Staro 21.12.2011., 21:44   #451
Dottore
Dottore's Avatar
Postovi: 7,691
Htio sam rootati ali bez uspjeha. Naime, trebam rootati da bi koristio aplikaciju BatteryCalibration ( traži root )
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 21.12.2011., 23:00   #452
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
USB kabel, origigi sa baje (UK) za ~42kn.
http://www.ebay.co.uk/itm/3103345760...84.m1439.l2649
radi i izgleda ko origigi.
http://www.ajtikupi.hr/pd/0540547/pg...in-Male.wshtml
evo ista stvar kod nas - 26kn
Ne znam zbog cega ti je trebao bas origigi samsung?
njuskalo je offline   Reply With Quote
Staro 21.12.2011., 23:30   #453
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Autor njuskalo Pregled postova
Jesi isprobao taj njihov? Sve radi ok?
Staro 21.12.2011., 23:46   #454
Facelessone
Facelessone's Avatar
Postovi: 4,204
U Galaxy Mini recimo ide samo orginal kabel. Bilo kakav drugi se treba obrezat da bi mogao sjesti u konektor.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 22.12.2011., 00:21   #455
Omerta
Omerta's Avatar
Postovi: 3,254
Zbog toga sam ga i pitao ono
Staro 22.12.2011., 00:42   #456
njuskalo
njuskalo's Avatar
Lokacija: Remetinec
Postovi: 925
Nisam probao. Nije mi palo na pamet da ima tak glupi konektor da i plastika mora uc unutra a ne samo metalni dio, ako je tako kako kazete :S
Razmisljao sam s onog aspekta da ako su sad standarnizirani (skoro) svi punjaci i mobiteli na micro usb da bi trebao i bilo koji kabel se moc ukopcat...
My bad
Staro 22.12.2011., 08:33   #457
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,307
My bad
kupio 3 jeftilen kabal na baji. samo jedan radi kako spada. to ti je vec 40-ak bacenih kn. racnunica je jednostavna. ovaj sto sam stavio link je siguran.
ovaj sto si stavio link je jeftilen sa baje koji je tamo pola cjene ;-).
Staro 23.12.2011., 20:06   #458
Mikeyy
Postovi: 2,078
Ljudovi, kako rootati SGS2?
Gledam sam po XDA i tamo ima 100 nekih kernela, Odin itd... Kada sam tražio kernel koji meni odgovara (T-mobile SGS2) vidim da ga nema (KK1 koliko sam skužio treba tražiti, a našao samo sa oznakom KK2 i KK5).
Kod Desire je to bilo super lagano, ovo mi već ide na živce.
Postoji li koji lagani način za nabaciti root na t-mobile SGS2?
Htio bi si staviti originalni rom, ali samo da ima downclock kada je mobitelu isključen ekran kako bi uštedio nešto baterije.
Ako može i prijedlog takvog roma ako netko zna.
Također, dali je uspio port Sense 3.0 na SGS2?
Zahvaljujem!
Staro 23.12.2011., 20:18   #459
geronimo_2
geronimo_2's Avatar
Postovi: 4,307
Autor Mikeyy Pregled postova
Zahvaljujem!
downclock bi ti na stocku trebao raditi bez problema kad je ugasen ekran, ako nemas neke velike wakelockove i drzis ukjljucene sve konekcije.
imas nekoliko nacina rootanja sII. CF-root (kernel), superoneclick, S2 Root.
moj savjet ti je da se bacis na citanje, jer lako je dobit ciglu, ako bas uopce neznas sta radis.
