Staro 26.05.2011., 15:55   #241
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
MSI R6950 Twin Frozr III Power Edition Unlocking
From MSI:
It is a common misconception that MSI's 6950 Twin Frozr III Power Edition cannot be unlocked because it's not a reference design.
The fact is, despite sporting a fully custom PCB with Military Class II components and the epic Twin Frozr III cooler it WILL unlock to 1536 shaders.
That said, it will only unlock because MSI are so confident about the capabilities of the card that they wrote a custom BIOS themselves.
You must use MSI's custom BIOS and NOT any reference BIOS/bios editor otherwise you are at high risk of killing the card
Sluzbeni unlock od msi-ja... dakle sve se koristi u svrhu marketinga
Staro 31.05.2011., 13:55   #242
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
PowerColor to Challenge ASUS MARS II with Monstrous Dual-HD 6970 Graphics Card
Empire strikes back.
While between the GeForce GTX 580 and Radeon HD 6970, the former is clearly the faster graphics card, the two share a disputed lead over each other in their dual-GPU avatars, GeForce GTX 590 and Radeon HD 6990, attributed to the HD 6990 sustaining clock speeds closer to those on its single-GPU implementation, and a better electrical design. While NVIDIA is fixing the electricals on a revised PCB design scheduled for release in the weeks to come, companies like ASUS are wasting no time in designing their own PCBs that can let the two NVIDIA GF110 GPUs sustain clock speeds identical to those on the single-GPU GTX 580. This would pose serious competition to the HD 6990. To ward that off, PowerColor is working on a new Radeon HD 6970 X2 graphics card, which has two AMD Cayman GPUs clocked on par with single-GPU HD 6970, and having the same overclocking headroom.
The new card from PowerColor is not just an overclocked HD 6990, but also has the overclocking headroom of the HD 6970. Further, unlike the HD 6990, it uses Lucid Hydra technology. The PLX-made, AMD-branded PCI-Express bridge chip is replaced by a LucidLogix-made bridge chip that gives each GPU PCI-Express 2.0 x16 bandwidth. Users can run the two GPUs in either AMD CrossFire (with Hydra features disabled), or enable Lucid Hydra Engine features, and let the two GPUs work in tandem with any other graphics card installed in the system, that uses GPUs of any make and generation.
The card draws power from three 8-pin PCI-E power connectors, power is conditioned by two sets of 6+2 phase VRM. Each GPU has 2 GB of GDDR5 memory across a 256-bit wide memory interface. The GPUs are said to have clock speeds equal to, or higher than those of the HD 6790, that's 880 MHz core, 5.50 GHz memory. The beast is cooled by a humongous triple-slot cooler that uses a 120 mm and a 140 mm fan, to cool dense aluminum fin array heatsinks. Display outputs are the same as HD 6970, that's two DVI, two mini-DP, and a HDMI.
http://www.techpowerup.com/146653/Po...hics-Card.html
http://www.techpowerup.com/146658/Po...hics-Card.html
C L O W N I N G A R O U N D
Zadnje izmijenjeno od: Doink the Clown. 31.05.2011. u 15:45.
Staro 31.05.2011., 16:13   #243
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
powercoloru pod hitno treba nekakav dizajner... ovo su strahote!
Staro 31.05.2011., 20:53   #244
Tomek32
Tomek32's Avatar
Datum registracije: Jan 2011
Postovi: 149
A nije ovo jos za prodaju sigurno.
Tomek32 je offline   Reply With Quote
Staro 31.05.2011., 21:10   #245
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Nadam se, ali i inace sam takvog misljenja, uzas su.
Mozda nisu toliko losi sto se tice kvalitete komponentli, ali brate mili pa daj malo trendove treba pratiti.
Pa sto ce mi kricavo crveni pcb s nekom rugobom u mat crnom kucistu? Pa tko to jos koristi?
Danas dobar izgled hladnjaka i nekakva luda naljepnica imaju vise utjecaja u odluci za kupovinu nego sam gpu...
Zadnje izmijenjeno od: bluefluid. 01.06.2011. u 00:14.
Staro 31.05.2011., 21:45   #246
Tomek32
Tomek32's Avatar
Postovi: 149
A vidi ovaj 14cm genericki vent desno .
Bit ce to dobro,ako bude za prodaju uopce.
Staro 01.06.2011., 10:08   #247
Doink the Clown
Postovi: 6,214
Mislim da je ipak konačna verzija kartice ova u drugom linku:
Staro 01.06.2011., 10:20   #248
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
A šta vas brine.... Dizajn grafičke kartice
Kao da ćeš ju objesiti na zid, a ne strpati u kućište
X
Staro 02.06.2011., 07:11   #249
Tomek32
Tomek32's Avatar
Postovi: 149
HD6870x2.
To bi moglo biti zanimljivo.
