Staro 02.11.2011., 19:50   #151
Dottore
Dottore's Avatar
Postovi: 7,604
Noctua Presents NH-D14 Special Edition for LGA2011
Noctua's award-winning NH-D14 heatsink features a 6 heatpipe dual radiator design that provides more surface area, better heat-distribution and superior airflow efficiency than conventional tower style heatsinks. Developed to provide ultimate quiet cooling performance in dual fan mode, the NH-D14 is renowned to be among the best premium-grade CPU coolers available.
Izvor : techpowerup
Službeni : Noctua
Za postojeće vlasnike NH-D14 postoji NM-I2011 mouting kit. Prije se moglo na nekim modelima moglo dobiti besplatno a sada valjda se plaća
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Dottore je online   Reply With Quote
Staro 02.11.2011., 19:56   #152
Postovi: 8,193
Piše da se neplaća ali je potrebno imati Noctua hladnjak i ploču ili procesor.
"Owners of Noctua CPU coolers can obtain the NM-I2011 Mounting-Kit free of charge via this form. A proof of purchase (photo, scan or screenshot of the invoice) of both a Noctua CPU cooler and either a socket LGA2011 mainboard or socket LGA2011 CPU are required.
Staro 02.11.2011., 19:58   #153
Dottore
Dottore's Avatar
Postovi: 7,604
Istina. Samo je pitanje hoće li to upaliti.
Isto možeš poslati tuđu fotografiju i pomoliti da nasjedaju na foru.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 02.11.2011., 21:20   #154
xtreme96
OC addict
xtreme96's Avatar
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
I onda kad im 50 ljudi minimalno posalje istu sliku onda bude sranje
NH-D14 bi najvise volio imat u svom kucistu...Hladnjak koji mi se najvise svidja..Jedina stvar koja mi je odvratna na Noctuama je bijelo-smedji ventilator,to odma ide u crno ako se mene pita....pogotovo ako se ima kuciste s prozorom...
Pošten trgovac: 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15...
- prije mi je bio nick "xTreme Gamer" (profil je isti ali sam promjenio nick)
xtreme96 je offline   Reply With Quote
Staro 05.11.2011., 01:12   #155
MafiaMan
MafiaMan's Avatar
Postovi: 83
http://www.guru3d.com/article/zalman-cnps-12x-review/
Ipak mozda nije toliko los. Cekan jos druge rw-e
Ja sam trenutno u dvojbi izmedju njega i H100 ..
MafiaMan je offline   Reply With Quote
Staro 05.11.2011., 08:57   #156
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Nebi ja stavlja Cnps12x i H100 u isti kos, koliko god se cinilo da zalman ima dobre performanse..
Valjalo bi definitivno pricekati ostale reviewe, no ako mislis izdvojiti toliku svotu novca na hladjenje,
radije uzmi H100. Svakako prije toga provjeri dali ti moze stati u/na kuciste...
Staro 05.11.2011., 09:02   #157
Postovi: 8,193
Ja bi definitivno išao na H100 ako već misliš potrošiti tu sumu novaca!
Staro 06.11.2011., 12:55   #158
MafiaMan
MafiaMan's Avatar
Postovi: 83
evo jos jedan
http://www.benchmark.pl/testy_i_rece...ona/15695.html
U slusaju da iden na H100 , onda ide i 650d kuciste ... U suprotnom zalman i fractal.. Pokusavam opravdat cjenu 650d naspram fractala ali mi neide, lol
Staro 06.11.2011., 13:02   #159
Postovi: 8,193
Koji fractal? Zašto mora H100 i cors kućište?
Staro 06.11.2011., 14:09   #160
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
http://www.youtube.com/watch?v=Ik4jx...eature=related
Ovdje se Zalman bas nije dobro proveo i treba racunat na veliki problem sa memorijom.
Staro 06.11.2011., 14:42   #161
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,543
Ni meni taj kuler nije nist posebno, silver arrow i d14 su puno bolji double tower hladnjaci.
Staro 06.11.2011., 14:57   #162
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,747
Meni zalman izgleda bolje nego itjedan double/single tower hladnjak i odaje jako dobru kvalitetu izrade baze i opcenito cilog hladnjaka..
Na stranu dobre performanse, cijena, kompatibilnost i ugradnja aftermarket ventova su presudne karakteristike u vecini slucajeva kod vecine ljudi...
Staro 06.11.2011., 15:18   #163
MafiaMan
MafiaMan's Avatar
Postovi: 83
Autor Pupo Pregled postova
Fractal R3 ili XL
Jer ciljam na sto optimalnije i tise hladjenje + volin kad sve to izgleda uredno . U koje se jos kuciste H100 da namontirati ?
