Staro 10.03.2005., 21:22   #1
Dottore
Dottore's Avatar
Postovi: 7,618
msi k8n neo2 platinum
ima li tko iskustava s MSI K8N Neo2 platinium s socketom 939 i kakva je?
ploča ima nForce 3 Ultra
a evo opis:
CPU
• Supports Socket 939 for AMD® Athlon™ 64 FX / Athlon™ 64 processor
• Supports up to 3500+, 3800+ Athlon 64 FX 53, or higher CPU
• nVIDIA® nForce3 Ultra Chipset
- HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU
- HyperTransport supporting speed up to 1GHz (2000MT/s)
- AGP3.0 8X interface at 533 MT/s (million transfers per second)
- Two independent SATA controllers, for four drives
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
- Dual Fast ATA-133 IDE controllers
Main Memory
• Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs .
• Supports a maximum memory size up to 4GB without ECC.
• Supports 2.5v DDR SDRAM DIMM.
Slots
• One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE/SATA
• An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
• Supports 4 SATA ports. Transfer rate is up to 150MB/s.
• NV RAID (Software)
• Supports up to 4 SATA & 2 ATA133 Hard drives
- RAID O or 1, 0+1, JBOD is supported
- RAID function work w/ATA133 + SATA H/D or 2 SATA H/D
Audio
• 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
• Supports dual LAN jacks
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY
- 1 LAN supports 10/100/1000 Fast Ethernet by Realtek 8110S (1000Mbps)
IEEE1394
• VIA 6306 chipset
- Supports up to 3 x 1394 ports.
- Transfer rate is up to 400Mbps
On-Board Peripherals
On-Board Peripherals include:
- 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 Audio jack(5-in-1), coaxial/fiber SPDIF out
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 2 RJ45 LAN jack
- 3 IEEE 1394 connectors (Rear x 1/ Front x 2)
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your
mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
• 6 mounting holes.
Staro 10.03.2005., 21:31   #2
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
sig govori sve .
to ti je najbolja AGP ploca za 939. ima najmane bugova i relativno dobra za ocing (s obzirom na mogucnosti 64-cetvorki kaj dolaze kod nas). ak trebas AGP plocu najbolji izbor ali ak mislis ici na neke novije dakle PCI-E radje zemi DFI NF4 plocu.
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 11.03.2005., 02:25   #3
Konan
Konan's Avatar
Datum registracije: Jun 2004
Lokacija: Xindi weapon
Postovi: 441
Kak to misliš koji dolaze kod nas?
Konan je offline   Reply With Quote
Staro 11.03.2005., 09:30   #4
N!NO
N!NO's Avatar
Datum registracije: Sep 2002
Postovi: 278
I moj glas za K8N Neo2 Platinum!
Izasao novi BIOS 1.5:
http://www.msi.com.tw/program/suppor...UID=607&kind=1
- Update NVPXE version to 2.03.0469.
- Update CBROM version to 1.47.
- Update NVRAID version to 4.81.
Zadnje izmijenjeno od: N!NO. 11.03.2005. u 11:23.
N!NO je offline   Reply With Quote
Staro 11.03.2005., 14:46   #5
violent
Postovi: 2
Kakva su vasa razmisljanja u svezi MSI K8N Neo4 Platinum ploce?Ima li itko iskustva s njom?
violent je offline   Reply With Quote
Staro 11.03.2005., 15:49   #6
Bl@de
Bl@de's Avatar
Postovi: 2,004
zato kaj kodnas dolaze samo koma stepinzi pa je max clock 2.5-2.6ghz.
Intel i5 4670k
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
Dell S2522HG
Staro 12.03.2005., 17:52   #7
MentalHarikiri
MentalHarikiri's Avatar
Postovi: 2,560
a čuj meni je tu na stolu jedan CBBHD 0450 koji bi trebao ići cca 2.7GHz
šteta kaj još skupljam lipe po stanu za Mbo
Staro 12.03.2005., 18:14   #8
N!NO
N!NO's Avatar
Postovi: 278
A kakav bi trebao biti CBBFD 0437 3200+?
Staro 12.03.2005., 19:27   #9
MentalHarikiri
Postovi: 2,560
po bazama na netu cca 2.5GHz @ 1.55V
Staro 12.03.2005., 23:01   #10
ante2
ante2's Avatar
Postovi: 1,313
hmh
:confused:
jel neko zna sta im dojdu one skracenice u opisu ispravki novog biosa za MSI K8N Neo 2 Platinum odnosi se na zanji BIOS 1.5
ante2 je offline   Reply With Quote
Staro 13.03.2005., 10:55   #11
N!NO
N!NO's Avatar
Postovi: 278
I mislio sam si da nije nista posebno. Niti 2.4GHz mu nije bas po volji... Hvala!
Staro 20.03.2005., 11:14   #12
N!NO
N!NO's Avatar
Postovi: 278
Eto da malo pohvalim plocu...
Jucer sam je malo isprobavao i dobio stabilan rad na 300 x 7 na 1,5V i memorija 300 8-4-4-2,5 2T na 2,75V.
Procesor na zalost nece stabilno raditi na 300x8, ali na 300x7 radi super. Polovicne mnozitelje ne koristim iz vjerskih razloga
Eto i mene u klubu 600
No stroj vozim na 290x8 s memorijom na 241 6-3-3-2,5 1T jer je tako dosta brzi u svim testovima.
