Premium spammer
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Nvidia Forceware v275.27 beta driveri
This is the first release from the Release 275 family of drivers (versions 275.xx to 279.xx). You can read more about this family of drivers on GeForce.com. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs. This driver package also includes the 3D Vision Controller driver. New in Release 275.27 GPU Support Adds support for the newly released GeForce GTX 560 GPU. Performance Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v270.61 WHQL drivers. The following are some examples of improvements measured on Windows 7. Results will vary depending on your GPU and system configuration: GeForce GTX 580: Up to 4% in Crysis 2 Up to 5% in Civilization V with SLI Up to 9% in Portal 2 Up to 13% in Bulletstorm with Antialiasing enabled Up to 15% in Batman: Arkham Asylum with PhysX High GeForce GTX 560: Up to 6% in Crysis 2 Up to 8% in Portal 2 Up to 14% in Batman: Arkham Asylum with PhysX High Up to 15% in Bulletstorm with Antialiasing enabled Najzanimljivije: Increases gaming performance by up to 12% for dual-core CPUs in CPU-limited cases. Win7 64bit: http://www.nvidia.com/object/win7-wi...ta-driver.html Win7 32bit: http://www.nvidia.com/object/win7-wi...ta-driver.html ostali: http://www.nvidia.com/Download/Find.aspx?lang=en-us |
...samo te gledam...
Postovi: 2,835
Neka, barem se trude ovi čudaci u Nvidiji. Ja ću ipak pričekati službenu verziju, za sada mi je zadnja verzija odlična. |
Datum registracije: Dec 2010
Postovi: 147
Fermi arhitektura je poznata po problemima sa nekim starijim CPU-ovima (prvenstveno C2Q i C2D, i stari Phenomi I). Kartice znaju imati nizak GPU Load i time očajne perfomanse. Valjda su poslsuaju jauke na sluzbenim forumima pa su sada malo poradili na tome, pa navode kao changelog. |
#5 | |
Premium spammer
Lokacija: D.Zagora
Postovi: 776
nadan se da ću bit u mogućnosti nabavit neko kvalitetno. Gledat cu da ima 550W+, 2x8pin PCI-E, 5+ onih za sata diskove, 8pin za cpu ispod toga nenabavljam :P tako da će mi tribat dobrin love, a bio san se ponada osvojit na nagradnoj igri sta je bila ovdje ![]() edit: sorry na OT |
Postovi: 2,523
masni OT, al eto nek se obrise ako je problem @Nick7, nije uopce problem u 400w, problem je u MS industrial napajanju za koje se zna da je bolje da imas neko no-name nego njih ![]() super da drzi, mora da se zalomio neki "bolji" primjerak ![]() |
Postovi: 346
? NVIDIA Update In Release 275, NVIDIA Update adds automatic SLI, multi-GPU, and antialiasing (AA) profile updates. These profile updates are automatically downloaded from NVIDIA and silently installed on your PC, keeping it up-to-the-minute with the latest game profiles. When you install a Release 270 or later GeForce driver from www.nvidia.com, you will be presented with the option to install NVIDIA Update. Click here to learn more about NVIDIA Update. |
Postovi: 2,835
Već i prethodna 270 verzija ima mogućnost provjere i instalacije novije verzije drajvera. Vidi HELP/UPDATES ako imaš 270 verziju. |
Postovi: 2,835
Kod Nvidie funkcionira sistem da samo pregaziš staru verziju s novom. |
