Staro 15.07.2011., 23:40   #1
Krtislav
Krtislav's Avatar
Datum registracije: Jul 2011
Lokacija: Vukovar
Postovi: 6
Unhappy Crashovanje Minecraft-a
Čao, ja sam Marko i prvi put postujem na vaš forum
Ovako, moj prijatelj ima laptop, i igrao je minecraft jedno 12 dana, sve je radilo kako treba, sada nemogu reći tačno šta se desilo, ali odjenom mu je počela igra crash-at nakon minute igranja , takođe pokaže se onaj balončić dole desno da se crashovala grafička kartica i da je uspešno povraćena, evo što piše u action center kada pokazuje detalje problema:
Code:
Description
A problem with your video hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name:	LiveKernelEvent
OS Version:	6.1.7601.2.1.0.768.3
Locale ID:	2057
Files that help describe the problem
WD-20110714-2005.dmp
sysdata.xml
WERInternalMetadata.xml
 View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Extra information about the problem
BCCode:	117
BCP1:	FFFFFA800641F4E0
BCP2:	FFFFF88006C07A1C
BCP3:	0000000000000000
BCP4:	0000000000000000
OS Version:	6_1_7601
Service Pack:	1_0
Product:	768_1
sysdata.xml:
Code:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<SYSTEMINFO>
<SYSTEM>
<OSNAME>Windows 7 Home Premium Home Edition</OSNAME>
<OSVER>6.1.7601 1.0</OSVER>
<OSLANGUAGE>2074</OSLANGUAGE>
<ARCHITECTURE>9</ARCHITECTURE>
<PRODUCTTYPE>3</PRODUCTTYPE>
</SYSTEM>
<MEMORYDIAGNOSTIC></MEMORYDIAGNOSTIC>
<DEVICES>
<DEVICE>
<DESCRIPTION>Standard Enhanced PCI to USB Host Controller</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_4396&SUBSYS_164A103C&REV_00</HARDWAREID>
<SERVICE>usbehci</SERVICE>
<DRIVER>usbehci.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>PCI standard host CPU bridge</DESCRIPTION>
<HARDWAREID>PCI\VEN_1022&DEV_1200&SUBSYS_00000000&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft ACPI-Compliant System</DESCRIPTION>
<HARDWAREID>ACPI_HAL\PNP0C08</HARDWAREID>
<SERVICE>ACPI</SERVICE>
<DRIVER>ACPI.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Generic volume shadow copy</DESCRIPTION>
<HARDWAREID>STORAGE\VolumeSnapshot</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>PCI standard PCI-to-PCI bridge</DESCRIPTION>
<HARDWAREID>PCI\VEN_1022&DEV_9605&SUBSYS_12341022&REV_00</HARDWAREID>
<SERVICE>pci</SERVICE>
<DRIVER>pci.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>IDE Channel</DESCRIPTION>
<HARDWAREID>1002-4391</HARDWAREID>
<SERVICE>atapi</SERVICE>
<DRIVER>atapi.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Disk drive</DESCRIPTION>
<HARDWAREID>
IDE\DiskTOSHIBA_MK7559GSXP______________________GN001C__
</HARDWAREID>
<SERVICE>disk</SERVICE>
<DRIVER>disk.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>ACPI Fixed Feature Button</DESCRIPTION>
<HARDWAREID>ACPI\FixedButton</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>CD-ROM Drive</DESCRIPTION>
<HARDWAREID>DTSOFTBUS&Rev1\DTCDROM&Rev1</HARDWAREID>
<SERVICE>cdrom</SERVICE>
<DRIVER>cdrom.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>CyberLink WebCam Virtual Driver</DESCRIPTION>
<HARDWAREID>clwvd</HARDWAREID>
<SERVICE>clwvd</SERVICE>
<DRIVER>clwvd.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>HP Mobile Data Protection Sensor</DESCRIPTION>
<HARDWAREID>ACPI\HPQ0004</HARDWAREID>
<SERVICE>Accelerometer</SERVICE>
<DRIVER>Accelerometer.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Standard OpenHCD USB Host Controller</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_4397&SUBSYS_164A103C&REV_00</HARDWAREID>
<SERVICE>usbohci</SERVICE>
<DRIVER>usbohci.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_1201&SUBSYS_00000000&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_9606&SUBSYS_12341022&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft System Management BIOS Driver</DESCRIPTION>
<HARDWAREID>ROOT\mssmbios</HARDWAREID>
<SERVICE>mssmbios</SERVICE>
<DRIVER>mssmbios.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>ATI High Definition Audio Device</DESCRIPTION>
<HARDWAREID>
HDAUDIO\FUNC_01&VEN_1002&DEV_791A&SUBSYS_00791A00&REV_1000
</HARDWAREID>
<SERVICE>AtiHdmiService</SERVICE>
<DRIVER>AtiHdmi.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Generic volume</DESCRIPTION>
<HARDWAREID>STORAGE\Volume</HARDWAREID>
<SERVICE>volsnap</SERVICE>
<DRIVER>volsnap.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Programmable interrupt controller</DESCRIPTION>
<HARDWAREID>ACPI\PNP0000</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft 6to4 Adapter</DESCRIPTION>
<HARDWAREID>*6to4mp</HARDWAREID>
<SERVICE>tunnel</SERVICE>
<DRIVER>tunnel.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>WAN Miniport (IKEv2)</DESCRIPTION>
<HARDWAREID>ms_agilevpnminiport</HARDWAREID>
<SERVICE>RasAgileVpn</SERVICE>
<DRIVER>AgileVpn.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Renesas Electronics USB 3.0 Root Hub</DESCRIPTION>
<HARDWAREID>NUSB3\ROOT_HUB30</HARDWAREID>
<SERVICE>nusb3hub</SERVICE>
<DRIVER>nusb3hub.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>UMBus Enumerator</DESCRIPTION>
<HARDWAREID>UMB\UMBUS</HARDWAREID>
<SERVICE>umbus</SERVICE>
<DRIVER>umbus.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft ISATAP Adapter</DESCRIPTION>
<HARDWAREID>*ISATAP</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>System timer</DESCRIPTION>
<HARDWAREID>ACPI\PNP0100</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>WAN Miniport (L2TP)</DESCRIPTION>
<HARDWAREID>ms_l2tpminiport</HARDWAREID>
<SERVICE>Rasl2tp</SERVICE>
<DRIVER>rasl2tp.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>High Definition Audio Controller</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_4383&SUBSYS_164A103C&REV_40</HARDWAREID>
<SERVICE>HDAudBus</SERVICE>
<DRIVER>HDAudBus.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft AC Adapter</DESCRIPTION>
<HARDWAREID>ACPI\ACPI0003</HARDWAREID>
<SERVICE>CmBatt</SERVICE>
<DRIVER>CmBatt.sys</DRIVER>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_1202&SUBSYS_00000000&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_9607&SUBSYS_12341022&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Direct memory access controller</DESCRIPTION>
<HARDWAREID>ACPI\PNP0200</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>USB Root Hub</DESCRIPTION>
<HARDWAREID>USB\ROOT_HUB&VID1002&PID4397&REV0000</HARDWAREID>
<SERVICE>usbhub</SERVICE>
<DRIVER>usbhub.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>IDT High Definition Audio CODEC</DESCRIPTION>
<HARDWAREID>
HDAUDIO\FUNC_01&VEN_111D&DEV_7605&SUBSYS_103C164A&REV_1001
</HARDWAREID>
<SERVICE>STHDA</SERVICE>
<DRIVER>stwrt64.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>WAN Miniport (Network Monitor)</DESCRIPTION>
<HARDWAREID>ms_ndiswanbh</HARDWAREID>
<SERVICE>NdisWan</SERVICE>
<DRIVER>ndiswan.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>AMD Processor</DESCRIPTION>
<HARDWAREID>ACPI\AuthenticAMD_-_AMD64_Family_16_Model_5</HARDWAREID>
<SERVICE>AmdPPM</SERVICE>
<DRIVER>amdppm.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft Teredo Tunneling Adapter</DESCRIPTION>
<HARDWAREID>*TEREDO</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Standard PS/2 Keyboard</DESCRIPTION>
<HARDWAREID>ACPI\PNP0303</HARDWAREID>
<SERVICE>i8042prt</SERVICE>
<DRIVER>i8042prt.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>USB Composite Device</DESCRIPTION>
<HARDWAREID>USB\VID_064E&PID_E258&REV_0400</HARDWAREID>
<SERVICE>usbccgp</SERVICE>
<DRIVER>usbccgp.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>WAN Miniport (IP)</DESCRIPTION>
<HARDWAREID>ms_ndiswanip</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>ACPI x64-based PC</DESCRIPTION>
<HARDWAREID>acpiapic</HARDWAREID>
<SERVICE>\Driver\ACPI_HAL</SERVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>
ATI I/O Communications Processor PCI Bus Controller
</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>AMD PCI Express (3GIO) Filter Driver</DESCRIPTION>
<HARDWAREID>ACPI\PNP0A08</HARDWAREID>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_1203&SUBSYS_00000000&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_960B&SUBSYS_12341022&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>WAN Miniport (IPv6)</DESCRIPTION>
<HARDWAREID>ms_ndiswanipv6</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>File as Volume Driver</DESCRIPTION>
<HARDWAREID>ROOT\BLBDRIVE</HARDWAREID>
<SERVICE>blbdrive</SERVICE>
<DRIVER>blbdrive.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>System CMOS/real time clock</DESCRIPTION>
