Staro 28.09.2011., 11:45   #1471
Danko86
Danko86's Avatar
Datum registracije: Jul 2009
Postovi: 600
Autor Neo-ST Pregled postova
Gledaj malo bolje...
(nije prevelika razlika, ali beta ionako nema pun potencijal frostbitea ni destructiona)
si to negdje pročito ili?
Danko86 je offline   Reply With Quote
Staro 28.09.2011., 11:47   #1472
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,308
Ne, intuitivno nagađam
Da, pretraži EA forum...
Staro 28.09.2011., 11:51   #1473
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor Danko86 Pregled postova
neo je u pravu, destructiona gotovo da nema, ispalis RPG u nesto i nista se ne dogadja
DeadMan+ je offline   Reply With Quote
Staro 28.09.2011., 11:55   #1474
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,308
If you right click on BF3 BETA in Origin and check for updates, in starts installing another 3.9gb update.
http://forums.electronicarts.co.uk/b...eta-patch.html
Staro 28.09.2011., 11:58   #1475
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Stišćem F5 kao retard, ali nemam sreće. Sada sam u queueu na live supportu, lol. Ne znam više koga, ni gdje da pitam za key. xD
You are currently number 860 in the queue. You should be connected to an advisor in about 32 minutes. The average amount of time a customer has to wait is 36 minutes.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 28.09.2011., 12:00   #1476
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,308
EDIT: sad sam već 200-i dok sam stavio ovaj screenshot...padaju ko muhe
Staro 28.09.2011., 12:05   #1477
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
nisam siguran da je to istina, meni svugdje pise da je igra up to date
Staro 28.09.2011., 12:07   #1478
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,308
Ne znam, da barem mogu provjerit, ali bio sam dovoljno glup i platio early access koji nisam dobio pa ne mogu.
Staro 28.09.2011., 12:09   #1479
pdx
pdx's Avatar
Datum registracije: Dec 2009
Lokacija: krk
Postovi: 506
ja sam vec 3 puta bio u live support , isvaki put me dropa , tje kaze da nema agenata
pdx je offline   Reply With Quote
Staro 28.09.2011., 12:14   #1480
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor proudixz Pregled postova
veky je sinoc 3 ili 4 puta dosao sa 2000+ na manje od 100 i svaki put bi ga dropali
Staro 28.09.2011., 12:19   #1481
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,308
evo moje iskustvo sa live chatom, nakon sat čekanja da mi daju key...
Vinod: Hi, my name is Vinod. How may I help you?
2310367452: hi there
Vinod: Hello.
2310367452: i preordered bf3 for Origin, but didn't get the key
2310367452: do you maybe have one?
Vinod: May I know the platform?
2310367452: PC
Vinod: I want to inform you that currently we are out of the beta code from our database,I would request you to contact again within 10 to 12 hour.
2310367452: i can't do that
Vinod: I do under understand but currently we are lack of code and when the code are back we will sure provide you the code within 10 to 12 hours.
2310367452: please give me the key or i will have to cancel my order
2310367452: can you email i to me as soon as you get it at least ?
Vinod: I want to inform you that you need to contact us and we will provide you the code.
2310367452: lol... you're useless, bye
tako da popodne ide refund request.
Staro 28.09.2011., 12:25   #1482
Beo
Lokacija: United Kingdom
Postovi: 512
Samo čekam nekoga da testira BF3 s sličnim ili čak slabijim kompom od mene, pa da vidim hoću li ja to moći igrati ma medium/high s bar 40-60 fps
Pa mi smo tu negdje sa konfama. Mogu ja svog stavit na 3ghz pa pustit fraps kad dojem s posla pa ti postam.
Beo je offline   Reply With Quote
Staro 28.09.2011., 12:25   #1483
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
^^ Hahhahaha, EA.Kakvi debili...to ti je hvala, Neo.
Staro 28.09.2011., 12:51   #1484
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,308
Jesi ti dobio?
Staro 28.09.2011., 12:52   #1485
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
You are currently number 28 in the queue. We apologize for the delay. We will assign you to an advisor as soon as one is available. The average amount of time a customer has to wait is 38 minutes.
Ako upadnem, vidjet ćemo što će meni reći.Ali, postaviti ću još nekoliko pitanja.
Npr. da li će key trebati i sutra, s obzirom da sutra počinje OPEN BETA, itd.
EDIT:
Shatmanyu: I am sorry but currently we are having technical problems.You may please contact us after some time we will definitely help you then.I apologise for thr problem caused to you.
trolololo
EDIT2:
Shatmanyu: You will definitely receive that key by tomorrow or after a few hours.
hahahaha, how yes no.
Zadnje izmijenjeno od: Alph4Dawg. 28.09.2011. u 13:12.
