Staro 20.02.2011., 19:37   #31
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Thumbs down Scythe Susanoo
Info - expreview.com (nema jos nista na sluzbenim stranicama)
Za ove specifikacije (dimenzije 210x210x160mm - DxŠxV / tezina 1565g.) imam samo jedan komentar
Cijena prava sitnica od oko 100USD - 4X10cm ventilatora i 12x6mm heatpipeova ipak ima svoju cijenu.
Usput preporucam setup drzati horizontalno na stolu bez kucista (ako uopce postoji big tower dovoljan za ovaj SSSR radijator) i bez ikakvog pomicanja.
Pomelo mi sig -.-
Staro 22.02.2011., 09:24   #32
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Zaward Vapor 120
_____________________
Zalman Intros ZM-F4 135 mm Fan with 120 mm Frame
Zalman rolled out the ZM-F4, a 135 mm case fan that features a 120 mm compatible frame that lets it fit into most 120 mm case fan mounts and CPU heatsinks. Capable of 900 to 1,300 RPM rotational speeds, the ZM-F4 has rated noise levels of 18 to 26 dBA. The advanced sleeve bearing is said to ensure a life-span of 50,000 hours. The fan uses standard 3-pin power input, a bundled resistor cable keeps the fan down to its minimum speed ensuring low noise output. Zalman also opted for rubber pins instead of metal screws to bundle with its fan. Pricing and availability is not known.
C L O W N I N G A R O U N D
Staro 28.02.2011., 10:33   #33
BojanZD
BojanZD's Avatar
Postovi: 1,398
Autor Drvoje Pregled postova
Fijuu, kila ipo`i visoko težište...backplate treba bit iza cijele matične?!
Ludilo...
BojanZD je offline   Reply With Quote
Staro 30.03.2011., 17:14   #34
Postovi: 8,202
Staro 30.03.2011., 17:18   #35
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Prije upotrebe pažljivo pročitajte uputu o lijeku. Za obavijesti o indikacijama, mjerama opreza i nuspojavama upitajte svog liječnika ili ljekarnika. NEOFEN Forte.
Staro 30.03.2011., 18:39   #36
Rebbit
Postovi: 660
mozda budes imo srece pa uspijes ukopcat i optiku s ovim nofenom..
nek sam isti kao on, ma nek sam isti ko stari moj, dok zivot juri, ja cu lagano....
Lenovo Thinkpad T14
Logitech MX Master 2S
Logitech MX Keys
Galaxy S23+
Rebbit je offline   Reply With Quote
Staro 30.03.2011., 19:16   #37
ukiy
ukiy's Avatar
Datum registracije: Apr 2008
Lokacija: ST
Postovi: 398
E bas sam nekidan naletio na review: “Dead Calm”: Nofen Set A40 Fanless System Review
Jako zanimljiv cooler...
ukiy je offline   Reply With Quote
Staro 30.03.2011., 21:03   #38
Doink the Clown
Postovi: 6,214
Autor Pupo Pregled postova
Dobije li se i hrčak uz ovaj kotač?
Staro 30.03.2011., 21:27   #39
ThePornstar
ThePornstar's Avatar
Postovi: 4,401
I o čudo ima 783 grama, nema ni kilu Najs
Mogu si zamislit reakcije i popratna pitanja neupućene ekipe kad bi to vidli u kutiji
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 31.03.2011., 11:48   #40
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,208
Čini se da je kotač za peć kestenje u biti sasvim ok
Bez potpisa.
Staro 02.04.2011., 10:53   #41
Boskre
Boskre's Avatar
Datum registracije: Jun 2010
Postovi: 31
Omg ,omg a što je ,je!
Nekad sam tako uspješno znao složiti tihi komp a sada...
Ova moja kanta sve gora i gora...