<HARDWAREID>ACPI\PNP0B00</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>USB Video Device</DESCRIPTION>
<HARDWAREID>USB\VID_064E&PID_E258&REV_0400&MI_00</HARDWAREID>
<SERVICE>usbvideo</SERVICE>
<DRIVER>usbvideo.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<HARDWAREID>USB\ROOT_HUB20&VID1002&PID4396&REV0000</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Composite Bus Enumerator</DESCRIPTION>
<HARDWAREID>ROOT\CompositeBus</HARDWAREID>
<SERVICE>CompositeBus</SERVICE>
<DRIVER>CompositeBus.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>HID-compliant mouse</DESCRIPTION>
<HARDWAREID>HID\VID_046D&PID_C05F&REV_5300</HARDWAREID>
<SERVICE>mouhid</SERVICE>
<DRIVER>mouhid.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>WAN Miniport (PPPOE)</DESCRIPTION>
<HARDWAREID>ms_pppoeminiport</HARDWAREID>
<SERVICE>RasPppoe</SERVICE>
<DRIVER>raspppoe.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>System board</DESCRIPTION>
<HARDWAREID>ACPI\PNP0C01</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>ATI I/O Communications Processor SMBus Controller</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_4385&SUBSYS_164A103C&REV_42</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft Composite Battery</DESCRIPTION>
<HARDWAREID>COMPOSITE_BATTERY</HARDWAREID>
<SERVICE>Compbatt</SERVICE>
<DRIVER>compbatt.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>PCI standard ISA bridge</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_439D&SUBSYS_164A103C&REV_40</HARDWAREID>
<SERVICE>msisadrv</SERVICE>
<DRIVER>msisadrv.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_1204&SUBSYS_00000000&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Renesas Electronics USB 3.0 Host Controller</DESCRIPTION>
<HARDWAREID>PCI\VEN_1033&DEV_0194&SUBSYS_164A103C&REV_04</HARDWAREID>
<SERVICE>nusb3xhc</SERVICE>
<DRIVER>nusb3xhc.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>WAN Miniport (PPTP)</DESCRIPTION>
<HARDWAREID>ms_pptpminiport</HARDWAREID>
<SERVICE>PptpMiniport</SERVICE>
<DRIVER>raspptp.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Motherboard resources</DESCRIPTION>
<HARDWAREID>ACPI\PNP0C02</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>WAN Miniport (SSTP)</DESCRIPTION>
<HARDWAREID>ms_sstpminiport</HARDWAREID>
<SERVICE>RasSstp</SERVICE>
<DRIVER>rassstp.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Broadcom 2070 Bluetooth</DESCRIPTION>
<HARDWAREID>USB\VID_0A5C&PID_21B4&REV_0481</HARDWAREID>
<SERVICE>BTHUSB</SERVICE>
<DRIVER>BTHUSB.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Standard AHCI 1.0 Serial ATA Controller</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_4391&SUBSYS_164A103C&REV_00</HARDWAREID>
<SERVICE>msahci</SERVICE>
<DRIVER>msahci.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Hamachi Network Interface</DESCRIPTION>
<HARDWAREID>hamachi</HARDWAREID>
<SERVICE>hamachi</SERVICE>
<DRIVER>hamachi.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>AMD Radeon HD 6400M Series</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_6760&SUBSYS_164A103C&REV_00</HARDWAREID>
<SERVICE>amdkmdap</SERVICE>
<DRIVER>atikmpag.sys</DRIVER>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_9601&SUBSYS_12341022&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Numeric data processor</DESCRIPTION>
<HARDWAREID>ACPI\PNP0C04</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Realtek PCIE CardReader</DESCRIPTION>
<HARDWAREID>PCI\VEN_10EC&DEV_5209&SUBSYS_164A103C&REV_01</HARDWAREID>
<SERVICE>RSPCIESTOR</SERVICE>
<DRIVER>RtsPStor.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Terminal Server Keyboard Driver</DESCRIPTION>
<HARDWAREID>ROOT\RDP_KBD</HARDWAREID>
<SERVICE>TermDD</SERVICE>
<DRIVER>termdd.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft ACPI-Compliant Embedded Controller</DESCRIPTION>
<HARDWAREID>ACPI\PNP0C09</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Validity Sensors (WBF) (PID=0018)</DESCRIPTION>
<HARDWAREID>USB\VID_138A&PID_0018&REV_0078</HARDWAREID>
<SERVICE>WUDFRd</SERVICE>
<DRIVER>WUDFRd.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Terminal Server Mouse Driver</DESCRIPTION>
<HARDWAREID>ROOT\RDP_MOU</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>USB Input Device</DESCRIPTION>
<HARDWAREID>USB\VID_046D&PID_C05F&REV_5300</HARDWAREID>
<SERVICE>HidUsb</SERVICE>
<DRIVER>hidusb.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft ACPI-Compliant Control Method Battery</DESCRIPTION>
<HARDWAREID>ACPI\PNP0C0A</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Plug and Play Software Device Enumerator</DESCRIPTION>
<HARDWAREID>root\swenum</HARDWAREID>
<SERVICE>swenum</SERVICE>
<DRIVER>swenum.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1002&DEV_970F&SUBSYS_164A103C&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_9602&SUBSYS_12351022&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>ACPI Power Button</DESCRIPTION>
<HARDWAREID>ACPI\PNP0C0C</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Realtek PCIe GBE Family Controller</DESCRIPTION>
<HARDWAREID>PCI\VEN_10EC&DEV_8168&SUBSYS_164A103C&REV_06</HARDWAREID>
<SERVICE>RTL8167</SERVICE>
<DRIVER>Rt64win7.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Consumer IR Devices</DESCRIPTION>
<HARDWAREID>root\circlass</HARDWAREID>
<SERVICE>circlass</SERVICE>
<DRIVER>circlass.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>DAEMON Tools Virtual Bus Driver</DESCRIPTION>
<HARDWAREID>root\DTSoftBus01</HARDWAREID>
<SERVICE>dtsoftbus01</SERVICE>
<DRIVER>dtsoftbus01.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Generic PnP Monitor</DESCRIPTION>
<HARDWAREID>MONITOR\SEC4251</HARDWAREID>
<SERVICE>monitor</SERVICE>
<DRIVER>monitor.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>ACPI Lid</DESCRIPTION>
<HARDWAREID>ACPI\PNP0C0D</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>AMD IO Driver</DESCRIPTION>
<HARDWAREID>*AMDIO</HARDWAREID>
<SERVICE>amdiox64</SERVICE>
<DRIVER>amdiox64.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft Windows Management Interface for ACPI</DESCRIPTION>
<HARDWAREID>ACPI\PNP0C14</HARDWAREID>
<SERVICE>WmiAcpi</SERVICE>
<DRIVER>wmiacpi.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<HARDWAREID>
IDE\CdRomhp_DVD_A__DS8A5LH_______________________1H68____
</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>ATI Mobility Radeon HD 4200 Series</DESCRIPTION>
<HARDWAREID>PCI\VEN_1002&DEV_9712&SUBSYS_164A103C&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<HARDWAREID>PCI\VEN_1022&DEV_9604&SUBSYS_12341022&REV_00</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>UMBus Root Bus Enumerator</DESCRIPTION>
<HARDWAREID>root\umbus</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Broadcom 4313 802.11b/g/n</DESCRIPTION>
<HARDWAREID>PCI\VEN_14E4&DEV_4727&SUBSYS_1483103C&REV_01</HARDWAREID>
<SERVICE>BCM43XX</SERVICE>
<DRIVER>bcmwl664.sys</DRIVER>
</DEVICE>
<DEVICE>
<DESCRIPTION>Synaptics PS/2 Port TouchPad</DESCRIPTION>
<HARDWAREID>ACPI\SYN1E46</HARDWAREID>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>Microsoft Virtual Drive Enumerator Driver</DESCRIPTION>
<HARDWAREID>ROOT\vdrvroot</HARDWAREID>
<SERVICE>vdrvroot</SERVICE>
<DRIVER>vdrvroot.sys</DRIVER>
</DEVICE>
<DEVICE>
</DEVICE>
<DEVICE>
<DESCRIPTION>ACPI Thermal Zone</DESCRIPTION>
<HARDWAREID>ACPI\ThermalZone</HARDWAREID>
</DEVICE>
<DEVICE>
<DESCRIPTION>Volume Manager</DESCRIPTION>
<HARDWAREID>ROOT\VOLMGR</HARDWAREID>
<SERVICE>volmgr</SERVICE>
<DRIVER>volmgr.sys</DRIVER>
</DEVICE>
</DEVICES>
<DRIVERS>
<DRIVER>
<FILENAME>
103C_HP_cNB_Pavilion dv6 Notebook PC_Y5335KV_0U_Q5CH110013S_E636148-031_4A_I164A_SHP_V06.18_BF.03_T110120_W73-0_L409_M5883_J750_7AMD_8F53_91.80_#110307_N_(LF047EA#ABU)_XMOBILE_CN10_Z_20595100000244710000020100.MRK
</FILENAME>
<FILESIZE>0</FILESIZE>
<CREATIONDATE>03-07-2011 22:00:41</CREATIONDATE>
<VERSION>0.0.0.0</VERSION>
<MANUFACTURER/>
<PRODUCTNAME/>
</DRIVER>
<DRIVER>
<FILENAME>1394ohci.sys</FILENAME>
<FILESIZE>229888</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:31</CREATIONDATE>
<VERSION>6.1.7601.17514</VERSION>
<MANUFACTURER>Microsoft Corporation</MANUFACTURER>
<PRODUCTNAME>Microsoft® Windows® Operating System</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>Accelerometer.sys</FILENAME>
<FILESIZE>43320</FILESIZE>
<CREATIONDATE>08-13-2010 00:24:30</CREATIONDATE>
<VERSION>4.1.1.1</VERSION>
