Staro 28.12.2011., 20:47   #1
Laxarus
Laxarus's Avatar
Datum registracije: Nov 2011
Postovi: 70
Uporno mi učitava samo integrirku
Danas sam u jedan stariji komp koji ima integriranu nvidia 610 graficku ugradio pci express graficku nvidia 210, u biosu postoji samo jedna opcija sto se tice grafickih a to je da odabrem default graficku koju ce mi pokretat ako ih ima vise, opcije su onboard, pci express i pce, odaberem pci express medutim uporno mi samo integrirka daje sliku..
disketna radi, vrti se vent, al nema slike na njoji, ideje?
Laxarus je offline   Reply With Quote
Staro 28.12.2011., 20:49   #2
Facelessone
Facelessone's Avatar
Postovi: 4,203
Ima negdje u biosu i opcija da se integrirana vga isključi. Onda kad prištekaš kabel u drugu grafu ti bude dao sliku.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 28.12.2011., 20:50   #3
Laxarus
Laxarus's Avatar
Postovi: 70
Ma nema, prekopao sam 10 puta cijeli bios..
Staro 28.12.2011., 20:51   #4
Facelessone
Postovi: 4,203
Ajde za početak ispuni mojkomp
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 28.12.2011., 20:52   #5
Laxarus
Laxarus's Avatar
Postovi: 70
Nije moj komp
Staro 28.12.2011., 20:54   #6
Facelessone
Postovi: 4,203
Onda napiši konfiguraciju tj. bar koja ploča je u igri.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 28.12.2011., 21:54   #7
Laxarus
Laxarus's Avatar
Postovi: 70
kako da u win xp vidim koja je maticna? Nemam net da skinem everest
Staro 28.12.2011., 21:58   #8
Sniper
Community Manager
Sniper's Avatar
Postovi: 313
Stavi si na stick CPU-z program
Sniper je offline   Reply With Quote
Staro 28.12.2011., 22:01   #9
Laxarus
Laxarus's Avatar
Postovi: 70
da imam odakle nebi pitao.. Ovo pisem sa java moba..
Staro 28.12.2011., 22:22   #10
Facelessone
Postovi: 4,203
Win + R -> dxdiag i pod System model bi trebalo pisati. Na 7 piše, za xp nisam siguran.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 28.12.2011., 22:33   #11
Laxarus
Laxarus's Avatar
Postovi: 70
pise sve osim maticne..
Integrirka je nvidia geforce 6100 nforce 405, cpu amd sempron 2800 plus, ddr2 ram, nebi trebalo biti previse maticnih koje podrzavaju navedeno
Staro 28.12.2011., 22:49   #12
Laxarus
Laxarus's Avatar
Postovi: 70
update, uspio sam otvorit cpu-z, maticna je ova http://www.asrock.com/mb/overview.as...l=AM2NF6G-VSTA
Zadnje izmijenjeno od: Laxarus. 28.12.2011. u 22:54.
Staro 28.12.2011., 23:05   #13
Facelessone
Postovi: 4,203
Probaj naći u opcijama Share Memory i stavi na Auto. Nakon toga spremi promjene i ugasi komp. Spoji novu karticu i uštekaj VGA kabel u nju a ne integriranu.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 28.12.2011., 23:14   #14
Laxarus
Laxarus's Avatar
Postovi: 70
na auto je od pocetka
Staro 22.02.2012., 11:16   #15
doee
Datum registracije: Jan 2012
Lokacija: bih
Postovi: 29
izvinjenje administratoru ako nisam postavio pitanje na mjestu a radi se o slijedećem.
računar mi je sa matičnom pločom ASUS P 4 p800 De luxe, intelov procesor 2.8 GHz.
ovo je ta
http://www.asus.com/999/html/events/...d/overview.htm
kod mene je na ploči VGA slot i u njemu grafička Nvidia 128 MB.
pitanje je... da li mogu promijenit grafičku i da stavim recimo 512 MB PCL-E,odnosno koju jaču grafičku mogu ugradit?
doee je offline   Reply With Quote
Staro 22.02.2012., 11:32   #16
veve
woot!!!
veve's Avatar
Postovi: 2,494
Slobodno mozes zaboraviti na PCI-E graficku, jer maticna podrzava samo AGP graficke.
Najbolja AGP graficka ako se ne varam je 3850, ali ujedno je skupa, ima probleme s driverima, nemogucnost potpunog iskoristavanja zbog CPUa, a i ne znam da li ces uopce to igdje naci.
Zapravo bilo kakvi upgrade na tvoju konfu je neisplativi.
Zadnje izmijenjeno od: veve. 22.02.2012. u 11:39.
veve je offline   Reply With Quote
Staro 23.02.2012., 13:12   #17
doee
Lokacija: bih
Postovi: 29
Autor veve Pregled postova
pa dobro, i to je informacija više...hvala puno
