Staro 05.04.2011., 14:18   #421
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,328
stvarno se negrije tako da će ti bit AC sasvim ok
SetH je offline   Reply With Quote
Staro 05.04.2011., 14:20   #422
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,180
Aj niš, da te ne gnjavim više, vidim da je najbolja opcija X6.
PC:
CPU:
Intel Core i7-7700
COOLER:
SCYTHE Mugen 3 rev. B
MBO:
MSI B250 GAMING M3
GPU:
ASUS Dual Radeon RX 6650 XT OC Edition 8GB GDDR6
RAM:
Kingston HyperX Fury (2x8GB) 2133MHz@2400MHz CL16 DDR4
SSD:
Samsung 870 EVO (500GB)
Samsung 970 EVO Plus (2TB)
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
Seagate Basic Portable Drive (1TB)
WD My Passport (1TB)
WD My Passport (2TB)
WD Elements (2TB)
Verbatim Vx500 (240GB)
Silicon Power PC60 (240GB)
Kingston XS1000 (1TB)
PSU:
Corsair 650W RM650, 2019, 80 PLUS Gold
MONITOR (TV):
Dell G2724D + Dell U2414H
Samsung UE55NU8002TXXH
Samsung QE43Q60AAUXXH
Philips 43PUS8506/12
KUĆIŠTE:
Antec 300, 2xSCYTHE Slip Stream 120mm (500rpm, 7.5 dB)
OS:
Windows 10 Pro 64-bit
TIPKOVNICA:
Logitech K800 Illuminated
MIŠ:
Logitech G502 Proteus Spectrum RGB + SteelSeries QcK Edge - Medium
Logitech MX Master 3 Black
Logitech MX Master 2S Bluetooth Edition Graphite
Logitech M590 Silent
ZVUČNICI:
Logitech Z-5500 (S/PDIF) + Logitech Bluetooth Audio Receiver
MAGNAT Monitor Supreme 202 Black 2-way bass reflex bookshelf speakers
MAGNAT Monitor Supreme Center 252 Mocca
SLUŠALICE:
Logitech Zone Vibe 100
Samsung Galaxy Buds3 Pro
Xiaomi Redmi Buds 5 Pro
Xiaomi Buds 3 Star Wars Edition
Mi True Wireless Earbuds Basic 2
Sennheiser CX 3.00
AKG Samsung Galaxy Earbuds
AKG Y500 Wireless
MOB:
Samsung Galaxy S7 Black, 4/32GB +
Samsung microSDXC 64GB EVO+
Samsung Galaxy S10e Black, 6/128GB +
Samsung microSDXC 256GB EVO+
Huawei P50 Pro Golden Black, 8/256GB
Samsung Galaxy A55 5G Awesome Navy, 8/256GB
Samsung Galaxy S24+ Onyx Black, 12/256GB
Samsung Galaxy S25+ Blue Black, 12/256GB
LAPTOP:
(Lenovo ThinkPad E560)
CPU: Intel Core i3-6100U
MBO: -
GPU: Intel HD Graphics 520
RAM: 2x4GB DDR3L 1600MHz
SSD: Kingston A400 480GB
OSTALO: 15.6-inch HD TN
OS: Windows 11 Pro 64-bit
PC POSAO:
(HP Z2 Tower G9 Workstation)
CPU: Intel Core i7-14700K
MBO: HP 895C
GPU: Nvidia RTX A2000 12GB
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MONITORI: 2 komada HP Z27 27-inch 4K UHD
PERIFERIJA: Logitech K750 Solar, Logitech MX Master 3 Graphite + Logitech MX Master 2S Bluetooth Edition Graphite
LAPTOP POSAO:
(Apple MacBook Air 13.6-inch M2 8/256GB MLXY3CR/A Silver)
(HP EliteBook x360 1040 G11 2-in-1, 14-inch WUXGA Touchscreen, Intel Core Ultra 7 155H, 16GB LPDDR5x, Samsung 1TB PCIe Gen4 NVMe TLC M.2 SSD, Backlit Keyboard, Windows 11 Pro 64-bit)
(HP ProBook 450 G7, 15.6-inch FHD, Intel Core i5-10210U, 8GB DDR4, Samsung 512GB NVMe M.2 SSD, MX250 Graphics, Backlit Keyboard, Windows 11 Pro 64-bit)
DiRT je offline   Reply With Quote
Staro 05.04.2011., 14:40   #423
kasko
kasko's Avatar
Lokacija: Ivanić_Grad
Postovi: 2,017
@DiRT
Jesi ti probao overclockirati taj procesor?