<MANUFACTURER>Hewlett-Packard Company</MANUFACTURER>
<PRODUCTNAME>Mobile Data Protection System</PRODUCTNAME>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>ACPI.sys</FILENAME>
<FILESIZE>334208</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:06</CREATIONDATE>
<GROUP>Boot Bus Extender</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>acpipmi.sys</FILENAME>
<FILESIZE>12800</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:14</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>adp94xx.sys</FILENAME>
<FILESIZE>491088</FILESIZE>
<CREATIONDATE>06-10-2009 20:36:24</CREATIONDATE>
<VERSION>1.6.6.4</VERSION>
<MANUFACTURER>Adaptec, Inc.</MANUFACTURER>
<PRODUCTNAME>Adaptec Windows 7 SAS/SATA Family Storport Driver</PRODUCTNAME>
<GROUP>SCSI Miniport</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>adpahci.sys</FILENAME>
<FILESIZE>339536</FILESIZE>
<CREATIONDATE>07-13-2009 21:59:32</CREATIONDATE>
<VERSION>1.6.6.1</VERSION>
<PRODUCTNAME>
Adaptec Windows Server 2003 SATA Family Storport Driver
</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>adpu320.sys</FILENAME>
<FILESIZE>182864</FILESIZE>
<CREATIONDATE>07-13-2009 21:59:33</CREATIONDATE>
<VERSION>7.2.0.0</VERSION>
<PRODUCTNAME>Adaptec Windows Ultra320 Family Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>afd.sys</FILENAME>
<FILESIZE>499200</FILESIZE>
<CREATIONDATE>06-16-2011 15:27:19</CREATIONDATE>
<VERSION>6.1.7601.17603</VERSION>
<GROUP>PNP_TDI</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>agp440.sys</FILENAME>
<FILESIZE>61008</FILESIZE>
<CREATIONDATE>07-13-2009 23:38:44</CREATIONDATE>
<VERSION>6.1.7600.16385</VERSION>
<GROUP>PnP Filter</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>aliide.sys</FILENAME>
<FILESIZE>15440</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:47</CREATIONDATE>
<VERSION>1.2.0.0</VERSION>
<MANUFACTURER>Acer Laboratories Inc.</MANUFACTURER>
<PRODUCTNAME>ALi mini IDE Driver</PRODUCTNAME>
<GROUP>System Bus Extender</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>amdide.sys</FILENAME>
<CREATIONDATE>07-13-2009 23:19:49</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>amdiox64.sys</FILENAME>
<FILESIZE>46136</FILESIZE>
<CREATIONDATE>03-07-2011 22:02:14</CREATIONDATE>
<VERSION>1.0.0.15</VERSION>
<MANUFACTURER>Advanced Micro Devices</MANUFACTURER>
<PRODUCTNAME>AMD IO Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>amdk8.sys</FILENAME>
<FILESIZE>64512</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:26</CREATIONDATE>
<GROUP>Extended Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>atikmdag.sys</FILENAME>
<FILESIZE>9359872</FILESIZE>
<CREATIONDATE>05-25-2011 04:26:56</CREATIONDATE>
<VERSION>8.1.1.1162</VERSION>
<MANUFACTURER>ATI Technologies Inc.</MANUFACTURER>
<PRODUCTNAME>ATI Radeon Family</PRODUCTNAME>
<GROUP>Video</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>atikmpag.sys</FILENAME>
<FILESIZE>309760</FILESIZE>
<CREATIONDATE>05-25-2011 02:25:42</CREATIONDATE>
<VERSION>8.14.1.6214</VERSION>
<MANUFACTURER>Advanced Micro Devices, Inc.</MANUFACTURER>
<PRODUCTNAME>AMD driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>amdppm.sys</FILENAME>
<FILESIZE>60928</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>amdsata.sys</FILENAME>
<FILESIZE>107904</FILESIZE>
<CREATIONDATE>07-13-2011 11:43:08</CREATIONDATE>
<VERSION>1.1.2.5</VERSION>
<PRODUCTNAME>AHCI 1.2 Device Driver</PRODUCTNAME>
<GROUP>SCSI miniport</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>amdsbs.sys</FILENAME>
<FILESIZE>194128</FILESIZE>
<CREATIONDATE>06-10-2009 20:37:35</CREATIONDATE>
<VERSION>3.6.1540.127</VERSION>
<MANUFACTURER>AMD Technologies Inc.</MANUFACTURER>
<PRODUCTNAME>AMD Technology AHCI Compatible Controller</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>amdxata.sys</FILENAME>
<FILESIZE>27008</FILESIZE>
<PRODUCTNAME>Storage Filter Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>appid.sys</FILENAME>
<FILESIZE>61440</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:12</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>arc.sys</FILENAME>
<FILESIZE>87632</FILESIZE>
<VERSION>5.2.0.10384</VERSION>
<PRODUCTNAME>Adaptec RAID Controller</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>arcsas.sys</FILENAME>
<FILESIZE>97856</FILESIZE>
<VERSION>5.2.0.16119</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>asyncmac.sys</FILENAME>
<FILESIZE>23040</FILESIZE>
<CREATIONDATE>07-14-2009 00:10:13</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>atapi.sys</FILENAME>
<FILESIZE>24128</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>AtiHdmi.sys</FILENAME>
<FILESIZE>125456</FILESIZE>
<CREATIONDATE>05-06-2010 12:21:46</CREATIONDATE>
<VERSION>7.11.0.7706</VERSION>
<MANUFACTURER>ATI Technologies, Inc.</MANUFACTURER>
<PRODUCTNAME>ATI HDMI Audio Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>AtiPcie64.sys</FILENAME>
<FILESIZE>16440</FILESIZE>
<CREATIONDATE>06-17-2010 13:15:36</CREATIONDATE>
<VERSION>1.3.3.70</VERSION>
<MANUFACTURER>Advanced Micro Devices Inc.</MANUFACTURER>
<PRODUCTNAME>AMD PCIE Filter Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>bxvbda.sys</FILENAME>
<FILESIZE>468480</FILESIZE>
<CREATIONDATE>06-10-2009 20:34:28</CREATIONDATE>
<VERSION>4.8.2.0</VERSION>
<MANUFACTURER>Broadcom Corporation</MANUFACTURER>
<PRODUCTNAME>Broadcom NetXtreme II GigE</PRODUCTNAME>
<GROUP>base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>b57nd60a.sys</FILENAME>
<FILESIZE>270848</FILESIZE>
<CREATIONDATE>06-10-2009 20:34:23</CREATIONDATE>
<VERSION>10.100.4.0</VERSION>
<PRODUCTNAME>Broadcom NetXtreme Gigabit Ethernet Driver</PRODUCTNAME>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>bcmwl664.sys</FILENAME>
<FILESIZE>3065408</FILESIZE>
<CREATIONDATE>03-07-2011 22:08:39</CREATIONDATE>
<VERSION>5.60.350.23</VERSION>
<PRODUCTNAME>Broadcom 802.11 Network Adapter wireless driver</PRODUCTNAME>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>Beep.sys</FILENAME>
<FILESIZE>6656</FILESIZE>
<CREATIONDATE>07-14-2009 00:00:13</CREATIONDATE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>BHDrvx64.sys</FILENAME>
<FILESIZE>1143416</FILESIZE>
<CREATIONDATE>07-05-2011 23:36:09</CREATIONDATE>
<MANUFACTURER/>
<PRODUCTNAME/>
<ALTITUDE>365100</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>blbdrive.sys</FILENAME>
<FILESIZE>45056</FILESIZE>
<CREATIONDATE>07-13-2009 23:35:59</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>bowser.sys</FILENAME>
<FILESIZE>90624</FILESIZE>
<CREATIONDATE>05-22-2011 08:35:08</CREATIONDATE>
<VERSION>6.1.7601.17565</VERSION>
<GROUP>Network</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>BrFiltLo.sys</FILENAME>
<FILESIZE>18432</FILESIZE>
<CREATIONDATE>07-14-2009 01:19:59</CREATIONDATE>
<VERSION>1.10.0.2</VERSION>
<MANUFACTURER>Brother Industries, Ltd.</MANUFACTURER>
<PRODUCTNAME>RemovableDisk</PRODUCTNAME>
<GROUP>extended base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>BrFiltUp.sys</FILENAME>
<FILESIZE>8704</FILESIZE>
<CREATIONDATE>07-14-2009 01:20:21</CREATIONDATE>
<VERSION>1.4.0.1</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>Brserid.sys</FILENAME>
<FILESIZE>286720</FILESIZE>
<CREATIONDATE>07-14-2009 01:19:06</CREATIONDATE>
<VERSION>1.0.1.6</VERSION>
<MANUFACTURER>Brother Industries Ltd.</MANUFACTURER>
</DRIVER>
<DRIVER>
<FILENAME>BrSerWdm.sys</FILENAME>
<FILESIZE>47104</FILESIZE>
<CREATIONDATE>07-14-2009 01:20:11</CREATIONDATE>
<VERSION>1.0.0.20</VERSION>
<PRODUCTNAME>Brother MFL Pro</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>BrUsbMdm.sys</FILENAME>
<FILESIZE>14976</FILESIZE>
<CREATIONDATE>07-14-2009 01:20:26</CREATIONDATE>
<VERSION>1.0.0.12</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>BrUsbSer.sys</FILENAME>
<FILESIZE>14720</FILESIZE>
<CREATIONDATE>07-14-2009 01:20:15</CREATIONDATE>
<VERSION>1.0.1.3</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>BthEnum.sys</FILENAME>
<FILESIZE>41984</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:53</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>bthmodem.sys</FILENAME>
<FILESIZE>72192</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:52</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>bthpan.sys</FILENAME>
<FILESIZE>118784</FILESIZE>
<CREATIONDATE>07-14-2009 00:07:00</CREATIONDATE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>BTHport.sys</FILENAME>
<FILESIZE>552960</FILESIZE>
<CREATIONDATE>07-13-2011 11:43:21</CREATIONDATE>
