#151 | ||||
8-bit Gen.
Lokacija: Giethoorn - ZG
Postovi: 3,159
To me izgleda odvelo na krivu pomisao. Citiraj:
Kilavi li se AMD 900-tka izvan spomenutih datuma? Ili jos unutar najava? Bilo bi lijepo vidjeti vec koju plocu. |
#152 |
Datum registracije: Mar 2009
Lokacija: Sk-Zg
Postovi: 1,097
Ima li koji noviji bench na netu? Bulldozer Shines in 3D Gaming and Rendering
Zadnje izmijenjeno od: McG. 06.05.2011. u 23:28. |
#154 |
Postovi: 7,568
Radeon HD 6550 u Llano APU modelima
AMD's upcoming Llano line of accelerated processing units (APUs), to compete with Intel's Sandy Bridge LGA-1155 processors, is said to embed what AMD will refer to as the Radeon HD 6550 graphics core. Unlike Sandy Bridge where a processor die is simply fused with a integrated graphics northbridge onto a single die, Llano will see the GPU part of the silicon integrated with the rest of the APU in many other levels, including assisting the x86 cores with serial processing loads. Llano's embedded GPU carries the AMD Radeon SKU of HD 6550. It will feature on AMD's Fusion A8-3550 and A8-3550P APUs, is DirectX 11 compliant, has 400 stream processors, and a core clock speed of 594 MHz. It uses memory shared from the main memory, but in all likelihood, AMD might work on SidePort-based memory support. Further, the Radeon HD 6550 can work in tandem with discrete AMD Radeon HD 6570 and HD 6670 "Turks" based graphics cards in the same way as AMD's IGPs have been known to work with entry-level Radeon GPUs using Hybrid CrossFireX. When the HD 6550 iGPU is working in tandem with HD 6670 or HD 6570, the graphics hardware will be recognized as "Radeon HD 6690".Izvor: techPowerUp |
#156 |
matori
Datum registracije: Feb 2011
Lokacija: ZADAR
Postovi: 169
Pa, strpi se još ovih misec dana. AMD je službeno potvrdio da 1.-og na azijskom Computex 2011. prvi na scenu stupa LIano i 9xx chipset, a onda 7.-og u LA na scenu stupa FX BD i nove AM3+ ploče. Zadnje izmijenjeno od: McG. 06.05.2011. u 23:28. |
#159 |
Lokacija: VG
Postovi: 1,758
Ako pricekas mozes biti samo u duplom dobitku, ili ce novi bull biti bolji i brzi ili nece ali ce srusiti cijene sandya, barem za malo. Mjesec dana zbilja nije puno, pogotovo ako planiras dati par kila kn za novi stroj kojic es koristii tko zna koliko dugo! Citiraj:
Zadnje izmijenjeno od: McG. 06.05.2011. u 23:37. |
#160 | ||
Anything Goes Martial Art
Lokacija: Tendo Dojo
Postovi: 542
"Water! Why does it always have to be water?!" Zadnje izmijenjeno od: McG. 06.05.2011. u 23:40. |
#162 |
Postovi: 5,991
Moje jedino ocekivanje je dobar "bang for buck" i nista drugo. Ako uspiju dosegnut performanse LYnfielda ili sl., "clock per clock" sa svom silom jezgri, bit ce to jako konkurentni procevi. Sam broj jezgri jos uvijek nije garancija performansi a kako ce se "hardwerski HT" ( cini mi se ko dobar naziv za takav nacin slaganja) snaci u svemu je za mene najveci ?. Pogotovo u situacijama gdje broj jezgri nije presudan faktor a toga ima jos uvijek podosta. Zadnje izmijenjeno od: McG. 06.05.2011. u 23:40. |
#163 | |
Lokacija: VG
Postovi: 1,758
Samo je pitanje cijene, a u svemu tome nekako me najvise veseli 6 jezgreni Phenom II za kilu kuna ![]() AMD lowers processor prices Pogle ovo: Citiraj:
Zadnje izmijenjeno od: McG. 06.05.2011. u 23:36. |
#164 |
Postovi: 5,991
TI SSovi mi nista ne znace. Rezultati u Vantageau sa integrusama mi nisu bitni u zivotu. Iz aviona je vidljivo da imaju puno jacu integrusu i da po tom pitanju sigruno jedu Intel za dorucak ali mene to ne interesira jer imam gtx 580. Dobar deal bi bio da ta integrusa ima dovoljno snage da prozvace neke razumne rezolucije i igre i nekome bi to sigurno bila savrsena kombinacija, iganje do 1680x1050 sa medium detaljima i u tom stilu. Zadnje izmijenjeno od: McG. 06.05.2011. u 23:40. |
#165 |
Datum registracije: Aug 2010
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
A čuj, nećeš propast ako se strpiš još malo. Ja bi rađe pričeko Buldoždera, možda bude bolji od intela, a i vrlo vjerojatno će cijene SandyB. pasti. Tako da, moj savjet ti je da pričekaš još mjesec dana, nije to neko strašno vrijeme niti ćeš nešto strašno izgubit ako se baciš u čekanje, baš suprotno možeš samo dobit. ![]() |
#166 | |
Lokacija: VG
Postovi: 1,758
Zadnje izmijenjeno od: McG. 06.05.2011. u 23:38. |
#167 |
Postovi: 375
Vrlo vjerojatno cu si na jesen slagati novu konfu i sigurno ce to biti am3+ konfiguracija. zasto? zato sto mogu piknuti neki 4-jezgreni bulldozer za normalnu cijenu (ne skuplje nego neki i5), a sigurno ce podrska za socket biti puno dugotrajnija nego na intelovoj strani i u trenutku kada ce mi doista trebati bolji proc, moci cu promijeniti bez da mijenjam cijelu konfiguraciju. |
