Staro 09.02.2005., 22:14   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi Catalyst 5.2
Kako je danas i najavljeno-izašla je najnovija verzija.
Izgleda da je bilo dosta bijesnih korisnika pa su se malo požurili
Mislim-takvo brzo ispravljanje bugova je za svaku pohvalu, vidi se da sad dosta drže do korisnika.
Novosti ima dosta:
New Features
This section provides information on new features introduced in the latest release of the CATALYST™ Software Suite.
The CATALYST™ Software Suite 5.2 introduces 3D setting options to the CATALYST™ CONTROL CENTER system tray. The shortcut allows the user to easily adjust their 3D settings without having to load the CATALYST™ CONTROL CENTER.
The 3D setting submenu will be found in the Adapter menu of the system tray. When a user selects the 3D submenu option, the following options will be made available:
Anti-Aliasing. Application managed options include, 2X, 4X, 6X, and Enable Temporal Anti-Aliasing
Anisotropic filtering. Application managed options include, 2X, 4X, 8X, and 16X.
CATALYST™ A.I. (For RADEON™ 9700 and above). Options include:
Disabled
Standard
Advanced
Mipmap detail level. Options include; High performance, Performance, Quality, and High quality.
TRUFORM™. Options include; Application pref, or Always Off.
Wait for vertical refresh. Options include; Always off, Off unless application specifies, On unless application specifies, and Always on
Direct3D Setting. Options include; Enable geometry instancing, Support DXT texture formats, and Alternate pixel center
OpenGL Settings. Options include; Triple buffering, and Force 24-bit Z-buffer depth
This feature is supported on ATI RADEON™ 9500 series or higher product line.
Performance Improvements
As with most CATALYST™ releases performance has increased in various situations. The following performance gains are noticed:
Efficiency improvements in vertex processing have produced performance enhancements in key applications such as Far Cry and 3DMark05 on RADEON™ X850, X800 and X700 series products
Far Cry "Regulator" and "Volcano" scores are up as much as 20% on RADEON™ X800 PRO at 1600x1200 resolution
3DMark05 gains range from 1-3% on RADEON™ X800 series products to as much as 9% on some RADEON™ X700 configurations
Issues Resolved in CATALYST™ Display Driver Version 5.2
The following section provides a summary of the issues that have been resolved in the latest version of CATALYST™. These include:
4x4 Evolution2: Attempting to play the game under Windows XP with an ATI RADEON™ X300/X600 series installed no longer results in the operating system failing to respond when the screen is set to 1600x1200 32bpp and OpenGL Renderer is enabled
4x4 Evolution 2: Display corruption is no longer noticed when having the display set to 1600x1200 32bpp along with the texture detail set to high and split screen rendering enabled
Serious Sam: Playing the game under Windows XP results in the display flashing when TRUFORM is enabled
Sims 2: Playing the game Veronaville under Windows XP while having the desktop set to 1024x768 32bpp along with AA set to 6X no longer results in corruption being noticed in the fields
Selecting the option; Enable Video Mode, results in the CATALYST™ CONTROL CENTER not being able to return to the default setting for the Enable Video Mode option
Switching language support for the CATALYST™ CONTROL CENTER no longer results in the slider bar for the engine clock being enabled when the option found in OVERDRIVE™ is locked
Navigating to View->Define a Custom View and deselecting all options found in the 3D option of the Edit Custom View tab, no longer results in the Standard Settings option remaining selected
Intermittent failure of the VPU Recover report not being sent is now resolved
Double-clicking the slider bar found in CATALYST™ A.I. no longer results in the Disable CATALYST™ A.I. option becoming de-selected
Disabling 3D preview no longer results in the preview continuing to run on a secondary display device
Having the 3D preview running on the secondary display adapter and attempting change display modes, no longer results in the primary display device displaying a black screen and error messages appearing
English is no longer the default language when installing the CATALYST™ CONTROL CENTER under Windows XP Japanese version
The CATALYST™ CONTROL CENTER Version number is now displayed correctly in all localized languages
The Display Manager Notification dialog box is now displayed in the correct localized language
The OpenGL driver is no longer disabled after boot up when both AGP Read and PCI Read are disabled
http://www.ati.com/support/driver.html
Release Note:
http://www2.ati.com/drivers/Catalyst...ase_notes.html
Staro 10.02.2005., 08:56   #2
Elven
Elven's Avatar
Datum registracije: Sep 2002
Postovi: 2,721
kaj je reko, jel radi sa njima WOW bez problema?
Ma skidam, pa javim kakvi su.
edit: zajeb, nije ovo omega. čekam omegu jer sam s njom siguran da neće rušiti WOW
Staro 10.02.2005., 10:20   #3
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 6,996
Dal je CCC verzija konačno OK, ili da i dalje ostanem na Control panel verziji?
