Staro 16.03.2005., 23:40   #1
del
del's Avatar
Postovi: 66
Firefox tips
Ok par tipova kak dodatno ubrzat liju
UPOZORENJE > ovi tweakovi se nece odraziti na vashu liju ukoliko se spajate prek modema
Lagano otvorite firefoxa u adres baru ( tam gdje obicno pisete imena stranica ) napisete about:config
nakon sto ste to napravili nadite sljedeche stvarchiche
network.http.pipelining
network.http.proxy.pipelining
network.http.pipelining.maxrequests
browser.turbo.enabled
network.dns.disableIPv6
i onda
Set network.http.pipelining to True
Set network.http.proxy.pipelining to True
Pipelining sets the browser to make multiple requests to a web page at one time.
Set network.http.pipelining.maxrequests to 20
This is the maximum number of requests to make to the web page at a time.
Set browser.turbo.enabled to True
Set network.dns.disableIPv6 to True
Sada kliknite bilo gdje desnom tipkom misha New, Integer. i dajte mu ime "nglayout.initialpaint.delay" i dajte mu vrijednost 0
Ova stavka odreduje vrijeme koliko ce browser chekati prije nego li pocne obradivat pristigli podatak
Cache Size Tweak
Firefox 1.0 is defaulted to use 51MB of your RAM cache which really is quite a lot if you are running other applicatins at the same time. This tweak allows you to set the maximum size cache that Firefox uses. Please note that this does not directley make Firefox faster but it can speed up your computer in general.
In the about:config screen create a new integer value and name it...
"browser.cache.memory.capacity"
Set its value to the maximum size of the cache you want Firefox to use in Kilobytes. I set mine to 20000 to use 20MB of cache. Restart Firefox for the changes to take affect.
Speed Up Loading Of Firefox In XP
In Windows XP you can speed up the loading of programs by making it one of the programs that XP "Prefetches". Prefetching works by letting XP have portions of a program already loaded to your hard drive. To do this for Firefox, find the Start Menu entry for Firefox and right click it, then select properties. In the 'Target' box add the following line at the end of the file path.
/Prefetch:1
Your Target box should now look something like this.
"C:\Program Files\Mozilla Firefox\firefox.exe" /Prefetch:1
del je offline   Reply With Quote
Staro 19.03.2005., 14:15   #2
Izopaceni
Izopaceni's Avatar
Lokacija: Enemy Territory
Postovi: 210
Mogo sam i ja copy pejstat nes s neta na forum....
It s Nice To be Important,But More Important is to be nice......
Izopaceni je offline   Reply With Quote
Staro 19.03.2005., 14:52   #3
Freek
Freek's Avatar
Lokacija: Zagreb/Dubrava
Postovi: 2,869
to je već bilo sve na forumu.
Staro 19.03.2005., 15:09   #4
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Pa što nisi?
Staro 19.03.2005., 17:25   #5
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 894
Ma dobro,čovjek dobrom namjerom malo truda si dao-ne ga odmah tuć
peace
MSI B450M pro-m2 max-ryzen 7 5800xt-nvidia 5060 ti - Asus rog swift PG278Q
damir1 je offline   Reply With Quote
Staro 19.03.2005., 18:05   #6
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Basta s prepucavanjima.
