Staro 02.06.2011., 20:07   #151
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
@ Doink gdje si je kupio,na nabavi nema
prt scr je offline   Reply With Quote
Staro 02.06.2011., 20:11   #152
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Autor prt scr Pregled postova
Inside tip, zadnji primjerak sa Asbisovog skladišta
C L O W N I N G A R O U N D
Staro 02.06.2011., 20:19   #153
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Da, ali GTX560 tek na 1GHz parira default GTX570.
Nema mi je smisla prodavat, dapače tu situaciju trebam iskoristiti i uzet još jednu GTX570 za povoljnu cijenu pred kraj godine.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 02.06.2011., 21:17   #154
Tomek32
Tomek32's Avatar
Postovi: 149
Nova je 2200kn,kaj ljudi zele?
A mislim nema ju smisla prodavat,sve ces moc jos jako dugo igrat s njom...Eh da mi je te kartice,zbilja je super,i stvarno,dok ne izade nekaj novo,ne mrdaj.
Tomek32 je offline   Reply With Quote
Staro 02.06.2011., 21:34   #155
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Nista se losije neces igrati na 560Ti/HD6950 za 1600 Kn
Staro 02.06.2011., 22:54   #156
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Neces sve dok se ne upali 8xaa na 1920x1080 u nekoj zahtjevnijoj igri. Onda je 570 ostavlja u prasini bez obzira na takt. Ipak ta grafa ima skoro 100 SPa i 260mb memorije vise. Ista stvar je i sa 580 vs 570. 570 ce ju stic u vecini igri ali u nekima nece jer ekstra SPovi i mema rade svoje.
GTX570 je u stanju prozvakat skoro sve igre sa 8xqaa i sa 2x ili 4xaa transparency aa a 560 bas i ne. Njoj vise odgovara 4xaa u 1920x1080. To je glavna razlika. Kome to nije bitno, 560 je super kupnja.
Zadnje izmijenjeno od: MAGARAC. 02.06.2011. u 23:01.
Staro 02.06.2011., 23:32   #157
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Autor DraŽ Pregled postova
Ne sa tim procem i napajanjem I kaj nisi vec imao cross, nije ovo puno bolje, a i cemu dvije 570 kad ti je jedna 560Ti taman. Probaj ju prodat dok jos vrijedi i odi na nereferentnu 570 ili TF 560Ti.
Staro 03.06.2011., 00:21   #158
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor HCS Pregled postova
Šta ne s tim procem? LOL
Napajanje će ih držat u igrama i na stock taktovima, normalno da neću palit furmarke i occt power supply test sa SLI-em.
TX650 može još jednu držat bez problema, ali ne u stress testovima.
Odakle mi pare za 570 phantom ili slično? Ispod 1800kn nedam ovu, bio bi mazohist da stavim 1700kn cijenu. GTX570 ubije boga u GTX560, 100 shadera razlike čini svoje. Između GTX580 i 570 je razlika samo 32 shadera pa opet kolika razlika zna biti.
TV: LG 7450
GAMEPAD: XBOX One
Staro 03.06.2011., 00:30   #159
Postovi: 8,231
Ma drži to napajanje 2 komada u čem god hoćeš. Pa nije 650W baš tak malo.
Staro 03.06.2011., 01:31   #160
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Lol jbt, dobio bi drito 30-40ak% bolje perfomanse pod tim. Pa nisam si uspio nahranit 6970 kak spada di ces ovo. Drzat ce sigurno, al kolko dugo je upitno.
Cijelih 12% je razlika izmedu njih, s time da je TF2 560Ti gro tisa, hladnija, jeftinija i kaj je najgore ima bolje izvedeno VRM sklopovlje.
