od LemilicE
Lokacija: Veli Lošinj
Postovi: 4,712
![]() Ovdje ću staviti samo copy/paste mog topica na engleskom sa XDA foruma.. ako netko baš želi, ja ću ga prevest na HR Ovo je ROM sa custom kernelom od mene za HTC Desire HD... Hi guys... and gals!!! From overclocker to overclockers... CyanogenLorDmod V2.0, LordMod kernel V4.0 This is my first ever ROM and custom kernel for any device.. I tested it for a long time and I think that it's ready for the community.. I've only wanted to implement smartass because everybody (almost) wants it, but the project took me much further than I imagined.. I've lost 7 days on this so don't be harsh on commenting my work. I'm a BEGINNER in kernel building and ROM modding. Don't expect to get some extra stuff other than listed bellow! If I found something useful to add to the kernel I will add it. If someone needs only the kernel that can be arranged in the near future ![]() Sorry for rapidshare link, but it's the only thing I got! Please share your mirror links if you found this ROM useful!! ROM is build from the latest commits of CM7 Kernel has been taken from “teamdesire” and modified a little to suit everybody!! For those who care – Quadrant score is about 3300 on 1800MHz PERFOMANCE mod I use UUV edition @ 122/1380MHz 24/7 Decided to update only the kernel... because ROM is basicaly CM7 nightly... I'll include kernel update.zip with and without SD Card Read speed increase patch! ROM:
KERNEL (for CM7 only, apparently works great for MIUI):"How to" for CM7 users:
Use 4.0 for CFS, or 3.1.3 for BFS V363!KERNEL V3.1.3 BFS - MIRROR RS, MIRROR MU KERNEL V3.0.3 CFS - MIRROR RS, MIRROR MU UV editions 3.X.3: Ultra Under Volt BFS and CFS Under Volt -25mV BFS and CFS KERNEL V3.1 BFS - MIRROR RS, MIRROR MU KERNEL V3.0 CFS - MIRROR RS KERNEL V2.1.1 noBFS VDD sqlite – MIRROR RS KERNEL V2.1.1 BFS VDD sqlite – MIRROR RS KERNEL V2.1 noBFS VDD - MIRROR RS KERNEL V2.1 BFS VDD – MIRROR RS KERNEL V2.0 - MIRROR RS KERNEL V1.2.2 (without SD patch) only .zip (Hope it works ![]() KERNEL V1.2.2_SDfix (kernel with script to increase SD card reading speed) - MIRROR RS I hope I implemented it right! KERNEL V1.1 - MIRROR RS KERNEL V1.0 - MIRROR RS Here are 2 sripts made by gokhanmoral that undervolts your CPU even more if it can handle it. Copy both .zip on your SD so if the UV doesn't work for you and gets unstable, just flash reset zip. update.zip reset.zipAGAIN - don't FORGET to do a nandroid backup prior to flashing! No need for screen shots, because everybody knows how CM7 looks like. History: Code:
17-04-2011 V4.0 LorDmod lernel
![]() ![]() Special thanks goes to DOALaboratories and teamdesire (all of them)!!
Member Of the PC Ekspert 100+kg Demolition Squad ----------------------------- ReadTheFuckingManual Da, to sam ja u avataru!!! Grobnik ----> 1:37.759... ko od vas može brže??? Nemam više lema!!! Zadnje izmijenjeno od: LorD ClockaN. 17.04.2011. u 23:06. |
imaš android temu! ![]() |
od LemilicE
Postovi: 4,712
Member Of the PC Ekspert 100+kg Demolition Squad ----------------------------- ReadTheFuckingManual Da, to sam ja u avataru!!! Grobnik ----> 1:37.759... ko od vas može brže??? Nemam više lema!!! Zadnje izmijenjeno od: LorD ClockaN. 04.04.2011. u 20:58. |
its slightly turbocharged
Postovi: 5,430
Stavio sam danas MDJ's Ultimate Droid sa tvojim Kernelom. Ovo je predobro! Nisam mislio da Cyanogen može biti bolji ali ti i MDJ ste me razuvjerili. CM je sada na novoj razini. Fenomenalno nešto!
blaa |
od LemilicE
Postovi: 4,712
Member Of the PC Ekspert 100+kg Demolition Squad ----------------------------- ReadTheFuckingManual Da, to sam ja u avataru!!! Grobnik ----> 1:37.759... ko od vas može brže??? Nemam više lema!!! Zadnje izmijenjeno od: LorD ClockaN. 12.04.2011. u 18:55. |
Svaka čast! Super score, ali iskreno. Čisto clockani CPU + I/O |
Postovi: 5,430
Kernel ti je čudo jedno! Baterija na DHD-u mi je izdržala 3 puna dana. ~2 sata igri (Hex Defence, Medieval Castle...), 2 sata Wi-Fia, ekran na 30% brightnessa, jedno sat vremena poziva sve skupa i 10ak poruka. O brzini da i ne govorim, natrpano aplikacija i widgeta, a mobitel održava istu brzinu odaziva, scrollanja i slično. Malo sad MDJ pretjeruje jer je od UD-a napravio CM7 Nightly i svaki dan možeš novu verziju stavljat.
blaa |
od LemilicE
Postovi: 4,712
opet sam novu verziju izbacio ![]() nadam se još bolja! a imaš sada i under volt editions kernela ![]()
DD9512
Postovi: 1,869
jel ti se ovaj sd card speed patch odnosi na vanjsku karticu?? |
Postovi: 5,430
Lord Clocki jesi vidio ovo: http://forum.xda-developers.com/show....php?t=1063343 ![]() Novi ROM sa tvojim kernelom. Mislim da ću ga večeras flashati, pošto MDJ napravio klasični discontinue na svoj UltimateDroid. BTW, zašto se ti ne okušaš u roštiljanju kakvog CM7 ROMa? ![]()
blaa Zadnje izmijenjeno od: hammer_of_thor. 04.05.2011. u 19:01. |
od LemilicE
Postovi: 4,712
Probaj ROM i onda stavi novu verziju HD 3.0 kernela koju sam upravo izbacio ![]() Neda mi se zezat oko toga... nemam vremena.. i ovako kernel uzme puno slobodnog vremena. a kamoli ROM
