#391 |
Postovi: 4,204
#392 |
Ne može se bez paypal računa? :/ |
#394 |
Nemam ni jedno, ni drugo... ni treće. Meh, nema veze... ![]() |
#395 |
Datum registracije: Feb 2003
Lokacija: Velika Gorica
Postovi: 499
Balancing Changes in 7.0 The following balancing adjustment will be applied in the upcoming 7.0 update. Reworked hitobxes of German tanks: - Pz B2 740 (f): 16 armour groups + spaced armor. - Pz 38H735 (f): 16 armour groups + spaced armor. - Pz S35 739 (f): 16 armour groups + spaced armor. Added side spaced armour. - Leichttraktor: 16 armour groups + spaced armor. - Panther II: slightly changed gun mantlets. - Pz 38 (t): 16 armour groups + spaced armor - Pz 38 nA: 16 armour groups + spaced armor - Pz III/IV: 16 armour groups + spaced armor - Pz II Luchs: 16 armour groups + spaced armor - Pz VI Tiger: 16 armour groups + spaced armor - Pz V-IV: slightly changed turret armour. - StuG III: 16 armour groups + spaced armor. Hull front armour set to 80mm. - JagdPz IV: 16 armour groups + spaced armor. - VK 1602 Leopard: 16 armour groups + spaced armor. - VK 3001 (H): 16 armour groups + spaced armor. - VK 3001 (P): 16 armour groups + spaced armor. - VK 3002 (DB): 16 armour groups + spaced armor. - VK 3601 (H): 16 armour groups + spaced armor. Rebalanced German tanks and guns: - 8.8cm L/71 damage: 220->240. - Minimum combat tier for VK1602 и T-50 increased by 1. - Imprved ventilation removed from Gw-Tiger и Gw-Panther. VK 3601 (H): - Reload time of 7.5cm KwK 41 L/58: 3.5->4.5 sec. - Aiming time of 7.5cm KwK 41 L/58: 1.1->2 sec. - Dispersion during movement and turret traverse of 7.5cm KwK 41 L/58 increased by 10%. PzKpfw V Panther: - Ammo Rack Hit points -20%. - View range of top turret: 420->430. Panther II: - Ammo Rack Hit points -10%. - View range of stock turret: 460->430 m. - View range of top turret: 460->450 m. - Reload time of 8.8cm KwK 43 L71 for top turret: 6.1->6.7 sec. E-50: - Ammo Rack Hit points -5%. - View range of stock turret: 460->450 m. - Reload time of 8.8cm KwK 43 L71 for stock turret: 6->6.6 sec. - Reload time of 8.8cm KwK 43 L71 for top turret: 5.8->6.4 sec. PzKpfw VI Tiger: - Reload time of 8.8cm KwK 43 L71 for top turret: 6.8->7.5 sec. PzKpfw VI Tiger (P): - Reload time of 8.8cm KwK 43 L71 for stock turret: 7.3->8.0 sec. - Reload time of 8.8cm KwK 43 L71 for top turret: 6.8->7.5 sec. PzKpfw VI Tiger: - Reload time of 8.8cm KwK 43 L71 for top turret: 6.8->7.5. PzKpfw VIB Tiger II: - Reload time of 8.8cm KwK 43 L71 for stock turret: 6.5->7.2 sec. - Reload time of 8.8cm KwK 43 L71 for top turret: с 6.1 до 6.7 sec. VK 4502 (P) Ausf. A: - Reload time of 8.8cm KwK 43 L71 for stock turret: 6.5->7.2 sec. - Reload time of 8.8cm KwK 43 L71 for top turret: 6.1->6.7 sec. VK 4502 (P) Ausf. B: - Reload time of 8.8cm KwK 43 L71 for stock turret: 6.1->6.7 sec. - Reload time of 8.8cm KwK 43 L71 for top turret: 5.8->6.4 sec. Е-75: - Reload time of 8.8cm KwK 43 L71 for stock turret: 6.1->6.7 sec. - Reload time of 8.8cm KwK 43 L71 for top turret: 5.8->6.4 sec. GW Tiger: - Reload time of 170mm K72 Sf: 27.3->25.5 sec. - Dispersion of 170mm K72 Sf: 