#31 |
Datum registracije: Aug 2008
Lokacija: Vukovar
Postovi: 35
Chieftec Turbo Series 650W - (CFT-650-14C) Code:
Chieftec power supply 650W Turbo Series, CFT-650-14C, EPS, 4×12V(18A), Active PFC, AFC, 14cm silent FAN, CE, over power protection, over current protection, over temp.protection, Cable management (20/24-pin ATX, 8-pin EPS 12V, 4-pin P IV, 2×6-pin PCIe, 7×PATA, 2×SATA, 1×floppy) Imam ovo napajanje od prvog mjeseca. Zasad sve u redu,konfa u my komp opciji... Tih je,odlicno kabeli tj. dugi su dosta..Napajanje je modularno sto je jos jedna prednost... Negativno: -cijena |
#32 |
Lokacija: VG
Postovi: 1,760
OCZ GameXstream 700W ![]() ![]() ![]() ![]() ![]() Specifications Main Features * 700W Configurations * OCZ PowerWhisper Technology * Multi-GPU ready * Internal 120mm fan * 3 year warranty backed by OCZs exclusive PowerSwap replacement program Technical specifications * 150 x 140 x 86mm * ATX12V v2.2 and EPS12V OCZ ConnectAll™ universal connectors: * 1 x 20+4Pin ATX * 1 x 4-pin/8-pin CPU (supports double CPUs/supplies stable voltage) * 2 x PCI-E * 6 x 4-pin peripheral * 2 x 4-pin floppy * 6 x S-ATA High efficiency: * 80% @ 115V (Typical load) * 83% @ 230V (Typical load) * Overvoltage/Overcurrent/Short-Circuit protection * Active PFC * MTBF:100,000 hours * 100~240Vac 10-5A 50/60Hz * +3.3V(36A), +5V(30A), +12V1(15A), +12V2(15A), +12V3(15A), +12V4(15A) The good: * Two PCI-E video card connectors * Active PFC * Four 12V rails * Good voltage stability * 20+4 and 4+4 ATX power connectors * Two separate rails for 6-pin PCI-E power * Six SATA connectors * All cables sheathed and shrink wrapped at ends * EZ-Grip connectors * 36 month warranty from OCZ and PowerExchange guarantee The bad: * Lines not modular * Price Napajanje je uglavnom pokupilo jako dobre rezutate i preporuke sa mnogih portala. Osobno sam s njim zadovoljan, ima stvarno puno konektora i dovoljno snage i za puno jace konfiguracije. Prije njega sam imao Fortron Blue Storm II i mogu reci da je u usporedbi s njim tise, iako nedovoljno i po mom ukusu bi moglo biti jos tise no to je nedostatak bilo kakve regulacije venta. Jos jedan plus je taj sto ga imam vec godinu dana otprilike i jos uvijek nema nikakvog zujanja koje se pojavilo i kod BSII i kod Chiefteca 550W nakon samo nekoliko tjedana koristenja. Cjenovno je prihvatljivije od npr Corsaira ili Thermaltake-a slicne ili jednake nazivne snage, no sve je stvar izbora Zadnje izmijenjeno od: bluefluid. 07.05.2009. u 01:52. |
#33 |
Lokacija: Čepin
Postovi: 297
Intel G1610; ASUS B75M-LX Plus; 4096 MB; Intel HD; Hitachi 7K1000.C 500 GB; LG GH24NS95; Silverstone Strider Essential 400 W; Logitech K200; Logitech B110; Logitech X-240 2.1; Philips 200V4LAB 20" DVI; Windows 7 64-bit Professional |
#34 |
Postovi: 306
