Staro 18.10.2011., 01:48   #1
Dottore
Dottore's Avatar
Postovi: 7,638
SeaSonic 80Plus Platinum
Čudim se što nema interesa, o krenimo redom
SS-1000XP
http://www.plugloadsolutions.com/80P...x?id=60&type=2
http://www.plugloadsolutions.com/psu...00W_Report.pdf
SS-860XP
http://www.plugloadsolutions.com/psu...60W_Report.pdf
Seasonic Platinum-860/1000 (SS-860XP & SS-1000XP)
http://www.seasonicusa.com/Platinum_Series.htm
Brochure
http://www.seasonicusa.com/PDF/Catal...P-850-1000.pdf
SeaSonic's 80Plus Platinum power supplies to reach Europe next month
As recently announced, SeaSonic is planning a November release for its previously-mentioned line of 80Plus Platinum certified power supplies. The units in the pipeline deliver 860W and 1000W of continuous power, are fully modular and have an efficiency of up to 92%.
SeaSonic's Platinum PSUs feature a 'near-perfect' DC-to-DC conversion, 99% active PFC (Power Factor Correction), Grade A 105℃ Japanese capacitors, gold-plated terminals, a dual sided PCB layout, one 12V rail, an Easy Swap connector, and a Sanyo Denki San Ace fan that can be set to operate in one of three modes - Fanless, Silent and Cooling.....
Link
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 18.10.2011., 09:22   #2
Postovi: 8,212
Ima interesa, napajanja su odlična al samo mali broj nas si ih može kupit. U tome je stvar. Ima i drugih, jednako dobrih a za malo manje para. Ta fanless thingy je super, al u slabijim napajanjima za htpc. Ova 850W/kW mi nekak nemaju smisla kad imaš hajend komp i već imaš 2 venta na noctui, 6 komada na dvije soc grafe i još 3-4 na kućištu. Taj u napajanju nepravi razliku.
Staro 18.10.2011., 10:23   #3
Dottore
Dottore's Avatar
Postovi: 7,638
Istina, za high end dovoljan. Ipak dolazi sa 7 godina garancije
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 24.10.2011., 16:20   #4
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Svi argumenti stoje ... odlična izrada, vrhunski dijelovi, ubojite performanse, te na kraju i takva cijena
Koliko vidim na prvi pogled napravili su i neke male preinake poput "čvršće" regulacije od ±2%, 7-godišnje garancije, a i još jednog malog detalja - postavili su poseban prekidač za uključivanje/isključivanje fanless modus operandia tj. napajanje će moći raditi u niskom opterećenju kao fanless ili kao aktivno hlađeni PSU (ovisno o poziciji prekidača tj. preferencijama korisnika).
Sve u svemu dugo im je trebalo, ali su konačno napravili nešto pošteno i nadam se da će ostvariti sve ono što su mnogi entuzijasti očekivali (po)duži period.
Cijena ... heh, nije za svakoga definitivno
Jedini problem je što u ovom trenutku Platinum verzije nisu dostupne u Europi.
No zato ćemo (ovaj tjedan, kada napajanje stigne) zainteresirati našu PCE populaciju sa jednim drugim vrlo zanimljivim primjerkom pod okriljem starog vuka - Delte ... VIDEO
BTW ovo je i jedan od razloga kašnjenja mini reviewa XFX-ovog 850W modela, jer će biti mala usporedba u tijeku i konačno će biti ponuđeni odgovori na pitanja po čemu se ovakva napajanja razlikuju od onih osjetno jeftinijih u našim shopovima (poput XFX-a)
Staro 24.10.2011., 16:48   #5
Dottore
Dottore's Avatar
Postovi: 7,638
Jedva čekam vidjeti
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 24.10.2011., 17:17   #6
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Vjerujem ... ipak se unutra krije Sanyo Denki PWM vent
Zadnje izmijenjeno od: dh41400. 24.10.2011. u 17:23.
Staro 25.10.2011., 08:13   #7
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Autor Dottore Pregled postova
Jedva čekam vidjeti
Autor dh41400 Pregled postova
Staro 13.11.2011., 10:54   #8
Dottore
Dottore's Avatar
Postovi: 7,638
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 13.11.2011., 23:02   #9
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Potrudio se Seasonic pošteno, a rezultati to i pokrivaju ... samo im cijena ne ide u prilog, stvarno ne znam koji bi bio bolji izbor Antec ili Sisa.
Ali zato je u isto vrijeme XFX predstavio 1000/1050/1250W ProSeries Black Edition (Gold i Platinum) modele bazirane na ovoj Seasonic platformi i to sa očitim ciljem ulaska na high-end dio tržišta.
