#152 |
Datum registracije: Feb 2011
Postovi: 190
1 x Gigabyte 990XA-UD3, AM3+, AMD 990X SB950, 4x DDR3 1 x Procesor AMD Phenom II X4 955 Black Editon, socket AM3, BOX,C3 1 x SCYTHE Katana 3 SCKTN-3000I White Box, 775/1155/1156/1366 1 x DDR3 8GB (2x4GB) Corsair, 1600Hz, 9-9-9-24,CMZ8GX3M2A1600C9,1.5V 1 x Napajanje SEASONIC 620W, SS-620GB, S12 II, aktivni PFC 1 x OCZ SSD Vertex2 120GB , MB 2.5" SATA II, Native TRIM support,MLC 1 x CoolerMaster HAF 932, AMD Edition,Full tower bez napajanja,crven 1 x Sapphire HD 6950, 2GB GDDR5 256bit, Dual Link DVI + HDMI 7.507,97Kn s time da pokušaj sačekati bulije pa odmah uzmi (rekao si da ćeš za 3 tjedna kupit, pa strpi se malo ![]() Zadnje izmijenjeno od: McG. 10.09.2011. u 21:32. |
#153 |
Datum registracije: Apr 2011
Postovi: 1,428
Offtopic, ali kao odgovor izvjesnim nevjernicima i prilika za vjerojatno solidan shopping: IPS ispod 1.400 kn (dobro, skoro 1.400) - jedino što maših dijagonalu pa je 23` http://www.magazinrs.hr/product.asp?...r&code=LG-0335 |
#154 |
Datum registracije: Feb 2010
Postovi: 971
Za te pare na stavit ssd je grijeh ![]() 1 x Coolermaster 690 II LITE, RC-692-KWN3, Mid Tower,side window 1 x DVD upisivač LG GH24NS, DVD±RW, 24x DVD±R ,8x DL , 40x CD-R 1 x Napajanje XFX Core Edition 80+ 550W PSU - EasyRail technology 1 x HDD SAMSUNG SpinPoint F3 1Tb 7200rpm 32MB cache Serial ATA II 1 x MSI GTX 560 HAWK TwinFrozr III 1024MB GDDR5 256 bits+ Lara kupon 2 x DDR3 4GB (1x4GB) Kingmax, 1600MHz, FLGF 1 x Asrock P67 EXTREME4 B3 - Intel P67, ATX, 4xDDR3 2133MHz 1 x Procesor Intel Core i5-2500K 3.3GHz,1MB/6MB,95W,Socket 1155 1 x ZALMAN CNPS10X Performa, 132(L) x 100(W) x 152(H)mm, 748g 6.797,99Kn + http://www.telebit.hr/SSD-OCZ-120GB-.../48898532.aspx ili http://www.protis.hr/products/detail...mz5pa128/44836 i zdravo ![]() |
#157 |
Datum registracije: Mar 2009
Postovi: 44
pozdrav zanima me konfiguracija do cca. 10 000 kn nemojte stedit na procesoru ![]() hvala za igrice uglavnom, igram dosta onih rpg, jedu procesor po mogucnosti da vecinu komponenti kupim na istom mjestu ak mozes preporuci mi i neki monitor do 2-3k (bar 22") Zadnje izmijenjeno od: McG. 10.09.2011. u 21:32. |
#158 |
► Play ▌▌ Pause ■ Stop
Datum registracije: Jan 2010
Postovi: 1,178
Zadnje izmijenjeno od: DiRT. 10.09.2011. u 20:01. Razlog: editirao |
#159 |
Lokacija: Zd
Postovi: 4,748