0.41->0.4. - Dispersion of 170mm K72 Sf during gun traverse: -5%. Reworked hitobxes of Soviet tanks: - А-20: 16 armour groups + spaced armor. - А-32: 16 armour groups + spaced armor. - АТ-1: 16 armour groups + spaced armor. - BT-7: 16 armour groups + spaced armor. - SU-85B: 16 armour groups + spaced armor. - IS-3: 16 armour groups + spaced armor. Added side spaced armour. - IS-4: 16 armour groups + spaced armor. - IS-7: 16 armour groups + spaced armor. Improved front turret armour, improved weld of upper and lower frint plates, added side spaced armour. - KV-13: 16 armour groups + spaced armor. - KV-3: 16 armour groups + spaced armor. - KV: 16 armour groups + spaced armor. - Matilda: 16 armour groups + spaced armor. - МS-1: 16 armour groups + spaced armor. - Object 704: 16 armour groups + spaced armor. Added side spaced armour. - SU-14 : 16 armour groups + spaced armor. - SU-152: 16 armour groups + spaced armor. - SU-18 : 16 armour groups + spaced armor. - SU-76 : 16 armour groups + spaced armor. - T-34: 16 armour groups + spaced armor. - Т-44: 16 armour groups + spaced armor. - Т-54: 16 armour groups + spaced armor. - Valentine: 16 armour groups + spaced armor. Rebalanced Soviet tanks and guns: - Changed models and specifications of both turrets for IS-3. - Shell price for 180mm F-600D: 1890->1980 credits. - Shell price for 180mm UBR-600: 1890->1980 credits. - Shell price for 203mm F-625D: 1442->1568 credits. - Shell price for 203mm G-620: 1092->1200 credits. Т-44: - Added LB-1 for top turret. - Added В-54-6 engine of 680 hp. - Ammo rack hit points: +15%. - traverse speed for stock suspension: 2 deg/sec; for top suspension - +1 deg/sec. - View range of stock turret: 430->420 m. - View range of top turret: 430->440 m. Т-54: - Ammo rack hit points: +5%. Reworked hitobxes of American tanks: - M12: fixed gun shields. - M2 Light Tank: 16 armour groups + spaced armor. - M2 Medium Tank: 16 armour groups + spaced armor.. - M4A2E4: 16 armour groups + spaced armor. - M4A3E8 Sherman: 16 armour groups + spaced armor. - M4 Sherman: 16 armour groups + spaced armor. - M5 Stuart: fixed the value of side hull armor. - M7: 16 armour groups + spaced armor. - Ram II: 16 armour groups + spaced armor. - T-14: 16 armour groups + spaced armor. Added side spaced armour. - T1 Cunningham: 16 armour groups + spaced armor. - T29: 16 armour groups + spaced armor. - T2 Light Tank: 16 armour groups + spaced armor. - T30: 16 armour groups + spaced armor. - T32: 16 armour groups + spaced armor.. - T34: 16 armour groups + spaced armor. - T40: 16 armour groups + spaced armor. Rebalanced American tanks and guns: - M4A3E8 Sherman: added 105mm SPH M4 L/23 gun for both turrets. - Repair cost of T40 TD: -60%. - Shell price for 105mm APCR T29E3M2: 12->10 gold. T20: - Ammo rack hit points: +10%. - View range of stock turret: 400->420 m. - View range of top turret: 420->440 m. M26 Pershing: - dispersion during movement: -10%. - View range of stock turret: 430->440 m. - View range of top turret: 450->460 m. M46 Patton: - Ammo rack hit points: +20%. - View range of stock turret: 450->460 m.
