Staro 21.07.2011., 13:05   #1
tihomir
tihomir's Avatar
Datum registracije: Jan 2002
Lokacija: ?
Postovi: 2,274
BSOD Win7
Nakon instalacije Win7 SP1 64bit na HP4515s ponekad zna doći do BSOD-a...
Podaci koje dobijem su:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1050
Additional information about the problem:
BCCode: 4a
BCP1: 0000000074372E09
BCP2: 0000000000000002
BCP3: 0000000000000000
BCP4: FFFFF880034AFCA0
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\072011-31793-01.dmp
C:\Users\xxx\AppData\Local\Temp\WER-47330-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Može pomoć?
Na BSOD-u još piše: irql gt at zero system service...
tihomir je offline   Reply With Quote
Staro 21.07.2011., 13:34   #2
nino
nino's Avatar
Postovi: 12,613
Dali koristis Zone alarm?
I ubaci konfiguraciju laptopa u opis kao i malo vise podataka, otkad se to desava, u kojim prilikama (kod boota, ukljucivanja odredjenih programa...itd).
Ekipa nikako da se nauci da daje sto vise podataka o problemu, a cude se ko pura dreku kad im obrisem topic.
I ovaj sam krenio obrisat...(clan od 2002.g.)
http://msdn.microsoft.com/en-us/libr...=vs.85%29.aspx
The following actions might prevent an error like this from happening again:
Download and install updates and device drivers for your computer from Windows Update.
Scan your computer for computer viruses.
Check your hard disk for errors.
Staro 21.07.2011., 13:59   #3
tihomir
tihomir's Avatar
Lokacija: ?
Postovi: 2,274
Da, imam Zonealarm, zadnju verziju 9.2.106 i počelo se događati nakon reinstalacije sustava, skinuo sam nove verzije programa i instalirao... Obrisao sam sad taj ZA i instalirao onaj stariji s kojim je sve radilo savršeno. To je verzija ZA 9.2.057...
Nema neke pravilnosti, BSOD se pojavi dok surfam internetom, gledam film u MPC HC, koristim Thunderbird - nisam primjetio nešto posebno.
Iako, nakon reinstalacije se - najviše primjetno kod gledanja filmova u MPC-HC, Yooutube ili u Flash igrama se zna dogoditi nešto kao kratko smrzavanje sustava ali u tom trenutku (1 sekunda) računalo radi i dostupno je ali zvuk onako zatrza u kratkom loopu - bzzzzzzzzzzz i odjednom nastavi dalje.
Konfiguracija je:
CPU brand: AMD
CPU tip: Turion X2 Dual-Core
CPU model: RM-76
CPU brzina [GHz]: 2,30
L2 Cache: 1 MB
Chipset (N): AMD RX781
Memorija [MB]: 2x 2048
Takt memorije [MHz]: 800
Memorijski utor: SO-DIMM DDR2
Max. količina memorije [GB]: 8
Broj memorijskih utora: 2
Ekran: 15,6"
Vrsta zaslona: BV (BrightView)
Max. rezolucija: 1366x768
HDD [GB]: SATA 500
Broj okretaja [rpm]: 5.400
VGA: ATI Radeon HD 4330 (512 MB)
Optička jedinica: DVD±RW DL
Mreža:
* 1x 10/100/1000 Ethernet
* 56k modem
* 802.11a/b/g/n
* Bluetooth
Staro 21.07.2011., 14:05   #4
tihomir
tihomir's Avatar
Lokacija: ?
Postovi: 2,274
Ustvari cijelo računalo se zamrzne na trenutak...
Staro 21.07.2011., 14:10   #5
nino
nino's Avatar
Postovi: 12,613
Vidim na netu da imaju problema sa ZA. Probaj ga obrisat pa vidi kako se ponasa. Inace je ZA znao na pojedinim racunalima uzrokovat BSOD.