@Jermanzg Konfa sa Ssd-om: Mbo: Asrock Fatal1ty P67 - 920kn Cpu: Intel Core i5-2500K - 1550kn Cooler: Corsair H60, Water Cooling™ - 530kn Ram: Kingston 8GB (2x4GB) 1600MHz - 440kn Vga: MSI GTX 560 HAWK TwinFrozr III - 1780kn Psu: SEASONIC 520W, SS-520GM - 600kn Ssd: Samsung 470 Series BOX 64Gb - 697kn Hdd: SAMSUNG SpinPoint F3 1Tb - 410kn Dvd: LG GH24NS, DVD±RW - 150kn Case: Coolermaster 690 II LITE - 649kn Monitor: DELL U2311H 23" - 1630kn ------------------------------------------------ ~9360 kn Sve komponente su iz Adm-a osim Ssd-a koji je iz Protisa. Ako je problem, uzmi si Corsair Force SSD 80GB iz Adm-a Konfa bez Ssd-a s jacom grafom: Mbo: Asrock Fatal1ty P67 - 920kn Cpu: Intel Core i5-2500K - 1550kn Cooler: Corsair H60, Water Cooling™ - 530kn Ram: Kingston 8GB (2x4GB) 1600MHz - 440kn Vga: MSI GTX 570 TwinFrozr III OC - 2620kn Psu: SEASONIC 520W, SS-520GM - 600kn Hdd: SAMSUNG SpinPoint F3 1Tb - 410kn Dvd: LG GH24NS, DVD±RW - 150kn Case: Coolermaster 690 II LITE - 649kn Monitor: DELL U2311H 23" - 1630kn ------------------------------------------------ ~9500 kn Edit: prestize me kolega, ispast ce da sam prepisiva ![]() Zadnje izmijenjeno od: Sn4k3. 10.09.2011. u 19:59. |
#160 |
Postovi: 1,428
Asrock P67 PRO3-B3 - Intel P67 Procesor Intel Core i5-2500K 3.3GHz SCYTHE Mugen3, SCMG-3000 2 x DDR3 4GB (1x4GB) Kingmax, 1600MHz MSI GTX 560 HAWK TwinFrozr III 1024MB GDDR5 256 bits HDD SAMSUNG SpinPoint F3 1Tb 7200rpm 32MB cache Serial ATA II Napajanje XFX Core Edition 80+ 550W PSU - EasyRail technology DVD upisivač LG GH24NS, DVD±RW CoolerMaster Storm Sniper Black Edition Mesh version LG W2363D-PF 23" 3D gaming ,black,wide screen 16:9,Full HD LCD, DVI-D,HDMI,3ms 9.509,40 - www.adm.hr |
#161 |
Glas za Sn4k3-ovu "konfu bez SSD-a", samo bi vodeno zamjenio s npr. Scythe Yasya. Igre nećeš "snimat" na tako male SSD-ove, a bolja grafulja će dobro doći. ![]() |
#162 |
Postovi: 44
hvala svima na odgovorima ssd mi nije neki must have, jos su mali ![]() kolika je ustvari razlika izmedju vodenog i standarnog hladjenja u performansama (buka od fana mi ne smeta toliko) |
#163 |
Onaj Corsair H60 je na tragu najboljim zračnim hladnjacima, a takva mu je i cijena. Zadnje izmijenjeno od: McG. 13.09.2011. u 14:47. |
#164 |
Datum registracije: Sep 2011
Lokacija: Zagorje
Postovi: 52
Može prijedlog koju bi trebao matičnu ploču i napajanje te hlađenje u računalo za : Procesor INTEL Core i7 2600K BOX, s. 1155, 3.40GHz, 9MB cache, GPU, Quad Core Grafička kartica PCI-E XFX AMD RADEON HD 6970, 2GB DDR5, HDMI, DualDVI, miniDP, HDTV Memorija PC-14900, 16 GB, G.SKILL Ripjaws X series, F3-14900CL9Q-16GBXL, DDR3 1866 MHz, kit 4x4GB ![]() |
#165 |
Nuclear Experiment
Datum registracije: Aug 2009
Postovi: 647
Ovisi koliko imaš za potrošiti Napajanje : Corsair 750W TX Corsair 650W TX Hladnjak: Thermalright Venemous X Prolimatech Armageddon... Matična: ASROCK P67 PROFESSIONAL...