Koje ti to igre zaštekaju tu i tamo?
kasko je online   Reply With Quote
Staro 05.04.2011., 15:32   #424
DiRT
DiRT's Avatar
Postovi: 1,180
Autor kasko Pregled postova
@DiRT
Ma jesam, do 3.7 max, radilo je normalno pod prime95 i orthosom kakvih 2 sata, nije se rušilo, ali veća voltaža treba, 1.475 V, ustvari nisam našao manju voltažu i frekvenciju gdje mu najbolje odgovara. Morao bi se igrat s tim, al mi se neda stalno malo po malo dizat frekv i napon i testirat. Nemam živaca. Čak boota sa 4.0 GHz i mogu bit na desktopu i sve radit, ali ako pokrenem prime il neš drugo za testiranje odma blue screen (mislim da je 1.55V bilo, i 1.535). Na 3.7 radi normalno, al je default najbolje. Jednom mi se rušio u tri tjedna i opet je super. Igre koje zaštekaju su shift 2, crysis 2, uglavnom ove bolje i novije, sve, ali baš sve na max i reza 1680x1050. Pomalo mi je glupo gledat kad mi koji put fps padne ispod 30. Neke situacije i 20. Framedrop se vidi i osjeti pri igranju, a to ne želim, a opet ne volim slabije detalje.
PC:
CPU:
Intel Core i7-7700
COOLER:
MBO:
MSI B250 GAMING M3
GPU:
RAM:
SSD:
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
WD Elements (2TB)
PSU:
MONITOR (TV):
KUĆIŠTE:
OS:
TIPKOVNICA:
MIŠ:
ZVUČNICI:
SLUŠALICE:
Sennheiser CX 3.00
AKG Y500 Wireless
MOB:
LAPTOP:
MBO: -
PC POSAO:
MBO: HP 895C
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
LAPTOP POSAO:
Zadnje izmijenjeno od: DiRT. 05.04.2011. u 15:41.
Staro 05.04.2011., 15:44   #425
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,295
Autor SetH Pregled postova
meni je temp proca,max 25c...nekako mi malo nerealno...idle jel...dok load nije preko 45c....al stvarno sam osjetio da sve nekako bolje i brže radi
x6 ima problema sa senzorima. Dodaj 10C na tu temp.
@dirt - ako neces oc-at x6 onda bi freezer64 bio dovoljan. U slucaju oc-a ipak treba neki bolji cooler.
Kod mene na 3.7@1.3375v temp pod prime-om ide na max 54C (zalman flex je u pitanju)
Staro 06.04.2011., 19:40   #426
kripton
Cars & Tunning
kripton's Avatar
Lokacija: Vukovar - Rijeka
Postovi: 536
Pozdrav svima, imam jedno pitanje. Odlucio sam se na zamjenu svoga procesora za neki drugi. U konfiguraciji se trenutno nalazi Phenom 9550 a odlucio sam se za kupnju Phenoma II 945 (3.0ghz +)ili nekog jaceg. Ono što mene zanima je dali mi je isplativ prelazak sa moga Phenoma koji radi na 2.2ghz a stabilan je nešto vise na oko 2.6ghz na Phenoma II koji radi na 3.0ghz. Tj. zanima hoce li skok biti osjetan u pitanju performansi u igrama?
Kolega 'chumaman' mi je ponudio Phenoma II 945 3.0ghz C3 revizija star 5 mjeseci, ima jos 31 mjesec garancije, kolega nije prvi vlasnik, procesor je kupio tu na forumu. Pošto nisam informiran oko cijena ne mogu pretpostaviti kolika bi bila prihvatljiva cijena za ovaj polovni procesor, jedino sam gledao malo po nabavi ali ne znam kakav omjer ponude/potraznje pa vas molim za savjet na ova 2 pitanja.
NovA Squadron
kripton je offline   Reply With Quote
Staro 07.04.2011., 00:35   #427
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Taj proc vrijedi cca 750kn jer novi dođe 890kn na nabava.net
Dobio bi po defaultu jaći procesor te sa malo boljim coolerom ide bez problema na 3.6-3.8GHz što bi bilo cca 1GHz više od tvog sadašnjeg.I ukoliko možeš mijenjaj bio bi to OK boost i lakše bi disao SLI
Staro 07.04.2011., 20:12   #428
kripton
Cars & Tunning
kripton's Avatar
Postovi: 536
Moze li Artic C. Freezer 64 PRO hladiti tog Phenoma 945 bez frke?