Staro 30.03.2005., 22:09   #13
ludivedran
ludivedran's Avatar
Datum registracije: Jul 2003
Lokacija: Croatia/Zagreb
Postovi: 43
Ploca je fenomenalna,toplo je preporucam nemam nikakvih zamjerki.
ludivedran je offline   Reply With Quote
Staro 08.04.2005., 12:32   #14
N!NO
N!NO's Avatar
Postovi: 278
Novi BIOS 1.6:
http://tinyurl.com/5xa6q
- Fix when CPU Temperature over 40.C and then to restar system the CPU Temperature still show 40.C
- Make the CPU FAN Starup Voltage over 6V
- Fix LAN BOOT function fail after update NVPXE 2.03.0469
Staro 23.04.2005., 19:10   #15
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Stigla i moja--NAPOKON- pa da odmah pitam;jel to normalno da neda memoriji u 3 slota(isprobano-definitivno-kada imam u 2 slota sve ok ali kada probam i u treći,neće)bilo koji od ova 3 izvadim i radi-znači svi su ispravni.
damir1 je offline   Reply With Quote
Staro 24.04.2005., 11:12   #16
N!NO
N!NO's Avatar
Postovi: 278
http://tinyurl.com/5rpsn
...a to imas i u manualu. Nije to specificnost samo ove ploce...
Staro 24.04.2005., 12:00   #17
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Aha,manual sam pročitao tek poslije kada sam popizdio od muke (neradi,neznam pa šta je više) i sjeo malo ohladiti :confused:
Staro 25.04.2005., 23:05   #18
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Pa na koju foru joj zaključate memoriju na 200 npr. to jest asinkrono itd?:confused:
Staro 26.04.2005., 09:41   #19
N!NO
N!NO's Avatar
Postovi: 278
Auto i 200 su sinkrono, 166 i 133 su dijelitelji, a 100 je mislim fiksno na 100(200).
Recimo "FSB" na 250 s dijeliteljom 166 daje takt memorije 208 itd.
166/200x250=208.
Staro 26.04.2005., 11:51   #20
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
E hvala puno-sad mi je jasnije.Probam 200,manual-diže koliko hoće.uglavnom dosad probao na 218x11 bez diranja voltaža super stabilno sve(prime;super pi;3dmark)
Staro 26.04.2005., 19:57   #21
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Pa sad više ne kužim.Nešta opet dobro neradim-neće recimo 240 dignuta voltaža čak probao i to a memorija onako na 166 pa je ukupno cca 390---- a radi evo sad na
11x225 sinkrono i sve ok znači 2475 MHz momentalno i mema 450 i sve to na 1.55V.....probao sam i na 235 sinhro ide a ako ne neide;zaključak:negdje hebem. Ajde molim neka netko posta svoje postavke iz biosa(bez latencija meme) pa da skužim gdje griješim--neke 240-50 npr a memorija asinhrono 166-znači 210-tak:confused:
Asus Z97-A-i5 4690K-xfx 470 -Kingston DDR3 1866 SDRAM 2x4GB -dvd ladice-asus 450W-sve to u chenbro gaming bomb, jedinici + Dell U2412HM
Staro 27.04.2005., 12:35   #22
N!NO
N!NO's Avatar
Postovi: 278
Nije da bas kuzim sto si htio reci...
Ako dizes "FSB", obavezno smanji HTT multiplier na 4x. Ako ides preko 250, obavezno na 3x.
Kako dizes takt memoriji, tako joj moras i "otpustati" latencije.
Staro 27.04.2005., 12:45   #23
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Ma znam za latencije(naravno) ali ovo HT dosad nisam imao-znači i to ima veze
Staro 27.04.2005., 13:38   #24
N!NO
N!NO's Avatar
Postovi: 278
Novi BETA BIOS 1.8 normal i modded:
http://www.zen15326.zen.co.uk/MSI_K8N_NEO2_BIOS/
Staro 29.04.2005., 16:04   #25
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
N!NO jesi probao te modane,šta ima kakvi su.Ja sam stavio ove obične i zasada sve ok(pazi ovo zasada-već 2 dana )
Staro 30.04.2005., 19:43   #26
N!NO
N!NO's Avatar
Postovi: 278
Nema nista posebno u tim modanim BIOSima osim sto su prikazane neke inace skrivene funkcije i hidden menu je po defaultu prikazan.
Staro 30.04.2005., 19:51   #27
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Aha,ok-a mene i dalje nabrijavanje hebe.
korumpira mi hard,već sam 2x win ponovo radio.popizdiću neznam gdje griješim;ajd daj mi navedi-nabroj svoje postavke N!NO. Dali može biti problem što je sata disk - imam ionako za njega dole ono ---
Safely Remove Hardware:confused:
Staro 01.05.2005., 11:40   #28
N!NO
N!NO's Avatar
Postovi: 278
Ma ovo safely remove hw te ne mora brinuti, a sto se tice korupcije, moras disk zastekati na konektor SATA 3.
Znaci ne na 1 nego na 3. Ako imas drugi disk na 2, njega ustekaj na 4 i rijesio si sve probleme.
Staro 01.05.2005., 14:50   #29
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Nadam se da je samo to,vidim pa ću javiti (hebo ih controler-i još taj što nevalja stave kao 1-2)
Staro 01.05.2005., 17:40   #30
N!NO
N!NO's Avatar
Postovi: 278
Nije problem sa SATA samo kod ove ploce. nFroce3 i 4 imaju s tim problema. Cipset ima podrsku za 4 SATA kanala s time da samo za dva ima u chipsetu PHY, a dva su vanjska.
Tako da za dva imas zalockani takt skupa s PCIom, a za dva takt raste kako se dize HTT.
Bolje je jedino kod ploca koje imaju posebni vanjski SATA kontroler on board.