Staro 02.06.2011., 08:26   #250
Postovi: 33,930
Postojala je i 4850x2 pa je skoro nitko nije kupovao, za razliku od 4870x2.
Staro 03.06.2011., 01:44   #251
puma29x
puma29x's Avatar
Datum registracije: Jun 2011
Lokacija: istra
Postovi: 33
Smile
procitao sam postove prije i ja imam EAH3870x2 1gb i jos sve sljaka iako vidim da ima potrebe za necim jacim naravno ... isao bi na neku 69xx e sad neznam procesor e 6850 3.0 dali je dovoljan ako neko ima prijedlog za neku kartu i savjet hvala unaprijed
puma29x je offline   Reply With Quote
Staro 03.06.2011., 08:53   #252
Postovi: 33,930
Proc će biti dovoljan, ali teško da ćeš izvući max iz grafe s njim. Za to ti ipak treba više jezgri od 2 koliko sada imaš.
Staro 05.06.2011., 15:12   #253
puma29x
puma29x's Avatar
Lokacija: istra
Postovi: 33
ma i razmisljao sam se za zamjenu ovog proca za neki quad uz nadoplatu ali to kod nas naci nema sanse ... a koliko i vidim tesko i novi quad proc naci za kupiti ..hebena dilema kad se nema love dovoljno
Staro 06.06.2011., 00:05   #254
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
MSI R6950 Twin Frozr III Power Edition OC review
MSI shines with the overall design, the nice but still shy factory overclock, the custom designed PCB has serious quality components harbored on it. The 'Military class' component usage is not a joke, MSI follows the specs and guidelines of military grade hardware, so when you peek at the Ferrite core chokes, Hi-c Capacitors and solid capacitors, you'll know they'll last a long time. It's as simple as that.
The new Twin Frozr revision III cooler is much better than it's predecessor, the Twin Frozer revision II. In idle the card is very silent, under full load .. well you can hear it but that's it really. Meanwhile at its baseline clock frequency we maxed out at 63 Degrees C, which is absolutely a lovely temperature.
Izvor: guru3d
Staro 07.06.2011., 13:05   #255
puma29x
puma29x's Avatar
Lokacija: istra
Postovi: 33
ako neko zna di se ova gore kartica moze kod nas nabaviti ili kad ce biti tnx
Staro 13.06.2011., 21:42   #256
Ivica121
Ivica121's Avatar
Datum registracije: Feb 2010
Lokacija: underground
Postovi: 71
Koju mi verziju ATI 6970 preporučate da kupim za svoj kompjuter?
MSI koja je malo skuplja ili Saphire!
MSI je malo OC verzija.
Spahire http://www.adm.hr/product_info.php?c...oducts_id=9520
MSI http://www.adm.hr/product_info.php?c...ducts_id=10064
Zadnje izmijenjeno od: Ivica121. 13.06.2011. u 21:49.
Ivica121 je offline   Reply With Quote
Staro 14.06.2011., 07:02   #257
Postovi: 33,930
Nijednu. Preskupe su za ono što nude. Radije uzmi neku 68xx.
Staro 14.06.2011., 10:55   #258
Ivica121
Ivica121's Avatar
Postovi: 71
Nude dosta, jesu preskupe ali skupilo bi se para. Dal da uzmem MSI onda ?
Ili pak možda neku GTX 560 ocanu?
Staro 14.06.2011., 10:59   #259
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor Ivica121 Pregled postova
Msi bi trebala imat 3 godine gare, a sapphirka 2, i hlađenje je definitivno way to go za msi. Dakle msi, još samo da nije toliko skuplja....
Staro 15.06.2011., 18:25   #260
newyxX
Mlatimudan
newyxX's Avatar
Lokacija: Zadar(ST)
Postovi: 418
MSI HD 6970 ima PCI Express 2.1 16x .
koja je razlika između PCI Express 2.1 16x i PCI Express 2.0 16x ???
i dali može grafa sa PCI Express 2.1 16x na maticnu koja ima PCI Express 2.0 16x ????????
newyxX je offline   Reply With Quote
Staro 19.06.2011., 16:23   #262
Ivica121
Ivica121's Avatar
Postovi: 71
Gledam sad na XFX stranici i tamo piše da za xfx ATI 6970 2 gb treba 650 W ?
Evo pogledajte http://xfxforce.com/en-gb/products/G...ries/6970.aspx
Dok recimo za Saphireovu istu grafičku piše 550 W.
Jel stvarno treba za tu XFX ATI 6970 napajanje od 650w?
Staro 19.06.2011., 16:49   #263
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,176
A to ti ništa ne znači, nek napišu i 10 kW kad ti konfa ne troši više od 400 W. Pa moja konfa ne troši 300 W, ova tvoja je malo jača u potrošnji, al ne previše...