NovA Squadron
Staro 07.04.2011., 21:32   #429
ECHO
Postovi: 2,354
Može, bit će sigurno bolje nego default cooler.Ako si sadašnji proc digao za 400MHz i nemaš problema sa temperaturama na 2.6GHz vjerujem da neće biti problem ni sa 945(3.0GHz) ako ga digneš na 3.4-3.6GHz dok mislim za više da bi ipak bio poželjan bolji cooler ali najbolje ako uzmeš 945 isprobaš dokle ide stabilno.Naravno sve zavisi i od primjerka kakav dobiješ.
Vjerujem da temperature neće biti problem.
Staro 08.04.2011., 17:04   #430
hari123
Brucos
hari123's Avatar
Lokacija: Bosnia
Postovi: 174
Pitanje da li na Asus M2V moze Athlon II X4 645? I da li se isplati taj proc za 500-640Kuna?nov sa garom
hari123 je offline   Reply With Quote
Staro 08.04.2011., 17:08   #431
Mandusin
Datum registracije: Mar 2010
Lokacija: Dubrovnik
Postovi: 83
ne moze, ploca je am2.
Mandusin je offline   Reply With Quote
Staro 08.04.2011., 17:09   #432
nino
nino's Avatar
Postovi: 12,613
Autor hari123 Pregled postova
Da pogledas na Asus supportu pa nam javis? http://www.asus.com/product.aspx?P_ID=OqYlEDFfF6ZqZGvp
Staro 08.04.2011., 17:11   #433
hari123
Brucos
hari123's Avatar
Lokacija: Bosnia
Postovi: 174
zurilo mi se zar je zabranjeno pitat .. a ovo mi odma bilo otvoreno inace odbio sam kupnju
Staro 11.04.2011., 00:15   #434
Marjag
Marjag's Avatar
Datum registracije: Feb 2011
Postovi: 168
HITNO savjet trebam.....isplati li se ovaj proc i matičnu za ove novce kupit??
AMD Phenom II X4 920-400kn-Gigabyte MA770-UD3 rev2.0-300kn
to je ok cijena?
Marjag je offline   Reply With Quote
Staro 11.04.2011., 00:52   #435
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
Ne čest procesor, ali definitivno se isplati....
Staro 11.04.2011., 02:30   #436
Prcko Prcić
Datum registracije: Sep 2010
Lokacija: Lepoglava
Postovi: 178
mislim da nove ploce ne podrzavaju 920 i 940
Prcko Prcić je offline   Reply With Quote
Staro 11.04.2011., 03:00   #437
Postovi: 7,568
Samo ako je riječ o novim AM3 pločama, jer na njih ne idu AM2+ procesori. Obzirom da on pita za kombinaciju AM2+ ploče i procesora, nema brige oko kompatibilnosti.
Staro 11.04.2011., 08:27   #438
Marjag
Marjag's Avatar
Postovi: 168
baš nedavno mi sugerirali da eventualno prijedjem na amd pošto su "dugotrajniji" glede nadogradnje i naravno povoljniji..pa me samo zanimalo dali bi sa ovom kombinacijom bio miran 1-2 godine.pc mi treba samo za internet i gaming.stime da ne tražim da vrti baš sve samo najnovije!
Staro 11.04.2011., 09:02   #439
Prcko Prcić
Lokacija: Lepoglava
Postovi: 178
za 700kn nema teorije da ces dobiti jaci proc i plocu zajedno, bar ne novo...
Staro 13.04.2011., 14:05   #440
Xan
networking wannabe guru
Xan's Avatar
Datum registracije: Sep 2002
Postovi: 1,001
molim znalce sa područja AMD-a ako mogu poredati ova tri proca po jačini, te ako ima neki od njih mane da ih navedu
AMD Phenom II X4 955 Black Editon
AMD Athlon II X4 645
AMD Phenom II X4 840
proc neće nikad bit overclockan niti će se išta kemijat s njim (dakle ugradnja sa stock coolerom, 90% vremena za surfanje, 10% vremena za Football Manager )
Quotation from the Bhagavad Gita famously quoted by J. Robert Oppenheimer upon witnessing the detonation of the first atomic bomb.
Also quoted numerous times by overly melodramatic players of Unreal Tournament upon detonation of the Redeemer weapon.
