#1891 |
Postovi: 4,069
#1892 |
Datum registracije: Mar 2012
Lokacija: Zaprešić
Postovi: 236
#1893 | |
Lokacija: C-Hill
Postovi: 12
Stock ROM i a.war-ov su imali istu adresu, a jučer sam instalirao ICS CM7 - teammat3 i MAC adresa se promijenila. Također imam sx763 i koristim MAC address filtering (za brdo uređaja.... od 3 stolna računala, 4 laptopa i 4 mobitela od kojih je jedan stock U8650 a drugi sa ICS CM7, jedan SE i jedan HTC) i sve radi u najboljem redu te nisam imao nikakvih problema sa upisivanjem MAC adresa. btw, zna li netko kako doći u onaj "secret menu" pošto mi na ICS CM7 ne reagira na *#*#2846579#*#* ??? (konketno zanima me dual microphone postavka) |
#1894 | |
Postovi: 419
Prepare two sets of SD card for upgrade SD card 1 Preparation 1. Copy the dload folder to SD card(root directory) 2. After copying is complete Please check that the following file is present dload/update.app SD card 2 Preparation 1. Create a New folder and name it as dload in SD card(root directory) 2. Copy the file update.app from vendor folder in PC to the dload folder in the SD card Insert the SD card 1 into the handset. Pressing the VOLUME UP key and VOLUME DOWN key, and then press the POWER key to power simultaneously on the phone and enter the Software Upgrade Mode. When the progress bar stop, the phone will restart automatically, and will bootup and come to Idle Screen. Make sure your handset is power off. Insert the SD card 2 into the handset. Pressing the VOLUME UP key and VOLUME DOWN key, and then press the POWER key to power on the phone and enter the Software Upgrade Mode. When the progress bar stop, the phone will restart automatically, and will bootup and come to Welcome Screen. PS Napominjen da ovu proceduru nisam ja proba, kopirana je iz Huawei pdf fajla (Software Upgrade Guideline). Pozdrav Zadnje izmijenjeno od: nino. 06.03.2012. u 17:39. |
#1895 | |
Postovi: 117
Sve to mora biti u rutu kartice. Meni je zaštekao nakon obavljenog posla. Baterija van nutra. sve postavke ispočetka, ali ima zastor! I da..kartica nemora biti formatirana.. Na svojoj imam cyan, zadkin, neku mjuzu..i još hrpu stvari.. |
#1896 | |
Datum registracije: Aug 2011
Lokacija: Ogulin
Postovi: 6
Dode mi "Povezivanje nije uspjelo" "Problem pri čitamnju s poslužitelja" Inace mi je normalno radio na stock pa.. |
#1897 | |
Datum registracije: Nov 2011
Postovi: 185
#1898 | |
Lokacija: C-Hill
Postovi: 12
Tako da s tim nisam bio prezadovoljan po pitanju upotrebljivosti. Prednost pred stockom je bila ta da je bilo oslobođeno više RAM-a i unutarnje pohrane. Dekodirao sam mobitel prije stavljanja a.war-a, a jučer sam instalirao ICS CM7 i ne koristim ga više za pozive pa mi ne smeta tiša slušalica, a ostale se prednosti gadno osjete. Prokleto je brz i fluidniji na 600MHz koje nisam dizao. Za bateriju ću još vidit jer sam ju stavio u štedljiv režim (kod a.wara nisam previše prčkao po mobu koliko sad po ICS-u tako da mi je tamo potrajala 3 dana i pala na 20%) Ugrađeni 360Launcher widget za kill-anje pozadinskih aplikacija tu na ICS CM7 mi oslobodi i do 80ak MB RAM-a (stock je išlo do 35MB, a.war do 40-50 MB) Unutarnja pohrana mi je na 131MB ICS (stock 80ak MB, a.war 120ak MB) AnTuTu skor na 600MHz RAM : 115 CPU integer : 203 CPU float-point: 152 2d graph : 289 3d graph : 562 Database IO : 135 SD card write (7.5MB/s) : 75 (SAMSUNG 8GB CL-10) SD card read (16.6MB/s) : 166 CPU freq : 600 MHz Total score : 1697 |
#1899 |
Datum registracije: Dec 2011
Postovi: 177
pozz ljudi..ja sam rooto mob s onim superoneclick-om..jos prije pa znaci ako zelim staviti novi 2.3.5 update moram li odrootat da bi stavio update na 2.3.5 ? Ako ne onda samo downoloadam update s ove stranice http://www.huaweidevice.co.in/Support/Downloads/ stavim "u8650.zip" u dload kartice(netreba odzipat jelda)..onak kak je keioffice reko ugasim mob i stisnem sve vol+, vol- i power zajedno...ajde mi to potvrdite..jer nisam siguran..strah me da nes ne zeznem.. i jos pitanje..onaj kod za secret menu to nemoram za novi rom radit neg dok cu ga rootat ponovo? i dali kad stavim taj update 2.2.5 gubim bas sve na sd? p.s. kolko sam skuzio nakon kaj skinem update..odzipam ga na kompu (ima oko 200mb) i kopiram samo dload folder (s update app) i u root kartice..ugasim mob stisnem one 3 tipke i to bi trebalo bit to..ak se ne varam ![]() Zadnje izmijenjeno od: Caks. 06.03.2012. u 10:46. |
#1901 |
