#1621 |
Datum registracije: Nov 2011
Lokacija: njemacka
Postovi: 3
Da li postoji unlock za iphone4 jb 4.1 verzija firmware baseband 02.10.04 ![]() |
#1627 |
Truth is out there!
Datum registracije: Aug 2003
Postovi: 497
Ima li jb za ios 5 untethered,na netu pise da ima ali di god kliknem nista od Informacija?
"Covjek je star koliko i zena koju osjeca!" C.Sheen |
#1628 |
Default
Lokacija: Požega
Postovi: 1,509
Nema untethered, ima semi-untethered. Slicno kao tethered, samo kad ti se ugasi, moci ces ga upaliti i koristiti samo osnovne funkcije (sms, poziv i jos nesto sitno) dok ga ne spojis na komp
#1630 |
Default
Lokacija: Požega
Postovi: 1,509
#1631 |
Premijum
Postovi: 1,360
Ma sve to meni za iOS 5 jasno, ali trenutno imam iOS 4.2.1 i on mi je JBkan, trebao bi biti ne jailbreakan. ![]() ![]() |
#1632 | |
Postovi: 8,400
Ako nema SHSH spremljene,skini si iFaith, dumpaj SHSH fajlove,napravi FW s tim shsh fajlovima (uputstva imas u iFaithu) i fleshaj telefon s tim fw-om. |
#1633 | |
Premijum
Postovi: 1,360
#1634 |
Truth is out there!
Postovi: 497
Pozz!Stavio sam 5.0.1 IOS na 3gs i sad nikako ne mogu napavit JB.Dok sam imao ranije verzije softwarea 4... bez problema sam to rjesavao,sad sta god pokusam ne radi,npr. redsnow javlja da na podrzava tu verziju softa. Mozete li me uputit kako da JB?
#1635 | |
bi0haZZ
Datum registracije: Oct 2010
Postovi: 155
If you don’t like the tethered boot process, hold out for an untethered release which is actively being worked on by the Dev Team, no ETA is available for that however. Requirements A supported iOS device: iPhone 4, iPhone 3GS, iPad 1, iPod touch 3rd or 4th gen – there is currently no support for iPad 2 or iPhone 4S iOS 5.0.1 installed already – download it here or use the OTA update if you haven’t already The previous iOS 5 IPSW for the device Redsn0w 0.9.9b8 – get it for Mac or grab it for Windows The jailbreaking process will be familiar to anyone who has done this before or who has used a custom IPSW. The main thing to remember here is that you are pointing at the older IPSW file despite running a newer version of iOS, this will continue to be the case until a new version of redsn0w is released to circumvent that aspect of the procedure. Jailbreaking iOS 5.0.1 with Redsn0w Turn the iOS device off and then connect it to the computer Launch Redsn0w and click the “Extras” button, then click on “Select IPSW” – locate the iOS 5 IPSW (not iOS 5.0.1) and click “Open” Click “Back” to return to the original Redsn0w screen and click on “Jailbreak” as usual Put the iOS device in DFU mode as redsn0w instructs, holding down the Power and Home button for 10 seconds, then release the power button but continue to hold the Home button for another 15 seconds or so As the jailbreak works, the iPhone/iPad/iPod will reboot and you’ll get a notification that it requires a tethered boot, let the device boot up as usual and then put the hardware into DFU mode yet again so you can perform the tethered boot and get Cydia to work Back in Redsn0w, go to “Extras” and select the iOS 5.0 IPSW again, then click on “Just Boot” at the top of the “Extras” menu to perform the tethered boot Enjoy your jailbreak If you have a white Cydia icon it’s because you didn’t perform a tethered boot properly, so just go through that step again and you’ll be fine. From this point it’s recommended to install the semi-tether since it improves the experience, it’s a free download from the Cydia store. If all of this seems confusing or causes a headache, just wait until a new version of redsn0w is available or better yet wait for the untether. Znaci kad lociras Select IPSW ne lociras 5.0.1 nego 5.0 jer redsnow do te verzije za sad podrzava ![]() |
#1636 |
bi0haZZ
Postovi: 155
Ovako , sori prvo za dupli post u prvom sam samo objasnjenje za jb pisao . Zanima me da li se nekome dogada sljedece . Kad god otvorim navigaciju ili google maps od iphonea pocne mi traziti gps uredaje i dogodi se to da mi skroz nestane mreze na mobu , pocne ju traziti , nade ju i ocita skroz i onda opet se izgubi i ponovno isto radi . Kad izadem iz gpsa sve normalno mreza se ne restarta ajmo reci . Jedino sto mi ponekad kad sam u autu i kad se krecem pogledam na mob i vidim da nema ni jedne cetice signala koda je zastekao , tek kad ukljucim pa iskljucim zrakoplovni mod mi se oporavi mreza. Jailbrejkao sam svoj 3gs na ios5.0.1 verziju i od tad se to dogada bb je 6.15 ( uvijek je bio taj bb od kad sam ga kupio preko oglasa) |
#1638 |
bi0haZZ
Postovi: 155
#1639 |
Postovi: 1,147
Dakle, kao što je kolega već rekao: osoba od koje si kupio mobitel je prije stavila modem firmware od ipad-a i opće poznato je da kod te kombinacije ima puno problema sa gps-om. guglaj malo pa ćeš vidit da nisi jedini. |
#1640 |
Truth is out there!
Postovi: 497
Hvala na odgovoru! Sada opet problem,znaci skinuo sam 5.0 ios i njega selectam u redsnow on napravi svoje,stisnem jailbreak and istall cydia,on napravi kao patching kernel i redsnow se jednostavno ugasi sam od sebe?
#1641 |
bi0haZZ
Postovi: 155
da li koristis win7 ? ako da , jesi li redsnow otvorio kao administrator(run as administrator) , da li ti je internet cijelo vrijeme ukljucen kad jailbraekas , probaj preko drugog pca jailbrakeat ako ti se na onom rusi redsnow??? |
#1642 |
Truth is out there!
Postovi: 497
zahvaljujem,sve rijeseno i stavljen semi tethered! Problem je bio sto ima vise ios 5.0 verzija,stavio sam neku raniju verziju i radi.
#1643 | |
bi0haZZ
Postovi: 155
#1644 | |
Lokacija: njemacka
Postovi: 3
#1645 |
P.E.B.K.A.C.
Postovi: 2,304
Jedan upit, kolegica kao sto obicno biva klikajuci samo na "next, yes,yes,next.." ![]() Trenutacno je na vipu treba tele2 kartica nutra??
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/ Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
#1648 |
P.E.B.K.A.C.
Postovi: 2,304
A eto tako ga je updejtala, to je onaj tip korisnika sa profilnom slikom sebe u ogledalu da se vidi iphone i bojler iza ![]() ![]() Koji da stavim sad ios uopce i sa cime da ga jb-am barem kad nemrem unlockat?
#1650 |
Lokacija: Zagreb, Centar
Postovi: 1,796
Skini tinyumbrellu i pogledaj koje shsh ima spremljene (na cydia serveru). Na četvorki se i BB downgradea sa downgradeom FW. Treba ti za 4.0 ili 4.0.1 jer čini mi se da su oni dolazili sa 01.59.00 BB. |
