Staro 16.07.2011., 21:48   #61
vranjba
vranjba's Avatar
Datum registracije: Aug 2009
Postovi: 613
preporučite mi neki ups, da je kvalitetniji malo, da u sebi ima prenaponsku zaštitu i da šalje server u shoutdown kad se potroši baterija, treba za firmu
nešto iuzmeđu 500kn i 1000kn, može 2 komada jedan skuplji i jeftiniji
iz linksa mora biti
CPU: AMD Phenom II X2 545 @X4 B45 + AC Freezer 64 Pro PWM
MBO: Asrock a780GXH @ bios 1.70
RAM: Kingmax 2x2GB PC2-8500
VGA: Sapphire HD5570 1GB
Zvučna: Asus xonar d1
HDD: WD6401AALS + WD2000JB + WD3200AAJS
PSU: Corsair cx400W
Case: Gigabyte GZ-X6
Keyboard: Logitech mk520 + Microsoft Natural Wireless Mouse 6000
Daljnski: Mce ir
Zvučnici: Swans d1080mkii 08
Monitori: Philips 220SW + HP L1950g
TV: Panasonic TX-P50C3E
AIO: HP Deskjet F4280
OS: Windows 7 x64
HP Compaq nx7010
CPU: Pentium centrino 2.0 GHz
RAM: 1gb + 512mb PC2700
VGA: ATI Mobility Radeon 9200 32mb
HDD: wd 40 GB
OS: Win XP SP3 x32
CPU: Pentium 3 1.0 GHz + Glacialtech igloo 2520
MBO: Intel D815EFV
RAM: 2x 256mb PC133
HDD: Maxtor 80gb + Seagate Barracuda 7200.7 160gb
PSU: Codegen 400W
OS: Win XP SP3 x32
PCI Lan: Linksys cisco gigabit EG1032 v3
Routher: Thomson ST780i WL
Net: T-com Flat
Acernote lite 350pc
CPU: Pentium 100 MHz
RAM: 8 mb edo onboard
VGA: chips&tech f65545
HDD: ibm 540 mb
OS: win 95
CPU: pentium 166 MHz
MBO: ga 586vx rev 3.37
RAM: 4x16 mb edo ram
VGA: Ati 3D rage II +dvd 4 mb
HDD: quantum fireball se2.1a 2.1 gb
PSU: seasonic ssa-200g
Monitor: Acer 13"
OS: dos 6.22
vranjba je offline   Reply With Quote
Staro 18.07.2011., 07:26   #62
vranjba
vranjba's Avatar
Postovi: 613
nitko
ako nema u linksu, može i zagreb neki web shop
PSU: Corsair cx400W
Daljnski: Mce ir
OS: Windows 7 x64
HP Compaq nx7010
HDD: wd 40 GB
OS: Win XP SP3 x32
MBO: Intel D815EFV
RAM: 2x 256mb PC133
PSU: Codegen 400W
OS: Win XP SP3 x32
Net: T-com Flat
Acernote lite 350pc
HDD: ibm 540 mb
OS: win 95
Monitor: Acer 13"
OS: dos 6.22
Staro 18.07.2011., 08:23   #63
Alister
Alister's Avatar
Postovi: 1,484
Koliko je jak server, koliko dugo bi trebao raditi? Nije isto kupiti UPS od 200W ili od 400W.
Inače mislim da danas svaki UPS ima opciju gašenja računala kada je baterija pri kraju, odnosno kada mu u software-u podesiš.
Inače koliko vidim u Linksu uzmi si UPS APC Back ES, 700 VA
Staro 18.07.2011., 12:39   #64
vranjba
vranjba's Avatar
Postovi: 613
nisam znao i backup serija ima mogučnost automatskog gašenja, mislio sam da samo smart serija apc-a ima tu mogučnost
ima e7500 proc, 4600 ati grafu i 3 diska, 4 ventilatora, u idlu je stalno pa kontam da ne pređe nikad preko 200w
PSU: Corsair cx400W
Daljnski: Mce ir
OS: Windows 7 x64
HP Compaq nx7010
HDD: wd 40 GB
OS: Win XP SP3 x32
MBO: Intel D815EFV
RAM: 2x 256mb PC133
PSU: Codegen 400W
OS: Win XP SP3 x32
Net: T-com Flat
Acernote lite 350pc
HDD: ibm 540 mb
OS: win 95
Monitor: Acer 13"
OS: dos 6.22
Staro 18.07.2011., 12:52   #65
Alister
Alister's Avatar
Postovi: 1,484
Koliko sam vidio na software-u ima runtime opcija za gašenje kompa, doduše back cs serija, no mislim da je to ista stvar.
