Datum registracije: May 2011
Postovi: 5
svaki put kad igram neku igru mi se pojavi blue screen
Molim pomoć, nakon što restartam komp dobijem slijedeću poruku: Additional information about the problem: BCCode: f4 BCP1: 0000000000000003 BCP2: FFFFFA8006CBF610 BCP3: FFFFFA8006CBF8F0 BCP4: FFFFF80002B9EF40 OS Version: 6_1_7601 Service Pack: 1_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\052311-13625-01.dmp C:\Users\ZORAN D\AppData\Local\Temp\WER-25578-0.sysdata.xml Računalo Tip računala ACPI x64-based PC Operativni sustav Microsoft Windows 7 Ultimate Instalirani Service Pack Service Pack 1 Internet Explorer 8.0.7601.17514 DirectX DirectX 11.0 Procesor DualCore AMD Athlon 64 X2, 3120 MHz (15 x 208) Naziv matične ploče ASRock ALiveNF5SLI-1394 (3 PCI, 1 PCI-E x1, 3 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394) Chipset na matičnoj ploči nVIDIA nForce 560 SLI, AMD Hammer Sistemska memorija 4096 MB (DDR2-800 DDR2 SDRAM) DIMM1: Kingmax KLDD48F-B8KY6 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) DIMM2: Kingmax KLDD48F-B8KY6 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) DIMM3: Corsair XMS2 CM2X1024-6400 1 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-13 @ 270 MHz) DIMM4: Corsair XMS2 CM2X1024-6400 1 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-13 @ 270 MHz) Tip BIOS-a AMI (04/09/08) Komunikacijski port Communications Port (COM1) Komunikacijski port ECP Printer Port (LPT1) Grafička kartica NVIDIA GeForce 8800 GTS (320 MB) 3D akceleratorski čip nVIDIA GeForce 8800 GTS Monitor Philips 220WS (220WS8) [22" LCD] (CU10731064107) Zvučna kartica Speakers (PnP Audio Device Diskovni podsustav IDE kontroler Standard Dual Channel PCI IDE Controller IDE kontroler Standard Dual Channel PCI IDE Controller IDE kontroler Standard Dual Channel PCI IDE Controller Tvrdi disk WDC WD6401AALS-00L3B2 ATA Device (596 GB, IDE) Optički uređaj Optiarc DVD RW AD-7241S ATA Device (DVD+R9:12x, DVD-R9:12x, DVD+RW:24x/8x, DVD-RW:24x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM) SMART status tvrdih diskova OK Particije C: (NTFS) 79899 MB (13080 MB slobodno) D: (NTFS) 518.0 GB (198.4 GB slobodno) Ukupna veličina 596.1 GB (211.2 GB slobodno) Ulazni uređaji Tastatura HID Keyboard Device Tastatura Standard PS/2 Keyboard Miš HID-compliant mouse Miš Microsoft PS/2 Mouse FireWire kontroler VIA VT6308 Fire IIM IEEE1394 Host Controller (PHY: VIA VT6307) USB1 kontroler nVIDIA nForce4 SLI (CK8-04) - OHCI USB 1.1 Controller USB2 kontroler nVIDIA nForce4 SLI (CK8-04) - EHCI USB 2.0 Controller DMI proizvođač BIOSa American Megatrends Inc. DMI verzija BIOSa P1.50 DMI proizvod matične ploče ALiveNF5SLI-1394 |
Lokacija: Čepin
Postovi: 1,522
Koji je točno naziv procesora ? Čini mi se da si radio OC proca (ispravi me ako griješim ) i da je to uzrok pojavljivanju BSOD dok je pokrenuta igra . |
Postovi: 5
ovo su svi podaci koje sam uspio izvuči za procesor Informacije o procesoru Procesor DualCore AMD Athlon 64 X2, 3120 MHz (15 x 208) Jezgra procesora Windsor CPU stepping JH-F3 Podržani setovi instrukcija x86, x86-64, MMX, 3DNow!, SSE, SSE2, SSE3 Originalna frekvencija 3000 MHz Min / Max CPU množitelj 4x / 15x Engineering Sample Ne L1 cache za kod 64 KB per core (Parity) L1 cache za podatke 64 KB per core (ECC) L2 cache 1 MB per core (On-Die, ECC, Full-Speed) Multi CPU CPU #1 AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, 3119 MHz CPU #2 AMD Athlon(tm) 64 X2 Dual Core Processor 6000+, 3120 MHz Fizikalne informacije o procesoru Tip pakiranja 940 Pin uOPGA Dimenzije 4.00 cm x 4.00 cm Broj tranzistora 227.4 milijuna Tehnologija izrade 9Mi, 90 nm, CMOS, Cu, DSL SOI Veličina silicijske pločice 230 mm2 Napon jezgre 1.100 - 1.400 V I/O napon 1.2 V + 2.5 V Zauzeće procesora 1. CPU / 1. jezgra 0 % 1. CPU / 2. jezgra 1 % Ja nisam ništa radio ,ne kužim se baš u kompove ,samo osnove + google Zadnje izmijenjeno od: domy_os. 24.05.2011. u 11:37. Razlog: spajanje postova |
Lokacija: Čepin
Postovi: 1,522