#168 | ||
Postovi: 542
"Water! Why does it always have to be water?!" Zadnje izmijenjeno od: McG. 06.05.2011. u 23:39. |
#169 |
Postovi: 7,568
Inženjerski primjerak AMD Llano FM1 ploče
We've seen pictures of the FM1 socket, the FM1 CPUs and even the mobile test board from AMD, but what we have for you today is the first picture of AMD's FM1 desktop test board. Please keep in mind that this is not an indication of what final production motherboards will look like, nor does it represent a final product by any means, but what it does give us is a glimpse into what AMD's Fusion motherboards for the FM1 socket will have to offer. As you can see from the picture, AMD's test board doesn't exactly look like a retail board and it has a lot of test points for oscilloscopes and other types of test equipment. However, what we can see is that the board has native USB 3.0 support thanks to the internal USB 3.0 header so this is most like an FCH A75 based board. As it should be, it's a single chipset board, although it appears that the FCH A75 requires active cooling which is somewhat disappointing. That said, hopefully a larger passive cooler will be enough on retail boards, or at least that's what we're hoping for.Izvor: VR-Zone |
#170 |
Postovi: 542
meni se baš sviđa zeleni PCB. da je malo ispranije boje bio bi ko Epoxica inače u prethodnom postu od blufluida mi je zapo za oči ovaj detalj: "and only includes those chipset models that rely on discrete graphics (leaving out AMD 980G, 990GX)." znači li to da će ipak biti chipseta sa integrušom na ploči, samo što ih Asus neće sad, ili ikad, izbaciti na tržište?
"Water! Why does it always have to be water?!" Zadnje izmijenjeno od: McG. 01.09.2011. u 21:43. |
#171 |
Postovi: 7,568
Llano dolazi s svojim AMD A75 i A55 čipsetima, a pošto Bulldozer modeli nemaju IGP, nema potrebe za G i GX izvedbama čipseta. 980G se prije pojavil na jednom od roadmap screenshota, ali to je bilo to. Kasnije ni traga ni glasa, samo 970 i 990 non-IGP verzije za Bulldozere. |
#172 |
Postovi: 542
znam za to, ali me rečenica iz onog linka malo cimnula jer se može dvojako shvatiti. a o ovome da na BD pločama nema potrebe se još da raspravljati. BD i LLano nisu baš ista kategorija procesora i meni osobno ne stoji logika "ako želiš IGP onda moraš uzeti i slabiji proc". imho. ukoliko su razlozi za odustajanje od IGP-a na 9xx chipsetima tehničke prirode onda je to druga priča.
"Water! Why does it always have to be water?!" |
#173 |
Postovi: 7,568
Možda ti ne paše ta logika, ali AMD-u i Intelu paše itekak. Zarada i samo zarada. Mogu oni staviti IGP na/u kaj god ih volja, ali onda nema te raznolikosti između proizvoda koja ih prodaje.Opet s druge strane, oni koji namjeravaju kupiti Bulldozer bi se žalili da kog vraga će im IGP u takvim procesorima i začarani krug je tu. AMD: Bobcat za embedded sisteme, Llano s IGP-om + FM1 socket za srednji i viši tržišni segment, te naposljetku non-IGP Bulldozer + novi AM3+ socket za high-end i enthusiast.Ovisno o potrebama, ljudi budu kupili ono kaj im najviše odgovara, a marketing bude se pobrinul da se isforsira novi socket i novi LGA i ljudi budu na ovaj ili onaj način kupili određeni proizvod, mada im možda ne treba sve kaj taj nudi. Pogledaj samo kak je završil LGA-1156 koji je do prije godinu-godinu i pol bil jako poželjan i konstantno preporučivan, a danas se skoro više i ne nudi u trgovinama, a preporuke su kompletno nestale. LGA-1155 ga je "pokopal" unutar nekoliko mjeseci postojanja i usprkos problemima s čipsetima. Da ne spominjem kak su svi pričali da je glupost kupovati procesor s IGP-om, ako im to ne treba, a onda uredno nabavili prvo LGA-1156 platformu, a kasnije prešli na novi LGA-1155. Ista stvar s AMD-om, jer kolko god ljudi negodovali radi ovog ili onog, na kraju kupe ono kaj se nudi. Zadnje izmijenjeno od: McG. 08.05.2011. u 17:38. |
#176 |
Postovi: 542
@McG možda se nismo skužili ali kad kažem IGP ne mislim na on-chip grafiku tipa Sandy ili LLano već kao u 890G chipsetima, integrušu na ploči. iskreno ne vidim što bi nekome smetala integrirana grafička na ploči koji podržava Bulldozere. kako nikome ne smeta integrušna na 890GX chipsetu? kladim se da je više ljudi, i to entuzijasta, kupilo tu ploču nego neku iz FX serije. jasno je meni sve gore napisano i da će marketing napraviti svoje ali ne vidim nekog pravog razloga niti argumenta zašto ne bi postoajo 9xxG chipset. kao što stef reče, za radne stanice gdje 3D performanse nisu bitne, ili čisto da imaš jednu grafiku viška ako zatreba. ja vidim samo prednosti postojanja i takvog jednog chipseta uz svu plejadu high-end ploča.