Staro 08.08.2011., 18:58   #66
sisak30
Datum registracije: Jul 2011
Lokacija: sisak
Postovi: 1
Molim za savjet: Kablovi za prednaponsku zastitu
Imam problema sa strujom, tocnije u cijeloj ulici svakodnevno 2-3 puta u neodredeno vrijeme dolazi do pada napona i racunalo kao i drugi uredaji koji su ukljuceni u struju dobivaju kratki strujni udar i gase .- pale se u tom trenutku, strah me je da mi nesto ne ode i zelio bih barem malo nade pa me zanima
1.moze li mi pomoci koji od ovih kablova ili bas moram ups kupit
2.ako i nemogu pomoci ipak me zanima koji je bolji
U ducanima sam pronasao APC,BELKIN te BANDRIDGE kablove za strujnom zastitom, Belkin je cuo sam najbolji ali imaju samo sa 4 utora bez mogucnosti za uklucivanje telefona u njega, kosta 105kn, APC ima 5+1 utor i kosta 130kn dok je Bandridge 6 + 2 i kosta 120kn, Belkin nudi dozivotnu garanciju sa ''kao'' 19,000 dok Bandridge nudi barem kako pise na kutiji 1god garancije na cak 37,000ampera
Sto da uzme, sto je kvalitetno ovdje.
Hvala unaprijed
sisak30 je offline   Reply With Quote
Staro 08.08.2011., 22:05   #67
Doom
Émile Flournoy
Doom's Avatar
Lokacija: Chicharija
Postovi: 1,528
Produžni kabeli sa prednaposnkom zaštitom djelomično štite spojene uređaje samo u slučaju neposrednog udara groma. U odnosu na standardni produžni kabel imaju plinske odvodnike prenapona i varistor.
Tebi treba autotransformator koji korigira mrežni napon kada on padne ispod neke granice (180-200V) http://www.elmatis.hr/Products.aspx?categoryId=97 ili neki ups.
Ups je isplativiji ako potrošnja spojenih uređaja ne prelazi 200-300W , za veće potrošače je isplativije uzeti neki od ovih stabilizatora.
Staro 08.08.2011., 22:55   #68
kokolo22
kokolo22's Avatar
Lokacija: LIČKI OSIK
Postovi: 115
Evo decki imam jednu malu zamolbu,trebao bi mi Ups koji ima ispravljač voltaže tj struje i prednaponsku zastitu na njega ce bit ukopčano:
Komp:
Amd athlon 2x4 640@ 3.0
Asrock 890 gx extreme3
6 gb ddr3 rama 1333 mhz
Ssd Mushkin Callisto deluxe 2 120 gb
Gtx 460 nvidia 768 mb
Corsair tx650 w
Panasonic 42x10y plasma
Stb max tv
Router
I telefon
kokolo22 je offline   Reply With Quote
Staro 09.08.2011., 00:53   #69
srale7
srale7's Avatar
Postovi: 5,768
Autor Nebbo Pregled postova
malo sam istrazivao po netu, i naisao na podjelu UPS-ova u 3 kategorije: "offline", "Line Interactive" i "Online".
offline - nazivaju ih jos i backup ups. Ne radi nista po pitanju variranja napona. Tek kad potpuno nestane struje, oni se pale i to sa odredjenim zakasnjenjem (35-45 milisekundi). Primjer: APC "BackUp" serija.
Line interactive - brzi odaziv u trenutku nestanka struje (cca 5 milisekundi) i imaju "automatic voltage regulation (AVR)" i "surge suppression" (ma sto god to znacilo). Isto tako, u slucaju pada ili rasta napona, prebacuju se na bateriju (ne cekaju potpuni nestanak struje). Primjer: APC "Smart UPS" serija
Online - nije za smrtnike, jer su papreno skupi. Radije riskirati da rikne cijeli komp i kupit novi, i tako jos nekoliko puta Uglavnom, da skratim pricu, takvi UPS-ovi za input imaju gradsku mrezu, a output cistu struju, bez varijacija. Naravno, nema vremena odaziva, jer UPS radi kao da je cijelo vrijeme na bateriji.
Zaključak iz ovog bi bio da vecina ovih jeftinije UPS-a su offline, znači ne rade nista po pitanju variranja napona, vec kad on padne ispod neke razine, onda prelazi na baterije kao izvor.