Isto je napravio i Be Quiet sa svojom novom Dark Power Pro P10 Platinum serijom.
Ova dva proizvođača bi trebala ponuditi nešto manje cijene od samog OEM-a tj. Seasonica
Staro 13.11.2011., 23:23   #10
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,550
Sam ja to dobro skuzio , ili njegov komp trosi 2200w na 1200watnom napajanju ?? i kako je to moguce ?
Staro 13.11.2011., 23:40   #11
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Autor xulos Pregled postova
2200W vuče iz zida, što bi značilo da samo napajanje daje ~1800W (uzevši u obzir efikasnost napajanja od ~80% na tom opterećenju).
E sad, upravo ga gledam iznutra kako je napravljeno ... ovo napajanje može dati 1800W zato jer je toliko dobro napravljeno da ga ne mogu sa apsolutno ničime usporediti po pitanju sirove snage i kvalitete/inteligencije samog dizajna.
Jednostavno je svaki dio u njemu barem dvostruko moćniji (i mnogo pametnije iskorišten) od npr. jednog XFX-a od 850W, za kojeg se stvarno može reći da je vrlo dobro napajanje (koje je zapravo Corsair TX 850).
Ne mogu se načuditi koliko je OEM (Delta) mislio na svaku sitnicu i koliko su ispred svog vremena po pitanju principa rada.
Staro 14.11.2011., 01:04   #12
Dottore
Dottore's Avatar
Postovi: 7,638
Čini se da su počeli ozbiljno raditi i na kvalitetu.
Vrijeme će pokazati. XFX je odlično, ali ne mogu progutati taj ružni svemirski izgled.
Pitam se gdje je uspavani Enermax...
@Pupo
Dugo se nije najavilo novosti
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Zadnje izmijenjeno od: Dottore. 14.11.2011. u 10:55.
Staro 14.11.2011., 01:12   #13
Postovi: 8,212
Kako misliš uspavani, taman je izašla/izlazi nova Platimax serija.
Staro 14.11.2011., 13:51   #14
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Enermax Platimax serija je tipičan primjer napajanja koje je išlo na visoku efikasnost nauštrb stabilnosti railova (12V npr.). Zato se ni ne spominje previše, a dijelom i zato što ostala napajanja poput AX1200 i HCP-1200 cijenom izgledaju vrlo povoljno naspram njega.
The Secret ...
Staro 14.11.2011., 15:53   #15
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,550
Taman htio napisati, serija prije ima puno stobalnije napone na railovima i kao takvi su isplativija kupnja. ako nadjem bas taj review okacim ga .
Staro 29.02.2012., 10:32   #16
DuHc
DuHc's Avatar
Lokacija: Dubrovnik
Postovi: 204
Nakon kilovatnog izašao je i 860 vatni model, 1. review na AnandTechu:
Probably the Best PSU Ever!
DuHc je offline   Reply With Quote
Staro 24.03.2012., 18:01   #17
dean225
DD9512
dean225's Avatar
Postovi: 1,869
ja sam trazio ovaj 860 wattni model ali ga nije bilo nigdje za uzet.. Uzeo veceg brata. Nikada mi nije bio bitan tih komp, ali nekako mi se sve pogodilo i sada je stvarno necujan. Napajanje mi nije ni blizu iskoristeno, radi u hibrid modu.
Evo malo slikica..
http://img804.imageshack.us/img804/4036/imag0262qm.jpg
http://img855.imageshack.us/img855/3584/imag0263e.jpg
http://img444.imageshack.us/img444/528/imag0264u.jpg
http://img338.imageshack.us/img338/9244/imag0265y.jpg
http://img703.imageshack.us/img703/2168/imag0268o.jpg
Primjetio sam da kod nekog opterecenja tipa obrada videa ili igranja, nesto "skljoca" u kompu (zvuk kao kod paljenja kompa) pa me zanima jel moguce da napajanje ima neku faznu regulaciju ili mi skljocaju grafe??! :/
EDIT: Iritantno je jako, dosta često pali gasi nešto.. nije vent, napajanje je skroz hladno i vent se ne vrti 100%. A vrijeme će pokazat hoće nesto izgorit ili je to normalno. Pripremio sam opremu za gašenje..
Zadnje izmijenjeno od: dean225. 25.03.2012. u 15:26.
dean225 je offline   Reply With Quote
Staro 25.03.2012., 11:54   #18
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Fali ti "soka" kod napajanja pa zato škljoca, ukljućuju se "crnci" s pedalama kako bi upogonili i dali višak snage
Staro 25.03.2012., 14:57   #19
Elpresidente1
Datum registracije: May 2009
Postovi: 389
Škloca relej ili tak neš koji pali vent.
Elpresidente1 je offline   Reply With Quote