Thermaltake ThoughPower 700W Konektori: 20+4pin x 1 8pin +12V x 1 4pin +12V x 1 molex x 7 4pin Floppy x 2 5pin sata x 6 6pin PCI-E x 2 Hlađenje: Aktivno 14 cm ventilator (maks. 1900rpm) Dimenzije: 160x150x85 Dimenzije i raspored kablova: 1X 20/24 Pin Motherboard Connector -48,26cm 1X 4/8 Pin +12V CPU Connector -48,26cm+15,24cm 1X 4X 4 Pin Molex Connectors + 1 X 4 Pin Floppy Power Connectors -50,8cm+15,24cm+15,24cm+15,24cm+15,24cm 1X 3X 4 Pin Molex Connectors + 1 X 4 Pin Floppy Power Connectors -50,8cm+15,24cm+15,24cm+15,24cm 2X 3X 5 Pin SATA Connectors -50,8cm+15,24cm+15,24cm 2X 6 Pin PCI Express Connectors -48,26cm Efikasnost: -prosječna 82,38% -50% load 84,46% *izvor: www.80plus.com Pozitivno: -apsolutno nečujno -pri 100% loadu moje konfe nema značajnijeg zagrijavanja -snaga -efikasnost -broj konektora* -dužine kabela* Negativno: -garancija samo godinu dana (tt daje 3 godine na ovu seriju, po novom 5, a vemil daje 1 godinu :S) -malo je većih dimenzija -previše konektora na istom kabelu -broj konektora* -dužine kabela* *ovo je totalno subjektivno mišljenje, ali malo je bed što nije modularno(mislim, postoji modularna verzija, ali je bila dosta skuplja kad sam ovo kupovo, ali želim reć da možda uopće nije ni potrebno da postoji obična verzija, već samo modularna), jer baš i nema previše smisla ovoliki broj kabela, ako se ne mogu ištekat, jer kad se ne koriste, teško ih je negdje smjestit a da ne smetaju jer ih ima previše. Bilo bi čak i bolje da ima više kablova sa manje konektora na njima, jer u slučaju da koristite jednu pržilicu koja ima samo molex utor, trebat razvuč gotovo metar dug kabel koji na sebi ima 5 konektora. moram spomenut jedan događaj, za koji je vjerojatno napajanje zaslužno što je komp preživio. tijekom jedne oluje, grom je udario u krugu 20 m od kuće u neku banderu ili tako nešto. nije nestalo struje ni na trenutak, a komp se u tom trenutku automatski izgasio, i upalio odma nakon toga. nakon nekog vremena skužio sam da je izgorio lan na matičnoj (to je bilo na nekoj staroj asusovoj matičnoj koja je tad bila u kompu), a sve ostalo je preživjelo. sve u svemu, odlično napajanje. Zadnje izmijenjeno od: pimpinjon. 22.06.2009. u 12:55. |
#35 |
80286
Datum registracije: Jul 2004
Lokacija: Dingolfing, DE
Postovi: 1,724
Codegen 400X RoHS 500W
Codegen 400X RoHS 500W Nemam sliku, a nemam s čime uslikati. Kupljeno u VeMilu za 184kn. Konektori: - 1 x 20+4 pin ATX - 4 x molex - 1 x 4-pin EPS - 2 x SATA - 1 x floppy Hlađenje: - aktivno 1 x 120mm ventilator Naponi: ![]() Nisam u mogućnosti sada izmjeriti točnu dužinu kabela, ali odokativno je neka standardna dužina i zadovoljit će veliku većinu kučišta. Mene napajanje dobro služi, bez problema gura konfiguraciju u potpisu sa overclockiranim CPU-om i još jednim dodatnim ventilatorom. Također je i prilično tiho, deklarirana glasnoća mu je 22dB. Ocijena 3/5. Pozitivno: - relativno tiho - stabilno - cijena (jer je 500W deklarirano) Negativno: - nema prekidača - cijena (jer su u tu cijenu mogli ubaciti još neke sitnice)
#36 |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
Corsair VX550w http://www.corsair.com/products/vx/default.aspx Tiho, pouzdano, stabilne voltaže, sasavim dovoljan broj konektora... Omjer cijene i kvalitete opravdan, ocjena 5/5
#37 | ||
Postovi: 7,504
EDIT: Nasljedio ga Q6600 @ 3200, i stvar i dalje radi dobro kao prije, malo se zapuše u 3D Loadu, ali ništa strašno ![]() Citiraj:
Zadnje izmijenjeno od: Baja 001. 29.06.2010. u 11:51. |
#38 |
Postovi: 7,504
Codegen 480X Napjanje OK za tadašnju P4 konfiguraciju, dočekalo ga C2D konfa. Uvijek je bilo bučno. Pozitivno: - dosta dugi kabeli - dobro se nosi sa opterećenjem (bar zasada) - jeftino Negativno: - ultra buka (2x80 mm, zamjenjeno sa CM 80mm + FM2) ![]() _______________________________________________________________________________________________________________________ Antec Phaeton 500 Napajnje od kolega, probao sam ga na ASUS P5Q + E6750 (3200) + 4GB RAMa + 2x320WD + 2xASUS DVD + nVidia 8800GTS Napajanje je iznimno tiho, vent se upali u full loadu, i ne čuje se. Stabilno je, grije se osrednje ipak radi 90% pasivno, kabeli su ok dužine. Jednostavno je meni super. ![]() Zadnje izmijenjeno od: Baja 001. 10.07.2009. u 08:06. |
#39 |
Señor Audiophile
Lokacija: Zabreg
Postovi: 3,280
Seasonic X-Series SS-650KM Posto se pokazao interes za ovaj model Seasonica napajanja pokusat cu opisati sto detaljnije u par recenica, a za pocetak LINK na stranice proizvodjaca. Dakle, da pocnemo od specifikacija ... ![]() ... neke od vaznijih stvari za napomenuti je nacin rada i unutarnja izvedba - radi se napajanju koje svoje 3.3V i 5V railove ima izvedene preko 12V raila (dakle napajanje u stvari uzima cijelu snagu preko 12V regulacije). Ovo mu omogucava da isporuci 100% svoje deklarirane snage na 12V railu, bez ikakvog opterecenja na 3.3/5V izvodima. Ono sto je zgodno za spomenuti jest nacin upravljanja "preklopnim" tranzistorima na primarnom dijelu strujnog kruga. Ovo je izvedeno pomocu serijsko-paralelnog resonantnog konvertera (LLC resonant) koji se automatski prilagodjava spojenom opterecenju, te u skladu s time mijenja nacin rada izmedju pulsne (PWM) i frekvencijske modulacije (FM). Ovo je i glavna razlika izmedju ostalih napajanja na trzistu i ovog Seasonic uratka. Dakle na ovaj nacin se ostvaruje iskoristivost najviseg stupnja - u normalnom radu gotovo uvijek 90+ % (cime je i zasluzilo 80Plus Gold certifikat). Napajanje je u radu iznimno tiho, a s obzirom da radi potpuno pasivno na manjem opterecenju (<25/30%) te da nema cvrcanja od unutarnjih elemenata, ovo je najbolja preporuka za Noise Freakove ![]() Buduci da su svi dijelovi untar njega proizvedeni od strane vrlo cijenjenih japanskih proizvodjaca, te je untrasnjost vrlo pristojno i uredno slozena ... mogu samo reci - pohvale japancima. Koristeni ventilator dolazi iz japanskog Sanyo Denkia - San Ace S1212P4M61 Podatke o termalnim karakteristikama mozete vidjeti na donjoj slici: ![]() Info o ukupno dostupnoj maksimalnoj snazi (izvan specifikacija) na ovom napajanju je prikazana na donjoj tablici: ![]() Jedini nedostatak koji se dao primjetiti nakon 2 mjeseca koristenja (osim cijene - ~1070 kn) su trunkicu prekratki kablovi, sto bi moglo najvise pogoditi ljude s vecim kucistima. Za znatizeljne evo i jednog video reviewa: "> Recenzije: JonnyGuru SilentPCReview HardwareSecrets PCPerspective HardOCP ThinkComputers ![]() |
#40 |
Postovi: 994