Koji bi bio najjeftini Ups sa AVR-om?
Staro 16.08.2011., 13:16   #70
lit
Lokacija: hr
Postovi: 976
Meni isto treba jedan UPS, nešto oko 1500 kuna... oko 800W(ako ima više još bolje)... da ne bude neki low-end već neka ajmo reć srednja klasa...
Ako ima koji test online javite, nisam uspio ništa takvo naći...
Nemam pojma koji su kvalitetni zato sve preporuke dobrodošle, hvala
lit je offline   Reply With Quote
Staro 21.08.2011., 23:54   #71
v3rbatim
v3rbatim's Avatar
Postovi: 46
Nedavno mi je zbog grmljavine krepao router, monitor, mrežna kartica i još neke sitnice.
Zanima me da li bi ovaj uređaj bio u stanju spriječiti takve scene > http://www.diskont24.com/product.php...cat=399&page=1
Na koju to foru uopće radi i kolika je trajnost toga?
Svejedno mi treba tako neka letva s utičnicama pa još ako i može nešto zaštiti, bilo bi dobro.
Para za neki kvalitetan UPS o kojima pričate - nemam, tako da me zanimaju samo prenaponske zaštite do max. 200 kn.
v3rbatim je offline   Reply With Quote
Staro 22.08.2011., 00:32   #72
Postovi: 23,501
To šta si linkao (produžni sa prenaponskom zaštitom) spada u prvi i osnovni korak zaštite uređaja. U ovoj i sličnoj temi smo skoro sve rekli.
Ovakva zaštita za koju pitaš je svakako bolja nego ništa.
Staro 22.08.2011., 00:36   #73
Den@
Datum registracije: Feb 2011
Postovi: 262
najbolji lijek je da ištekaš iz utičnice...i mislim i jedini
ps.to ti neće ništa riješiti po pitanju grmljavine
Den@ je offline   Reply With Quote
Staro 22.08.2011., 08:40   #74
v3rbatim
v3rbatim's Avatar
Postovi: 46
Ok, vidim da ste dosta skepticni u vezi tih prenaponskih uredjaja pa me zanima koja je onda njihova konkretna namjena i sto takvi uredjaji mogu sprijeciti?
Mislim, zasto se uopce proizvode ako su beskorisni?
Ili jednostavno moraju radit u paru s jos nekih zastitnim sistemima da bi bili ucinkoviti?
P.S. Kako cu znati da me je takav uredjaj zastitio ukoliko dodje do necega?
Da li on crkne ili na neki nacin pokaze da je doslo do prenapona?
Hvala
Staro 22.08.2011., 09:06   #75
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Autor v3rbatim Pregled postova
A da malo proguglaš ono kaj si linkao?
Ima sklopku koja izbaci kad je preveliki napon...
Za 230 kuna možeš dobiti najači model koji ima i splitter i zaštitu za antenski kabel.
I 5 godina garancije.
Staro 22.08.2011., 17:21   #76
v3rbatim
v3rbatim's Avatar
Postovi: 46
Ma evo ipak sam naručio belkinovu zaštitu > Link.
194,00 kn.
Belkin zaštita-8 utičnica,1xtelefon,4m kabel (F9M820de4M-GRY)
Jedinstvene prenaponske zaštite koje štite vaše uređaje od prenapona i udara groma. Zaštita dolazi s doživotnim jamstvom te jamstvom na priključene uređaje.
U slučaju oštećenja priključenih uređaja (TV, telefon, muzička linija, računalo itd...) zbog prenapona ili udara groma, Belkin nadoknađuje troškove popravka ili zamjene novim uređajem.
Osigurane svote se kreću of 40.000€ do 275.000€ ovisno o modelu zaštite.
Jamstvo: Doživotno jamstvo
Marka proizvoda: BELKIN
Opis/specifikacija:
Serija koja Vam omogućava optimalno prijenosno osiguranje visokog napona.
Prednosti:
- osiguranje visokog napona struje izlazne mreže
- doživotna garancija
- uzemljenje mreže s 3 promjenjive zaštite od preopterećenja struje izlazne mreže
Obilježja:
- maksimalno strujno opterećenje od 25.000A
- EMI/RFI odvodni filter
- svjetlosni pokazivači koji pokazuju da li su Vaši aparati ispravno uzemljeni i osigurani
A valjda nešto i valja kad daju doživotno jamstvo i nadokađuju troškove popravka.