PC:
CPU: Intel Core i7-7700
COOLER: SCYTHE Mugen 3 rev. B
MBO: MSI B250 GAMING M3
GPU: ASUS Dual Radeon RX 6650 XT OC Edition 8GB GDDR6
RAM: Kingston HyperX Fury (2x8GB) 2133MHz@2400MHz CL16 DDR4
SSD: Samsung 840 Pro (128GB), Samsung 970 EVO Plus (2TB)
HDD: WD1003FZEX (1TB), WD20EZRZ (2TB)
PSU: Corsair 650W RM650, 2019, 80 PLUS Gold
KUĆIŠTE: Antec 300, 2xSCYTHE Slip Stream 120mm (500rpm, 7.5 dB)
OS: Windows 10 Pro 64-bit
Externi HDD/SSD:
Seagate Basic Portable Drive (1TB)
WD My Passport (1TB)
WD My Passport (2TB)
WD Elements (2TB)
Verbatim Vx500 (240GB)
Silicon Power PC60 (240GB)
Kingston XS1000 (1TB)
MONITOR (TV):
Dell G2724D + Dell U2414H
Samsung UE55NU8002TXXH
Samsung QE43Q60AAUXXH
Philips 43PUS8506/12
TIPKOVNICA:
Logitech K800 Illuminated
MIŠ:
Logitech G502 Proteus Spectrum RGB + SteelSeries QcK Edge - Medium
Logitech MX Master 3 Black
Logitech MX Master 2S Bluetooth Edition Graphite
Logitech M590 Silent
ZVUČNICI:
Logitech Z-5500 (S/PDIF) + Logitech Bluetooth Audio Receiver
MAGNAT Monitor Supreme 202 Black 2-way bass reflex bookshelf speakers
MAGNAT Monitor Supreme Center 252 Mocca
SLUŠALICE:
Logitech Zone Vibe 100
Samsung Galaxy Buds3 Pro
Xiaomi Redmi Buds 5 Pro
Xiaomi Buds 3 Star Wars Edition
Mi True Wireless Earbuds Basic 2
Sennheiser CX 3.00
AKG Samsung Galaxy Earbuds
AKG Y500 Wireless
MOB:
Samsung Galaxy S7 Black, 4/32GB +
Samsung microSDXC 64GB EVO+
Samsung Galaxy S10e Black, 6/128GB +
Samsung microSDXC 256GB EVO+
Huawei P50 Pro Golden Black, 8/256GB
Samsung Galaxy A55 5G Awesome Navy, 8/256GB
Samsung Galaxy S24+ Onyx Black, 12/256GB
LAPTOP:
(Lenovo ThinkPad E560)
CPU: Intel Core i3-6100U
MBO: -
GPU: Intel HD Graphics 520
RAM: 2x4GB DDR3L 1600MHz
SSD: Kingston A400 480GB
OSTALO: 15.6-inch HD TN
PC POSAO:
(HP Z2 Tower G9 Workstation)
CPU: Intel Core i7-14700K
MBO: HP 895C
GPU: Nvidia RTX A2000 12GB
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MONITORI: 2 komada HP Z27 27-inch 4K UHD
PERIFERIJA: Logitech K750 Solar, Logitech MX Master 3 Graphite + Logitech MX Master 2S Bluetooth Edition Graphite
(HP Z2 Tower G4 Workstation)
CPU: Intel Core i7-8700K
MBO: HP 8455
GPU: Nvidia Quadro P2200 5GB
RAM: 1x16GB DDR4
SSD: Samsung 512GB
HDD: WD 1TB
LAPTOP POSAO:
(Apple MacBook Air 13.6-inch M2 8/256GB MLXY3CR/A Silver)
(HP EliteBook x360 1040 G11 2-in-1, 14-inch WUXGA Touchscreen, Intel Core Ultra 7 155H, 16GB LPDDR5x, Samsung 1TB PCIe Gen4 NVMe TLC M.2 SSD, Backlit Keyboard, Windows 11 Pro)
(HP ProBook 450 G7, 15.6-inch FHD, Intel Core i5-10210U, 8GB DDR4, Samsung 512GB NVMe M.2 SSD, MX250 Graphics, Backlit Keyboard, Windows 11 Pro)
DiRT je offline   Reply With Quote
Staro 19.06.2011., 17:57   #264
Ivica121
Ivica121's Avatar
Postovi: 71
Hvala!
Zadnje izmijenjeno od: Ivica121. 19.06.2011. u 18:34.
Staro 04.08.2011., 22:21   #265
Doink the Clown
Postovi: 6,214
Sapphire Launches Radeon HD 6950 TOXIC Edition, Fastest HD 6950 Yet
SAPPHIRE Technology – the world leading supplier of graphics solutions, mainboards and other PC products - has just announced the SAPPHIRE HD 6950 TOXIC Edition, the fastest production card in its class.