Corsair 400 CX Link: http://www.corsair.com/products/cx/default.aspx Pozitivno: - cijena oko 400-450 kunda trenutno - performanse - sleavani kablovi - stabilni naponi Negativno: - buka pri većem opterećenju konkretno kod mene clockani phenom IIx4, nvidia 260GTX, par ventilatora, 2 harda, 2 przilice. Napajanje vuce komp bez problema, ali je problem sto je navedena konfiguracija prejaka za njega, te je pri zahtjevnijem radu (igre) napajanje preglasno jer ventilator radi na full okretajima. |
#41 |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Coolermaster RealPower M 620W LINK: http://www.coolermaster.com/product....roduct_id=2573 Featuresi : 1.Modularized cable design to eliminate clutter and improve airflow inside the chassis. 2.Eco-design for energy and money saving by Active PFC.(>0.99) / high efficiency(>80%) 3.Two 6 pin / one 8 pin PCI-e connectors offer great future upgradeability 4.Clear color identifiable connectors for user friendiness 5.Ultra-silent operation with intelligent 120mm fan speed control (< 16dBA) 6.Multiple protection function provides full-scale protection for your components 7.Real power capacity satisfies high-end system operation 8.Five-year warranty Specke : ![]() Plus i minus,i konačni dojam : + modularno + tiho(120mm odličan vent)&hladno + dovoljno dugi kablovi(opet ovisi o cable managementu ostalih komponenti u kućištu) + kablovi su sleevani + red LED u slučaju power failurea + 2x6pcie i 8pin pcie za grafiku,sli certified,80plus certified (85% avg) + daje nešto više snage nego je deklarirano,navodni max output 700W okruglo - nedostupno u većini trgovina - preskupo (cca.800kn retail cijena) Nažalost po dobre stvari ovog napajanja,mnogi će se okrenuti Corsairu ili Seasonicu što modularnim,što "običnim" napajanjima iste,ili čak dosta veće snage za novac koji košta ovaj CM. Inače odlično napajanje,i četvrto iz CM-a u mojim kompovima,s kojim sam nekako najzadovoljniji ujedno. Cijena i nedostupnost tj. dostupnost očito samo u Feniksu mnogima će uzrokovati glavobolju,što ne znači da je napajanje loše,dapače,odlično je,samo 200kn preskupo.Ježiga,rekli bi. ![]() ![]() ![]() ![]() |
#42 | |
Varilnik
Postovi: 1,648
Chieftec Turbo Series 850W
Chieftec Turbo Series Plus -Tiho i hladno napajanje -Sleevani kablovi -Certificirano na 80+ -Dovoljno dugacki kablovi i za najveca kucista -Modularni kablovi -2x6 pin i 2x8pin pci-e konektori Minus -Prevelika cijena -Velika tezina (barem po meni) -Za tu cijenu su mogli napraviti da svi kablovi budu modularni |
#43 |
OC addict
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
Ja vec nekih godinu dana imam Fortrona PNF 400W i zadovoljan sam... Vrti X2 5000+ BE 3Ghz ,4gb ddr2,9500gt oc,dva harda,dvije przilice i dosta ventilatora jos otkad je kupljen,a od danas je tu 4850.... Al ni ne uznoji se u 3d loadu,nešto sitno jače puše nego u idleu,ali je opet kraj freezera necujno...ne grije se puno... kablovi nisu sleevani ali meni je vise bitna snaga nego izgled ....Jedini nedostatak (bar meni) je to sto nema 6pin/8pin PCI-E power konektor...al opet dobro...i to sto ima samo 2 sata kabla za napajanje...meni dovoljno jer imam (zasad) samo dva harda ali bilo bi pozeljno da ima vise.... |