Sigurno da tu ima sitnih slova i caka ali mi se ne da zamarat s time i proučavat, šta bude bude.
Staro 22.08.2011., 21:19   #77
Jelc
Super Moderators
Postovi: 17,485
Mislim da ta jamstva vrijede za EU...
Staro 30.08.2011., 10:13   #78
Jackson
Postovi: 648
Prednaponska zaštita
Pozdrav, razmišljam o kupnji prednaponske zaštite pa me zanimaju preporuke.
Primarna zadaća je da štiti komp i hi-fi od nestanaka struje, a sekundarna da malo pročisti napon za hi-fi (garant je kvalitetnija od produžnog za 12kn kojeg trenutno koristim).
Mislio sam uzeti ovo http://www.links.hr/index.php?naziv=...kl=150.900.012
Postoji li ovaj produžni negdje jeftinije, te da li postoji neka druga marka/jeftinija koja bi bolje obavljala posao?
Jackson je offline   Reply With Quote
Staro 30.08.2011., 10:20   #79
nino
nino's Avatar
Postovi: 12,600
Autor Jackson Pregled postova
Onda ti treba UPS, a ne "letva".
Staro 30.08.2011., 10:56   #80
syss
syss's Avatar
Postovi: 10,805
obrati pozornost na sam naziv letve - PREnaponska, znači štiti od strujnih peakova, udara groma i sl.
koliko uspješno je sad drugi par rukava, a sami filtracijski dio takvih letvi su obično neki osnovni pasivni lc članovi koji nemre napraviti čuda.
Staro 30.08.2011., 13:20   #81
Jackson
Postovi: 648
Ok, možda sam se krivo izrazio - treba mi prenaponska letva da mi zaštiti uredjaje od strujnog udara kad se struja vrati nakon nestanka.
Za filtraciju znam da ne može biti nešto posebno, više se nadam da će kvalitetnije ožičenje poboljšati stvari.
Ima li kvalitetnih alternativa ovo bandridgeu?
Staro 30.08.2011., 13:42   #82
syss
syss's Avatar
Postovi: 10,805
samo ups će te zaštititi od toga, nemreš jeftino proć nikak.
pogledaj raspravu stranicu prije
Staro 02.09.2011., 14:23   #83
viking.software
viking.software's Avatar
Lokacija: rijeka / krk
Postovi: 550
molim savjet....
dakle, kupim polovni ups, ovaj.
baterija drži kojih destak minuta kompjuter i 22" lcd.
sve bi to bilo ok, ali, ups radi samo kad je na bateriji?! kada se priključi na struju, izlazi se gase i više ništa ne radi. probam sa običnom lampom, dok je isključen iz zida, lampica najnormalnije radi "battery", radi priključeni potrošač, ali kad ga ukopčam u struju, sve se gasi. naravno, struje ima! ;-)
do sada sam imao nekoliko ups-ova, ni jedan se nije tako ponašao, trenutno koristim "mustek 600", on najnormalnije radi, kad padne napon ili nestane struje, pišti, drži neko vrijeme, gasim kompjuter ako je potrebno i ok. ali ovaj apc radi SAMO kad nema struje?! ono, WTF?!?
pa ako netko ima ideju da li sam bacio lovu ili je nekakva banalna stvar.
hvala!
viking.software je offline   Reply With Quote
Staro 02.09.2011., 15:12   #84
Postovi: 23,501
Ako ga nisi zaboravio priključit na napajanje onda je neispravan, dobro provjeri i vidi sa prodavačem . . .
Staro 02.09.2011., 20:59   #85
viking.software
Postovi: 550
heh, sve je na napajanju! ;-) to ti je tako. nađeš oglas, povoljno, računam, 'ajde, promjenim bateriju još sam u plusu. no, nekako mi se ne čini da će biti tako.
da je baterija, ne vjerujem da bi se tako ponašao. a i ne bi izdržao skoro deset minuta.
inače, misliš da mi se prodavač javlja? jasno mu je da mi je frknuo bofl ili, da ne "griješm dušu", se nešto skrhalo u transportu.
odnio sam ga majstoru, neka pogleda, pa ako proradi ok, ako ne, hebi ga, sve ostaje na prodavaču.
izgorio relej (i driveri) za prebacivanje 220<->baterija. cifra 250-280. pravac smeće.
pa sad treba vjerovati kada na oglasu napišu 100% ispravno...
Zadnje izmijenjeno od: viking.software. 10.09.2011. u 13:25.