Datum registracije: Sep 2011
Postovi: 42
Jel jos tko trazi unlock huawei-a. mislim da imam dobar algo za kalkulaciju |
#1902 |
Postovi: 185
usrani vendor sto sam ga i instalirivao.. prvi put kad sam stavio 2.3.5 kamera je imala 5mp, i normalno boot android animaciju, instaliram vendor i bude 3mp kamera itd..odlucim pobrisat sve i ponovo stavit samo 2.3.5 al on i dalje ima 3mp a ne ko prije 5mp |
#1903 |
420
Lokacija: Le Molve
Postovi: 1,576
#1904 |
Lokacija: u kući
Postovi: 10
jel ko proba inst taj novi update, jer kad san ga skinija onda u zipu unutra pise india_trench nesto, pa sad neman pojma jel to odgovara na sve ili samo iz odredenih drzava edit ---- evo sad san procita official manual za update na 2.3.5 i unutra ima nekih screenshotova i po meni nema nikakve rezlike naspram 2.3.3 osim cloud app (valjda) tako da ga ja necu jos update-at.... i ja nezz kakva vam je kamera, al probajte skinut zadnju masku (poklopac bat) i onda probajte slikat, ja sam sebi iscupa onu plastiku sto pokriva kameru.. je da ima prasine malo vise, al zato kamera je 10x bolja Zadnje izmijenjeno od: Luksi. 06.03.2012. u 13:39. |
#1905 |
Postovi: 185
na ovome 2.3.5 originalniom, nije mi više 5mp kamera od kad sam stavio vendor onaj i da sad šteka ko lud... izbrišem sve i ponovo idem stavit 2.3.5 ali ne stavljam taj vendor i kad se update završi opet sve isto koda sam stavio vendor???? |
#1906 | |
Lokacija: u kući
Postovi: 10
tu imas sve stock verzije, pa probaj ga instalirat na 2.3.3 pa na 2.3.5 |
#1907 | |
Postovi: 185
neznam zasto... prvi put sam ovaj 2.3.5 rom stavljo preko supersonicgenov4 i kad se intalirao imao sam 5mp kameru itd sve radilo super, i stavim taj vendor kao za notifikacija, i sad sam fleshao mob za 5 custom romova i dva put sa originalnim 2.3.3 al kad idem stavit ovaj novi 2.3.5 (nediram vendor uopce) opet kad se boota rom je kao s vendorom znaci bez 5mp kamere, s notifikacijama u baru i nekim dodatnim glupostima intaliranim kojih nije bilo s vendorom....MOLIM POMOĆ kako vratit da mi bude 5mp bez notifikacija u baru jer ovako mi je mob cijeli spor neznam ni ja zasto Zadnje izmijenjeno od: goranszd. 06.03.2012. u 15:34. |
#1908 |
Bannija :D
Lokacija: Sisak
Postovi: 1,098
Mene zanima jedna druga stvar. Znam da se e mail može forwardat tako da se pošalje u obliku sms-a, a da li se kako na dotičnom telefonu, uz pomoć nekakve aplikacije može napraviti obrnuto, da mi sve dolazne poruke budu poslane na moju mail adresu? Ako da, molio bih da mi netko objasni kako ![]() |
#1911 | |
Postovi: 4,069
Mislio sam da ne treba sve isponova. Neda mi se ponovno onda rutat, prebacivat aplikacije i flashat CWM. Vraćam se na Tele2 2.3.3 i Supercharger skriptu. Bar sve radi i ne trza ništa, jedino što imam 20-ak MB manje memorije. Mogao bi se i Tele2 požurit onda sa updateom na 2.3.5... |
#1912 | |
Lokacija: Zaprešić
Postovi: 236
Kod za secret menu bi trebao raditi stalno kad ga prvi put upišeš, bar meni radi. Ne gubiš ništa na SD kartici ovim updateom. |
#1913 | |
Postovi: 117
#1914 |
Lokacija: Zaprešić
Postovi: 236
#1915 | |
Postovi: 185
#1916 |
Lokacija: u kući
Postovi: 10
ekipa ja stavija 2.3.5 i sad neman u notification baru one prekidace, jel neko zna kako se to aktivira, jer se sican na 2.3.3 da je bilo negdi u postavkama, al sad ne mogu to naci... |
#1917 | ||
Lokacija: rijeka
Postovi: 34
zašto uopće to pitaš,podjeli to sa nama odmah ja sam napravio update na 2.3.5 ništa prije nije dirano,mobitel 2 dana radi savršeno,bez i jedne mane...folder vendor nisam prebacivao i kamera je 5mgpx Citiraj:
#1918 |
Lokacija: u kući
Postovi: 10
#1919 |
Postovi: 185
ako staviš vendor trajno češ izgubit 5mp kameru koliko god romova flashao poslije i kad opet zelis stavit samo 2.3.5 nece.. znam ja mene je zajebalo |
#1920 |
Lokacija: u kući
Postovi: 10
evoooo nasa san ga, ispalija san na zivce, cilo popodne ga trazin.... https://market.android.com/details?id=com.jim2 app imate tamo i video i sve, al da vam pojasnin na brzinu, instalirate ga, i onda na homescreenu nadite praznu plohu i dodajte widget 4*1 i kroz postavke poklikajte sto vam triba, u dnu app imate '' Theme, Advanced, itd...'' to si provrtite (imate gps, koristenje procesora itd, i imate U '' Advanced '' - Notification i Widget Invisible, to oboje oznacite i stisni Apply... To bi bilo to.... P.S. - ako nekome nije jasno imate video na marketu na min 9:00 do 9:10 pokazano evo malo slika... |
