosno 160$ za Node 605. Kolika će cijena bit kod nas, možemo se samo moliti za milost uvoznika Navodno že vani biti dostupni u 8. mjesecu.
Autor Omerta Pregled postova
Je, ošao je Fractal nažalost, u korist LianLi-a. Al to će se promjenit jednog dana opet u korist Fractala
Staro 06.07.2012., 20:09   #43
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
Za sve vlasnike R3-ica jedna lijepa vijest.
Od osmog mjeseca u Fractalovoj ponudi naći će se bočna stranica sa prozorom
Crna verzija
Bijela verzija
Staro 06.07.2012., 22:13   #44
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Zanimljivo... Meni se svidja
Nadam se da ce bit dostupno u RH
Campeonato je offline   Reply With Quote
Staro 07.07.2012., 08:59   #45
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
Evo saznao sam i cijenu. 19.99 $
Staro 07.07.2012., 12:54   #46
Postovi: 8,202
Znaci kod nas 200kn minimalno, ako uopce bude dostupno
Staro 08.07.2012., 12:03   #47
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Autor Pupo Pregled postova
Jeftinije bi ispalo da sam izrezes lim i stavis plexi
Staro 20.07.2012., 12:50   #48
Postovi: 8,202
Define R4
Autor Introducing Define R4
The Fractal Design Define R4 is the latest in the Define Series of computer cases offering minimalistic and stunning Scandinavian design fused with maximum sound reduction, configurability and functionality.
The Define R4 side and front door panels are fitted with dense, sound-absorbing material making it a benchmark for noise reduction. Moreover, the Define R4 accommodates up to 8 HDDs, all modern graphics card sizes, and multiple ventilation options - including two standard Silent Series R2 hydraulic bearing fans - to keep internal components at optimal temperatures.
For ultimate functionality, the Define R4 features a front interface with USB 3.0 and an integrated three-speed fan controller behind the front panel door.
Define R4 Black Pearl
Define R4 Titanium Grey
Define R4 Arctic White
Kako gore sve već piše, sada i službeno izlazi nasljednik definea, model R4. Zadržane su više manje sve karakteristike starog R3, uz neke promjene poput:
- podržava "onthefly" dva 240 slim radijatora
- prihvat za 2 SSD-a na MBO trayu
- šire kućiše nego prije za još lakši kejbljvb
- i ono najbitnije, mogućnost jednostavnog uklanjanja oba HDD kaveza
Staro 20.07.2012., 13:05   #49
veve
woot!!!
veve's Avatar
Postovi: 2,495
Evo i videa za bolji pregled promjena i novosti i jedan review.
veve je offline   Reply With Quote
Staro 22.07.2012., 11:13   #50
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,576
crko mi onaj bracket s potenciometrom za ventove... kučište mi je na stolu i samo vidim kako ventovi stanu.. vrtim, ne radi.. uštekam jedan vent direkt na ploču radi.. znači potenciometar crko.. dal to pokriva garancija, i ako da, dal moram slati cijelo kučište?
radi se o arc midi
T0mB1ll je offline   Reply With Quote
Staro 22.07.2012., 11:31   #51
Shockre
Shockre's Avatar
Lokacija: Dublin
Postovi: 582
vrlo vjerojatno moras nosit cijelo sto naravno nema smisla. al mozes i poslat mail fractalu i oni ce ti poslat novi za dzabe.
Staro 23.07.2012., 23:05   #52
Omerta
Omerta's Avatar
Postovi: 3,253
Autor T0mB1ll Pregled postova
radi se o arc midi
Prodam ti ja svoj, ne koristim ga..
Staro 23.07.2012., 23:26   #53
lolofuxy
lolofuxy's Avatar
Postovi: 3,319
radi se o arc midi
Imao sam istu situaciju, pošalješ im mail, opišeš problem i pošalješ im serijski broj kućišta koji ti je vrlo vjerojatnu na dnu kućišta s prednje strane.
Daš im svoje podatke, adresu i za tjedan dana dobiš paket s cijelom zamjenskom kutijom uključujuči šrafiće i potenciometar.
KLIK
U međuvremenu se strpiš i spojiš sve ventove na matičnu
I za kraj trebalo bi te ispast 0 kuna, barem mene je
Staro 02.08.2012., 11:55   #54
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,576
samo da javim, kontaktirao FD, poslali mi cijeli kit (šarafi, potenciometar, vezice, poklopac za kučište..) ide plus za njih..
Staro 04.08.2012., 17:39   #55
sapunko_HR
Datum registracije: Oct 2011
Lokacija: _
Postovi: 277
Kad će define r4 u hr?
sapunko_HR je offline   Reply With Quote
Staro 04.08.2012., 22:09   #56
Nacki
Faktor nesreće
Nacki's Avatar
Datum registracije: Nov 2011
Lokacija: Sesvete, Zagreb
Postovi: 219
Autor sapunko_HR Pregled postova
ja sam trazio, nisam nigdje vidil
inace, imam neki filing da se biti puno skuplji od R3
Ja bi rado da MSAN pocne uvozit ventove i ostale njihove umotvorine, a ne da trazim njihove ventove ko pokisli sunce
Nacki je offline   Reply With Quote
Staro 04.08.2012., 22:15   #57
sapunko_HR
Lokacija: _
Postovi: 277
Autor Nacki Pregled postova
Ako bude skuplji ne kupujem
Evo šta su mi rekli u fractalu:
"Since the R4 has reached the majority of the European markets I would expect it to reach Croatia in the near future.
The price in different regions may vary so I cant say what the exact price will land on in Croatia, but it will have a similar price to the R3. Should be around €100"
Staro 04.08.2012., 23:34   #58
Nacki
Faktor nesreće
Nacki's Avatar
Postovi: 219
Ako bude tako super, samo sto mi se ipak R4 nije svidio toliko da bi ga bas isao kupovat
inace, neznam politiku MSANa, ali ako im negdje na lageru vise R3, ovaj ce biti ziher skuplji
ja bi rađe eksperimentiral s njihovim napajanjima
Staro 05.08.2012., 11:19   #59
explorer 4
explorer 4's Avatar
Postovi: 517
Evo gledam sad i Define r4 je lakši 2 kila od r3, a veći je po dimenzijama.
Štedili su negdje :O
explorer 4 je offline   Reply With Quote
Staro 05.08.2012., 11:35   #60
sapunko_HR
Lokacija: _
Postovi: 277
Autor explorer 4 Pregled postova
Gdje si to vidio,koliko vidim razlika je 12.5kg vs. 12.3(define r4) netto
Dakle malo je lakši,baš me zanima gdje su štedjeli,a koliko mm je debeo lim u r3
Sviđa mi se i arc,možda i on dobi nasljednika