Staro 28.09.2011., 13:20   #1486
Postovi: 16,689
Autor Beo Pregled postova
Ajde pls.. Mogu i ja svog dići na 3.5 ali za sada nepotrebno.. Ako će tebi vrtjeti s 3.0, onda će i meni full
Staro 28.09.2011., 13:26   #1487
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,308
@mansky
Da ne čitam sad sve one preporuke, gdje je najbolje uzet LE ali da mogu od sutra igrat? Zapravo ne znam kako to točno ide ako nije preko Origina
Staro 28.09.2011., 13:29   #1488
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
@mansky
Ja sam uzeo ovdje:
Code:
http://www.cdkeyhouse.com/video-games/action-fps/buy-cd-key-battlefield-3-limited-edition_322
Sutra bi svi trebali moći igrati, a ako je suditi po nekim informacijama key neće ni trebati.
Kupio sam kod njih već 6 keyeva, samo sam jednom imao problem i to mi je njihov live support sredio preko teamviewera.
BF3 LE smo tu naručili Striko, ja i još nas par sa TS-a.Preporuka.
Staro 28.09.2011., 13:35   #1489
musso
Unregistered User
musso's Avatar
Datum registracije: Jun 2002
Lokacija: Beč
Postovi: 722
http://www.cjs-cdkeys.com/products/B...etCurrencyId=3
ovdje je malo jeftinije, tu sam kupio nekoliko keyeva
tu je jos fora da ako imas refer na frenda 10% manje platis, do 5 frendova i imas igru za 50% manje...
tako da ako tu netko kupio molio bih da ga mi se javi, hvala.
musso je offline   Reply With Quote
Staro 28.09.2011., 13:46   #1490
veve
woot!!!
veve's Avatar
Postovi: 2,494
Ja bi je mozda kupio, ali nakon sto isprobam betu.
veve je offline   Reply With Quote
Staro 28.09.2011., 13:49   #1491
Dottore
Dottore's Avatar
Postovi: 7,627
@thesekiman, beo i deadman
Hvala na opseznom opisu igre i problematike.
Bas me zanima hoce li finalna verzija ispravljati te silne nedostatke a mozda jos popravlja zahtjevnost komfiguracije tipa graficke.
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 28.09.2011., 13:58   #1492
Postovi: 16,689
http://www.youtube.com/watch?v=k-Agej_m5xw
je ko vidio ovo?! ja majkemi mile ne vidim razliku bas IKAKVU izmedju low i high settingsa.?!
edit: oke vidi se neka mala razlika. al stvarno minorna u odnosu da je bas sve maxano i bas sve lowano. najvise se vidi u ovoj ambijentalnoj okluziji i AA. ostalo vise manje, slicno... jako sam zadovoljan sad
Slažem se s tobom.. Da su reze iste, a detalji low i high bila bi čista mizerija, tako da ću čak i igrati i na medium ako na high neće ići fluidno A to inače nevolim, ali ajde.. Ovo je iznimka
Staro 28.09.2011., 14:06   #1493
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Razllika je poprilicna a bit ce jos i veca kad izade igra je izgleda da Ultra nije nabrijana kako ce bit, ponajvise teksture..
Tu se fino vidi.. HBAO i sjene cine svoje a teksture ce bit jos bolje.
Zadnje izmijenjeno od: MAGARAC. 28.09.2011. u 14:35.
MAGARAC je online   Reply With Quote
Staro 28.09.2011., 14:10   #1494
The Fury
The Fury's Avatar
Lokacija: Velika Gorica
Postovi: 178
Na diabolicu sam žicao key, nadam se da ću ga i dobiti još danas
Može mi netko poslati info za TS? Izgubio sam info -.-
Unaprijed hvala.
The Fury je offline   Reply With Quote
Staro 28.09.2011., 14:12   #1495
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor The Fury Pregled postova
Imaš PM.
Staro 28.09.2011., 14:19   #1496
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Kad bi se uopce mogla ocekivat beta. Mislio sam da je sutra ali vidim da se keyevi zicaju posvuda pa me malo sad to zainteresiralo..I u koliko sati bi to mogli bit?
Staro 28.09.2011., 14:24   #1497
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,715
Autor Mansky Hunt Pregled postova
Imaš PM.
neo, smrade.
Staro 28.09.2011., 14:26   #1498
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,308
Šta sam ti ja sad skrivio?
Staro 28.09.2011., 14:28   #1499
KixzoR
noob?
KixzoR's Avatar
Datum registracije: Jan 2011
Lokacija: Zaprešić
Postovi: 135
to ni oni neznaju vidiš da su kreteni žešči taj EA umjesto da se primpreme podijele svima keyeve koji dan prije i bok a ne ovak zajebavat ekipu koja je platitla preorder da nemrem igrat dok neki koliko sam vidio na forumima nemaju veze s battlefield ili moh-om su dobili!Očito EA nezna kome šalje!Nesposobni su žešće!
KixzoR je offline   Reply With Quote
Staro 28.09.2011., 14:34   #1500
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
zer0four4lpha@gmail.com: thank you Andrew, can you please tell me how are we suppose to get inside Battlefield 3 BETA on september 29th? Do we need a key or something?
zer0four4lpha@gmail.com: are you still here, mr. Andrew?
Andrew M.: Yes I am still here, there should not be a code, let me see if we have that info for you.
Iako im ne vjerujem, level2 na support live-u tvrdi da ne bi trebalo biti key-eva za open betu koja počinje sutra.
Znači, trebalo bi skinuti i pokrenuti, još chatam pa ću apdejtat.
