Zaključane teme
Staro 23.08.2011., 22:45   #691
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,741
Autor srale7 Pregled postova
Realno, Rukavina je trebao zabit 2 gola minimalno i da je to zabio utakmica bi bila davno gotova, ali ovako je bilo napeto :P
Minimalno 3 gola. 3 čista zicera.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline
Staro 23.08.2011., 22:46   #692
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
Autor MAGARAC Pregled postova
Hahaha Balkanska Barcelona. To moze izjavit samo totalni nepoznavatelj hrvatskog nogometa i mentaliteta.
i onda gledas ovih 90 i nesto minuta, i sve nesto oci zinule na ovu balkansku barcelonu .
ja inace ne navijam niti za dinamo niti za hajduk onako, konkretno, ali ovo veceras sto je dinamo pruzio je negdje na razini HNL-a, cak i ispod. sram me bilo gledati ovakav nogomet iskreno, oni doslovce nisu u stanju bili zadrzati dvije minute loptu. dvije minute!
jurcic bi odletio brzinom eustahije brzica sa klupe dinama da je pao jos jedan gol, iz uber junaka u uber tragicara po cro receptu, ali nista od toga. kakti liga prvaka, sve pohvale dinamu i slicna sranja, ali sa ovakvom predstavom nebu nikako isli sa odraslim klubovima.
inace jedini sto su veceras bili na razini su kelava, sammir (iako je pred kraj malo kiksao), i vida. rukavina je presmijesan sto je zapucao, badelj vise-manje se ne zna sastati s loptop, ostatak nesto trcao......... da je dinamo i ispao - ispao bi zasluzeno. tko god kaze drugacije nije nimalo objektivan, ili nije gledao vecerasnju "utakmicu" (zapravo je 90 minuta bilo 10-9, viktorije, igra na jedan gol ).
Burko je offline
Staro 23.08.2011., 22:46   #693
Starsailor
Starsailor's Avatar
Datum registracije: Jan 2011
Lokacija: CRO
Postovi: 219
Ima li ko da nije navijao za Malmo kod 2:0?
Starsailor je offline
Staro 23.08.2011., 22:47   #694
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,835
Autor flyer1 Pregled postova
nego, koga točno u nadolazećoj skupini lp planirate potrgat ko vola u kupusu?
Očekujem da neće gola dati. Ali ako dođe Barca, Chelsea, Man Utd ili tako neki klub, idem gledat.. Zato sam i navijao da prođu danas
Privatno
Razlog: Opci bahatluk i nekultura
10.08.2023. 06:44 autor: Hamm 30 / Expired
John Creasy je offline
Staro 23.08.2011., 22:47   #695
spawn
spawn's Avatar
Postovi: 8,380
Covjece ,jos me i pitaju zasto ne gledam tekme s nasim ekipama. Nisam dugo gledao ,i sad me skoro srce strefilo jbtkcpsmtr. Fijuuuuu portrosio sam rolu salveta psmtr.
Autor Starsailor Pregled postova
Skoro pa sam poceo.
spawn je offline
Staro 23.08.2011., 22:48   #696
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Autor nino Pregled postova
To te ja pitam, bmk sto MAGARAC & Co. truju topic.
Ja ga imam pravo trovat jer igra Dinamo koji je moj klub i kojeg volim bez obzira na sve ove debilane. Ne znam bas da se ti toliko zivciras i umaras gledajuci ovakve tekme posto pise da si iz Umaga. Pretpostvaljam da to ne mozes ni shvatit pa necu dalje.
MAGARAC je offline
Staro 23.08.2011., 22:49   #697
hrvatska1991
Datum registracije: Feb 2010
Postovi: 130
Bitno da je onaj ciganski Villarreal pobjedio,ala su mi prošli tjedan rušili listić
hrvatska1991 je offline
Staro 23.08.2011., 22:50   #698
h4ze
h4ze's Avatar
Datum registracije: Aug 2008
Lokacija: Amsterdam
Postovi: 179
Autor hammer_of_thor Pregled postova
Onda pod hitno traži pare natrag jer tko god te treniro nije ti objasnio pravila
Ili bar proguglaj pojam passive offside jer očito neznaš što je to (iako ovdje nije suigrač došao do lopte ali isto pravilo vrijedi).