Odin je softwer od Samsunga za fleshanje. Mobile ODIN je sw od ChainFire-a (pisac CF-Root kernela) koji ti omogucava fleshanje direkt na mobu (stock romova + automatski root).
citaj, citaj i citaj jos po XDA i nakon toga odi napravi sta treba, to ti je moj savjet.
ako hoces posaljem ti C/P mojih biljeski na PM pa ti mozda razjasni neke stvari ;-).
edit: pocni odavde
http://forum.xda-developers.com/show....php?t=1075278
http://forum.xda-developers.com/show....php?t=1103399
http://forum.xda-developers.com/show....php?t=1125282
i prije svega pobrini se da napravis BACKUP EFS-a da nebi bilo...
http://forum.xda-developers.com/show....php?t=1068193
http://forum.xda-developers.com/show....php?t=1308546
http://forum.xda-developers.com/show....php?t=1336635
http://forum.xda-developers.com/show....php?t=1314719
http://forum.xda-developers.com/showthread.php?t=859914
poz
edit2: ukucaj *#1234# i paste ovdje
Zadnje izmijenjeno od: geronimo_2. 23.12.2011. u 20:36.
Staro 23.12.2011., 21:17   #460
Mikeyy
Postovi: 2,078
Zahvaljujem. Već sam neke od njih čitao, morat ću preći po svima.
Nego odmah sam primjetio da se nigdje ne spominje moja verzija kernela, barem ja mislim.
Znači ovo mi piše na "O telefonu":
Android verzija: 2.3.5
Osnovna verzija: I9100BOKJ1
Kernel verzija: 2.6.35.7-I9100BOKK1-CL511356 root@DELL150 #2
Broj verzije: GINGERBREAD.BOKK1
Rijetko gdje se spominje KK1 u tim temama, ali nikada u veziji BOKK1.
Koliko sam vidio ovaj firmware se koristi u DE, AT, HR na T-Mobile mobitelima.
Je li bitno pogoditi točno kernel?
EDIT: Sada sam tek vidio tvoj edit. Ovo dobijem kada ukucam kod.
PDA: I9100BOKK1
PHONE: I9100BOKJ1
CSC: I9100CROKJ4
Build Info: Thu Nov 3 13:41:40 KST 2011
Staro 23.12.2011., 22:36   #461
geronimo_2
geronimo_2's Avatar
Postovi: 4,307
PDA: I9100BOKK1
PHONE: I9100BOKJ1
CSC: I9100CROKJ4
milsim da mozes stavit cf-root kk2, ali nek ti to potvrdi neko ko je siguran. ili jednostavno probaj sa superoneclickom rootat5.
Staro 24.12.2011., 15:50   #462
zwer
crnjo
zwer's Avatar
Postovi: 1,907
Kifla, SGN iz VIP-a je lockan... Iz prve ruke, frend dobio maloprije. Nis, sad ko mladi majmuni cekat da dodje u T-Mobile...
9900K-32GB-5TB-3060TI
zwer je offline   Reply With Quote
Staro 24.12.2011., 16:21   #463
Dottore
Dottore's Avatar
Postovi: 7,691
Autor zwer Pregled postova
koji sgn? možeš otključati
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 24.12.2011., 16:38   #464
Mikeyy
Postovi: 2,078
Pretražio sam thread pa jednom kažu da stavi kk2 drugom da pokuša ali da ne preporučuju.
Još jedno noob pitanje, ako rootam sa superoneclick, kako gore nabaciti clockworkmod recovery?
EDIT: Sada sam pročitao prvi post, pa vidim da se može preko Rom Managera. Pokušat ću nakon rootanja tako.
Staro 24.12.2011., 17:56   #465
spawn
spawn's Avatar
Postovi: 8,459
Ja sam stavio cfroot od verzije kg6 na kg2 firmware i nije bilo nikakvih problema. Nikakve razlike u radu nisam vidio.
Staro 24.12.2011., 20:22   #466
zwer
crnjo
zwer's Avatar
Postovi: 1,907
Autor Dottore Pregled postova
Kak koji? Pa sta nema samo jedan Samsung Galaxy Nexus?
Bo, ja u procesu nabavke (jos trazim nekog ko produzuje u VIPu pretplatu), al' pricekat ce da se uvjerim da se daju unlockat 'sam tak' prije nego iskesiram bilosta
Staro 24.12.2011., 20:27   #467
Dottore
Dottore's Avatar
Postovi: 7,691
Aha, nisam skužio Ostario sam se valjda.
Testirao sam GN i zadovoljan sam jednako kao i GS2.
