Staro 01.03.2005., 13:21   #1
skate to hell
skate to hell's Avatar
Lokacija: Varazdin
Postovi: 288
bios Flash
Kako na msi k8n neo2 flashat bios.I koji je najbolji bios
Skinuls sam novi bios i awfl833d flash i dok ocu flashat stalno mi javlja da nemre najit fajl.
Msi neo2/wini 3200+/OCZ TCCD/6600gt
skate to hell je offline   Reply With Quote
Staro 01.03.2005., 21:00   #2
skate to hell
Lokacija: Varazdin
Postovi: 288
Bilo ko. Molim vas dajte mi poblize objasnite flash biosa.
Staro 01.03.2005., 21:03   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Bilo je takvih tema podosta. I par detaljnih tutoriala. Potraži.
Staro 01.03.2005., 22:42   #4
komer
motocross
komer's Avatar
Lokacija: Kutina
Postovi: 2,438
neda mi se prevadat po 100-ti put vec
evo copy paste
. Go get your Win98 boot disk that you have stashed away somewhere. If you never had a Win98 boot disk, you can get it here:
Win98 Boot Disk
2. Download AWDflash.exe and the BIOS you want:
Click here and then click on the blue "flash" link near the top to download AWDflash.exe
(I know it's an Abit website but the AWDflash program is the same)
3. Copy the AWDflash.exe program and the new BIOS file onto one floppy disk or make 2 seperate disks (One Win98 boot disk and one disk containing AWDflash.exe and the BIOS).
4. Set current BIOS to boot from floppy and use the Win98 boot disk to boot into DOS.
5. At the A:\ prompt type awdflash biosname.bin (Your BIOS file might have a different extension, so change it accordingly........also, if you did the 2 disk method you have to insert your other disk before typing this) and hit enter.
6. After BIOS updating is complete, your system will restart. After it restarts power it down immediately and do the post bios updating procedure outlined below (can never be too cautious lol).
POST BIOS UPDATING PROCEDURE
1. Unplug the power cord to the computer to completely power down
2. clear CMOS jumper for 30 seconds
3. Power computer back up, and immediately go into the BIOS
4. Choose "Load Failsafe Defaults" or "Load Optimized"
5. Save and exit
Immediately after reboot, go back into the BIOS and configure to your liking
komer je offline   Reply With Quote
Staro 07.03.2005., 01:04   #5
Konan
Konan's Avatar
Datum registracije: Jun 2004
Lokacija: Xindi weapon
Postovi: 441
Konan je offline   Reply With Quote
Staro 08.03.2005., 00:57   #6
Brada13
MemBeer
Brada13's Avatar
Lokacija: V.G.
Postovi: 70
bios Flash
Jeste covjeku zakomplicirali zivot. Pazi tu.
1. Podrazumijeva se da imas bios i awdflash(programcic koji sluzi za flashanje)
2. Pod winXP formatiraj disketu(desni klik misem na 3,5 Floppy A,zatim format i u kartici koja ti se otvori stavi kvacicu kod Create an MS-DOS startup disk)
3. Nakon toga kopiraj novi BIOS i awdflash na tu disketu
4. Restartaj PC i pod uvjetom da ti je ''first boot device removable ili floppy''(ako nije udji u BIOS i postelaj to) racunalo ce ti se podici sa diskete
5. Upisi awdflash.exe
6. U njemu ces upisati kad te upita ime novog BIOSA i to je to
7. Jos samo jedan restart(izvadis disketu prije)
Brada
Asus A8N-SLI De Luxe
64 x2 4400+
2X1Gb ST CL2
Gainward 7800GT/512Mb
Hitachi T7K250 SATA2 250 Gb
Hitachi SATA 2 320 Gb/16 Mb
Brada13 je offline   Reply With Quote
Staro 08.03.2005., 01:12   #7
komer
motocross
komer's Avatar
Lokacija: Kutina
Postovi: 2,438
a kaj sam ja napiso?tj pejsto?
Staro 22.03.2005., 01:30   #8
ertuzio
ertuzio's Avatar
Postovi: 149
ASUS -Ez Flash- rulezzzz!!!
Tko ima ASUS ploču zna o čem pričam!
Laptop Fujitsu Siemens Mobile P4533 3.06 Ghz, 1 Gb DDR 400, 60 Gb HDD, ATI M 9700 128 Mb, DVD/RW Dual layer, Firewire, IrDA, LAN, Wireless, Modem, Widescreen 1280x800, 3xUSB...
ertuzio je offline   Reply With Quote
