Postovi: 191
Firefox 4 problem
Pozzzz... Instaliro sam firefox 4 i desava mi se nes cudo. Imam otvoren firefox na ekranu. I da npr otvorim Win explorer, posle 2,3 sekunde ničim izazvan, firefox ce mi se podizat i spustat preko Win explorera non stop i nemmrem napravit. Stvar je ok kad firefox minimiziram, onda se ne podize. Ali kad je maximiziran i bilo sta oda otvorim, bilo koji program, firefox mi se digne i zajebe stvar... hlp
vip |
skini ekstenziju "Minimize to tray revived" i poštelaj da ti se FF minimizira u tray i nećeš imati tih problema. |
Postovi: 191
ne al ne zelim svaki put minimizirat firefox. Zelim da on bude na ekranu al da mi se ne pojavljuje preko drugih programa.. mozda nisam dobro objasnio...naso sam da jos jedan tip ima isti problem...mozda ovak se boje pojasni Firefox keeps taking over my screen! I have been having a very annoying issue with Firefox since downloading Firefox 4. Frequently when I switch from Firefox to another application, after a few seconds the Firefox screen will "take over," even though it does not show up as the selected program in the taskbar. Basically it's just the image of the Firefox window that takes over my screen, not the application (I can't, for example, click on anything that appears), and I have to toggle back and forth between programs in the takbar to get back to the window of the application that I was using. I never had this problem before, but it happens very often now. Is this happening to anyone else?
vip |
Postovi: 1,673
low_rider
Postovi: 486
Pozdrav..evo da se i ja nadvežem na još jedan bug u ff4 a da ne otvaram novi thread. Ne znam dali je već negdje to spomenuto ali nakon određenog vremena surfajući u firefoxu 4, strelica miša doslovno popi.di! Poćne blinkat, nestajat i slićne gluposti. Moram ga zatvorit i ponovno pokrenut. Ni u jednom drugm programu nemam ovakih manifestacija pa pretpostavljam da je do nove quattro verzije. Ima li netko slićnih problema?
A bu bu.... |