"Now I have become death, the destroyer of worlds who has come to annihilate everyone."
Xan je offline   Reply With Quote
Staro 13.04.2011., 14:41   #441
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,479
ako stvarno mislis ne-clockat onda ti netreba BE .
Zadnje izmijenjeno od: McG. 13.04.2011. u 15:46.
Staro 13.04.2011., 14:48   #442
Xan
Xan's Avatar
Postovi: 1,001
eh, BE je zato jer nema običnog u ADM-u
ono što me zapravo muči je zašto je Athlon II X4 645 100kn skuplji, a slabiji od Phenom II X4 840
EDIT: mislim da će ipak ić taj phenom jer nema potrebe za jačim
Staro 13.04.2011., 15:48   #443
Ranma 1/2
Anything Goes Martial Art
Ranma 1/2's Avatar
Lokacija: Tendo Dojo
Postovi: 542
ne treba ni Phenoma ako misli samo surfati i igrati Fucu
"Water! Why does it always have to be water?!"
Ranma 1/2 je offline   Reply With Quote
Staro 13.04.2011., 16:28   #444
G-rage
Datum registracije: Apr 2011
Postovi: 30
ljudi jel mogu igrat black ops i takve zahtjevne igre sa procesorom amd Phenom 555 x2 3.2 GHz
G-rage je offline   Reply With Quote
Staro 13.04.2011., 16:42   #445
geronimo_2
geronimo_2's Avatar
Postovi: 4,479
Autor G-rage Pregled postova
pitanje je samo na kojim rezolucijama, koliko detalja i naravno koja igra. ja sam do nedavno na kompu iz siga imao takav proc i vidio sam razliku kad sam uboo x4, najvise u GTAIV dok npr. Batman AA nema jednog FPS-a razlike (benchmark).
btw jel imas taj proc ili ga kupujes? ako ga kupujes daj si truda proucit tematiku i zamoli prodavaca da ti ga pokaze prije kupovine pa trazi oznake navedene na netu koje se daju otkljucati na x4, mozda budes imao srece .
Staro 04.05.2011., 15:15   #446
bebach87
Datum registracije: Oct 2010
Lokacija: doma
Postovi: 18
Athlon II X4 640 (660kn) vs Phenom II x4 955 (900kn) ?
osim razlike u L3 memoriji (koja se koliko citam manifestira u igrama) i vece potronje struje, ima li znacajne razlike koja bi me natjerala da uzmem Phenoma?
nisam neki gejmer, tu i tamo kakav PES, možda kakve utrke...
radije budem tih 250 kn razlike iskoristio na grafičku pa umjesto 5ookn i hd 5670, uzeo hd 5830 xtreme za 760kn.
dal ispravno razmisljam?
edit:
čitam i da stock kuler na phenomu je jako bučan pa još uz 200-250kn za novi hladnjak, mislim da niš od phenoma
Zadnje izmijenjeno od: bebach87. 04.05.2011. u 16:38.
bebach87 je offline   Reply With Quote
Staro 04.05.2011., 15:38   #447
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Po meni potpuno ispravno. Razlika u cijeni je neopravdana i bolje ju je uložiti u tu grafu.
cccp je offline   Reply With Quote
Staro 04.05.2011., 16:46   #448
StormTTC
StormTTC's Avatar
Postovi: 31
iskljucivo za igranje (full hd rezolucija), koji je procesor bolji?
AMD Phenom II X6 1055T, 2.8GHZ, 6MB, AM3
ili
Intel Core i5 2400 3.1Ghz,6MB,LGA 1155
ostatak konfe bi bio 8gb ddr3 i dvije graficke u rangu 5850-6870...
StormTTC je offline   Reply With Quote
Staro 04.05.2011., 17:39   #449
cccp
cccp's Avatar
Postovi: 1,030
Bez overclocka, i5.
Staro 16.05.2011., 01:55   #450
bebach87
Lokacija: doma
Postovi: 18
evo, bliži se kupnja pa da razrijesimo dilemu..
Athlon II X4 640 ili Phenom II X4 840 ??
koliko citam, taj phenom je zapravo Athlon x4 650...
razlika je samo u taktu 3.0 vs 3.2Ghz.
po meni se isplati dati 20 kn vise za Phenoma.
jedino me brine kakav je stock kuler na njemu?
kod athlona su kuleri relativno tihi, dok sam za phenome cuo da su jako bucni pa me to brine...
dakle, ako imaju iste kulere, uzimam phenoma!