U vezi ovog YT review-a.... na guru3d forumu je lik navea razlog zasto ovaj nije dobia dobre rezultate . Ako cooler najnormalnije funkcionira u guru3d polozaju onda nevidim bas problem sa clearance-om , tj to mu postaje i jedna od prednosti..
Zadnje izmijenjeno od: MafiaMan. 06.11.2011. u 15:25.
Staro 06.11.2011., 15:21   #164
Postovi: 8,193
Koji fractal planiraš kupiti?
Autor MafiaMan Pregled postova
Jer ciljam na sto optimalnije i tise hladjenje + volin kad sve to i izgleda uredno . U koje se jos kuciste H100 dade namontirati ?
Ovo tiho i uredno ovisi samo jednim dijelom o kućištu, a većim o tome kakvi se koriste ventovi, koliko ih je i sl. Jer nema kućišta koje će utišati glasan vent, a pogotovo ne više njih!
Staro 06.11.2011., 15:33   #165
MafiaMan
MafiaMan's Avatar
Postovi: 83
edit-a san post gore
A znam , ali po slikama sto san vidia na netu ...u kakvo se stanje corsair da dovesti , to me privlaci njemu + h100 se savrseno uklapa u njega. Nikako nevolin koncpet ovih 1kg hladnjaka .Kad to slozin onda cu vidit koliko je sve to bucno/tiho , pa nije problem uloziti u ventove ili pak nekakv potencimetar koji ce bit skriven unutar kucista
Staro 07.11.2011., 09:27   #166
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Cooler Master Announces LGA2011 Bracket Free Upgrade Program
Cooler Master, an industry leading chassis, thermal solution, peripheral, and accessory manufacturer today extends its support for its customers. As was previously announced, Cooler Master is providing a free bracket to support LGA2011 on the Hyper 212 EVO. This will now be extended to one of Cooler Master’s best-selling CPU Coolers. Loyal owners of the award-winning Hyper 212 Plus need not worry as this offer covers the Hyper 212 Plus as well.
Support will continue to grow for other Cooler Master CPU Coolers. To be notified when new CPU Coolers brackets are available through this program or CM Store, please sign up for the Cooler Master Newsletter.
To Obtain a Bracket Upgrade:
A free LGA2011 bracket will be provided to those that purchased a Hyper 212 EVO/Plus before the inclusion of this bracket in the product packaging.
  • Visit our parts request page here
  • Be ready to provide one of the following options Heatsink serial number and an invoice for a LGA2011 motherboard or processor
    o Heatsink serial number and a picture of your new LGA2011 motherboard or processor
For more information, visit this page.
http://www.techpowerup.com/154755/Co...e-Program.html
C L O W N I N G A R O U N D
Staro 07.11.2011., 13:18   #167
Postovi: 8,193
A što Intel truje s tim "standardima". Opet će biti par mm razlike između rupa i sad odma novi mounting kit.
Ako već ideš na fractala, mislim da ima boljih hladnjaka od tog zalmana. Tipa venomousX ili Prolimatech Megahalems. H100 je isto super, samo trebaš malo proučit kućište da li stane.
Staro 07.11.2011., 16:32   #168
Dottore
Dottore's Avatar
Postovi: 7,604
Koliko ja vidim polagano postajem razočaran. Naime, ovi bracketi kako kažu proizvođaći ali bez donji dio. Ide direktno na Lotes adapter
npr.
i kit gornji dio od Noctue
Zado me polagano hvata depra zašto bez donjeg bracketa ( meni je bolji jer dodaje još veći pocršinu hladenja. )
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 09.11.2011., 18:31   #169
klem
Postovi: 591
Fan clip za zalman performu cnps10x
trebao bih malu pomoć...dal netko zna di se može nabavit fan clipova za 120mm ventilatore. Fali mi još jedan par za zalman performu . Na ebayu ima najjeftiniji scytheovi za 6 $ + još toliko poštarina
klem je offline   Reply With Quote
Staro 09.11.2011., 19:35   #170
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Autor klem Pregled postova
Bilo je u "Stinksa" baš Scytheovih za 15kn, a sad ih više nema. Nazovi pa pitaj možda znaju kad dolaze - evo ti i stari link
http://www.links.hr/index.php?option...0.912.103%5D=1
PS Možda i Chipoteka ali nekako sumnjam
Pomelo mi sig -.-
Staro 14.11.2011., 08:06   #171
Doink the Clown
Postovi: 6,214
EVGA Intros LGA2011 Mounting Kit for SuperClock CPU Cooler
EVGA made its SuperClock CPU fan-heatsink ready for Intel's new "Sandy Bridge-E" socket LGA2011 platform with a mounting kit update that can be purchased separately, as well as could be included in future batches of the product. Carrying the part number M020-00-000234, the LGA2011 mounting kit update for EVGA SuperClock, is priced at US $9.99 on the EVGA store. EVGA released the SuperClock CPU fan-heatsink this May, it is a tower-type fan-heatsink with design based on Swiftech Polaris 120. EVGA's implementation makes use of black fins, heat pipes, and a red LED-illuminated fan. Excluding the LGA2011 mounting kit, the EVGA SuperClock is priced at $55.