I ja moram čekati 2 godine da produžim
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 25.12.2011., 11:17   #468
geronimo_2
geronimo_2's Avatar
Postovi: 4,307
pozdrav svima i sretan bozic .
moze kratko objasnjenje ove 2 opcije jer na googlu bas i ne nalazim kratko i jasno objasnjenje:
"push messages" pod Messaging - ja bi to iskljucio ako nema veze sa SMS-ovima da mi ne zdere slucajno promet jer MMS ionak nikad ne koristim.
"cb activation" - sta je ovo? jel to ono kad dobijem postavke za MMS,net,... ili je ovo nesto drugo sto ce mi zderat promet pa da to odma bacim na disable?
Staro 25.12.2011., 12:08   #469
spider100
spider100's Avatar
Datum registracije: Oct 2011
Postovi: 51
SRETAN BOŽIĆ SVIMA ! ! ! !
spider100 je offline   Reply With Quote
Staro 25.12.2011., 12:15   #470
Dottore
Dottore's Avatar
Postovi: 7,691
Ne diraj dok je ispravno.
Isključi notifikaciju e-maila i auto sikronizaciju pa češ sam ručno provjeriti.
Tako je meni produžio trajanje baterije i najmanje troši data paket.
Neće ti ništa žderati promet dok nije uključen na automatsko ( većinom tipa social mrežama tipa twitter, e-mail i facebook po defaultu namješteni svakih 5min , no imaš veći izbor isključivanje, 5 min do 5 sata)
Koliko znam , najčešće svi aparati kupljeni kod operatora imaju namještene postavke Internet i MMS.
Ako tebi smeta MMS i odeš pod Settings-Wireless and network-Mobile network-Access Point Names i izbriši MMS postavke. I mirna Bosna.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 25.12.2011., 15:37   #471
geronimo_2
geronimo_2's Avatar
Postovi: 4,307
neznam jesam ja corav or what, ali sta SII nema za namjestit normalni voice calling kao sto sam npr. imao na SE W980. znaci u imeniku pod nekim kontaktom snimim rijec i onda kad kliknem tipku na BT slusalici kazem to i zovem tu osobu (ako uspije naci ) ?
znam za ovaj voice talk (dupli klik home buttona), ali to mi ne funkcionira ako nije na netu, kaze "please check your network and try again" ? a bome i lose\sporo radi.
kad kliknem dvoklik na BT slusalici zove mi zadnju osobu, ali ako kliknem jednom, sto je na SE 980W bilo za opciju voici calling, srusi mi se i kaze "the process com.android.phone has stoped unexpectedly. Please try again."
Staro 26.12.2011., 12:38   #472
johnson
Lokacija: istra
Postovi: 25
za ekipu sa SGSII - podatkovna mreža je isključena i nema onih strelica koje prikazuju kao aktivnosti prometa al ikona za 3g je stalno vidljiva - to normalno ili propustih koju opciju za isključivanje?
thx
johnson je offline   Reply With Quote
Staro 26.12.2011., 13:06   #473
Tomek32
Tomek32's Avatar
Datum registracije: Jan 2011
Postovi: 149
Oprostite sto spamam tu.
Iso sam starcima otkljucat jednu nokiu sto je nebitno.
I sad dodu oni meni da ce od 1.1.2012. sve operateri morati davati otkljucane uredaje tj. da ce se za 0kn moci da ti dodes kod njih i kazes ja hocu da mi ga otkljucate.
Isto tako da ce se moci raskinut ugovor bez ikakvih penala,tj. da nas vise nece moci samo tako drzati u saci.
Da li je to istina i da li je itko drugi vidio taj prilog na TVu?
Sve najbolje !
Tomek32 je offline   Reply With Quote
Staro 26.12.2011., 14:01   #474
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Autor johnson Pregled postova
thx
settings->wireless and network -> mobile networks -> network mode -> prebaci na gsm only.
Staro 26.12.2011., 14:05   #475
Postovi: 34,029
Autor Tomek32 Pregled postova
Sve najbolje !
