Lokacija: Zagreb, Croatia
Postovi: 66
Mala analiza aktualnih Nvidijinih DX11 grafičkih kartica
uzeo podatke s raznih testova da si napravim nekakvu usporedbu pa odmah i da podijelim sa zainteresiranima: NVIDIA GeForce GTX 470 @ 2000 kn - Total Framerate: 73.1, 29.0, 43.6, 55.9, 42.6 = 244.2 - Average Framerate: 73.1, 29.0, 43.6, 55.9, 42.6 = 48.84 - Idle/Load GPU Temperature: 46 / 92.5 - Idle/Load Noise Levels: 44.0 / 61.5 - Idle/Load Power Consumption: 173 / 387.0 NVIDIA GeForce GTX 480 @ 2100 kn - Total Framerate: 91.9, 36.0, 55.7, 68.9, 41.8 = 294.3 - Average Framerate: 91.9, 36.0, 55.7, 68.9, 41.8 = 58.86 - Idle/Load GPU Temperature: 51 / 93.0 - Idle/Load Noise Levels: 44.0 / 64.1 - Idle/Load Power Consumption: 190 / 450.0 NVIDIA GeForce GTX 560 Ti @ 1500 kn - Total Framerate: 82.6, 31.0, 44.1, 61.7, 49.9 = 269.3 - Average Framerate: 82.6, 31.0, 44.1, 61.7, 49.9 = 53.86 - Idle/Load GPU Temperature: 28 / 75.0 - Idle/Load Noise Levels: 42.2 / 46.7 - Idle/Load Power Consumption: 161 / 334.5 NVIDIA GeForce GTX 570 @ 2300 kn - Total Framerate: 96.3, 36.5, 55.1, 70.8, 41.5 = 300.2 - Average Framerate: 96.3, 36.5, 55.1, 70.8, 41.5 = 60.04 - Idle/Load GPU Temperature: 37 / 85.0 - Idle/Load Noise Levels: 42.5 / 57.9 - Idle/Load Power Consumption: 169 / 403.5 NVIDIA GeForce GTX 580 @ 3400 kn - Total Framerate: 110.6, 42.0, 63.7, 82.4, 41.5 = 340.2 - Average Framerate: 110.6, 42.0, 63.7, 82.4, 41.5 = 68.04 - Idle/Load GPU Temperature: 37 / 84.0 - Idle/Load Noise Levels: 44.4 / 59.9 - Idle/Load Power Consumption: 173 / 439.5 GTX 560 Ti se cini definitivni best buy, a i tiha je, ne trosi puno W i manje se grije. Zadnje izmijenjeno od: Igor Volkin. 10.11.2011. u 13:45. |
Postovi: 1,068
Nisam baš siguran za cijene, barem za cijenu GTX 470. Doma mi je u kompu GTX 470 TFII (koju uopće ne koristim) i mislim da ih se s garancijom može nabaviti za cca 1100 kn. Odakle su uzeti rezultati? |
Postovi: 66
za informaciju o cijeni sam gledao nabava.net, ali sad sam napravio mali update. rezultati skupljeni sa raznih testova na: www.anandtech.com/bench/GPU11 Zadnje izmijenjeno od: Igor Volkin. 10.11.2011. u 13:54. |
Postovi: 12,420
GTX470 i GTX480 su sve samo ne aktualne kartice, to su EOL kartice. Drugo nisi naveo u kojim igrama i pri kojim postavkama su dobiveni rezultati. Potrošnja se ne odnosi na kartice već na kompetan stroj, koji također nije naveden. Razina buke je isto vrlo šarena jer ne postoji samo jedna verzija tih kartica, buka može jako varirati od izvedbe o izvedbe. Na kraju čemu ono zbrajanje rezultata?
#6 | |
Postovi: 66
stroj bi trebao biti isti/slican da bi njihovi podaci o potrosnji imali smisla, mislim da su u anandtechu mislili na to ![]() za razinu buke tvrdnja stoji, ali mislim da su ipak podaci korisni cisto za neku okvirnu sliku. zbrajanje rezultata sam napravio da bih dobio neki agregatni 'skor' za avg framerate jer se kartice mogu razlicito ponasati u razlicitim igrama (kartica koja je brza od neke druge kartice u jednoj igri, moze biti sporija u drugoj igri). |
Postovi: 12,420
I opet, niti ja znam koje su to tebi najzanimljivije igre, niti znam koje su to max grafičke opcije za tu meni, kao promatraču, još uvijek nepoznatu igru. To je kao da ja sad sa svog testa kartica samo prepišem brojeve i ćao đaci. Nit imate pojma o kojim se igrama radi, nit imate pojma koje su postavke, niti raspolažete informacijama o testnoj konfiguraciji. Ne slažeš li se da to u principu nema nekog smisla? ![]() Za razinu buke opet, ako se ne kaže koja je konkretno kartica u pitanju ne daje niti okvirnu sliku jer, kao što sam rekao, nazivno isti model može proizvest posve različitu zvučnu kulisu obzirom na tip hladnjaka i regulaciju njegova ventilatora. Nitko nikog ne linčuje, samo dajem svoje viđenje navedenog posta.
