Datum registracije: Apr 2008
Lokacija: GER
Postovi: 724
Ne mogu otvoriti Task Manager
Bok, imam problem s task managerom stisnem ctrl alt del i ne otvori se nego pise Task manager has been disabled by the administrator instliro sam xp na netbook ima 10ak dana i tek sad primjetio ovo |
Postovi: 12,607
Paaa, google kaze: Method 1 Click Start, Run and type this command exactly as given below: (better - Copy and paste) Code:
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f * Click Start, Run and type Regedit.exe * Navigate to the following branch: HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System * In the right-pane, delete the value named DisableTaskMgr * Close Regedit.exe Method 3: Using Group Policy Editor - for Windows XP Professional * Click Start, Run, type gpedit.msc and click OK. * Navigate to this branch: User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager * Double-click the Remove Task Manager option. * Set the policy to Not Configured.
Lokacija: GER
Postovi: 724
googlo sam bio, naso nesto al nije uspjel, ne znam sto sam krivo radio P.S. thx evo radi EDIT Kar se komp ugasi i opet upali ili resetira opet task manager ne radi Zadnje izmijenjeno od: croclocker. 14.03.2011. u 19:30. |
čudovište
Postovi: 757
Bilo bi dobro da prvo proskeniraš gamad... Takve peripetije su često njihovo maslo...
Failure is always an option. |