Staro 10.02.2005., 10:29   #4
Mailman
Mailman's Avatar
Postovi: 1,606
pa tek sam skinuo omegu...
Mailman je offline   Reply With Quote
Staro 10.02.2005., 13:27   #5
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
meni se nekak čini da bi im bilo bolje da nove drajvere izdaju svakih dva-tri mjeseca a da to naprave kak spada
ovak svako malo zaseru neku verziju od koje onda ionak ništ koristi
pinsla je offline   Reply With Quote
Staro 10.02.2005., 14:06   #6
Jelc
Super Moderators
Postovi: 17,485
Ja sam ih skinul samo sa CP-om da ih probam, sve điđe kaj nemaš ca CP-om lako uključiš sa ATI Tray Tools
CCC u moju hižu nebu ušel tak brzo
Staro 10.02.2005., 14:10   #7
Jelc
Super Moderators
Postovi: 17,485
Kak nema koristi???
Ovak bar gamad mora nekaj delat
Sad možeš fino birati-službeni, Omega, Unian, Forsage, DNA...bla-bla
I-kakav ti je novi RadLinker???
Staro 10.02.2005., 17:53   #8
pinsla
pinsla's Avatar
Postovi: 1,860
Originally posted by Jelc
Kak nema koristi???
pa delaju ali na brzinu i ne kak spada
ko bude ti sad išel instalirat te 5.1 drajvere kad su provjereno problematični i nestabilni barem u većini slučajeva
kaj se tiče Uniana, DNA i slično to po meni ništ ne vredi jedino Omega kolko tolko drži neki nivo ali i on u zadnje vreme ne stigne nekaj puno prčkat po samim drajverima
a novi radlinker mi je najbolji dosad
nego kaj ti rasprodaješ celi komp??
kaj hoćeš preći na nvidijinu SLI kombinaciju vraže jedan???
Staro 10.02.2005., 21:14   #9
Jelc
Super Moderators
Postovi: 17,485
Čekao ATI-štanga, VIA PCI-E isto štanga...a parice u teškoj opasnosti da se istope...
Htio sam danas uzet DFI NF4 vulgaris-nije došla...aaaaa...
A baš sam si bio lijepo sve isplanirao
Jebiga.
Staro 11.02.2005., 01:13   #10
pinsla
pinsla's Avatar
Postovi: 1,860
Jebiga.
a kaj buš s grafom?
ma skrij ti te parice pa se ne budu istopile
pričekaj još malo s pločom da vidimo kaj valja a kaj ne
Staro 11.02.2005., 02:07   #11
Jelc
Super Moderators
Postovi: 17,485
a kaj buš s grafom?
PCI S3 Virge 4MB
Staro 11.02.2005., 09:36   #12
Denzil
Secret Undercover Agent
Denzil's Avatar
Datum registracije: Sep 2004
Lokacija: Parallel Universe
Postovi: 1,130
mi moze netko (molim lijepo) u kratko obajsnit razliku/prednost Control Panela i Control Centra?? da ne skidam oboje... i za kolko vermena izade novi Omega nakon novog Catalysta??
jel netko mozda isprobao Far Cry?? zanima me da li fakat ima performance boost...ja nemam vremena za isprobavanje pa ak je neko isprobo..pliz... ja imam 9600XT, 512 RAMa i Athlon Xp 1700+ i jedino me zanima dal ce mi FarCry radit brze... tenks
"I can resist everything except temptation"
Denzil je offline   Reply With Quote
Staro 11.02.2005., 10:59   #13
marac
marac's Avatar
Postovi: 2,030
oce kad kupis jos 512MB-a rama i upgrejdas proc na 2500+ nadalje
Staro 11.02.2005., 21:18   #14
damir1
Ancient
damir1's Avatar
Lokacija: Đakovo
Postovi: 893
Far Cry definitivno ŽDERE memoriju.To Ti je najslabija točka.
Asus Z97-A-i5 4690K-xfx 470 -Kingston DDR3 1866 SDRAM 2x4GB -dvd ladice-asus 450W-sve to u chenbro gaming bomb, jedinici + Dell U2412HM
damir1 je offline   Reply With Quote
Staro 12.02.2005., 14:39   #15
Jelc
Super Moderators
Postovi: 17,485
Ma dosta je na 512 dokupiti 256MB, kaj se tiče Far Cry-a.
Staro 12.02.2005., 15:29   #16
Denzil
Denzil's Avatar
Postovi: 1,130
Igro sam ja FarCry i sa ovih 512 bez problema... jedino di mi je falilo memorije je onaj kraj..kad se penjes na vulkan..odmah nakon onog slapa gdje si bez oruzja.. uglavnom na tom djelu sam JEDVA igrao...sve drugo frame rate bez problema na 30...