Staro 03.06.2011., 01:45   #161
MAGARAC
MAGARAC's Avatar
Postovi: 5,992
Nema problema sa regulacijom ako se graficka ne ganja sa 1.21v pa i onda nije da ce bas riknut. Ta regulacija je isto 3+1 ko na 560 i bolje je ohladena jer je na TF2 gola. Referentna 570 se ne cuje uopce kad je u kucistu a nije ni da je TF2 neko mjerilo tisine, pogotovo u toplom ambijentu sto tom hladnjaku poprilicno povisuje temperature.
Ja nebi ganjao te dve na tx650 jer nebi bio miran. Moze to napajanje poganjat i vise od toga ali uz dosta brundanja i zagrijavanja. Kao dugorocno rjesenje tx650 nje bas najbolji. Neka nova napajanja sa 750w bi bila bolji izbor. Pogotovo ak ce se overclockirat.
Po meni ni jedna SLI komb. jaca od gtx460 nema smisla jer je ovrkill za jedan monitor a za 3 ce im falit memorije. Tu je jedino gtx580 u igri ali i ona zna zastekat zbog meme.
Staro 03.06.2011., 02:07   #162
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Govoriš kao da je Phenom II x6 škart. Može ih nahranit bar 90%.
Vidiš na monitor uopće nisam mislio. Sad sam opet na početku, a to je najbolje ništa ne mjenjat osim možda preći na intela i7 pošto sam se počeo bavit encodingom blu ray anime-a, no sumnjam da bi dobio neki veliki napredak u odnosu na clockanog PII x6.
TV: LG 7450
GAMEPAD: XBOX One
Staro 04.06.2011., 11:29   #163
Tomek32
Tomek32's Avatar
Postovi: 149
@Doink-Jel stigla Phantomka?
Rijec,dvije?
Staro 04.06.2011., 11:31   #164
Doink the Clown
Postovi: 6,214
Autor Tomek32 Pregled postova
Rijec,dvije?
Mislim da ću je u ponedjeljak pokupit, stay tuned
Staro 05.06.2011., 09:17   #165
gjokic
Datum registracije: Jun 2011
Lokacija: Pag
Postovi: 59
Decki meni jucer stigla GAINWARD GTX570 GS
evo par slikica jos je nisam spojio najvjerojatnije sutra
pa vam malo javim kako radi
Zadnje izmijenjeno od: gjokic. 22.10.2015. u 18:07.
gjokic je offline   Reply With Quote
Staro 05.06.2011., 12:05   #166
Brlja
Postovi: 874
Autor gjokic Pregled postova
Ta ide na bar 950MHz .
Brlja je offline   Reply With Quote
Staro 05.06.2011., 12:25   #167
Tomek32
Tomek32's Avatar
Postovi: 149
Lik ima 1366 proc i 1156 plocu.i7 980 i P7P55D Evo.
Pa kak to radi covjece ?
Opasna kartica,ali mislim iznad 900mhz je apsolutno nepotrebno,osim ak nemas neki 30",a kolko vidim imas 23",tako da...
Javi temperature i buku!
Staro 05.06.2011., 15:23   #168
Brlja
Postovi: 874
Baš vrtim Kombustor da vidim stabilnost na 880MHz na 1050mV i jedan od ventilatora stvara zvukove ko cvrčak. Primjetno već i na 2000rpm. Valjda ležaj prdnuo.
Sad, s jedne strane nosio bi je na garu (ak se to prizna pod garanciju) a s druge strane se bojim da mi ne daju drugu jer ova se poprilično dobro kloka (valjda dobar čip). Nikako na zelenu granu s tim grafama.
Edit: Eto 10 minuta na Kombustoru 1920x1200 4xMSAA.
Staro 05.06.2011., 15:39   #169
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
NHF ali kakvo isusovo klokanje ? . Nosi to na garanciju dok ti ne stane vent jednom, ne's primjetit i krepat ce ti.