Jedini koji ovdje nema pojma si ti... Uhh skoro sam i zaboravio Grahama
Šteta za crveni Vrsaljka, da ga nije dobio ovi nebi dali gola nikad.. A sad u ligu prvaka ))
h4ze je offline
Staro 23.08.2011., 22:51   #699
nino
nino's Avatar
Postovi: 12,602
Reko sam ti da me bk. Navijac sam Dinama duze od tebe. Imas svoje misljenje i iznosis ga. Istotako ja svoje.
U nogometu ima dobrih i losih tekmi. Jbga, treba nekad i srecu i guzicu imat, ali ipak trovat toliko....
nino je offline
Staro 23.08.2011., 22:53   #700
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,741
Krunoslav Jurčić nakon utakmice:
"Dinamo je kontrolirao cijelu utakmicu..."
WTF!?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 23.08.2011., 22:56   #701
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Mamiću pripremi eure!
ShanTech je offline
Staro 23.08.2011., 22:56   #702
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Treba ih trovat i kritizirat jer ces u protvnom desit opet Balkanska Barcelona , napuhavanja i onda surova realnost. Cesta pojava u nasem sportu a narocito u nogometu.
MAGARAC je offline
Staro 23.08.2011., 22:57   #703
tutix
tutix's Avatar
Postovi: 4,068
Kakav drlog ovaj Rukavina. Jebo majku, al dobro je prošlo . Sutra navijat za onaj drlog od Arsenala da prođe, da ga Dinamo izvuče u petak i imamo neke šanse barem za 3. mjesto .
tutix je offline
Staro 23.08.2011., 22:58   #704
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Meni samo nije jasan Badelj?
Mali Kovačić uđe, normalno pretrcava ekipu, nema straha, a Badelj?Koji im je vrag...
Halos je offline
Staro 23.08.2011., 22:58   #705
Starsailor
Starsailor's Avatar
Lokacija: CRO
Postovi: 219
Pa zašto se momke nebi nazvalo Balkanskom Barcelonom, osnuj ti klub na ovim prostorima pa ga uvedi u Ligu Prvaka pa da vidimo što bi rekao da neko pljuje po tebi.
Navijao sam za Malmo kod 2:0 ali je činjenica da dok nisu imali igrača više nisu prdnuli na terenu.
Staro 23.08.2011., 22:59   #706
Flood
Into my head it goes
Flood's Avatar
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 778
BM,kaj znaci ulaz u utakmicu...dobro je proslo...
@hammer_of_thor
h4ze ti pokusava objasniti razliku izmedju ofsajda i pasivnog ofsajda ali ti to jednostavno ne razumijes...na OVOJ slici ti je objasnjena razlika pa pogledaj...
Flood je offline
Staro 23.08.2011., 23:01   #707
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Autor Flood Pregled postova
@hammer_of_thor
Ne potiči ih
Pomelo mi sig -.-
Drvoje je offline
Staro 23.08.2011., 23:04   #708
h4ze
h4ze's Avatar
Lokacija: Amsterdam
Postovi: 179
Kakva realnost?
3 100000% šanse Rukavine kakve Malmo nije imao tokom cijele utakmice?
Crveni karton koji je odlučio ovaj susret, jer ovi bez crvenog nebi dali gol.
Kelava, Vida, Tonel odlični.
Sammir vrlo dobar, a Badelj neprepoznatljiv
Jurčić je sjebao, trebao je Šituma umjesto Rukija staviti, a ne vaditi jedinog koji može zadržati loptu..
@Drvoje nema šta poticati, ja znam da sam u pravu od početka rasprave
Zadnje izmijenjeno od: h4ze. 23.08.2011. u 23:14.
h4ze je offline
Staro 23.08.2011., 23:06   #709
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Brijem da je ono sa Vrsaljkom bilo za žuti ali nikako za crveni.
Jelc je offline
Staro 23.08.2011., 23:08   #710
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,734
Autor h4ze Pregled postova
To sam htio napisati. Njih trojica su odigrali vrhunski.