The SAPPHIRE HD 6950 TOXIC Edition ships with clock speeds of 880MHz for the core and 1300Mhz (5.2 Gb/sec effective) for the memory making it the fastest production HD 6950 on the market. This has been achieved by building the card on a high specification PCB with digital VRMs for excellent power regulation and 8 + 6 pin power connectors. It has a high performance cooler featuring a Vapor Chamber, blower fan and a new perforated backplate to increase airflow out of the system case.
Like the standard HD 6950, the SAPPHIRE HD 6950 TOXIC Edition boasts true DX 11 capability and the powerful configuration of 1408 stream processors and 88 texture processing units. A Dual BIOS feature allows enthusiasts to experiment with alternative BIOS profiles and settings. Performance can be further enhanced with SAPPHIRE TriXX – the company’s dedicated overclocking tool which allows memory and core clock speeds and voltages to be modified and monitored and is available free to download.
With its two DVI, one HDMI and two mini-DisplayPort outputs, the SAPPHIRE HD 6950 TOXIC Edition supports a wide range of monitor configurations, including AMD Eyefinity with up to four screens.
The SAPPHIRE HD 6950 TOXIC Edition has the latest Gen3 on-board hardware UVD (Unified Video decoder), considerably reducing CPU load and delivering smooth decoding of Blu-ray and other video content for both VC-1 and H.264 codecs, as well as Mpeg files. The UVD can decode two 1080p HD video streams simultaneously and display HD video in high quality with Windows Aero mode enabled. The card has HDMI 1.4a which also supports Stereoscopic 3D output.
The SAPPHIRE HD 6950 family is supported by AMD's DirectX 11 WHQL certified graphics driver which delivers support for all of the key DirectX 11 level features required for new gaming experiences and acceleration of the latest generation of browsers, transcoding and other high performance applications (AMD APP acceleration).
Staro 05.08.2011., 01:42   #266
DiRT
DiRT's Avatar
Postovi: 1,176
To je to. Nadam se još jednoj Toxic grijalici ko mojoj 6850 koja je crkla sama od sebe.
PC:
Externi HDD/SSD:
WD Elements (2TB)
MONITOR (TV):
TIPKOVNICA:
MIŠ:
ZVUČNICI:
SLUŠALICE:
Sennheiser CX 3.00
AKG Y500 Wireless
MOB:
LAPTOP:
MBO: -
PC POSAO:
MBO: HP 895C
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MBO: HP 8455
RAM: 1x16GB DDR4
SSD: Samsung 512GB
HDD: WD 1TB
LAPTOP POSAO:
Staro 05.08.2011., 11:31   #267
skyman
skyman's Avatar
Datum registracije: Aug 2008
Postovi: 775
Hm..ja imam HD6850 Toxic..max temp pod punim opterećenjem nije prelazila 73 stupnja..to je još opalo na 56 stupnjeva instalacijom Twin turba PRO...kupio je čim je izašla (bila par kn skuplja od obične) i radi besprijekorno cijelo vrijeme...nemoj generalizirat, nije dobro za zdravlje
skyman je offline   Reply With Quote
Staro 05.08.2011., 11:45   #268
Roby86
Postovi: 73
Pozdrav!
Ima li netko ovu 6950, to je nova verzija Sapphirke sa 1 GB, uz nju se dobiva u budleu Dirt 3, no zanima me čisto ako ima netko da kaže par riječi jel zadovoljan?
U par reviewa su rekli kako ima jako dobro riješeno hlađenje, do čak 10 C razlike u odnosu na konkurenciju.
http://www.links.hr/index.php?naziv=...kl=051.806.731
http://www.sapphiretech.com/presenta...n=&lid=1&leg=0
Hvala!
Roby86 je offline   Reply With Quote
Staro 06.08.2011., 19:19   #269
ProboY
Lokacija: Koprivnica
Postovi: 68
pozdrav ekipo... dali ima ko iskustva s ati hd6990?
ProboY je offline   Reply With Quote
Staro 09.08.2011., 14:08   #270
JVC HX-Z10
Sruk
JVC HX-Z10's Avatar
Datum registracije: Sep 2004
Postovi: 1,163
jel ko igra rift sa ovom karticom? meni su fps kaoticno slabi, ako sve pogasim dobijem 30ak fps u gradu, googlao sam ali nisam nista pametno pronasao, probao sam i sa radeon pro programcicem, ali bez razlike. ostale igre lete, ali rift mi fps zna past ispod 10 ako je malo vise ekipe, dok na otvorenom i bez ekipe oscilira i zna skociti i do 50ak fps. ali svejedno traljavo radi.
Jel ima tko kakav savjet kako bi se to dalo malo ubrzati? ili neke posebne drivere za preporuku?
JVC HX-Z10 je offline   Reply With Quote