#44 |
Postovi: 2,398
Corsair AX850. I da, toliko je dobro kao što ljudi na netu govore. Ja mu jednostavno nisam našao manu... Imao sam prije HX620 koje je samo po sebi fenomenalno napajanje, ali AX je još malčice bolji (obožavam onu opciju da se skinu svi kablovi, kod HX-a sam imao jedan bespotreban kabel). Uglavnom, da sada kupujem napajanje, opet bih uzeo AX-a. Jest overkill za ovu moju konfu, ali kada radi pasivno dok surfam netom...predobro. ![]() |
#45 |
Postovi: 664
fortron 400w PNF... potpis na extreme gamera u vezi konektora.. znaci stara verzija PNF-a ima samo 2 sata konektora, ostali su obicni molexi 24pin i 4pin... to je jedina mana, imam 3sata uređaja i konverter, isto kao i za graficku... tjera uredno bez problema phenom II b50 @ 3.8ghz i 1.5V, rame na 900mhz i 2hdd-a, hd5770... jedno vrijeme je bez problema tjerao i b50@3.6gh i 1.4v i 2xhd5770.... tak da s moje strane, jako zadovoljan, jedino su fail konektori, ali dobro... p.s. tisina ovisi o ventilatori koji stavite gore.. ja imam neki kineski kojeg necujem sada trenutno, al pocinje srotati svakih 4-5 mjeseci pa ga planiram zamjenit necim tisim al sa boljim protokom..
nek sam isti kao on, ma nek sam isti ko stari moj, dok zivot juri, ja cu lagano.... ![]() |
#46 |
Corsair TX650 650W Pozitivno: - dovoljno dugi kablovi, idealni za big tower kućišta - ventilator se ne čuje na mojoj Brko Gamer konfi čak ni kada se igram po par sati - sexy izgled (mat hrapava površina, crna boja, snake sleev-ani kablovi, pakiranje. izrada) - 5 godina jamstva Negativno: - cijena (konstanto je sve skuplje i skuplje) |
#47 |
1
Postovi: 3,610
Imao fortrona 400w PNF i riknulo je nekim čudom napuhane kondice su bile unutra garancija više nije trajala.Nabavio seasonic M12II-520W modularno, odlično napajanje ima dosta duge kablove, jako je tiho i pri najvišem loudu, ima 3 godine jamstva sviđa mi se i pakiranje dobi se vrečica platnena u kojoj su kablovi, za negativno nemam baš ništa reć za ovo napajanje. |
#49 |
Datum registracije: Jun 2010
Postovi: 15
#50 |
Postovi: 34,077
Corsair CX430M Radi se o novoj liniji Corsair napajanja. Po onome što piše na kutiji, radi se o 80+ Bronze kategoriji napajanja. U kutiji se dobije: naponski kabel, 10 crnih plastičnih vezica, 4 crna vijka, 4 modularna kabela. Oznaka M označava da se radi o modularnom napajanju. U realnosti se radi o polumodularnom jer su ATX i 8-pin EPS kabeli spojeni direktno sa samim napajanjem i ne mogu se odspojiti. Na napajanju postoje 4 utora u koje se stavljaju modularni kabeli. Od 4 utora, 3 su 6-pinski, a jedan je 8-pinski. 8-pinski se koristi za PCI-E 6+2 kabel, a 6-pinski za za molexe i SATA kabele. Postoje 2 SATA kabela na kojima se nalaze po 2 SATA konektora. Molex kabel na sebi ima 3 molexa i 1 floppy konektor. Svi kabeli su plastificirani tako da su tanki, a široki. Po garantnom listu, uvoznik je Asbis i ima 3g. garancije. Slike i konkretna recenzija idu kasnije.
