Lokacija: rfhgf
Postovi: 16
Toshiba satellite C660-120 Vs Toshiba Satellite L635-12H
Postovanje, Molim vas za procjenu koji od ova dva laptopa je bolji, odnosno isplativiji, neke glavne prednosti i mane. Laptop mi treba prvenstveno za posao (faklutet itd), pogledati koji film na njemu ili odigrati igricu je sekundarno. U prilici sam kupiti ovaj C660 za 2800kn ili ovaj L635 4300kn - u sklopu nekakvog prebijanja duga. Kao i vecini ovih dana 1500kn mi nije malo, ali cu pregristi ako se isplati. C660 Processor type : Intel® Celeron® Processor T3500 clock speed : 2.10 GHz Front Side Bus : 800 MHz 2nd level cache : 1 MB Operating system Genuine Windows® 7 Home Premium 64-bit (pre-installed, Toshiba-HDD recovery) Design Colour colour : Black finish with textured pattern and black keyboard System memory standard : 2,048 MB maximum expandability : 4,096 MB technology : DDR3 RAM (800 MHz) Hard disk capacity : 250 GB drive rotation : 5,400 rpm DVD Super Multi drive (Double Layer) compatibility : CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-R(DL), DVD-RW, DVD+R, DVD+R(DL), DVD+RW, DVD-RAM maximum speed : Read: 24x CD-ROM, 8x DVD-ROM/ Write: 24x CD-R, 4x CD-RW, 10x HS CD-RW, 24x US CD-RW, 8x DVD-R, 6x DVD-R (Double Layer), 6x DVD-RW, 8x DVD+R, 6x DVD+R (Double Layer), 8x DVD+RW, 5x DVD-RAM type : DVD Super Multi (Double Layer) drive Display size : 39.6cm (15.6”) type : Toshiba TruBrite® HD TFT High Brightness display with 16 : 9 aspect ratio and LED backlighting internal resolution : 1,366 x 768 Graphics adaptor manufacturer : Intel® type : Mobile Intel® Graphics Media Accelerator 4500M memory : up to 828 MB shared memory with 2 GB system memory installed, and up to 1,759 MB with 4 GB system memory, (with pre-installed 64-bit operating system) memory type : shared Internal video modes The following internal video modes are supported: resolution : 1366 x 768 Max External Video Modes Max Resolution : 2,048 x 1,536 Max Refresh Rate : 85 Hz Non-interlaced resolution with max refresh rate : 1,600 x 1,200 Interfaces 1 × DC-in 1 × external monitor 1 × RJ-45 1 × external microphone 1 × headphone (stereo) 1 × integrated VGA Web Camera with built-in microphone 2 (Right 2) × USB 2.0 1 × Multi-Card Reader (supports SD™ Card up to 2 GB, miniSD™/microSD™ Card with adapter up to 2 GB, SDHC™ Card up to 32 GB, SDXC™ Card up to 64 GB and MultiMedia Card™ up to 2 GB) Expansion 2 × memory slots Wireless communication Compliancy : Wi-Fi® Network Support : 802.11b/g/n Wireless Technology : Wireless LAN Wired communication topology : Fast Ethernet LAN speed : 10BASE-T/100BASE-TX Sound system supported audio format : 24-bit stereo speakers : built-in stereo speaker manufacturer : Toshiba Bass Enhanced Sound System Keyboard keys : 102 Windows keys : Yes special features : Full-size black flat keyboard with 10-digit keypad Pointing device type : Touch Pad with Multi-Touch Control supporting two-finger scroll, pinch, flip and rotate. Battery technology : lithium-ion maximum life : up to 4h00min (Mobile Mark™ 2007) AC adaptor input voltage : autosensing AC adapter (100/240 V) for worldwide usage output voltage : 19 V output current : 3.42 A Physical dimensions W x D x H : 380.5 x 254.0 x 28.0 (front) / 35.6 (rear) mm weight : starting at 2.30 kg Warranty 1 year EMEA Carry-in including Pick-up & Return in the UK & Ireland. Toshiba also offers a large range of services to upgrade your standard warranty, please have a look at our website www.toshiba.co.uk/services/ to find the right service for your product. Bundled hardware AC adaptor L635 Processor type : Intel® Core™ i3-370M Processor clock speed : 2.40 GHz Front Side Bus : 1,066 MHz 3rd level cache : 3 MB Operating system Genuine Windows® 7 Home Premium 64-bit (pre-installed, Toshiba-HDD recovery) Design Colour colour : Steel Grey Metallic with Dual Mesh pattern and silver chrome accents, black keyboard System memory standard : 3,072 (2,048 + 1,024) MB maximum expandability : 8,192 MB technology : DDR3 RAM (1,066 MHz) Hard disk capacity : 320 GB drive