Staro 03.03.2005., 12:37   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Nvidia 71.84 Drivers
NVIDIA has released ForceWare version 71.84 beta drivers for Windows 9x, ME, 2000, and XP at their nZone web site. This driver has passed WHQL tests and will be posted at NVIDIA.com after receiving an electronic signature from WHQL, which is expected any day now.
The new driver increases the performance of NVIDIA graphics processing units (GPUs) in single and multi GPU configurations. The number of games with SLI profiles has increased to over 70 titles and personal application profiles can be created using CoolBits.
Više:
http://www.nzone.com/object/nzone_do...etadriver.html
Podržane igre i aplikacije:
http://www.nzone.com/object/nzone_sl...ifiedapps.html
NVIDIA SLI application Profiles using Coolbits:
http://www.nzone.com/object/nzone_sli_appprofile.html
Staro 07.03.2005., 08:27   #2
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,617
Vrlo dobri driveri, rade mi odlično. Temperatura GPU-a se nije podigla, šta je boljka mnogih novijih beta drivera.
virty je offline   Reply With Quote
Staro 08.03.2005., 05:35   #3
smash3r
smash3r's Avatar
Datum registracije: Feb 2004
Lokacija: 220 km/h a mozda i malo brze,cekam novi auto
Postovi: 180
ce biti dobri za 6800 ultru?
smash3r je offline   Reply With Quote
Staro 08.03.2005., 08:38   #4
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,617
Trebalo bi biti! Ekipi sa 6800 Ultrom rade savršeno kao i meni.
Staro 09.03.2005., 01:19   #5
srkyno1
srkyno1's Avatar
Lokacija: st
Postovi: 1,084
@ virty
jesi možda proba 71.50 od leadtek-a?
ako jesi koja ti je razlika u odnosu na 71.84?
ASUS K8N & Zalman NB32K @ HTT x3 / A64 3000+ 263x8 / 2x256MB TwinMOS @ 210 / Club3D 5200 & Zalman ZM80C-HP / Maxtor 30GB, 2MB / WD Caviar 80GB, 8MB / Maxtor DM10 250GB, 16MB / Xilence 420W / CoolerMaster Centurion 5
srkyno1 je offline   Reply With Quote
Staro 09.03.2005., 08:31   #6
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,617
Originally posted by srkyno1
@ virty
Prika, nisam te drivere proba. Mislim da ću sad neko vrime ostat na ovim v71.84, uredno i stabilno rade.
Staro 09.03.2005., 13:27   #7
Jozha
Jozha's Avatar
Datum registracije: Oct 2001
Lokacija: Sesvete/Soblinec
Postovi: 773
Ja tupio ove 71.84 i dobivam bolje reze ali nemrem podič frekvenciju memorije na 1.1ghz nego mi maks daje 1.09ghz i temperatura se digla za par stupnjeva u odnosu na stare!
Jozha je offline   Reply With Quote
Staro 11.03.2005., 00:12   #8
Saeta
Saeta's Avatar
Datum registracije: Jun 2004
Lokacija: Kaštela<->Varaždin
Postovi: 178
ja ih instalira i temperature iste ka i prije,jos nisam OC
Untitled Document
DFI Lanparty Rev. B ( TicTac Bios)
Leadtek 6600GT @ 561/1153
AMD Athlon - M 2600+@2525Mhz ( 240*10.5, 1.85V )
Water Cooled by Dr.Ice
HDD 80GB WDD
Enermax 350W
Corsair CMX512-3200C2 rev. 1.1 (2 2 2 9, 3.2V)
Samsung 19" 957DF
Saeta je offline   Reply With Quote
Staro 12.03.2005., 16:43   #9
BELIAL
BELIAL's Avatar
Datum registracije: Jul 2004
Postovi: 151
Evo izasli su i offical 71.84, iliti NAPOKON offical drajveri nakon sto sam probo 100 beta http://www.nvidia.com/object/winxp_2k_71.84.html
BELIAL je offline   Reply With Quote
Staro 12.03.2005., 17:37   #10
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Datum registracije: Sep 2004
Postovi: 1,163
Driveri su super,prva koji su,po meni, bolji od onih zadnjih(koji nisu Beta)
Uz njih sam napravio čudo od kartice!
uf,nisam dobro pazio kad sam čito postove,
mislio sam da se proča o BETI 71.84-pa sam misliona njih.,
sad skidam ove 71.84 Forceware
JVC HX-Z10 je offline   Reply With Quote
Staro 12.03.2005., 17:47   #11
virty
Ronon Dex
virty's Avatar
Lokacija: DS9
Postovi: 1,617
Skoro identični kao i beta 71.84, ali u svakom sličaju vrlo dobri driveri!
Staro 12.03.2005., 18:17   #12
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
SKORO-bi trebalo naglasiti, baš sam ih instalirao-i na clocku od 450/1200 se komp zablokirao u 3Dmarku,
za moju grafičku su fulana priča.
Beta, će ostati dok ne dođe nešto drugo i bolje.
Staro 12.03.2005., 19:38   #13
Moki
Moki's Avatar
Lokacija: Vrulja
Postovi: 484
Sto se mene tice 71.84Beta driveri su za sada najbolji driveri koi su do sada izisli. Kartica radi stabilno na 561/1180. dalje nisam probao jer mi temp. ide do 59°C pa se boim da se nesto neplanirano ne desi. Ako netko moze reci do kud moze temp. ici da znam dali je jos mogu kloknuti neka javi.
Pozdrav Moki!
Moki je offline   Reply With Quote
Staro 12.03.2005., 19:47   #14
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
za tvoju karticu neznam,
ali moja je radila,kad sam imo problema, i na 80C+ stabilno
Staro 12.03.2005., 21:49   #15
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
dobri su drajveri sam daju manje 3dmarka al koda je to bitno
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 14.03.2005., 10:20   #16
A-V
A-V's Avatar
Postovi: 293
Kakvih problema?
Kak si skino temp dolje (samo nemoj reci da si mijenjao pastu jer nisam bas toliko upucen da bi to radio pa da jos shebem grafu), kuciste je dobro ventilirano (bas sam ga nedavno mijenjao)?
A-V je offline   Reply With Quote
Staro 14.03.2005., 13:34   #17
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Postovi: 1,163
imao sam sve OC,i bez ijednog dodatnog venta u kućištu...
prvi problemi su se javili kad sam imo fx5200 OC tem u kutiji je otišla prek 42+C
tak da sam moro skinut bočnu stranicu, onda je prašina naletila na cooler i temp je odlazila u visine-pa sam stalno moro čistiti.
ali i unatoč čitom Cooleru i otvorenoj stranici temp je išla na 67C u igricama.i onda sam kupio novo kućište i clocknuo karticu na 450/1200-i temp ne dolazi ni do 55C.
AeroCool Silver Engine-Links 506kn