<VERSION>6.1.7601.17607</VERSION>
<GROUP>PNP Filter</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>BTHUSB.sys</FILENAME>
<FILESIZE>80384</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>btwampfl.sys</FILENAME>
<FILESIZE>344616</FILESIZE>
<CREATIONDATE>03-07-2011 22:11:20</CREATIONDATE>
<VERSION>6.3.0.6060</VERSION>
<MANUFACTURER>Broadcom Corporation.</MANUFACTURER>
<PRODUCTNAME>Bluetooth Software</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>btwaudio.sys</FILENAME>
<FILESIZE>102952</FILESIZE>
<VERSION>6.3.0.6150</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>btwavdt.sys</FILENAME>
<FILESIZE>135720</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>btwl2cap.sys</FILENAME>
<FILESIZE>39464</FILESIZE>
<VERSION>6.3.0.3850</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>btwrchid.sys</FILENAME>
<FILESIZE>21544</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>cdfs.sys</FILENAME>
<FILESIZE>92160</FILESIZE>
<GROUP>Boot File System</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>cdrom.sys</FILENAME>
<FILESIZE>147456</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:10</CREATIONDATE>
<GROUP>SCSI CDROM Class</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>circlass.sys</FILENAME>
<FILESIZE>45568</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:34</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>CLFS.sys</FILENAME>
<FILESIZE>367696</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:59</CREATIONDATE>
<GROUP>Filter</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>clwvd.sys</FILENAME>
<FILESIZE>31088</FILESIZE>
<CREATIONDATE>12-11-2010 07:03:46</CREATIONDATE>
<VERSION>1.0.0.0</VERSION>
<MANUFACTURER>CyberLink Corporation</MANUFACTURER>
<PRODUCTNAME>CyberLink WebCam Virtual Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>CmBatt.sys</FILENAME>
<FILESIZE>17664</FILESIZE>
<CREATIONDATE>07-13-2009 23:31:03</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>cmdide.sys</FILENAME>
<FILESIZE>17488</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:48</CREATIONDATE>
<VERSION>2.0.7.0</VERSION>
<MANUFACTURER>CMD Technology, Inc.</MANUFACTURER>
</DRIVER>
<DRIVER>
<FILENAME>cng.sys</FILENAME>
<FILESIZE>459248</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:45</CREATIONDATE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>compbatt.sys</FILENAME>
<FILESIZE>21584</FILESIZE>
<CREATIONDATE>07-13-2009 23:31:02</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>CompositeBus.sys</FILENAME>
<FILESIZE>38912</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>crcdisk.sys</FILENAME>
<FILESIZE>24144</FILESIZE>
<CREATIONDATE>07-14-2009 00:01:14</CREATIONDATE>
<GROUP>Pnp Filter</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>dfsc.sys</FILENAME>
<FILESIZE>102400</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:18</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>discache.sys</FILENAME>
<FILESIZE>40448</FILESIZE>
<CREATIONDATE>07-13-2009 23:37:18</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>disk.sys</FILENAME>
<FILESIZE>73280</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:57</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>drmkaud.sys</FILENAME>
<FILESIZE>5632</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:16</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>dtsoftbus01.sys</FILENAME>
<FILESIZE>254528</FILESIZE>
<CREATIONDATE>06-25-2011 10:52:07</CREATIONDATE>
<VERSION>4.40.2.210</VERSION>
<MANUFACTURER>DT Soft Ltd</MANUFACTURER>
<PRODUCTNAME>DAEMON Tools Lite</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>dxgkrnl.sys</FILENAME>
<FILESIZE>982912</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:41</CREATIONDATE>
<GROUP>Video Init</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>evbda.sys</FILENAME>
<FILESIZE>3286016</FILESIZE>
<CREATIONDATE>06-10-2009 20:34:33</CREATIONDATE>
<VERSION>4.8.13.0</VERSION>
<PRODUCTNAME>Broadcom NetXtreme II 10 GigE</PRODUCTNAME>
<GROUP>base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>eeCtrl64.sys</FILENAME>
<FILESIZE>481912</FILESIZE>
<CREATIONDATE>05-22-2011 13:09:26</CREATIONDATE>
<MANUFACTURER/>
<PRODUCTNAME/>
<ALTITUDE>329010</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>elxstor.sys</FILENAME>
<FILESIZE>530496</FILESIZE>
<CREATIONDATE>06-10-2009 20:36:49</CREATIONDATE>
<VERSION>7.2.10.211</VERSION>
<MANUFACTURER>Emulex</MANUFACTURER>
<PRODUCTNAME>Emulex LightPulse Storport Miniport Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>EraserUtilRebootDrv.sys</FILENAME>
<FILESIZE>136824</FILESIZE>
<CREATIONDATE>05-22-2011 08:31:38</CREATIONDATE>
<MANUFACTURER/>
<PRODUCTNAME/>
</DRIVER>
<DRIVER>
<FILENAME>errdev.sys</FILENAME>
<FILESIZE>9728</FILESIZE>
<CREATIONDATE>07-13-2009 23:31:04</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>exfat.sys</FILENAME>
<FILESIZE>195072</FILESIZE>
<CREATIONDATE>07-13-2009 23:23:29</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>fastfat.sys</FILENAME>
<FILESIZE>204800</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>fdc.sys</FILENAME>
<FILESIZE>29696</FILESIZE>
<CREATIONDATE>07-14-2009 00:00:54</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>fileinfo.sys</FILENAME>
<FILESIZE>70224</FILESIZE>
<CREATIONDATE>07-13-2009 23:34:25</CREATIONDATE>
<GROUP>FSFilter Bottom</GROUP>
<ALTITUDE>45000</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>filetrace.sys</FILENAME>
<FILESIZE>34304</FILESIZE>
<CREATIONDATE>07-13-2009 23:25:40</CREATIONDATE>
<GROUP>FSFilter Activity Monitor</GROUP>
<ALTITUDE>385000</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>flpydisk.sys</FILENAME>
<FILESIZE>24576</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>fltmgr.sys</FILENAME>
<FILESIZE>289664</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:26</CREATIONDATE>
<GROUP>FSFilter Infrastructure</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>FsDepends.sys</FILENAME>
<FILESIZE>55376</FILESIZE>
<CREATIONDATE>07-13-2009 23:26:13</CREATIONDATE>
<ALTITUDE>407000</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>Fs_Rec.sys</FILENAME>
<FILESIZE>23104</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:46</CREATIONDATE>
<GROUP>File System</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>fvevol.sys</FILENAME>
<FILESIZE>223248</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:15</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>gagp30kx.sys</FILENAME>
<FILESIZE>65088</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>GEARAspiWDM.sys</FILENAME>
<FILESIZE>34152</FILESIZE>
<CREATIONDATE>06-05-2011 20:56:23</CREATIONDATE>
<VERSION>2.2.0.1</VERSION>
<MANUFACTURER>GEAR Software Inc.</MANUFACTURER>
<PRODUCTNAME>CD DVD Filter</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>hamachi.sys</FILENAME>
<FILESIZE>33856</FILESIZE>
<CREATIONDATE>03-18-2009 16:35:42</CREATIONDATE>
<VERSION>7.0.1.1</VERSION>
<MANUFACTURER>LogMeIn, Inc.</MANUFACTURER>
<PRODUCTNAME>Hamachi Virtual Network Interface Driver</PRODUCTNAME>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>hcw85cir.sys</FILENAME>
<FILESIZE>31232</FILESIZE>
<CREATIONDATE>07-13-2009 22:53:43</CREATIONDATE>
<VERSION>1.31.27127.0</VERSION>
<MANUFACTURER>Hauppauge Computer Works, Inc.</MANUFACTURER>
<PRODUCTNAME>hcw85cir.sys</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>HdAudio.sys</FILENAME>
<FILESIZE>350208</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>HDAudBus.sys</FILENAME>
<FILESIZE>122368</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>HidBatt.sys</FILENAME>
<FILESIZE>26624</FILESIZE>
<CREATIONDATE>07-13-2009 23:31:06</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>hidbth.sys</FILENAME>
<FILESIZE>100864</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>hidir.sys</FILENAME>
<FILESIZE>46592</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:23</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>hidusb.sys</FILENAME>
<FILESIZE>30208</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>hpdskflt.sys</FILENAME>
<FILESIZE>30008</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>HpSAMD.sys</FILENAME>
<FILESIZE>78720</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:17</CREATIONDATE>
<VERSION>6.12.6.64</VERSION>
<PRODUCTNAME>Smart Array SAS/SATA Controller Media Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>HTTP.sys</FILENAME>