Boskre je offline   Reply With Quote
Staro 07.04.2011., 18:11   #42
baban
baban's Avatar
Datum registracije: Aug 2008
Lokacija: DE
Postovi: 591
High Performance CPU Cooler Shootout Q2 2011
..Today's shootout will take several of the latest and (potentially) greatest coolers, of all shapes and sizes, and see what they can do. We will of course be establishing which is the best performer, but we will also be looking at things like build quality, ease of mounting, noise and the price...
http://www.clunk.org.uk/reviews/high...t-q2-2011.html
baban je offline   Reply With Quote
Staro 12.04.2011., 23:14   #43
Doink the Clown
Postovi: 6,214
GELID Announces Slim Silence I-Plus CPU Cooler
Thermal Solutions specialist GELID Solutions adds a 28mm high 1U ultra slim CPU Cooler with high quality heatpipe and premium copper plate to its Silent product line. The “Slim Silence i-Plus” is especially designed to fit Intel most popular sockets such as 775/1156 and 1155. This petite cooler supports an incredibly CPU thermal design power (TDP) up to 82W with a good case ventilation.
With a compact heatsink design for Mini ITX, Micro ATX, ATX, HTPC, Panel PC, Car PC and 1U server the “Slim Silence i-Plus” is equipped with a highperformance heatpipe, premium copper plate and a silent fan.
Thanks to the small but high performance heatpipe and a pure copper plate the “Slim Silence i-Plus” ensures a fast and efficient heat transfer from core to aluminum fins.
The frameless silent fan includes a ball bearing and a GELID intelligent PWM (Pulse Width Modulation) control which ensures a silent operation at low CPU temperature and accelerates the fan speed when necessary.
The “Slim Silence i-Plus” is RoHS and WEEE conform and has a warranty of 5 years.
”This cooler is the perfect choice for HTPC users who are looking for a 1U sized cooler capable of cooling the latest generation of Intel core i3 and i5 CPU’s”, said Gebhard Scherrer co-founder and Sales Director of GELID Solutions Ltd.
The “Slim Silence i-Plus” has a MSRP of USD 26 / Euro 20 and is available now.
http://www.techpowerup.com/143948/GE...PU-Cooler.html
Staro 23.04.2011., 21:36   #44
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,208
Bez potpisa.
Staro 23.04.2011., 21:44   #45
Drvoje
Drvoje's Avatar
Postovi: 4,037
Autor RaneZ Pregled postova
..ovo je uberkill
Prethodna strana, post #172 - mislim da onaj facepalm primjerenije opisuje tu grdobinu
Pomelo mi sig -.-
Staro 23.04.2011., 21:58   #46
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
1.5kg a cito sumnjam da ce hladit ista bolje od 3x manjeg Venomusa sa 2 puta manje ventova.
MAGARAC je online   Reply With Quote
Staro 26.04.2011., 00:03   #47
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
blaa
Staro 14.05.2011., 11:10   #48
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,269
Staro 20.05.2011., 11:20   #49
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Corsair Hydro H80 and H100 coolers to be launched
Yikes a small leak from an etailer exposes some of the stuff Corsair is to launch soon as TC-Mag noticed Corsair will soon introduce two new watercooling kits; the H80 with a 120mm radiation and the H100 with a 240mm rad.
"Both models use two fans. Both upcoming CPU coolers have their fans operate at up to 2600 RPM, they boast a sound output of 22 to 39 dBA, and support Intel LGA 775/1155/1156/1366 and AMD AM2/AM2+/AM3 processors.
According to the now removed store pages, the H80 costs €107, while the H100 is €120". Click on the thumbnail, to enlarge and see what its about.
