Staro 13.10.2011., 20:23   #1
Facelessone
Facelessone's Avatar
Postovi: 4,203
"Server" kanta daje BSOD
Evo, sad zadnje.
Stavim nešto skidat od frenda preko remotea, vratim se doma za 20 min i komp smrznut.
Konfiguracija pod "Server"
Ako netko iz ovoga zna do čega bi moglo biti.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 13.10.2011., 20:30   #2
nino
nino's Avatar
Postovi: 12,602
Pokusaj ovo.
The behavior may occur if the win32k.sys is corrupted. Go to
C:\WINDOWS\System32 and rename the Win32k.sys file to Win32k.old and then
close the window. Now go back to the system32 folder and you will have a
new and non-corrupt Win32k.sys file.
The behavior also may be caused by that the virtual memory of the Windows XP
is corrupted. Disable and then enable the Virtual Memory to see whether it
solved the problem.
Staro 13.10.2011., 20:36   #3
Facelessone
Postovi: 4,203
Hvala. Napravio oboje, sad čekat i nadat se da se više nikad ne pojavi
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 13.10.2011., 20:45   #4
nino
nino's Avatar
Postovi: 12,602
To mi je google prvo izbacio.
Staro 22.10.2011., 21:09   #5
Facelessone
Postovi: 4,203
Evo, od tada, dogodilo se opet. Skroz ista stvar kao na screenshotu gore.
Mislim da se dogodilo dok sam brisao file koji je na Serveru sa svog kompa, ili par sekundi odmah nakon toga. (Njegovi hardovi su mi mapirani ko network drive.)
Još neki savjet oko problema?
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 26.10.2011., 23:25   #6
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,750
Jebote, zar nije ocito?
http://tinypic.com/r/intwk8/5 (da mi je znati zasto ova kurcina od TinyPic-a poveca moj jebeno optimizirani PNG od ispod 200 kb na jebenih 600 i kusur kb i mogu umrijet sretan)
Probaj neki VNC server (tipa TightVNC) pa vidi dogadjali se isto i s njime.
Programer
Staro 31.10.2011., 14:04   #7
Facelessone
Postovi: 4,203
Nije bilo očito
Stavio sam Teamviewer za sad, lakše mi je jer se mogu s faksa spojit onda.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