<FILESIZE>753664</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:59</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>hwpolicy.sys</FILENAME>
<CREATIONDATE>06-09-2011 10:30:43</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>i8042prt.sys</FILENAME>
<FILESIZE>105472</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:58</CREATIONDATE>
<GROUP>Keyboard Port</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>iaStorV.sys</FILENAME>
<FILESIZE>410496</FILESIZE>
<VERSION>8.6.2.1014</VERSION>
<MANUFACTURER>Intel Corporation</MANUFACTURER>
<PRODUCTNAME>Intel Matrix Storage Manager driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>IDSvia64.sys</FILENAME>
<FILESIZE>488056</FILESIZE>
<CREATIONDATE>07-14-2011 11:07:31</CREATIONDATE>
<MANUFACTURER/>
<PRODUCTNAME/>
</DRIVER>
<DRIVER>
<FILENAME>igdkmd64.sys</FILENAME>
<FILESIZE>6108416</FILESIZE>
<CREATIONDATE>06-10-2009 20:37:05</CREATIONDATE>
<VERSION>8.15.10.1749</VERSION>
<PRODUCTNAME>
Intel Graphics Accelerator Drivers for Windows Vista(R)
</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>iirsp.sys</FILENAME>
<FILESIZE>44112</FILESIZE>
<VERSION>5.4.22.0</VERSION>
<MANUFACTURER>Intel Corp./ICP vortex GmbH</MANUFACTURER>
<PRODUCTNAME>Intel/ICP Raid Storport Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>intelide.sys</FILENAME>
<FILESIZE>16960</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>intelppm.sys</FILENAME>
<FILESIZE>62464</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>ipfltdrv.sys</FILENAME>
<FILESIZE>82944</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:14</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>IPMIDrv.sys</FILENAME>
<FILESIZE>78848</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:11</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>ipnat.sys</FILENAME>
<FILESIZE>116224</FILESIZE>
<CREATIONDATE>07-14-2009 00:10:03</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>irenum.sys</FILENAME>
<FILESIZE>17920</FILESIZE>
<CREATIONDATE>07-14-2009 00:08:59</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>isapnp.sys</FILENAME>
<FILESIZE>20544</FILESIZE>
<CREATIONDATE>07-13-2009 23:31:08</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>msiscsi.sys</FILENAME>
<FILESIZE>273792</FILESIZE>
<CREATIONDATE>06-09-2011 10:32:12</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>kbdclass.sys</FILENAME>
<FILESIZE>50768</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:50</CREATIONDATE>
<GROUP>Keyboard Class</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>kbdhid.sys</FILENAME>
<FILESIZE>33280</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>ksecdd.sys</FILENAME>
<FILESIZE>95616</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:16</CREATIONDATE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>ksecpkg.sys</FILENAME>
<FILESIZE>152960</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:02</CREATIONDATE>
<GROUP>Cryptography</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>ksthunk.sys</FILENAME>
<FILESIZE>20992</FILESIZE>
<CREATIONDATE>07-14-2009 00:00:19</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>lltdio.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:08:51</CREATIONDATE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>lsi_fc.sys</FILENAME>
<FILESIZE>114752</FILESIZE>
<CREATIONDATE>07-13-2009 21:59:34</CREATIONDATE>
<VERSION>1.28.3.52</VERSION>
<MANUFACTURER>LSI Corporation</MANUFACTURER>
</DRIVER>
<DRIVER>
<FILENAME>lsi_sas.sys</FILENAME>
<FILESIZE>106560</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>lsi_sas2.sys</FILENAME>
<FILESIZE>65600</FILESIZE>
<VERSION>2.0.2.71</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>lsi_scsi.sys</FILENAME>
<FILESIZE>115776</FILESIZE>
<VERSION>1.28.3.67</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>luafv.sys</FILENAME>
<FILESIZE>113152</FILESIZE>
<GROUP>FSFilter Virtualization</GROUP>
<ALTITUDE>135000</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>megasas.sys</FILENAME>
<FILESIZE>35392</FILESIZE>
<CREATIONDATE>06-10-2009 20:37:14</CREATIONDATE>
<VERSION>4.5.1.64</VERSION>
<PRODUCTNAME>
MEGASAS Storport Driver for Windows 7\Server 2008 R2 for x64
</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>MegaSR.sys</FILENAME>
<FILESIZE>284736</FILESIZE>
<VERSION>13.5.409.2009</VERSION>
<MANUFACTURER>LSI Corporation, Inc.</MANUFACTURER>
<PRODUCTNAME>MegaRAID Software RAID</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>modem.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:10:49</CREATIONDATE>
<GROUP>Extended base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>monitor.sys</FILENAME>
<CREATIONDATE>07-13-2009 23:38:53</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>mouclass.sys</FILENAME>
<FILESIZE>49216</FILESIZE>
<GROUP>Pointer Class</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>mouhid.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:00:20</CREATIONDATE>
<GROUP>Pointer Port</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>mountmgr.sys</FILENAME>
<FILESIZE>94592</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:49</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>mpio.sys</FILENAME>
<FILESIZE>155008</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:41</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>mpsdrv.sys</FILENAME>
<FILESIZE>77312</FILESIZE>
<CREATIONDATE>07-14-2009 00:08:25</CREATIONDATE>
<GROUP>network</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>mqac.sys</FILENAME>
<FILESIZE>189440</FILESIZE>
<CREATIONDATE>07-14-2009 00:26:13</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>mrxdav.sys</FILENAME>
<FILESIZE>140800</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:20</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>mrxsmb.sys</FILENAME>
<FILESIZE>158208</FILESIZE>
<CREATIONDATE>06-16-2011 15:27:14</CREATIONDATE>
<VERSION>6.1.7601.17605</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>mrxsmb10.sys</FILENAME>
<FILESIZE>289280</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>mrxsmb20.sys</FILENAME>
<FILESIZE>128000</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>msahci.sys</FILENAME>
<FILESIZE>31104</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:07</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>msdsm.sys</FILENAME>
<FILESIZE>140672</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:18</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>Msfs.sys</FILENAME>
<FILESIZE>26112</FILESIZE>
<GROUP>File system</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>mshidkmdf.sys</FILENAME>
<FILESIZE>8192</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:24</CREATIONDATE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>msisadrv.sys</FILENAME>
<FILESIZE>15424</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>MSKSSRV.sys</FILENAME>
<FILESIZE>11136</FILESIZE>
<CREATIONDATE>07-14-2009 00:00:18</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>MSPCLOCK.sys</FILENAME>
<FILESIZE>7168</FILESIZE>
<CREATIONDATE>07-14-2009 00:00:17</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>MSPQM.sys</FILENAME>
<FILESIZE>6784</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>MsRPC.sys</FILENAME>
<FILESIZE>366976</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:34</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>mssmbios.sys</FILENAME>
<FILESIZE>32320</FILESIZE>
<CREATIONDATE>07-13-2009 23:31:10</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>MSTEE.sys</FILENAME>
<FILESIZE>8064</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>MTConfig.sys</FILENAME>
<FILESIZE>15360</FILESIZE>
<CREATIONDATE>07-14-2009 00:02:08</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>mup.sys</FILENAME>
<FILESIZE>60496</FILESIZE>
<CREATIONDATE>07-13-2009 23:23:45</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>nwifi.sys</FILENAME>
<FILESIZE>318976</FILESIZE>
<CREATIONDATE>07-14-2009 00:07:24</CREATIONDATE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>ENG64.SYS</FILENAME>
<FILESIZE>117880</FILESIZE>
<CREATIONDATE>07-14-2011 18:07:41</CREATIONDATE>
<MANUFACTURER/>
<PRODUCTNAME/>
</DRIVER>
<DRIVER>
<FILENAME>EX64.SYS</FILENAME>
<FILESIZE>2011768</FILESIZE>
<MANUFACTURER/>
<PRODUCTNAME/>
</DRIVER>
<DRIVER>
<FILENAME>ndis.sys</FILENAME>
<FILESIZE>951680</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:58</CREATIONDATE>