Sammir vrlo dobar
Ke? Dvije lopte je dao i to je to. Ostalo je brljavio i navlačio igrače na sebe da bi potom loptu vratio prema nazad i napravio apsolutno ništa. Krme je crklo oko 50. minute.
Kladim se da je u onoj boci kaj ju je cuclao bio jeger ili tome slično.
Sve u svemu totalni show. Ošli živci na tekmi...
@jelc..ma vrsaljko je zasluženo dobio crveni ali neka. Da mu je barem nogu strgao jer su se od starta švedi postavili ko zadnji pederi koji nisu zaustavljali tekmu kad je netko od naših ležao.
Hamm je offline
Staro 23.08.2011., 23:10   #711
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,255
Ruki kralj al ko ga jebe dok vozis m3 mozes i promasit 3 zicera biće jos utakmica.i oni bi barcelonu da vide di su?hehe
microsoft66 je offline
Staro 23.08.2011., 23:11   #712
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Pojavila se nova terapija za maničnu depresiju! Name, medicinski je dokazano da normalan i zdrav čovjek nakon odgledane utakmice Dinama u europskim natjecanjima počinje pokazivati simptome manične depresije, koja se manifestira kroz 1-5 minuta nakon posljednjeg sučevog zvižduka.
Stariji sam 2 godine, posijedio, depresivan i lud. Ajmo Dinamo! ( Hala Madrid :P)
burmuz je offline
Staro 23.08.2011., 23:11   #713
h4ze
h4ze's Avatar
Lokacija: Amsterdam
Postovi: 179
Imao je par odličnih driblinga, zadržavao je loptu kad je to bilo potrebno itd.
Ma nebitno je sve, važno da smo u LP
h4ze je offline
Staro 23.08.2011., 23:13   #714
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Kaže Jurčić dinamo je držao utakmicu pod kontrolom.. Juričiću ja ti vjerujem!
dean225 je offline
Staro 23.08.2011., 23:13   #715
Drvoje
Drvoje's Avatar
Postovi: 4,037
@Drvoje nema šta poticati, ja znam da sam u pravo od početka rasprave
Srića da je "čekić od tura" offline jer bi i on reka isto - da je u "pravo"
BTW Jedva čekam "ždrijebanje"
Pomelo mi sig -.-
Drvoje je offline
Staro 23.08.2011., 23:13   #716
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,734
Ma dobri su ti driblinzi ali završavaju ili prema nazad s loptom ili mu istu uzmu. Nek zavalja igrača dva i nek šalje loptu u for.
Ajde sad treba vidjeti kak će se sutra odigrati. Nadam se da će udinese potrgati arsenal.
Hamm je offline
Staro 23.08.2011., 23:14   #717
gnjepar
gnjepar's Avatar
Postovi: 642
Rukavina je imao tri prilike koje su morale biti pretvorene u gol. Meni nije jasno zašto ga Jurčić gura kada je očito do on nije nikakav golgeter ni slično. Nije ga bezveze Vahid držao na klupi. Golove kakve je on davao za Dinamo do sada sam mogao i ja dati. Da je Šituma ubacio ne bi bilo nikakve drame a ovako skoro gadno popušili. LOL
Ni Beqiraj se nije nešto pokazao ove sezone.
The Truth
gnjepar je offline
Staro 23.08.2011., 23:16   #718
Mljac
Mljac's Avatar
Datum registracije: Feb 2003
Lokacija: Zaprešić/Laduč
Postovi: 460
Ja nisam navijal za nikog zadnjih 10 minuta.
Nakon drugog gola sam piknul mp3 u uha i otišel napraviti krug po kvartu.
Mamu im retardiranu.
A crvenog ono nije vidlo, u najgoroj varijanti je to žuti.
Mljac je offline
Staro 23.08.2011., 23:17   #719
tutix
tutix's Avatar
Postovi: 4,068
Op, Joe u Dinamu?
tutix je offline
Staro 23.08.2011., 23:20   #720
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ma koje mučko đubre....klošar i vucibatina
DinamooooOOOoo....idem se sad ubit pivom ko' zvijer
Dizel je offline
Zaključane teme
