LateralusX
Postovi: 1,788
Nvidia ForceWare v285.62 WHQL driveri
GeForce 285.62 Driver This is the recommended driver for Battlefield 3. It contains several performance and compatibility enhancements for the final release of the game. Check here to see if your PC is ready for Battlefield 3. This is also the recommended and enhanced driver for Batman: Arkham City and RAGE. Check here to see if your PC is ready for Batman: Arkham City Contains a fix for the driver timeouts reported with the R285 beta drivers. http://us.download.nvidia.com/Window...ease-Notes.pdf New in R285 Drivers Performance Increases performance for GeForce 400 and 500-series GPUs in several PC games vs. v280.26 WHQL drivers. The following are some examples of improvements measured on Windows 7. Results will vary depending on your GPU and system configuration: GeForce GTX 580: Up to 6% in Battlefield 3 Up to 5% in Call of Duty: Black Ops Up to 7% in Civilization V with SLI Up to 5% in Crysis 2 DX11 with SLI Up to 7% in F1 2010 with SLI Up to 5% in Lost Planet 2 with SLI Up to 5% in Mafia 2 with SLI Up to 13% in Metro 2033 with SLI Up to 8% in STALKER: Call of Pripyat with SLI Up to 5% in StarCraft 2 GeForce GTX 560: Up to 4% in Bulletstorm Up to 5% in Battlefield: Bad Company 2 with SLI Up to 11% in Battlefield 3 Up to 6% in Call of Duty: Black Ops Up to 5% in Crysis 2 DX11 with SLI Up to 7% in Dragon Age 2 with SLI Up to 7% in F1 2010 with SLI Up to 5% in Just Cause 2 with SLI Up to 5% in Lost Planet 2 with SLI Up to 4% in Mafia 2 with SLI Up to 7% in Metro 2033 with SLI Up to 11% in STALKER: Call of Pripyat with SLI Up to 7% in StarCraft 2 NVIDIA PhysX Updates PhysX System Software to version 9.11.06.21. NVIDIA SLI Added or updated SLI profiles for Battlefield 3, Dead Island, Diablo III, Dragon Age 2, Need for Speed: The Run, and Saints Row: The Third. HD Audio Updates HD Audio driver to version 1.2.24.0. OpenGL Adds support for OpenGL 4.2 for GeForce 400 series and 500 series GPUs. NVIDIA 3D Vision The 3D Vision Controller (USB) driver is included in this driver package. Users are no longer required to install the 3D Vision CD driver or a separate 3D Vision Controller driver. For more information, please view this knowledgebase article. Adds support for viewing 3DVisionLive.com and YouTube 3D with NVIDIA SLI PCs. Please view this knowledgebase article for more information on 3D Vision Window Mode. Window mode is now the default viewing option for the 3D Vision Photo Viewer. Added the following 3D Vision game profiles: Aion Diablo 3 Dead Rising 2: Off The Record Defense of the Ancients (DOTA) 2 From Dust Harry Potter and the Deathly Hollows Part 2 Last Remnant Benchmark Men of War Assault Squad Stock Car Update the following 3D Vision game profiles: Dirt 3 – updated rating to Excellent Other Details Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP. Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards. Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software. Users without US English operating systems can select their language and download the International driver here. |
Datum registracije: Jun 2004
Lokacija: Sj. Njemacka
Postovi: 503
Jedno pitanje. Kako sad dugo nisam bio u zelenom taboru, da li se za upgrade drivera kod nvidie isto preporuca prvo potpuno brisanje starih kao kod ati-a ili kod nevidie moze samo puknut upgrade preko starih a da ne bude blesiranja poslije? |
LateralusX
Postovi: 1,788
moze se, i jos u installeru ima opcija clean install |
Postovi: 919
Nema nikakvog blesiranja kod upgradea, mit. |
Postovi: 3,788
PRO
Postovi: 4,878
odlično radi bc2 i deux ex, temp začuđujućih hladnih 87°C u loadu. Ne žalim se. ![]()
#16 |
LateralusX
Postovi: 1,788
#18 |
Postovi: 518
Unatoč tome meni opet nerade i prestaju radit na mojoj grafičkoj. Počinjem se pitati hoću li zauvijek ostati na 275.33 |