<GROUP>NDIS Wrapper</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>ndiscap.sys</FILENAME>
<FILESIZE>35328</FILESIZE>
<CREATIONDATE>07-14-2009 00:08:13</CREATIONDATE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>ndistapi.sys</FILENAME>
<FILESIZE>24064</FILESIZE>
<CREATIONDATE>07-14-2009 00:10:00</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>ndisuio.sys</FILENAME>
<FILESIZE>56832</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:23</CREATIONDATE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>ndiswan.sys</FILENAME>
<FILESIZE>164352</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:09</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>NDProxy.sys</FILENAME>
<FILESIZE>57856</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:37</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>netbios.sys</FILENAME>
<FILESIZE>44544</FILESIZE>
<CREATIONDATE>07-14-2009 00:09:26</CREATIONDATE>
<GROUP>NetBIOSGroup</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>netbt.sys</FILENAME>
<FILESIZE>261632</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:48</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>netw5v64.sys</FILENAME>
<FILESIZE>5434368</FILESIZE>
<CREATIONDATE>06-10-2009 20:35:28</CREATIONDATE>
<VERSION>12.4.1.4</VERSION>
<PRODUCTNAME>Intel® Wireless WiFi Link Adapter</PRODUCTNAME>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>nfrd960.sys</FILENAME>
<FILESIZE>51264</FILESIZE>
<VERSION>7.10.0.0</VERSION>
<MANUFACTURER>IBM Corporation</MANUFACTURER>
<PRODUCTNAME>IBM ServeRAID Controller</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>npf.sys</FILENAME>
<FILESIZE>35344</FILESIZE>
<CREATIONDATE>06-25-2010 17:07:26</CREATIONDATE>
<VERSION>4.1.0.2001</VERSION>
<MANUFACTURER>CACE Technologies, Inc.</MANUFACTURER>
<PRODUCTNAME>WinPcap</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>Npfs.sys</FILENAME>
<FILESIZE>44032</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>nsiproxy.sys</FILENAME>
<CREATIONDATE>07-13-2009 23:21:03</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>Ntfs.sys</FILENAME>
<FILESIZE>1659776</FILESIZE>
<VERSION>6.1.7601.17577</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>Null.sys</FILENAME>
<FILESIZE>6144</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:38</CREATIONDATE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>nusb3hub.sys</FILENAME>
<CREATIONDATE>11-19-2010 18:34:26</CREATIONDATE>
<VERSION>2.0.30.0</VERSION>
<MANUFACTURER>Renesas Electronics Corporation</MANUFACTURER>
<PRODUCTNAME>USB 3.0 Device Driver</PRODUCTNAME>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>nusb3xhc.sys</FILENAME>
<FILESIZE>181248</FILESIZE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>nvraid.sys</FILENAME>
<FILESIZE>148352</FILESIZE>
<VERSION>10.6.0.18</VERSION>
<MANUFACTURER>NVIDIA Corporation</MANUFACTURER>
<PRODUCTNAME>NVIDIA nForce(TM) RAID Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>nvstor.sys</FILENAME>
<FILESIZE>166272</FILESIZE>
<PRODUCTNAME>NVIDIA nForce(TM) SATA Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>nv_agp.sys</FILENAME>
<FILESIZE>122960</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>ohci1394.sys</FILENAME>
<FILESIZE>72832</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:45</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>parport.sys</FILENAME>
<FILESIZE>97280</FILESIZE>
<CREATIONDATE>07-14-2009 00:00:41</CREATIONDATE>
<GROUP>Parallel arbitrator</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>partmgr.sys</FILENAME>
<FILESIZE>75136</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>pci.sys</FILENAME>
<FILESIZE>184704</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:22</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>pciide.sys</FILENAME>
<FILESIZE>12352</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>pcmcia.sys</FILENAME>
<FILESIZE>220752</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>pcw.sys</FILENAME>
<CREATIONDATE>07-13-2009 23:19:30</CREATIONDATE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>peauth.sys</FILENAME>
<FILESIZE>651264</FILESIZE>
<CREATIONDATE>07-13-2009 23:51:01</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>raspptp.sys</FILENAME>
<FILESIZE>111104</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:05</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>processr.sys</FILENAME>
<FILESIZE>60416</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>pacer.sys</FILENAME>
<FILESIZE>131584</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:20</CREATIONDATE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>ql2300.sys</FILENAME>
<FILESIZE>1524816</FILESIZE>
<CREATIONDATE>06-10-2009 20:37:36</CREATIONDATE>
<VERSION>9.1.8.6</VERSION>
<MANUFACTURER>QLogic Corporation</MANUFACTURER>
<PRODUCTNAME>QLogic Fibre Channel Stor Miniport Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>ql40xx.sys</FILENAME>
<FILESIZE>128592</FILESIZE>
<VERSION>2.1.3.20</VERSION>
<PRODUCTNAME>QLA40XX iSCSI Host Bus Adapter</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>qwavedrv.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:09:48</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>rasacd.sys</FILENAME>
<FILESIZE>14848</FILESIZE>
<CREATIONDATE>07-14-2009 00:10:09</CREATIONDATE>
<GROUP>Streams Drivers</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>AgileVpn.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:10:24</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>rasl2tp.sys</FILENAME>
<FILESIZE>129536</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:21</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>raspppoe.sys</FILENAME>
<FILESIZE>92672</FILESIZE>
<CREATIONDATE>07-14-2009 00:10:17</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>rassstp.sys</FILENAME>
<FILESIZE>83968</FILESIZE>
<CREATIONDATE>07-14-2009 00:10:25</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>rdbss.sys</FILENAME>
<FILESIZE>309248</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>rdpbus.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:17:46</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>RDPCDD.sys</FILENAME>
<FILESIZE>7680</FILESIZE>
<CREATIONDATE>07-14-2009 00:16:34</CREATIONDATE>
<GROUP>Video Save</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>rdpencdd.sys</FILENAME>
</DRIVER>
<DRIVER>
<FILENAME>rdprefmp.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:16:35</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>RDPWD.sys</FILENAME>
<FILESIZE>210944</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:43</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>rdyboost.sys</FILENAME>
<FILESIZE>213888</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:51</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>rfcomm.sys</FILENAME>
<FILESIZE>158720</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:56</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>RtsPStor.sys</FILENAME>
<FILESIZE>329832</FILESIZE>
<CREATIONDATE>03-07-2011 22:06:15</CREATIONDATE>
<VERSION>6.1.7600.69</VERSION>
<MANUFACTURER>Realtek Semiconductor Corp.</MANUFACTURER>
<PRODUCTNAME>
Realtek Pcie CardReader Driver for 2K/XP/Vista/Win7
</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>rspndr.sys</FILENAME>
<FILESIZE>76800</FILESIZE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>Rt64win7.sys</FILENAME>
<FILESIZE>406632</FILESIZE>
<CREATIONDATE>03-07-2011 22:05:33</CREATIONDATE>
<VERSION>7.30.1019.2010</VERSION>
<MANUFACTURER>Realtek</MANUFACTURER>
<PRODUCTNAME>Realtek 8136/8168/8169 PCI/PCIe Adapters</PRODUCTNAME>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>sbp2port.sys</FILENAME>
<FILESIZE>103808</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:04</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>SCDEmu.sys</FILENAME>
<FILESIZE>91568</FILESIZE>
<CREATIONDATE>05-22-2011 21:53:35</CREATIONDATE>
<VERSION>4.7.0.0</VERSION>
<MANUFACTURER>PowerISO Computing, Inc.</MANUFACTURER>
<PRODUCTNAME>scdemu</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>scfilter.sys</FILENAME>
</DRIVER>
<DRIVER>
<FILENAME>sdbus.sys</FILENAME>
<FILESIZE>109056</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>secdrv.sys</FILENAME>
<CREATIONDATE>07-14-2009 02:36:07</CREATIONDATE>
<VERSION>4.3.86.0</VERSION>
<MANUFACTURER>
Macrovision Corporation, Macrovision Europe Limited, and Macrovision Japan and Asia K.K.