Staro 23.10.2011., 20:45   #86
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
Bump teme, molio bih preporuku za UPS, trebao bi drzat konfu iz "moj komp" Dovoljno mi je 5-6 min cisto da mogu spremit podatke i sigurno ugasit pc. Rasploažem sa 700 kn
Hvala
Zadnje izmijenjeno od: QuidZz. 24.10.2011. u 17:40.
Staro 24.10.2011., 17:40   #87
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,533
any1?
Staro 24.10.2011., 19:53   #88
c-shadow
c-shadow's Avatar
Postovi: 3,464
Ne znam koliko trosi ta tvoja konfa, ali ja nedugo uzeo ovo:
http://www.optimum-online.hr/detalji...ve-schuko.aspx
Za moju konfu skupa s monitorom i routerom:
Code:
The UPS information shows as following:
	Properties:
		Model Name................... DX800E
		Firmware Number.............. BFN9102-351.B
		Rating Voltage............... 230 V
		Rating Power................. 480 Watt
	Current UPS status:
		State........................ Normal
		Power Supply by.............. Utility Power
		Utility Voltage.............. 233 V
		Output Voltage............... 234 V
		Battery Capacity............. 100 %
		Remaining Runtime............ 16 min.
		Load......................... 158 Watt(33 %)
		Test Result.................. Unknown
		Last Power Event............. Blackout at 2011/09/18 20:27:00
Full load (otkljucani L3 cache na procu), prime:
Code:
	Properties:
	Current UPS status:
		Utility Voltage.............. 232 V
		Output Voltage............... 232 V
		Remaining Runtime............ 8 min.
		Load......................... 244 Watt(51 %)
Za windowse UPS ima neki šareni softver, za linux je neki daemon, u konzoli možeš dobiti gore navedene informacije (samo s root ovlastima), ima 2 skripte koje se okinu jedna odmah po nestanku struje, a druga kad je baterija pri kraju i u koje možeš utrpati što ti treba (default je shutdown). Mislim da ga kuze i gnome i xfce power manager.
Već 4 mjeseca sve ok. Preživio je ljetne vrućine i česte nestanke struje.
Staro 13.11.2011., 17:16   #89
bez_panike
dijete u vremenu
bez_panike's Avatar
Lokacija: OS
Postovi: 295
ljudi, trebao bih preporuku ups-a ali ne za računalo već za pumpu centralnog grijanja (možda je OT al jbg)....uglavnom, najbitniji faktor je da što duže baterija drži a ostale fore tipa koliko će brzo odreagirati i sve što je bitno za računalo ovdje mi ne igra baš nikakvu ulogu, ni količina utičnica itd....ta pumpa je snage 62W, upravo sam izmjerio.....budžet je do 500kn, pucajte....hvala
besposlen pop i jariće krsti
bez_panike je offline   Reply With Quote
Staro 13.11.2011., 19:52   #90
Postovi: 23,501
Obzirom na teret (elektromotor) treba obratit pažnju na neke druge karakteristike pa evo na šta:
- "izmjerio" si 62W ali bi bilo bolje / teh. korektno da pročitaš i napišeš šta piše na motoru (VA / W)
- pogodio si da nije toliko bitna brzina transfera ali je zato važno / potrebno da bude full Sine Wave ili dobar Simulated Sine Wave (valni oblik izlaznog AC napona).
Radi se o tome da bi motor mogao otežano radit, pregrijavat se, čak i "crknit" (ovisi kako je napravljen), ako je izlazni napon jako deformiran tj. puno odstupa od idealne sinusoide.
Ako tražiš rješenje za dugotrajan rad (više od 1 - 2 sata) onda zaboravi cijelu ideju jer rješenja zahtjevaju puno veći buđet od tih 500 Kn.
Možda kad bi besplatno dobio kakav dobar full Sine Wave 1.000 - 2.000 W ups sa baterijama kojima je istekao rok pa da radiš home made modifikaciju da koristiš auto - kamion baterije sa drugim punjačem jer ugrađeni u ups nije dovoljnog kapaciteta.
Jedno od rješenja je dodatna ili zanjena postojeće sa DC pumpom, tada ne treba AC inverter i postići ćeš veću autonomiju a ovisno o kapacitetu baterije. Jasno, tada treba odgovarajući punjać a dodatnu automatiku (par releja i/ili sklopnika) za aktiviranje dodatne pumpe kada nema AC napajanja nije komplicirano složit.
