#31 |
Lokacija: NaN
Postovi: 3,438
Tako (očito) dobra igra, a tek jedna stranica na threadu. ![]() Jedinica mi je bila pravo osvježenje, a piknut ću dvojku valjda tokom sljedećeg tjedna, jedva čekam. Što se tiče pojeftinjenja, neće to tako brzo sigurno, barem ne na Steamu. Ja još uvijek čekam Dead Space 2, ali još ću se očito načekati (jedino ako neka akcija ne upadne). Zadnje izmijenjeno od: Matth€w. 21.04.2011. u 19:40. |
#32 | |
LateralusX
Postovi: 1,788
#33 | |
Postovi: 82
#34 |
Datum registracije: May 2009
Lokacija: brlog
Postovi: 489
easter egg ili ne svaka im cast ![]() |
#35 |
Datum registracije: Mar 2008
Postovi: 347
#36 |
Postovi: 4,205
Code:
A new update for the PC and Mac versions of Portal 2 is now live on Steam, offering a number of bug fixes. The patch, which will be applied automatically when you restart your Steam client, smooths over a few glitches and makes a couple of minor gameplay tweaks. Here's the full list of changes: Fixed unrecoverable black screen in elevator save Fixed infinite loop on Mac OSX server Fixed Mac OSX font rendering and glyph corruption Fixed GC memory leakVarious localization content improvements Support for English subtitles in Turkish builds Minor string/interface glitches Fixes for multiple crashes Improved detection and handling for various errors and/or crashes Activated UI to enable joystick in-game ![]() edit 2: Code:
! If you lost your saves after installing update, do the following: Go to the root folder of Portal 2; Default – C:\Program Files (x86)\Valve\Portal 2\ Then go to portal2\SAVE; There should be 2 or more folders in there. Open them, until you find the one which has your saves in it, then copy the contents to all the other folders in the save folder.
Zadnje izmijenjeno od: Facelessone. 22.04.2011. u 01:43. |
#37 |
Lokacija: brlog
Postovi: 489
ma i da izgubimo save-ove nema problema..jer je stvarno uzitak prelaziti ovu igru! jedva cekam portal 3 ![]() |
#38 |
Postovi: 347
Završio s igrom. Nije toliko dugo koliko sam se nadao. Većina testva je dosta lagana, za neke je ipak trebalo malo skužiti što gdje i kako. Odlična priča koja se fino nastavlja na prvi dio igre. Humor. Jako sam zadovoljan igrom. |
#39 | |
Lokacija: Ostrovo
Postovi: 351
![]() Btw. prešao ju jednom i odmah ponavljam, pravo osveženje ![]() |
#42 |
Postovi: 347
#43 |
These go to 11
Lokacija: Czarnia
Postovi: 1,854
#44 |
Suit up!
Postovi: 5,975
Predobra igra, Portal 2 je napokon nešto vrijedno igranja ![]() Meni je čak bolja od jedinice jer je dosta koherentnija i više objasni stvari a i Wheatley/GlaDOS kombinacija je komična ![]()
"When I get sad, I stop being sad and be awesome instead. True story." - Barney Stinson Zadnje izmijenjeno od: Mar. 24.04.2011. u 02:19. |
#49 |
Postovi: 751
#50 |
Lokacija: Grobnik - Rijeka
Postovi: 3,254
#51 |
Zvoni. Kucanje ne radi.
Lokacija: ZAGREB DUBRAVA
Postovi: 714
aaa citam sad i ne vjerujem!!!dvojka je vani!!!!yeeees!!! pre pre predobra igrica je jedinica bila,idem sad nabavit dvojku!!!!
Those who believe in telekinetics, raise my hand! |
#52 |
► Play ▌▌ Pause ■ Stop
Datum registracije: Jan 2010
Postovi: 1,179
Na početku igre, sam sam se sebi čudio kako sam glup jer ne kužim igru (IQ=0). Dobro, i onda shvatim treba razmišljati di stvorit portale da se može prelazit s lakoćom. I tako je napokon krenulo... ![]()
#53 |
Lokacija: Sveta Nedelja
Postovi: 24
Ma nije teško, samo treba mislit malo... Inače, tak sam negdje na sredini chaptera 6, nisam baš puno igrala. Ali zakon je igra. ![]()
“I think we can put our differences behind us. For science. You monster.” |
#56 |
Brat od Đon Vejna
Lokacija: zg-vg
Postovi: 1,204
Igra je remek djelo,bolja od vecine danasnjih "hitova". Valve do dana danasnjeg nije izdao losu igru. Jadina zamjerka je lagana monotonija na "oldtimer" djelu igre. inace odlicna zabava, duhovite scene i monolozi, konstantno aktivna radnja. Igra radi na 50-100-150 fpsa ovisno o kadru na max detaljima i rezi (to se zove optimiziranost ) Odigrao sam sad 7 chaptera u komadu, otprilike od 9 sati ![]()
#57 |
Postovi: 347
#58 |
Upravo završio igru. nisam htio ništa pisati dok je ne pređem. Igra je fenomenalna, rekao bih najbolja do sada u 2011. koja je izašla. Najjača mi je "žuta" kugla na kraju: "I'm in space... SPAAAAACEEEE... Space, Woo-hooo... Space, I'm in it..." ![]() ali takva doza humora i genijalnosti nije dugo u jednoj igri izašla. P.S., u prvoj polovici igre, GlaDOS me podsjeća na curu mog kuma. Bitcharka do jaja ![]() |
#59 |
Datum registracije: Aug 2009
Postovi: 637
Ajme kraja kako je dobar!!! Najbolji kraj ikad, svaka im čast. Tek sam sada pročitao da je glas Cave Johnsonu dao J.K.Simmons poznatiji kao Schillinger iz Oza. ![]() I nitko ne pohvaljuje glazbu!?!? Glazba je prepredobra kao i u Half-Lifeu 2. |
#60 |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