For everything you gain, You lose something else. |
#166 |
Postovi: 1,450
Ma novci mu nisu problem ![]() |
#167 |
Lokacija: Zd
Postovi: 4,748
Imho, zar nije bolje u konfu tog ranga staviti neko modularno napajanje poput SEASONIC 620W, SS-620GM ili XFX 650W 80+ Bronze Certified Semi-Modular. Vise vati od ovih 620-650 ti ne triba.. Hladjenje, ako ides na zracno Venomous X (kolega je da dobre preporuke) + jedan/dva kvalitetna venta, a moze proci i vodeno Corsair H60 koji je u rangu high-end zracnih coolera.. Maticna, takodjer dobra preporuka kolege Stridera, ASrock P67 Fatal1ty Professional ili P67 Extreme4 B3, ovisno sto mislis raditi s konfom i sto ocekujes od komponenti.. Malo detaljnije pisati, da bi savjeti bili bolji.. |
#168 |
Postovi: 1
Pomoc
Danas sam zamolio da mi sloze u ducanu konfiguraciju koja je što tiša ali da mi moze obavljati sve sto mi treba za posao plus da tu i tamo mogu igrati neke kvalitetne igrice. Evo samo me zanima vase misljenje dali je ovo ok ili sta bi vi mjenjali? 1. Procesor INTEL Core i5 2500K BOX, s. 1155, 3.30GHz, 7MB cache, GPU, QuadCore 2. Matična ploča ASUS P8Z68-V PRO, iZ68, DDR3, zvuk, S-ATA, RAID, G-LAN, BT, HDMI, DVI, D-SUB, PCI-E, CrossfireX, SLI, FW, eSATA, USB 3.0, ATX, s. 1155 3. Grafička kartica PCI-E SAPPHIRE AMD RADEON HD 6870 VAPOR-X, 1GB DDR5, HDMI, DualDVI, Dual DP 4. Memorija PC-12800, 8 GB, G.SKILL Ripjaws X series, F3-12800CL9D-8GBXL, DDR3 1600MHz, kit 2x4GB 5. Napajanje 600W, COOLERMASTER Silent Pro M600 RS-600-AMBA-D3, ATX V2.3, 135mm vent, PFC, modularno 6. Tvrdi disk 1000.0 GB WESTERN DIGITAL Caviar Green, SATA, 64MB cache, 7200 okr/min, za desktop 7. SSD 120.0 GB CORSAIR Force 3 series CSSD-F120GB3-BK, SATA3, 2.5", MLC-Chip, maks. do 550/510 MB/s 8. Cooler COOLERMASTER V8, socket 775/1156/1155/1366/AM3/AM2/AM2+ 9. DVD±RW ASUS DRW-24B3ST/BLK/B/AS, 24x, SATA, Dual Layer, crna, bulk 10. Kućište COOLERMASTER SILEO 500 RC-500, MIDI, crno, bez PS sveukupna cijena: ca. 8800kn Sta mislite jel ovo ok ili bi mogao dobiti za te novce puno bolje?? Hvala |
#169 |
Lokacija: Zd
Postovi: 4,748
Mislim da se moze bolje/jeftinije, ovisno o tome sto ti triba: Mbo: Asrock Z68 Extreme3 Gen3 - 1065kn Cpu: Intel Core i5-2500K - 1600kn Cooler: Corsair Cooling Hydro H80 - 765kn Ram: 8GB (2x4GB) Kingmax, 1600MHz - 430kn Vga: Gigabyte GTX 560 Ti 1Gb - 1685kn Psu: SEASONIC 520W, SS-520GM - 600kn Ssd: Corsair SSD 80GB Force Series - 1040kn Hdd: SAMSUNG 2TB, F4EG EcoGreen - 635kn Dvd: LG GH24NS, DVD±RW - 150kn Case: Cooler Master, Sileo 500 - 540kn ---------------------------------------------- ~8500 kn Pitanje je dali ti uopce triba SSD.. Ubaceno je vodeno, s tim da jedan SCYTHE Mugen3 moze obavljati posa bez problema, tad cijena pada za ~400kn.. Grafa je dosta tiha, HDD i napajanje takodjer. |
#170 |
Datum registracije: Oct 2011
Lokacija: istra
Postovi: 25