http://www.techpowerup.com/155075/EV...PU-Cooler.html
Staro 15.11.2011., 10:49   #172
Dottore
Dottore's Avatar
Postovi: 7,604
Thermalright LGA 2011 Retention kit Release
1. For Thermalright’s Silver Arrow/HR-02/Archon/ Venomous and models with the VenomousX BTK
pressure plate kit, we have our minimalist LGA
2011 Adapter Kit with 4 2011 Screw Pillars.
2. For Thermalright’s HR-02 Macho/True Spirit 140/ True Spirit and all models using the new universal
Intel/AMD bracket, we have the new LGA2011
Retention Kit. Comprised of a new 2011 Retention
Bracket and 2011 Screw Pillar Type B.
Izvor :sluzbeni link od Thermalright-a
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 15.11.2011., 11:01   #173
Postovi: 8,193
Znači da u biti svatko ko ima BTK pressure plate kit može s malo mašte namontirat isti na LGA 2011, samo mu treba malo mašte i par odgovarajućih matica i 4 malo duža šarafa il navojnu šipku da od njih napravi brezone.
Staro 15.11.2011., 20:37   #174
Dottore
Dottore's Avatar
Postovi: 7,604
Noctua Introduces NF-F12 Focused Flow Fan
Možda nije tema za novosti ventilatora ali spada u hlađenje hladnjake tipa high end.
Noctua today introduced the new NF-F12 120mm Focused Flow fan. Teaming up eleven stator guide vanes with a specially conceived seven blade impeller, the NF-F12’s Focused Flow system creates outstanding static pressure and focuses the airflow for superior performance on heatsinks and radiators. At the same time, a wide range of advanced aerodynamic design measures, second generation SSO-Bearings and Noctua’s new, custom designed PWM IC for fully automatic control guarantee astounding quietness of operation.
Izvor : techpowerup
Službeni : Noctua
Nudi vrlo visok statički tlak zrak i podržava PWM regulaciju brzine vrtnje putem 4-pinskog konektora. Okretaji, i puno veći tlak u odnosu na NF-P12
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 17.11.2011., 16:18   #175
Mad_Duke
EDIT: Mod ak može pobrisat, fulao temu! Sorry
Zadnje izmijenjeno od: Mad_Duke. 17.11.2011. u 16:34.
Staro 23.12.2011., 18:50   #176
Doink the Clown
Postovi: 6,214
Zalman's CNPS10X Optima CPU Cooler Goes up for Pre-order
Announced earlier this month, Zalman's CNPS10X Optima CPU cooler has started to pop up in store listings as a pre-order item. Set for a January arrival, this new tower cooler makes use of Direct Touch Heatpipe (DTH) technology and comes with support for Intel LGA 1155 / 1156 / 1366 / 775 and AMD AMD Socket FM1 / AM3+ / AM3 / AM2+ / AM2 processors.
Zalman's creation measures 132 (L) x 85 (W) x 152 (H) mm, it weights 630 grams, and has four copper heatpipes, aluminum fins, and one 120 mm FSB (Fluid Shield Bearing) fan which features Shark Fin blades (for increased airflow and lower noise & vibration) and operates at 1,000 to 1,700 RPM (sound output is 17 to 28 dBA).
The CNPS10X Optima is bundled with a pinch of ZM-STG2M thermal grease and can be found priced as low as 22.76 Euro.
Staro 24.12.2011., 19:08   #177
kian
kian's Avatar
Datum registracije: Oct 2001
Lokacija: Velika Gorica
Postovi: 600
X-bit-ovci mu dali Editor's Choice
We are proud to award Zalman CNPS12X cooler with our Editor's Choice title as the best air cooler available today:
Two Pounds of Pure Efficiency: Zalman CNPS12X Super Cooler Review
Staro 24.12.2011., 21:03   #178
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Duplo manji Achon sa 1260rpm hladi isto ko i ovaj sa 3x1000 i vjerojatno je osjetno jeftinji..
Staro 03.01.2012., 12:50   #179
drz_nedaj
Axl Rose
drz_nedaj's Avatar
Postovi: 395
jel se moze negdje u hrvatskoj kupiti Thermalright Venomous vise??
drz_nedaj je offline   Reply With Quote
Staro 11.01.2012., 21:13   #180
Doink the Clown
Postovi: 6,214
A CPU Cooling Heatsink With Built In Computer From Cooler Master