#20 |
LateralusX
Postovi: 1,788
#21 |
Postovi: 518
Samo si promjenio u postavkama power menagment moda s adaptive na max performance? (to si stavio i u global settings i u program settings). Jer ja sam samo u global settingsima to stavio a mozda sam trebao i u program settinsu prebacit?? |
#22 |
LateralusX
Postovi: 1,788
trenutno mi je samo za firefox max preformance, sa nekom starijom verzijom drivera sam morao imati i global |
#23 |
Postovi: 518
Stavio sam na global max performance i u programima samo za mozillu max performance jer su mi se u njoj najcesce i rusili. E sad imam tamo ponudjeno jos par programa za glazbu i filmove pa neznam da i na njima odaberem ili da za pocetak vidim kako ce se ovo ponasat? Mislim da je mozilla dovoljna |
#25 |
Prvoklasni Krkan
Postovi: 5,369
Pa napisao ti ja da imam, BETA mi radila normalno, ali ja za razliku od tebe nemoram napravit hard reset nego me samo baci na desktop, igram cca 10-20min i op na desktop i tako stalno. Konfa iz potpisa. |
#26 |
Lokacija: Sv.Nedelja
Postovi: 5,830
Ma htio sam cut ostatak ljudi ak ima ko istih problema. Hard reset sam bezveze napravil, trebalo je jos malo pricekat, pa me na desk izbaci. A nis bum sutra stavil te beta drivere pa bumo vidli. |
#27 |
Postovi: 682
Battlefield 3 mi radi kao podmazan sa ovim driver-ima, igram na 460GTX. Jedini problem kod drivera je onaj koji se ponavlja i od zadnjih beta, a to je da se znaju zblesirati u 2d modu tj. najčešće prilikom surfanja (Firefox), no to se da lagano riješiti. Osim toga driveri rade sasvim dobro. |
#28 |
Postovi: 65
Već oko godinu dana koristim programska rješenja za poštimavanje taktova, napona i brzine ventilatora, trebalo mi je jedno vrijeme da uhodam to sve ali rezultati u praksi su zapravo vrlo dobri. Budući da na svoju grafičku imam spojen projektor kao sekundarni display grafička niti neće u 2D mod ali se ipak u MSI Afterburneru mogu značajno smanjiti taktovi i napon što rezultira manjom potrošnjom i zagrijavanjem, te postavke sam pohranio pod profil 1, a pod profil 2 sam stavio postavke za grafičku na kojima je overclockirana i taj profil se koristi za 3D zahtjevne aplikacije. Također sam dodao funkciju koja upravlja sa radom ventilatora, u početku sam bio nepovjerljiv što ako zakaže ili nešto ali vrijeme je pokazalo da nema razloga za brigu i da sve super radi. U MSI On-Screen Display-u sam dodao aplikacije (DVBViewer, GoogleEarth, StereoPlayer...) koje koriste DDI a da za njih ne želim da mi auto prebacuju u profil 2 (performance) te za svaku pojedinačno Application detection level stavio na None. Evo tu su vam SS-ovi mojih postavki: http://imageshack.us/photo/my-images/825/89090786.jpg/ http://imageshack.us/photo/my-images/717/57537096.jpg/ http://imageshack.us/photo/my-images/510/39496931.jpg/ http://imageshack.us/photo/my-images/715/13922773.jpg/ http://imageshack.us/photo/my-images/26/14874211.jpg/ http://imageshack.us/photo/my-images/717/98039846.jpg/ http://imageshack.us/photo/my-images/522/21809508.jpg/ http://imageshack.us/photo/my-images/444/83369083.jpg/ http://imageshack.us/photo/my-images/830/29868814.jpg/ http://imageshack.us/photo/my-images/823/64100043.jpg/ http://imageshack.us/photo/my-images/88/62951195.jpg/ Nadam se da će nekom biti od koristi. |
#30 |
Postovi: 518
Nakon sto sam i u programima tj mozilli stavio na max performance driveri mi se za sad neruse ali jos cu obratit paznju. Nakon par dana pracenja sve je ok psim sto mi je temperatura grafe osla za dobrih 10 stupnjeva gore. Sad je na 39 a bila je 29-30 stupnjeva. Evo probao se vratit na 275.33 i temperatura pada na 29 stupnjeva. Nevjerojatno, a ja se jos cudio zasto mi je toplija grafa kad sam kuciste nesto otvarao. Zadnje izmijenjeno od: NemoRS. 29.10.2011. u 18:53. |