</MANUFACTURER>
<PRODUCTNAME>Macrovision SECURITY Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>serenum.sys</FILENAME>
<FILESIZE>23552</FILESIZE>
<CREATIONDATE>07-14-2009 00:00:33</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>serial.sys</FILENAME>
<FILESIZE>94208</FILESIZE>
<CREATIONDATE>07-14-2009 00:00:40</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>sermouse.sys</FILENAME>
</DRIVER>
<DRIVER>
<FILENAME>sffdisk.sys</FILENAME>
<FILESIZE>14336</FILESIZE>
<CREATIONDATE>07-14-2009 00:01:01</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>sffp_mmc.sys</FILENAME>
<FILESIZE>13824</FILESIZE>
<CREATIONDATE>07-14-2009 00:01:03</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>sffp_sd.sys</FILENAME>
<CREATIONDATE>06-09-2011 10:30:09</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>sfloppy.sys</FILENAME>
<FILESIZE>16896</FILESIZE>
<CREATIONDATE>07-14-2009 00:01:02</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>Sftfslh.sys</FILENAME>
<FILESIZE>721768</FILESIZE>
<CREATIONDATE>04-24-2010 00:10:20</CREATIONDATE>
<VERSION>4.6.0.10191</VERSION>
<PRODUCTNAME>Microsoft Application Virtualization</PRODUCTNAME>
<GROUP>FileSystem</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>Sftplaylh.sys</FILENAME>
<FILESIZE>269672</FILESIZE>
<CREATIONDATE>04-24-2010 00:10:28</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>Sftredirlh.sys</FILENAME>
<FILESIZE>25960</FILESIZE>
<GROUP>FSFilter Top</GROUP>
<ALTITUDE>406000</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>Sftvollh.sys</FILENAME>
<FILESIZE>22376</FILESIZE>
<CREATIONDATE>04-24-2010 00:10:32</CREATIONDATE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>SiSRaid2.sys</FILENAME>
<FILESIZE>43584</FILESIZE>
<CREATIONDATE>06-10-2009 20:37:40</CREATIONDATE>
<VERSION>5.1.1039.2600</VERSION>
<MANUFACTURER>Silicon Integrated Systems Corp.</MANUFACTURER>
</DRIVER>
<DRIVER>
<FILENAME>sisraid4.sys</FILENAME>
<FILESIZE>80464</FILESIZE>
<VERSION>5.1.1039.3600</VERSION>
<MANUFACTURER>Silicon Integrated Systems</MANUFACTURER>
</DRIVER>
<DRIVER>
<FILENAME>smb.sys</FILENAME>
<FILESIZE>93184</FILESIZE>
<CREATIONDATE>07-14-2009 00:09:09</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>spldr.sys</FILENAME>
<FILESIZE>19008</FILESIZE>
<CREATIONDATE>07-13-2009 20:27:56</CREATIONDATE>
<VERSION>6.1.7127.0</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>SRTSP64.SYS</FILENAME>
<FILESIZE>744568</FILESIZE>
<CREATIONDATE>05-22-2011 08:31:19</CREATIONDATE>
<VERSION>12.3.1.22</VERSION>
<MANUFACTURER>Symantec Corporation</MANUFACTURER>
<PRODUCTNAME>AutoProtect</PRODUCTNAME>
<GROUP>FSFilter Anti-Virus</GROUP>
<ALTITUDE>329000</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>SRTSPX64.SYS</FILENAME>
<FILESIZE>40568</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>srv.sys</FILENAME>
<FILESIZE>467456</FILESIZE>
<CREATIONDATE>06-16-2011 15:26:39</CREATIONDATE>
<VERSION>6.1.7601.17608</VERSION>
</DRIVER>
<DRIVER>
<FILENAME>srv2.sys</FILENAME>
<FILESIZE>410112</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>VSTAZL6.SYS</FILENAME>
<FILESIZE>292864</FILESIZE>
<CREATIONDATE>07-13-2009 22:04:21</CREATIONDATE>
<VERSION>7.80.2.0</VERSION>
<MANUFACTURER>Conexant Systems, Inc.</MANUFACTURER>
<PRODUCTNAME>SoftK56 Modem Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>VSTDPV6.SYS</FILENAME>
<FILESIZE>1485312</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>VSTCNXT6.SYS</FILENAME>
<FILESIZE>740864</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>srvnet.sys</FILENAME>
<FILESIZE>168448</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>stexstor.sys</FILENAME>
<FILESIZE>24656</FILESIZE>
<VERSION>5.0.1.1</VERSION>
<MANUFACTURER>Promise Technology</MANUFACTURER>
<PRODUCTNAME>Promise SuperTrak EX Series</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>stwrt64.sys</FILENAME>
<FILESIZE>520192</FILESIZE>
<CREATIONDATE>03-07-2011 22:03:39</CREATIONDATE>
<VERSION>6.10.6315.0</VERSION>
<MANUFACTURER>IDT, Inc.</MANUFACTURER>
<PRODUCTNAME>IDT PC Audio</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>swenum.sys</FILENAME>
<FILESIZE>12496</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>SYMDS64.SYS</FILENAME>
<FILESIZE>450680</FILESIZE>
<VERSION>1.2.0.15</VERSION>
<PRODUCTNAME>SymDS</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>SYMEFA64.SYS</FILENAME>
<FILESIZE>912504</FILESIZE>
<VERSION>2.1.3.3</VERSION>
<PRODUCTNAME>EFA</PRODUCTNAME>
<ALTITUDE>260600</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>SYMEVENT64x86.SYS</FILENAME>
<FILESIZE>174200</FILESIZE>
<CREATIONDATE>03-07-2011 22:22:40</CREATIONDATE>
<MANUFACTURER/>
<PRODUCTNAME/>
</DRIVER>
<DRIVER>
<FILENAME>Ironx64.SYS</FILENAME>
<FILESIZE>171128</FILESIZE>
<VERSION>1.6.0.37</VERSION>
<PRODUCTNAME>Iron</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>SYMNETS.SYS</FILENAME>
<FILESIZE>382584</FILESIZE>
<VERSION>11.1.1.12</VERSION>
<PRODUCTNAME>Symantec Security Drivers</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>SynTP.sys</FILENAME>
<FILESIZE>1403440</FILESIZE>
<CREATIONDATE>12-17-2010 02:28:38</CREATIONDATE>
<VERSION>15.2.4.4</VERSION>
<MANUFACTURER>Synaptics Incorporated</MANUFACTURER>
<PRODUCTNAME>Synaptics Pointing Device Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>tcpip.sys</FILENAME>
<FILESIZE>1923968</FILESIZE>
</DRIVER>
<DRIVER>
</DRIVER>
<DRIVER>
<FILENAME>tcpipreg.sys</FILENAME>
<CREATIONDATE>06-09-2011 10:30:26</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>tdpipe.sys</FILENAME>
<FILESIZE>15872</FILESIZE>
<CREATIONDATE>07-14-2009 00:16:32</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>tdtcp.sys</FILENAME>
</DRIVER>
<DRIVER>
<FILENAME>tdx.sys</FILENAME>
<FILESIZE>119296</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>termdd.sys</FILENAME>
<FILESIZE>63360</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>tssecsrv.sys</FILENAME>
<FILESIZE>39424</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:45</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>tsusbflt.sys</FILENAME>
<FILESIZE>59392</FILESIZE>
<CREATIONDATE>06-09-2011 10:32:41</CREATIONDATE>
<GROUP>base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>tunnel.sys</FILENAME>
<FILESIZE>125440</FILESIZE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>uagp35.sys</FILENAME>
<FILESIZE>64080</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>udfs.sys</FILENAME>
<FILESIZE>328192</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>uliagpkx.sys</FILENAME>
<FILESIZE>64592</FILESIZE>
<CREATIONDATE>07-13-2009 23:38:48</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>umbus.sys</FILENAME>
<FILESIZE>48640</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:29</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>umpass.sys</FILENAME>
</DRIVER>
<DRIVER>
<FILENAME>usbaapl64.sys</FILENAME>
<FILESIZE>51712</FILESIZE>
<CREATIONDATE>02-18-2011 15:36:58</CREATIONDATE>
<VERSION>1.55.0.0</VERSION>
<MANUFACTURER>Apple, Inc.</MANUFACTURER>
<PRODUCTNAME>Apple Mobile Device USB Driver</PRODUCTNAME>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>usbccgp.sys</FILENAME>
<FILESIZE>98816</FILESIZE>
<CREATIONDATE>07-13-2011 11:43:22</CREATIONDATE>
<VERSION>6.1.7601.17586</VERSION>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>usbcir.sys</FILENAME>