Postovi: 66
nisam se dobro izrazio ili me nisi shvatio - nisam uzeo testove meni najzanimljivijih igara (koji tebi ili kome drugome ne moraju, naravno, biti zanimljive). s anandtecha sam uzeo _sve_ raspolozive testove kartica na rezoluciji koja mi se cini najzastupljenija (1920x1080 ili 1920x1200) i s max grafickim postavkama (max quality sto igra dopusta + 4xAA; niti nema drugacijih testova). naravno, netko ce mozda gledat neku drugu rezoluciju, ali smatrao sam da je navedeno nekakva referentna tocka za ljude koji kupuju graficku karticu. ali tvoje primjedbe djelomicno stoje, trebao sam odmah navesti source i koju vrstu testova sam uzeo da bude jasno. |
Postovi: 874
Pa ok je usporedba. Npr. mogli bi sad iscupati zakljucak koliko te kosta svaki average frame rate za svaku karticu pa imamo: GTX 470: 40.95kn (Ali kartica se rabljena za znatno manje para moze nabaviti.) GTX 480: 35.67kn GTX 560 Ti: 27.85kn GTX 570: 38.3kn GTX 580: 49.97kn Jel...manje je bolje. E sad, da li ti treba jace napajanje za neku, bolji proc itd. o tome se ne radi u postu. |
#10 | ||
Postovi: 12,420
![]() Shvatio sam upravo onako kako si napisao. Citiraj:
![]() btw samo kao dobro namjerna opaska ne postoji ''najreferentniji'', postoji samo ''referentan''.
Postovi: 66
nije isto - da sam samo stavio link na anandtech, onda bi svatko morao odabirati razne testove i pronalaziti interesantne kartice u sumi drugih kartica iz izgenerirane slike/grafova, a usporedjivati vise kartica na taj nacin je komplicirano. posto sam sve to vec ucinio i prepisao sve rezultate pa ih sumirao u jednostavnu listu, pomislio sam da bi to moglo biti korisno i drugima. definitivno nije isto kao da sam stavio link. 'hrpa brojeva' itekako ima znacenje i u najmanju ruku pokazuje relativne odnose izmedju kartica. kaj se tice rijeci 'najreferentniji', ne slazem se. ne radi se o rijeci 'najoptimalniji' koja ne postoji jer rijec 'optimalan' vec sama po sebi opisuje da je nesto 'naj'. daj argument (link, source) jer ovako je to samo jedno (tvoje) misljenje ![]() ![]() |
Datum registracije: Sep 2010
Lokacija: Vk
Postovi: 572
posto usporedjujes DX11 graficke bilo bi fora kad bi stavio i odvojenu usporedbu sa ukljucenim/iskljucenim tessellationom i eventualno jos nekim "forama" tipa FXAA (i naprednijim anti-aliasingom) |
Postovi: 1,011
Evo ja imam 2 * GTX480, kupljene polovne, jedna ima pola godine, a druga godinu garancije. Nisu necujne pod opterecenjem, ali nisu ni glasne. Temperature sa zadnjim beta drajverima se krecu oko 80 stupnjeva C, kad igram igre (mozda jer je dosla zima). 3D markove nisam jos igrao, a i neplaniram, tako da ti za to nebih znao reci ![]() Svi pljuju po tim karticama, a stvari uopce nisu toliko crne. ![]() |
#17 |
Postovi: 1,011
Ja nisam nigdje tvrdio da su graficke ultra hladne i negladne. Da trose i da se griju vise od ostatka ponude je istina, ali i daljem mislim da su reakcije pretjerane. Kilovatno napajanje sigurno netrbam za sli, ali trenutno je takva situacija. Jedno od ta dva ce sigurno vanka, ovo je onak, privremeno. 3-sli nenamjeravam praviti ![]() |
