Staro 20.05.2011., 19:52   #1
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Arrow Problem sa dual-bootom (Windows 7 x64 i Ubuntu 11.04 x64)
Na kompu imam instalirana dva OS-a:
Windows 7 Ultimate x64
Ubuntu 11.04 x64
Dual-boot radi ok, ali je problem kada hocu unutar OS-a odabrati default OS.
Znaci ovo u Windowsima:
Advanced system settings -> Advanced -> Startup and Recovery -> Settings
Ovdje pod "Defaul OS" nemam nista tj. stoji mi sve prazno!? Prije mi je uvijek tu stajala lista OS-eva te sam si tu namjestio default OS i vrijeme koliko je lista dugo pokazana kod boota.
Probao sam instalirat EasyBCD no ni on ne nalazi OS tj. evo sta mi on izbaci:
Klikni za screenshot!
Dali ima tko savjet kako da dodem do liste OS-eva....dali mogu bar "rucno" to nekako sredit tj. kroz registry ili cmd?
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
Staro 20.05.2011., 21:14   #2
nino
nino's Avatar
Postovi: 12,613
Koliko se sjecam, cini mi se da win boot loader "vidi" samo win os-eve, xp,vistu.
Staro 20.05.2011., 21:14   #3
Facelessone
Facelessone's Avatar
Postovi: 4,205
Default OS odaberi u GRUB-u a ne u Windowsima, jer se GRUB nasere prije WIN bootloadera.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 20.05.2011., 21:17   #4
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
Jel ti defaultni boot loader GRUB?
Ako bas zelis koristiti ovaj od windowsa, tu nazalost ne znam pomoci jer sa EasyBCD-om nisam nikad uspio nista postici - uvijek bi rezultiralo time da mi sve zezne Iako, vidim da ljudi imaju dobrih iskustava, tako da sam vjerojatno ja nesto lose radio.
Ako zelis u grubu postaviti defaultni OS, editiraj file /etc/default/grub (ono GRUB_DEFAULT, ako je na 0 onda je defaultni kod boota prvi na listi) i onda pokrenes update-grub.
Staro 20.05.2011., 23:04   #5
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
@ win32
Ako sam to dobro shvatio onda preko GRUB-a to nije problem. U Ubuntu-u nađi opciju pod Control Center/System/Start-Up Manager i tamo si odaberi glavni OS, odnosno koji će se prvi učitat pri bootanju. Također možeš i vrijeme štimat.
Jučer je i meni rendula objasnio ovo s editiranjem fajla, ali sam kasnije naišao na ovo koje je mnogo jednostavnije.
Osobno sam na Mintu, no ta opcija bi morala postojat na Ubuntu.
Evo i SS (sry na "stručnom" označavanju ) :
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