Nije baš tako. Pažljivije pročitaj šta HAKOM kaže.
http://forum.pcekspert.com/showthread.php?t=226056
Staro 26.12.2011., 15:09   #476
johnson
Lokacija: istra
Postovi: 25
Autor Pomo Pregled postova
noup...i dalje je tamo
mislim ja kad se pokušam spojit na net kaže nema mreže i to sve štima - palim gasim kad hoću, al ikona je stalno gore
Staro 27.12.2011., 14:05   #477
dean225
DD9512
dean225's Avatar
Postovi: 1,869
I ovo sa gsm only sigurno radi???
dean225 je offline   Reply With Quote
Staro 27.12.2011., 14:24   #478
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,948
e toliko puta je to napisano u ovoj temi, pa i par strana prije...
Nemoj biti lijen, pogledaj. Em ces odma dobiti odgovor, em neces ostavljati dojam gotovana i ljencine.
Nešto kao ti pošto očito ni moj post nisi pročitao Piše u njemu sve, da sad ne ponavljam, jedino me geronimo_2 navukao na led jer sam mislio da je njegov reply poziv na pomoć, a ne čisto "ja ne znan ništa, ti postaj, pa ako ko uleti"
I vjerovao ili ne, temu san pročitao kad sam se rješio ispita i posla i u temi ne piše skoro pa ništa, uglavnon se sastoji od individualnih problema i rješenja ili djelomičnih rješenja istih koje je teško upotrijebit ako baš nisi u toku, a nisam u toku. Ne piše čak ni sitnica kako naprimjer spasit kalendar, a odgovor na to koliko god banalan bio meni recimo puno znači jer u njemu iman 200+ unosa (ne FB gluposti, nego konkretnih stvari).
Uglavnon, nebitno, fala A.J. na konkretnim informacijama, malo sam se i sam pozabavio s svim tim skupa kad sam dobio neke osnovne smjernice i rezultat je da sam sad na Darky 10.2.2, još ću malo proguglat kako to dodatno nadogradit, pa nek stoji tako dok se ICS ne stabilizira malo....
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Mr.Ex.President je online   Reply With Quote
Staro 27.12.2011., 14:40   #479
A.J.
A.J.'s Avatar
Lokacija: Rijeka (Umag)
Postovi: 1,197
Drago mi je da si uspio. Sorry, ali vise od toga ti nisam mogao pomoc. Imao sam puno svog posla, a premalo vremena. Vec par mjeseci imam sgs2 i zaboravio sam kako sam sta radio sa sgs1. Nedavno je izasao darkyota s kojim je olaksano, ali trazi određene verzije da bi se moglo koristit.
sad vidim da je 10.2.2 zadnja full verzija od darkya, ali zato ficeto radi base verzije za koje on i ostatak ekipe rade modove s kojima prilagodis mobitel po svojoj zelji.
Ovdje mozes vidjet koji modovi su dostupni za svaku verziju.
Preporučam ti da prije napravis backup u recovery sa nandroidom za svaki slucaj da ti se nesto zblesira zbog isprobavanja raznih tema i slicnoga.
Uzivaj u isprobavanju.
A.J. je offline   Reply With Quote
Staro 27.12.2011., 15:20   #480
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,841
Na svakoj stranici,pored linka za skidanje roma piše kako se instalira, da li ODIN-om ili CWM-om, ako ne znaš kako to koristiti, hvala bogu, imaš prvi post na ovoj temi u kojem sve lipo piše. Konkretno za Darky-a, bar Darky i ficeto napišu tutorijal kako treba gdje pokriju sve probleme, tako da na tom području ne bi trebao imati nedoumica.
Titanium Backup Pro - za njega si čuo, skinuo, i naravno pročitao sve u podtemi "Android aplikacije", u kojoj ima više manje sve o tematici aplikacija i backupa podataka. A što se kalendara tiče...syncat sa google-om?
I da, sve to piše - ili tu ili pod "Android aplikacije".
A o tome da sam lijen pomoći, tu uopće nemam komentara.
I naposlijetku, ako sam nešto krivo shvatio iz tvog posta, ispričavam se.