Izvor: guru3d
Staro 24.05.2011., 13:32   #50
Doink the Clown
Postovi: 6,214
EVGA Intros SuperClock, its First CPU Air Cooler
Here is the first EVGA-branded CPU air cooler, the EVGA SuperClock. Based on the design of Swiftech Polaris 120, the EVGA SuperClock uses nearly the same materials, but uses black-colored fins and heat pipes, apart from an illuminated fan. Like the original, the main heatsink consists of a heat pipe direct contact base, where the five heat pipes make direct contact with the CPU, the pipes in the central portion of the base (which receive most of the heat), propagate from a portion of the aluminum fin array that gets the maximum airflow. The heatsink is ventilated by a 120 mm spinner that lights up red, spins at 750 - 2500 RPM, pushing up to 84 CFM of air. At US $49.99, it's cheaper than the Swiftech Polaris 120, that's priced at $59.99 on the company store.
http://www.techpowerup.com/146276/EV...ir-Cooler.html
U očekivanju konkretnih reviewa...
Staro 30.05.2011., 18:10   #51
hammer_of_thor
Postovi: 5,430
Baš se pitam dali će ga Links nabaviti.
Vani ide po ~75-80$
blaa
Staro 30.05.2011., 18:16   #52
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Nece jer su digli ruke od Thermalrighta.
Staro 30.05.2011., 18:33   #53
Doink the Clown
Postovi: 6,214
Autor MAGARAC Pregled postova
Ha?
Dakle više se ne mogu nabaviti TR hladnjaci kod nas?
Staro 30.05.2011., 18:39   #54
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Onda sam kupio zadnji HR-02 u HR
Staro 30.05.2011., 18:48   #55
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Ja se nadam da ce jednog dana doc opet. Koliko sam cuo, TR je jako tezak za suradnju sa visokim cijenama i jako malom dostupnoscu, pogotovo u ovim krajevima.
Staro 30.05.2011., 18:54   #56
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
ni netreba ih,ima vodenih corsair-a
prt scr je offline   Reply With Quote
Staro 30.05.2011., 19:05   #57
TheBEaST
TheBEaST's Avatar
Postovi: 666
Mislim da nisu baš digli ruke, barem ne u tom smislu riječi. Išla je prije par tjedni narudžba, ali nisu bili dostupni hladnjaci za ovu regiju bar sam ja tako čuo...
Nadam se budu uzimali još, jer mi treba jedan Venomous X Black, a tu ih nitko ne prodaje ... niti rabljene.
TheBEaST je offline   Reply With Quote
Staro 30.05.2011., 19:09   #58
MAGARAC
MAGARAC's Avatar
Postovi: 5,986
Prije ces ga dobit ak ga narucis iz USA, nego ga tu docekat i neces ga ni skuplje platit, pogotovo ak se dogovoris sa jos par ljudi za skupnu narudzbu jer postarina ubija.
Ta prica se ponavlja vec godinama ali ovaj put je najgore do sad, sto se dostupnosti tice.
btw. vodeni Corsair, ekvivalent Venomusu ili sl. ce kostat duplo skuplje pa ko voli nek izvoli. Ovi jeftiniji mu nisu konkurencija.
Archon vs H60 vs H50 vs H60, i7 920, HardOCP..
Rade bi 3c losije temp i tisinu nego satro vodenu zujalicu koja bude male bebe...
Zadnje izmijenjeno od: MAGARAC. 30.05.2011. u 19:59.
Staro 30.05.2011., 19:48   #59
TheBEaST
TheBEaST's Avatar
Postovi: 666
Uzeo bi s nekim kad bi bilo zainteresiranih ljudi.
U ovoj temi s ventilatorima sam probao pokrenuti neku grupnu narudžbu za ventilatore pa ništa od toga kak se čini.
Uglavnom ako ima zainteresiranih ljudi za jedno ili drugo nek se jave...lakše je dok nas je više.
Staro 30.05.2011., 22:12   #60
hammer_of_thor
Postovi: 5,430
Autor TheBEaST Pregled postova
Ako bi se našao kakav seller na ebayu ili online shop koji ima sve što nam treba, ja bi vjerovatno uzeo TR Archona
Da se skupi još 2 ljudi pa podjelimo poštarinu i PDV na carini.
blaa
