Povratak   PC Ekspert Forum > Računala > Periferija > Pisači i skeneri
Staro 11.03.2011., 19:05   #1
Den@
Datum registracije: Feb 2011
Postovi: 262
hp laserjet 1000 win 7 64bit driveri???
dakle radi se o printeru hp laserjet 1000
imam jedan problem a taj je da mi ne radi na win 7 64 bit?? za 32 bit ima drivere
da li ga netko ima, i je li ikako uspio riješiti problem???
hvala
Den@ je offline   Reply With Quote
Staro 15.03.2011., 00:09   #2
Minex_zd
Postovi: 9
Autor Den@ Pregled postova
hvala
Baš sam nedavno to pokušavao riješiti i izgleda da neće biti ništa od toga. Postoje samo 32-bitni driveri. Nema druge nego se prebaciti na 32bitni windows7 ako se isplati zbog tog printera.
Pozdrav
Minex_zd je offline   Reply With Quote
Staro 13.04.2011., 16:03   #3
Krvavy
Dva puta tata... :)
Krvavy's Avatar
Postovi: 52
hvala
Zanima me gdje si vidio Win7 32bit drivere kad piše na HP stranici:
HP LaserJet, Color LaserJet, and LaserJet AiO/MFP Products - Products Not Supported in Windows 7 (32-bit and 64-bit versions)
The following products are not supported in Microsoft Windows 7 operating system.
  • HP Color LaserJet 1500 series printer
  • HP Color LaserJet 3500 series printer
  • HP Color LaserJet 3550 series printer
  • HP Color 9850 multifunction product
  • HP LaserJet 1000 product
  • HP LaserJet 1010 product
  • HP LaserJet 1012 product
  • HP LaserJet 3100 all-in-one product
  • HP LaserJet 3150 all-in-one product
If you are using the new Windows 7 operating system on your PC, consider an upgrade to a newer HP product that will work with Microsoft's new Windows 7 operating system.
Krvavy je offline   Reply With Quote
Staro 13.04.2011., 16:23   #4
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,491
jesi probao možda driver x64 od viste