Originalna frekvencija tvog procesora je 3000 Mhz dok je kod tebe ta frekvencija 3200 Mhz . Iz toga zaključujem da ti je procesor OC-an + vidim da imaš različite module memorije (različite proizvođače) sa različitim latencijama . DIMM1: Kingmax KLDD48F-B8KY6 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) DIMM2: Kingmax KLDD48F-B8KY6 1 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) DIMM3: Corsair XMS2 CM2X1024-6400 1 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-13 @ 270 MHz) DIMM4: Corsair XMS2 CM2X1024-6400 1 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-13 @ 270 MHz) Pokušaj za početak izvaditi 2 modula (istog proizvođača) pa pokreni igru . Izvadi npr oba modula corsair memorije pa pokreni igru . Javi ako ponovo budeš imao BSOD "Blue Screen of Death" |
Postovi: 5
Pokušat ću sad izvaditi 2 modula memorije ,pa javim kako je prošlo ,a sad sam bio nešto gledao po Action Centru i izvukao slijedeće error reporte Windows Problem: Video hardware error Files that help describe the problem: WD-20110414-1644.dmp sysdata.xml WERInternalMetadata.xml View a temporary copy of these files Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer. Windows Problem: Video hardware error Files that help describe the problem: WD-20110519-2029.dmp sysdata.xml WERInternalMetadata.xml View a temporary copy of these files Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer. Windows Problem: Shut down unexpectedly Files that help describe the problem: 052211-12359-01.dmp sysdata.xml WERInternalMetadata.xml View a temporary copy of these files Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer. Windows Problem: Shut down unexpectedly Files that help describe the problem: 040811-42281-01.dmp sysdata.xml WERInternalMetadata.xml View a temporary copy of these files Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer. |
Postovi: 5
Izvadio sam 2 modula memorije Kingmax i sad sve šljaka hvala Zadnje izmijenjeno od: zoletan. 24.05.2011. u 20:14. |
Postovi: 5
Izvadio sam 2 modula memorije Kingmax i sad igre šljakaju bez problema ,al sam kasnije pokušao pokrenuti program Combofix i opet sam dobio BSOD A taman sam pomislio da je sve ok... |
Lokacija: Čepin
Postovi: 1,522
Možda bi bilo dobro da staviš win 7 bez service pack-a ! Tko zna što si skinio sa neta i kakve sve probleme nosi taj service pack 1 (znaš dobro o čemu pričam ) napravi to što sam ti rekao pa se onda javi da vidimo dali je sve u redu ! |
Datum registracije: Aug 2009
Postovi: 19
Imao sam problema sa BSOD prije i nosio sam na servis računalo, no nikada nisu otkrili problem dok nisam uzeo stvar u svoje ruke. Kasnije sam otkrio da mi u servisu nisu ni mogli pomoći. Kako se sjecam koristio sam Debugging Tools from Microsoft za koje sam prije instalacije morao instalirati paket specijalnih simbola, također od MS-a, kako bi alatka mogla prikazati rezultate. Na kraju tih kratkih testova, koje se baziraju oko tog crash dumpa koji ostaje nakon pada sustava, otkrio sam točno koji file uzrokuje BSOD. Ne sjecam se točno ali primjerice shge.exe. Ukucao sam u google i otkrio da je to driver od zvučne kartice (eksterne, koju naravno nisam nosio na servis s računalom) i samo sam obrisao driver jer tada još nije bilo drivera za win7. Nakon toga više nisam imao problema, ali sam bar naučio kako analizirati što točno uzrokuje BSOD. Eto nadam se da sam ti ovime bar malo pomogao ![]() |
Datum registracije: Apr 2011
Postovi: 3,784
Sve je to OK, nek pusti memtest...al ne bi bilo prvi put da se s ddr2 vrti memtest cijeli dan bez errora, a u Windowsima BSOD nakon 2 sata rada (imal sam par slučajeva). Imam jednog Kingmaxa koji se upravo tak ponaša (sav hardware, driveri, latencije, voltaže...OK) @zoletan Uđi u bios (odmah dok upališ računalo tiskaj F2 na tipkovnici), pojavi ti se ekran (na vrhu piše "bios setup utility"), vide se izbornici: main, advanced, h/w monitor, boot, security i exit, odi u exit i odaberi "load optimal defaults" (potvrdi s OK), zatim odi na "save changes and exit" (potvrdi s OK) Pretpostavljam da nema nikakve veze s tvojim problemom...grafa mora biti u bijelom PCI Express slotu (žuti su za SLI) Zadnje izmijenjeno od: ShanTech. 27.05.2011. u 10:34. |