Doctor!!!... Doctor!!!... MY BRAIN HURTS... |
#396 | |
Tehničar
Datum registracije: Dec 2011
Postovi: 1,079
#398 | |
Postovi: 196
Što se tiče Tigera on je i dalje meni kanta za napucavanje jer dere me artiljerija s drugog kraja mape tako da nema micanja iz baze a dok ja skupim dovoljno experience bodova za nadogradnje ja ću posijediti pogotovo što me non stop gura sa najjačima tierima pa sam uvjek dole na dnu liste po jačini. |
#401 |
Lokacija: Slav. Brod
Postovi: 491
Ovo vise nitko ne igra? Uglavnom 7.0 u ponedeljak http://worldoftanks.eu/news/757-update-v70-maintenance/ Po pisanju na RU i SAD forumima nista dobro u novom updatu Skresana zarada artia ali i ostalih tenkova u igri, igrivost su uspijeli pogorsati i jos puno toga.
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3, IX::IS8 VIII:: Lorr. 155 51, AC Mle 48 PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke |
#402 |
Trebali bi nešto napravit i sa ovim Type 59 tenkovima... Ne pamtim da sam ijednu igru s Pershingom odigrao bez Typea u protivničkom timu. A obično ih je dvoje i više. >.< |
#404 |
Postovi: 417
Da, nažalost, uglavnom loše vijesti o novom patchu. MM i dalje ne uzima u obzir skill igrača, što je blago rečeno smiješno. Premda u zadnje vrijeme igram jako malo, od stotinjak posljednjih public matcheva (uglavnom odigranih sa top tier tenkovima) pamtim možda desetak izjednačenih, sve ostalo su bile nadmoćne pobjede jedne strane. Stvarno ne znam na koji način takvom politikom misle zadržati stare igrače, a kamoli tek pridobiti nove. Što se tiče artiljerije, mislim da je dobar potez to što su im smanjili zaradu jer su ih svi počeli igrati upravo iz tog razloga pa je to postalo više neizdrživo i u zadnje vrijeme su runde sa 4-5 artya po ekipi postale normalna stvar (ne mogu naći screen sa ukupno 15 artya na obje strane ![]() Kad su već spomenuti T59, evo jedna runda od prije par dana ![]() ![]() Sve ih je više i stvarno žalim ekipu koja tek počinje igrati. Tu sam mislio na nove igrače koji žele napredovati u igri, ne na noobove (grom ih ubio ![]() Zadnje izmijenjeno od: The Satara. 17.12.2011. u 23:12. |
#405 |
Datum registracije: Jun 2003
Lokacija: Vinkovci
Postovi: 305
Dogs of War prima nove članove. Posted Image Svi su dobrodošli. Igrači sa tier X heavy tenkom, tier IX mediumom, tier IX TD ili tier VIII artiljerijom, upadaju direktno u glavni DOW klan. Nudimo prije svega dobru zabavu, svakodnevne CW (bitke), komunikaciju putem Ventrila i foruma, ekipu za platoon-e i Tank Company-je... Oni koji još nisu stigli do gore zadanih "tenkovskih" uvjeta, ukoliko žele, upadaju u DOW-B (Dogs of War Bootcamp). Nakon postizanja gornjih uvjeta, iz Bootcampa vas prebacujemo u glavni klan. U Bootcampu, također imate privilegiju igranja platoona uz korištenje Ventrilo servera te sudjelovanje na forumu. Ukoliko ste zainteresirani, nakon registracije na forum (potrebno je neko vrijeme dok naši commanderi ne odobre registraciju), otvorite novu temu s prijavom u ovom podforumu i to po ovom obrascu. Nakon toga, dobit ćete pozivnicu za DOW ili DOW-B, ovisno o ispunjenim uvjetima. ![]() |
#406 |
Ma ne treba ih previše žalit, prokletnici... Bore se protiv Type-a od Tier 5 pa sve dok ne dođu do Tier 10, a opet ga preko 90% njih ne zna probit. Jučer sam gledao kako kinez masakrira Lowea, Tigera i IS-3, i to nakon što sam ga ja spustio na 60%. ![]() |
#407 |
Lokacija: u mraku
Postovi: 846
i što velite na patch 0.7? meni je ok manje više , samo su arty sjebali dobrano, otežali su posao to je ok, no ne kontam zasto onda smanjit toliko zaradu da možeš biti jedva na nuli ako uspiješ pogodit nekog. |
#408 |
Postovi: 499
Šta je s camo-om? Hoće li s novim patchem postati adaptivan ili ne? Koliko sam vidio, ljudi ga stavljaju za sad samo zato da netko ne bi mogao koristiti na njima skinove sa zonama.