#53 |
OC addict
Postovi: 1,001
OCZ Fatal1ty 700W - znam, overkill je za moju konfu, no svejedno: - prednosti: 80+. dosta dugacki kablovi, dosta konektora, kablovi presvuceni u nekakav sleeve, dosta snage, noise i ripple niski sve do 700+W opterecenja.... - mane: ventilator nije bas neki poseban, ako imate manje kuciste biti ce viska kablova jer ih ima dosta, nebi bilo lose da ima vise konektora za grafu, ima 2x 6+2pin.. jednom sam ga nosio kod frenda pa smo s njime vrtili 2x HD6970 + 2500k @4.5ghz bez ikakvih problema... |
#54 |
ghotic warrior
Lokacija: Jastrebarsko
Postovi: 398
Corsair HX620 (620w), 5 god. ga imam i mogu samo sve rijeci hvale... tad kad sam ga kupovao kostalo je ko danas neko 1k+ napajanje ali mi ni kune nije zao + tada je to bilo mozda jedno od 2 dostupna modularna napajanja na trzistu. ![]() |
#55 |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,630
Nedavno kupio i ubacio Corsair CX430, zasad ekstra zadovoljan, nečujno je totalno a i koliko sam čitao jako kvalitetno napajanje i best buy napajanje do 350 kn ![]() |
#56 |
Detect, Respond, Complain
Datum registracije: Dec 2011
Lokacija: Remote
Postovi: 253
Ja sam bio jako zadovoljan sa modularnim HX520w. 5 godina je bio star i onda je riknuo par dana nakon zavrsetka gare ![]() Sad imam cx430w i zadovoljan sam, tiho, kvalitetno...
I Read Logs So You Don’t Have To Zadnje izmijenjeno od: KrpaZG. 02.05.2013. u 01:06. Razlog: ... |
#57 |
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Corsair HX 650W Odlićno,jako i tiho polumodularno napajanje s Gold certifikatom i 7god. garancije što je jako pohvalno, s obzirom na snagu vjerojatno ga nikada neću moći potjerati ma max. pa ni približno opteretiti hardwerom kako sad tako i ubuduće.Volio bi da bude drugaćije ali...... i ovako zadovoljava sve moje potrebe pa i više te u neku dublju recenziju istog ni nebi ulazio, prvenstveno zbog oskudnog znanja o svim tim elementima od kojih se sastoji a sve ima na net-u![]() |
#58 |
Seasonic X-760 (SS-760KM Active PFC F3) Review ![]() Napajanje koje je zamjenilo TX650-tku nakon što je otišla sa stilom Imam ga već godinu i 4 mjeseca.Pozitivno: - full modularac - zlatni ćertifikat - dovoljno dugi kablovi, idealni za big tower kućišta, puno konektora - ventilator se pali svake prestupne godine, a otkako sam zamjenio i7 875K sa i7 2600K, sad više ni toliko - presexy izgled (mat hrapava površina, crna boja, snake sleev-ani kablovi, pakiranje. izrada, nema smrada out-of-box po jeftinoj kineskoj farbi) - 5 godina jamstva Negativno: - uvjetno rečeno cijena, no kad se vidi da ima nemodularaca za 100-200kn manje... i nije tako A Johnny Guru kaže: The Good:
The Bad:
The Mediocre:
#59 |
Skoro 4 godine mog CX 400W Corsairs! Predobra stvar! |
#60 |
Datum registracije: Feb 2010
Postovi: 187
Seasonic X-650 (SS-650KM) Overkill za moju konfu, ali kad sam ga ja kupovao koštao je dobrih 200kn manje nego sada. Osim cijene koja je sada stvarno paprena, mana je malo kratak 8pin EPS. Pošto je X 660 dobio duže kablove i to je riješeno. Brko je sve rekao o pozitivnim stvarima. Drago mi je što sam se počastio s njim ![]() Zadnje izmijenjeno od: gibo. 06.05.2013. u 17:56. Razlog: typo |