pozz svima dugo vremena izbivao od hardvera i kofiguracija pa malo zahrđo =) planiram uzet novu konfiguraciju, treba mi svee iznos: ~9000kn za monitor vidim da svi preporučaju dell 23" , mislim da ću taj i uzeti, sve preko 23 mi ne odgovara a ovaj je izgleda trenutno best buy za ostatak rado primam savjete & stuff šta mislite o ovoj gotovoj konfiguraciji? http://www.adm.hr/product_info.php?c...ducts_id=10150 manje više takve komponente se vrte u preporukama , pa ono..dal štima ? ako bi nešto mjenjali i zašto? i7 je skuplji od i5 2500k al podrška kod multithreadinga je više nego dobra, a kako je konfa zamišljena da ipak traje par godina & nadogradnju ta investicija u i7 mi se ne čini ni toliko loša ssd disk nebi još uzimao jer su preskupi, a 60gb mi premalo za sistemsku particiju ... ako uspijem nabavit izvana jeftinije ako ne počekat će malo dok ne skupim za neki barem 100gb+ pa ubacim s vremenom u ovoj navedenoj konfi nema hladnjaka za cpu? zaboravili valda ![]() i da, planiram iz adm-a naručit sve, pa kakva su iskustva? thx |
#172 |
Lokacija: istra
Postovi: 25
jeli... onda, ono šta bi mogao napravit je: uzet odmah ssd od 80gb i maknut hdd i7 bi pustio, rezao bi još i na kučištu, netreba mi svjetleći lunapark od 800kn hdd bi uzeo naknadno, drugi mjesec kad plaća stignea edit: skidam i i7 ![]() Zadnje izmijenjeno od: johnson. 04.10.2011. u 20:22. Razlog: xrx |
#173 |
Postovi: 5,991
Mislim da ti je od gotovih iz AMDa ova bolja ako dodas jos 4gb i 2600k ak bas hoces. U onoj kofi bezveze dajes vise love za kuciste i maticnu, mislim i napajanje. Ovaj ve te jeftinije izac a dobit ces isto.. Nije velika razlika izmedu 2500k i 2600k i oba proca su podjednako future proof.. |
#175 |
Lokacija: istra
Postovi: 25
thx jackass bit će ipak custom s ssd @dirt tamann, jedino uzmem ssd od 80gb tih par sto kn će se naći valda thx |
#176 |
Lokacija: Zd
Postovi: 4,748
Mbo: Asrock Fatal1ty P67 - 940kn Cpu: Intel Core i5-2500K - 1600kn Cooler: SCYTHE Mugen3 - 350kn Ram: Kingmax 2x4GB 1600MHz - 430kn Vga: Gigabyte GTX 560 Ti 1Gb - 1685kn Psu: SEASONIC 520W, SS-520GM - 600kn Ssd: Intel SSD 80GB 320 Series - 1130kn Hdd: SAMSUNG SpinPoint F3 1Tb - 430kn Dvd: LG GH24NS, DVD±RW - 150kn Case: CoolerMaster Elite 430 - 350kn Monitor: DELL U2312HM IPS - 1589kn ------------------------------------------ ~9250 kn |
#177 |
Postovi: 5,991
Ta Fatality ploca je bezveze. P67 pro3 u sarenoj boji i skoro 200kn skupljoj cijeni. Moze i na napajanju ustedit i uzet xfx 550w i za svu tu razliku ubost postenije kuciste. Ne znam da Mugen 3 radi probleme sa blokiranjem memorije ali moga bi. Za te novce se nade Zalman perf. koji je puno elegantniji i jednako efikasan. Zadnje izmijenjeno od: MAGARAC. 04.10.2011. u 23:26. |
#178 |
Lokacija: Zd
Postovi: 4,748
Znam da je Fatal1ty cisto "obojana" Pro3 - to stoji, modularno napajanje je tu s razlogom - ipak se radi o puno kablova u ne bas prostranom kucistu (razlika u odnosu na xfx je ~100kn).. Da se mene pita ja bi uzea barem 690II Lite. Sto se tice Mugena, da, moglo bi biti problema sa ramom - Performa je otprilike jednako efikasan no nesto bucniji (out of the box).. |
#179 |
Lokacija: istra
Postovi: 25
![]() ok , imaju valda kakav popust na gotovinu? lool kakva je spika da mugen zahebe ekipu? |
#180 |
Postovi: 5
Bok ekipa! Evo ja stvaarno dugo nisam slagao komp a ovaj mi je počeo rikavat i ne služit više pa bi mi trebala neka konfiguracija. Ugl za zahtjevne igrice i za 3d modeliranje, tipa rhino, catia, ACad i slicno. Monitor imam, sve dodatne komponente imam, znaci samo kutija i čudesa u njoj. Zahvalan unaprijed ![]() |