#409 |
Meni je bezveze ovaj camo... preskup je za korištenje u random igrama. A za skinove se ne brinem, onaj tko zna koristit skin taj ionako igra dovoljno dugo da otprilike zna gdje je weakspot. ![]() Jučer sam kupio S-51. Moja prva artiljerija, i odmah mi se ne sviđa. Možda će bit bolja s drugim topom, bit će to naporan grind (40.000 exp.). |
#410 |
Postovi: 196
#411 | |
Postovi: 499
BTW, igra me počela žešće živcirati, ne zbog same igre i patcha, već zbog !!!MORONČINA!!! koji obitavaju u velikom broju na serverima. Nije mi jasno kako ljudi mogu biti toliki kreteni. Danas mi se dogodilo da 3 mape zaredom popušimo zbog glupana. Naprave s najjačim tenkovima lemming train na uskom prostoru tipa Abbey, Lakeville i drugo krilo ostave potpuno nepokriveno. I možeš ti glupanima govoriti do sutra, ne zombiji krenu nezaustavljivo ![]() I ne bih ništa rekao da prođu i cap-aju, ali kreteni su u klancu, niti se mogu međusobno pokrivati paljbom, totalno su nekorisni. Naravno s druge strane nas ovi zgaze. Za popiz...i. Ako ću prestati igrati ovu igru, biti će to zbog ovoga, a ne zbog loših patcheva.
#412 |
#413 |
Postovi: 4,068
Ima netko problema možda s ovom igrom? Frendu se usred igre ugasi monitor i ode sleep (zvuk se čuje u pozadini ali ne može ništa napraviti osim restartat komp). U drugim igrama nema problema samo u WoT-u. ATI-eva HD3850 je u pitanju, poslijednji driveri. Nije imao problema do zadnjeg patcha... Hvala |
#415 | |
Lokacija: u mraku
Postovi: 846
#416 |
Lokacija: Popovača
Postovi: 98
#418 |
Postovi: 499
Moram podijeliti s vama svoje oduševljenje... Nakon što sam se razočarao jer nije bilo popusta za Božić na King Tigera, ipak sam se odlučio počastiti Jagdpantherom. Iskoristio sam sav free XP i opremio ga najbolje što sam mogao, sve osim 105mm (kasnije sam i njega otključao, ali ipak mi više paše duga 88ica). Posadu sam prebacio iz JgPzIV, sad su na 96-97%. Moram reći da mi je to najbolji tenk kojeg sam igrao!!! ![]() Naprosto sam očaran, brz, okretan (ne kao JgPzIV, ali nije ni puno lošiji), bounca puno toga i, što je možda i najvažnije, pogađa i probija gotovo sve. To me i čudi, jer isti taj top na mom Tigeru ima puno lošije rezultate, odnosno ne probija ni približno kao na JagdPantheru. Sumnjm da je faktor sreće u pitanju, jer mi se to dogodilo u previše situacija da bi bilo slučajno. Uglavnom, ovaj TD je našao zauvijek mjesto u mojem srcu i garaži ![]()
#419 |
Casual Racist
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Odlican je JPanther s 88mm. 105mm sam probao i bio je uber junk. Neprecizan unatoc statistikama, shell skup, a sam tenk je trutima s tim topom. Doduse 88mici ce nerfat RoF u 7.1, ali bit ce super i nakon toga. |
#420 |
Postovi: 491
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3, IX::IS8 VIII:: Lorr. 155 51, AC Mle 48 PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke Zadnje izmijenjeno od: Audi45. 01.01.2012. u 21:06. |