rotation : 5,400 rpm DVD Super Multi drive (Double Layer) compatibility : CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-R(DL), DVD-RW, DVD+R, DVD+R(DL), DVD+RW, DVD-RAM maximum speed : Read: 24x CD-ROM, 8x DVD-ROM/ Write: 24x CD-R, 4x CD-RW, 10x HS CD-RW, 24x US CD-RW, 8x DVD-R, 6x DVD-R (Double Layer), 6x DVD-RW, 8x DVD+R, 6x DVD+R (Double Layer), 8x DVD+RW, 5x DVD-RAM type : DVD Super Multi (Double Layer) drive Display size : 33.8cm (13.3") type : Toshiba TruBrite® HD TFT High Brightness display with 16 : 9 aspect ratio and LED backlighting internal resolution : 1,366 x 768 Graphics adapter manufacturer : ATI type : ATI Mobility Radeon™ HD 5430 supporting HyperMemory™ technology memory amount : 512 MB dedicated VRAM (total available graphics memory using HyperMemory™ technology can be up to 1,783 MB with a 32-bit operating system and 4 GB system memory or 3,571 MB with a 64-bit operating system and 8 GB system memory) memory type : DDR3 Video RAM (resp. Video RAM and system memory combined) connected bus : PCI Express® Internal video modes The following internal video modes are supported: resolution : 1,366 x 768 Max. external video modes max. resolution : 2,048 x 1,536 max. refresh rate : 100 Hz non-interlaced resolution with max. refresh rate : 1,600 x 1,200 Interfaces 1 × DC-in 1 × external monitor 1 × RJ-45 1 × external microphone 1 × headphone (stereo) 2 × USB 2.0 1 × integrated VGA Web Camera with built-in microphone 1 × HDMI supporting 1080p signal format 1 × Multi-Card Reader (supports SD™ Cards up to 16 GB, Memory Stick® up to 256 MB, Memory Stick Pro™ up to 2 GB and MultiMedia Card™ up to 2 GB) 1 × eSATA/USB 2.0 Expansion 2 × memory slots (1 to configure) Wireless communication Compliancy : Wi-Fi® Network Support : 802.11b/g/n Wireless Technology : Wireless LAN Wireless Technology : Bluetooth® Wired communication topology : Fast Ethernet LAN speed : 10BASE-T/100BASE-TX Sound system supported audio format : 24-bit stereo speakers : built-in stereo speakers manufacturer : Toshiba Bass Enhanced Sound System with Dolby® Advanced Audio Keyboard keys : 87 Windows keys : Yes special features : Full-size matt black flat keyboard Pointing device type : Touch Pad with Multi-Touch Control Battery technology : lithium-ion maximum life : currently no official battery benchmark result available AC adapter input voltage : autosensing AC adapter (100/240 V) for worldwide usage output voltage : 19 V output current : 3.95 A Physical dimensions W x L x H : 329.0 x 221.0 x 27.9 (front) / 36.9 (rear) mm weight : starting at 2.10 kg Hvala! |
Lokacija: Kupres
Postovi: 4,085
Teško je usporediti ta dva laptopa. Dovoljno je pogledati i cijenu. Prvi je dovoljan za najosnovnije, surfanje, obrada teksta ... Nikakve novije igre ne dolaze u obzir. Kvalitetom je dno. L serija je opet nešto kvalitetnija od C, grafička je dovoljna i za pokrenuti neku noviju ne prezahtjevnu igru. Procesor odličan, itd. Ipak, 13,3" ekran i nije baš sjajan ako se radi o laptopu koji će ti biti glavno računalo, dakle cjelodnevni rad na njemu, mnogo tipkanja i slično bi moglo biti malo naporno. Jesu li ta dva laptopa jedine opcije? Ako da, sam ocijeni što ti je bitnije, ne može ti nitko dati odgovor na to. |
Lokacija: ST
Postovi: 117
puno je jaci ovi drugi, proc i vga........su neusporedivo bolji.......provjeri jamstvo koliko koji ima.... |
Lokacija: rfhgf
Postovi: 16
Ovo su jedine opcije u ponudi po tim cijenama. Do toga je uopce doslo jer sam ja napomenuo da trazim laptop itd, tako da nije da moram uzeti ovaj ili nista. Mogu dobiti novac, pa ako za recimo 4000kn postoji bolji laptop (a da je nov) onda ne moram uzeti niti jedan od ovih. Samo me tip uvjeravao da daje puno ispod cijene (gledao sam na nabava.com, jesu jeftiniji). Garancije na oba su 2 godine. Hvala na odgovorima. |
Postovi: 33,987
Datum registracije: Feb 2011
Postovi: 173
Bolje uzmi novac, pa kupi nešto jeftinije pošto ti igre nisu napete. Ili čak dobar polovni....više će ti love ostati za djevojku! ![]() |
Lokacija: Kupres
Postovi: 4,085