Staro 05.06.2011., 17:31   #170
gjokic
Lokacija: Pag
Postovi: 59
sorry krivo sam napisao imam i7 870 1156 socket
pozz
Staro 05.06.2011., 21:15   #171
Brlja
Postovi: 874
Autor xulos Pregled postova
Misliš zašto to klokanje općenito ili sada zbog venta? A gle, ne čuje se to tako jako. Mislio sam snimit pa se na snimci ne čuje. Vidit ću, ak se pogorša odnijet ću na zamjenu. Živcira me jer se dugo čeka a nemam zamjenu.
Staro 05.06.2011., 21:45   #172
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Mislim na to kakve veze koliko je dobar cip? Kao nemozes na stocku vrtit sve igre, a i kao puno kvalitetnih igara ima za vrtit danas, da se ubijes.Nabavi neku jeftinu grafu cisto da imas za rad a ovo nosi na garu.
Staro 05.06.2011., 22:44   #173
Brlja
Postovi: 874
Ma ne vozim ju OCanu. To mi je samo jedan profil na Afterburneru s kojim se zabavljam tu i tamo kad mi je dosadno, tipa dok kud će na 1050mV pa malo vrtim Kombustor i igram Far Cry 2.
A za vent, to ću vidjet kaj ću, možda sačekam da se pogorša malo, i da crkne jedan vent čujem kak se drugi ubrzava pa odmah idem gledat temp, uglavnom ne bojim se da će mi grafa izgorit.
Staro 06.06.2011., 08:20   #174
gjokic
Lokacija: Pag
Postovi: 59
decki evo da i ja napisem dojmove za svoju gtx570 GS
vrhunska izrada kartice tesko mi je je bilo instalirat u kuciste gdje se ne vidi
ali niti par minuta nakon stratanja kompa odmah je gore isao msi afterburner i clokanje je pocelo
za sada sam na
naponu od 1.038 mV,
taktu GPU od 880 MHz,
i memorije 4200 MHz
testirao sam sa msi kombustorom skoro 30 minuta,
odvrtio 10-tak 3dmark11 za redom skroz stabilna
a najveci test mi je bio dva sata igranja Bad Company 2 sve na ultra high kada se kartica zagrijala na max. 78°C a ventilator je bio na 68%
ja sve u svemu presretan
pozz
Staro 06.06.2011., 08:57   #175
Doink the Clown
Postovi: 6,214
za sada sam na
naponu od 1.038 mV,
i memorije 4200 MHz
pozz
Još da si nabacio i koji rez 3DM11 gdje bi ti bio kraj?
Staro 06.06.2011., 11:59   #176
Brlja
Postovi: 874
za sada sam na
naponu od 1.038 mV,
i memorije 4200 MHz
pozz
Odličan čip. Daj mi reci koju voltažu uzima na deffault clocku?
Staro 06.06.2011., 19:49   #177
Doink the Clown
Postovi: 6,214
Stigla bebica
Pošto moram odraditi generalno čišćenje kućišta i zamjenu paste na procu pa tek onda ubacujem grafu a danas stvarno ne stignem to sve onda će prikapčanje nove beštije na struju pričekati koji dan (jbg, nisam baš sretan zbog toga ali tako je kako je ). Za sada dojam - stvarno impresivan komad
Staro 06.06.2011., 22:11   #178
gjokic
Lokacija: Pag
Postovi: 59
super izgleda
svaka cast na kupovini
pozz
Staro 07.06.2011., 19:20   #179
Alfa_R
Alfa_R's Avatar
Postovi: 2,924
Jeli grizeš nokte?
Kartica je zvijer....
Staro 07.06.2011., 20:18   #180
Doink the Clown
Postovi: 6,214
Autor Alfa_R Pregled postova
Jeli grizeš nokte?
A čuj, nije mi lako gledati ju u kutu sobe zatvorenu u kutiji ali nadam se da će se do kraja tjedna veselo grijati u Obsidianu
Btw. upit za vlasnike GTX-ice: koje drivere imate instalirane? Malo sam ispao iz štosa pa da ne bi bilo da stavim neki nestabilan forceware...
Zadnje izmijenjeno od: Doink the Clown. 07.06.2011. u 20:41. Razlog: typo
