Zaključane teme
Staro 06.05.2011., 19:43   #1
TomislavKt
Datum registracije: May 2011
Lokacija: Kutina
Postovi: 2
Molim pomoc
Ljepi pozdrav,
problematika je slijedeca. Netko mi je haknuo dva facebook racuna (privatni i od kluba) i isto tako i gmail adrese na koje su registrirani ti racuni.
Naravno taj šaljivdjija je postavio i sigurnosno pitanje na gmailove koje glasi na privatnom: "dobar haker ha" a na klupskom "jeben haker ha?".
Molim pomoć ako je ikako moguće da ponovno steknem kontrolu nad tim računima. Pogotovo na ovom fb od kluba.
Puno hvala!
TomislavKt je offline
Staro 06.05.2011., 19:48   #2
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Veki-os je offline
Staro 06.05.2011., 19:51   #3
TomislavKt
Lokacija: Kutina
Postovi: 2
Autor Veki-os Pregled postova
This Connection is Untrusted
You have asked Firefox to connect
securely to www.facebook.com, but we can't confirm that your connection is secure.
Normally, when you try to connect securely,
sites will present trusted identification to prove that you are
going to the right place. However, this site's identity can't be verified.
What Should I Do?
If you usually connect to
this site without problems, this error could mean that someone is
trying to impersonate the site, and you shouldn't continue.
Technical Details
I Understand the Risks
If you understand what's going on, you
can tell Firefox to start trusting this site's identification.
Even if you trust the site, this error could mean that someone is
tampering with your connection.
Don't add an exception unless
you know there's a good reason why this site doesn't use trusted identification.
Staro 08.05.2011., 09:16   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
tor je offline
Zaključane teme