#177 |
Postovi: 7,568
Jasno je sve, samo velim su da i na AMD i na Intel strani procesori s IGP-om isključili potrebu za standardnim čipsetom kakav je 880G i 890GX, te svi prije njih. Intel je isto tak fural Gxx čipsete na matičnim pločama, ali čim su stigli prvi Clarkdale, a kasnije Sandy Bridge modeli - klasičnim IGP čipsetima ni traga ni glasa. Meni je tak svejedno da li ploča nudi IGP ili procesor ili jedno i drugo, ali očito da AMD i Intel imaju neke svoje planove i fokus stavljaju na procesore koji dolaze s integriranom grafikom. Ta je pak iz generacije u generaciju sve bolja i samo je pitanje vremena kad iz igre izbaci dobar dio sadašnjih diskretnih kartica iz nižeg dijela tržišta. Evo sad i nove ploče temeljene na Z68 čipsetu podržavaju istovremeno clockanje procesorskih jezgri i integrirane grafike, te samim time sve ploče (bar na papiru) dolaze sa svim potrebnim video izlazima, a opet su vodeći proizvođači najavili (Gigabyte među prvima - 1, 2) da nude ploče koje iako dolaze bazirane na Z68 čipsetu, ne budu imale video izlaze, jer postoji dio tržišta koji je spreman kupiti Sandy Bridge i kasnije Ivy Bridge, a ne žele da im ploča nudi mogućnost iskorištavanja tog IGP-a, pa makar je u pitanju dekodiranje videa. Lud, zbunjen i nimalo normalan. ![]() Da ne spominjem kak je danas većina ljudi još uvijek uvjerena da ploče s klasičnim IGP čipsetom i ovi novi procesori s IGP-om, ne valjaju i da je to namijenjenom trećerazrednim proizvodama i kupcima koji nemaju za bolje. Možda AMD sklepa kakav 980G ili 990GX, pa ga proizvođači iskoriste za svoje workstation i server orijentirane proizvode, ali na ovom tržištu za "gamere" i "clockere", već imaju spremne nove generacije proizvoda i kolko se da skužiti oba proizvođača idu dalje bez klasičnih čipseta s IGP-om. |
#178 |
Lokacija: Zabok
Postovi: 3,409
Prave serverske ploče, čak i one AM3, obično imaju posebnu grafiku integriranu na ploči. Neki jednostavni adapter koji obično nije posebno hlađen, čak ni pasivno. Ali za neku radnu stanicu ili "PC server" bi 880G/890GX još uvijek dušu dao. S druge strane, teško da će AMD razvijati više nove IGP čipsete. Zadnje izmijenjeno od: stef. 09.05.2011. u 09:23. |
#179 |
Postovi: 542
@McG mislim da je kod Intelovog Gxx chipseta problem ipak bio i u samim performansama te grafike koja je bila očajna i za običan uredski rad. osim ako se korisnik nije koristio isključio word-procesorima naišao bi na probleme i kod pokretanja web preglednika čim bi se na ekranu pojavio malo zahtjevniji grafički prikaz ili neki flash. po mom iskustvu Intel je neki ozbiljniji korak ka upotrebljivosti svoje on-board grafike napravio tek sa mobilnim X3100 grafikama, ili tu negdje. znam da je ovo mala digresija ali samo želim reći da je bilo i drugih razloga zašto Gxx chipset nije baš usporediv sa današnjom on-chip grafikom koja je zvijer Z68 je nešto druga priča jer ipak podržava i one "najjače" procesore iz serije i integriranu grafiku. ovo da će biti Z68 ploča bez video izlaza mi i nije tako čudno. očito žele smanjit cijenu finalnog proizvoda izbacujući fičure koji neće biti potrebni, samo se onda pitam čemu P-chipseti no dobro, ovo je već bila druga digresija ![]() a ovo da ima ljudi koji će misliti da su chipovi s integriranom grafikom glupost neka im. uskoro možda neće imati ništa drugo za kupiti. ![]()
#180 | |