<FILESIZE>100352</FILESIZE>
<CREATIONDATE>07-14-2009 00:06:37</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>usbehci.sys</FILENAME>
<FILESIZE>52736</FILESIZE>
<CREATIONDATE>07-13-2011 11:43:23</CREATIONDATE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>usbfilter.sys</FILENAME>
<FILESIZE>38528</FILESIZE>
<CREATIONDATE>03-07-2011 22:03:13</CREATIONDATE>
<VERSION>1.0.16.106</VERSION>
<PRODUCTNAME>AMD USB Filter Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>usbhub.sys</FILENAME>
<FILESIZE>343040</FILESIZE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>usbohci.sys</FILENAME>
<FILESIZE>25600</FILESIZE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>usbprint.sys</FILENAME>
<FILESIZE>25088</FILESIZE>
<CREATIONDATE>07-14-2009 00:38:18</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>USBSTOR.SYS</FILENAME>
<FILESIZE>91648</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>usbuhci.sys</FILENAME>
<FILESIZE>30720</FILESIZE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>usbvideo.sys</FILENAME>
<FILESIZE>184960</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:56</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>vdrvroot.sys</FILENAME>
<FILESIZE>36432</FILESIZE>
<CREATIONDATE>07-14-2009 00:01:31</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>vgapnp.sys</FILENAME>
<FILESIZE>29184</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>vga.sys</FILENAME>
</DRIVER>
<DRIVER>
<FILENAME>vhdmp.sys</FILENAME>
<FILESIZE>215936</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:38</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>viaide.sys</FILENAME>
<VERSION>6.0.6000.170</VERSION>
<MANUFACTURER>VIA Technologies, Inc.</MANUFACTURER>
<PRODUCTNAME>VIA PCI IDE MINI Driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>volmgr.sys</FILENAME>
<FILESIZE>71552</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:19</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>volmgrx.sys</FILENAME>
<FILESIZE>363392</FILESIZE>
</DRIVER>
<DRIVER>
<FILENAME>volsnap.sys</FILENAME>
<FILESIZE>295808</FILESIZE>
<CREATIONDATE>06-09-2011 10:31:33</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>vsmraid.sys</FILENAME>
<FILESIZE>161872</FILESIZE>
<CREATIONDATE>06-10-2009 20:37:58</CREATIONDATE>
<VERSION>6.0.6000.6210</VERSION>
<MANUFACTURER>VIA Technologies Inc.,Ltd</MANUFACTURER>
<PRODUCTNAME>VIA RAID driver</PRODUCTNAME>
</DRIVER>
<DRIVER>
<FILENAME>vwifibus.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:07:21</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>vwififlt.sys</FILENAME>
<FILESIZE>59904</FILESIZE>
<CREATIONDATE>07-14-2009 00:07:22</CREATIONDATE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>vwifimp.sys</FILENAME>
<CREATIONDATE>07-14-2009 00:07:28</CREATIONDATE>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>wacompen.sys</FILENAME>
<FILESIZE>27776</FILESIZE>
<CREATIONDATE>07-14-2009 00:02:07</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>wanarp.sys</FILENAME>
<FILESIZE>88576</FILESIZE>
<CREATIONDATE>06-09-2011 10:30:57</CREATIONDATE>
</DRIVER>
<DRIVER>
</DRIVER>
<DRIVER>
<FILENAME>wd.sys</FILENAME>
<FILESIZE>21056</FILESIZE>
<CREATIONDATE>07-13-2009 23:19:55</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>Wdf01000.sys</FILENAME>
<FILESIZE>654928</FILESIZE>
<CREATIONDATE>07-13-2009 23:22:11</CREATIONDATE>
<VERSION>1.9.7600.16385</VERSION>
<GROUP>WdfLoadGroup</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>wfplwf.sys</FILENAME>
<GROUP>NDIS</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>wimmount.sys</FILENAME>
<FILESIZE>22096</FILESIZE>
<CREATIONDATE>07-13-2009 23:29:31</CREATIONDATE>
<ALTITUDE>180700</ALTITUDE>
</DRIVER>
<DRIVER>
<FILENAME>WinUSB.sys</FILENAME>
</DRIVER>
<DRIVER>
<FILENAME>wmiacpi.sys</FILENAME>
</DRIVER>
<DRIVER>
<FILENAME>ws2ifsl.sys</FILENAME>
<FILESIZE>21504</FILESIZE>
<CREATIONDATE>07-14-2009 00:10:34</CREATIONDATE>
</DRIVER>
<DRIVER>
<FILENAME>WudfPf.sys</FILENAME>
<FILESIZE>112128</FILESIZE>
<GROUP>base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>WUDFRd.sys</FILENAME>
<FILESIZE>172544</FILESIZE>
<GROUP>Base</GROUP>
</DRIVER>
<DRIVER>
<FILENAME>yk62x64.sys</FILENAME>
<FILESIZE>389120</FILESIZE>
<CREATIONDATE>06-10-2009 20:35:33</CREATIONDATE>
<VERSION>11.0.5.3</VERSION>
<MANUFACTURER>Marvell</MANUFACTURER>
<PRODUCTNAME>Marvell Yukon Ethernet Controller.</PRODUCTNAME>
<GROUP>NDIS</GROUP>
</DRIVER>
</DRIVERS>
</SYSTEMINFO>
Code:
<WERReportMetadata>
<OSVersionInformation>
<WindowsNTVersion>6.1</WindowsNTVersion>
<Build>7601 Service Pack 1</Build>
<Product>(0x3): Windows 7 Home Premium</Product>
<Edition>HomePremium</Edition>
<BuildString>7601.17592.amd64fre.win7sp1_gdr.110408-1631</BuildString>
<Revision>1130</Revision>
<Flavor>Multiprocessor Free</Flavor>
<Architecture>X64</Architecture>
<LCID>1033</LCID>
</OSVersionInformation>
<ProblemSignatures>
<EventType>LiveKernelEvent</EventType>
</ProblemSignatures>
<DynamicSignatures>
<Parameter1>6.1.7601.2.1.0.768.3</Parameter1>
<Parameter2>2074</Parameter2>
</DynamicSignatures>
<SystemInformation>
<MID>67D50F12-5F71-4515-A9FA-5920AB7973A6</MID>
<MarkerFile>
</MarkerFile>
<SystemManufacturer>Hewlett-Packard</SystemManufacturer>
<SystemProductName>HP Pavilion dv6 Notebook PC</SystemProductName>
<BIOSVersion>F.03</BIOSVersion>
</SystemInformation>
</WERReportMetadata>
LINK= WD-20110714-2005
Konfiguracije laptopa moga druga:
-Phenom II P960 Quad Core 1.8 GHz
-Hewlett-Packard HP Pavillion dv6 Notebook PC
-ATI Mobility Radeon HD 4200
-6 GB RAM
Probavao sam reinstalirat drivere za grafičku, probavao sam reinstalirat igru, probavao sam po googleu tražit, ništa nisam našao .
Znaći pop***** sam.
Molim vas, pomozite nam.
Zadnje izmijenjeno od: Krtislav. 16.07.2011. u 00:17.
Krtislav je offline   Reply With Quote
Staro 22.07.2011., 01:03   #2
Krtislav
Krtislav's Avatar
Lokacija: Vukovar
Postovi: 6
%refresh%
Staro 22.07.2011., 12:54   #3
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,059
Očisti komp s Driver Sweeperom i onda probaj ponovno staviti friške drivere.
Meni je MC crashao sa 11.6 driverima dok sa 11.2 radi sve bez problema.
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 23.07.2011., 17:30   #4
Krtislav
Krtislav's Avatar
Datum registracije: Jul 2011
Lokacija: Vukovar
Postovi: 6
Autor Mario92 Pregled postova
Sve drajvere ili samo grafičku, pošto sam grafičku sweep-ovao već
Staro 23.07.2011., 17:47   #5
branuschi
branuschi's Avatar
Lokacija: Sinj
Postovi: 397
stavi starije drivere ja sam imao sličan problem kad sam update-o na 11.6 sa HD4290
Moje trgovine: 1 ,2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 10 , 11 , 12 , 13 , 14 , 15 , 16 , 17 , 18 , 19 , 20 , 21 , 22 , 23 , 24
branuschi je offline   Reply With Quote
Staro 25.07.2011., 14:58   #6
Mario92
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,059
Da, kao što sam već napisao stavi 11.2 drivere.
Inače, zapelo mi je ovo za oko:
amdkmdap
atikmpag.sys
A veliš da imaš 4200M.
Sve više krivim drivere.
Ryzen 7 5700G
AsRock B550 Pro4
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
13.3" FHD IPS
Staro 28.07.2011., 19:49   #7
Krtislav
Krtislav's Avatar
Lokacija: Vukovar
Postovi: 6
greška
