Lokacija: /
Postovi: 2,053
![]() Dakle imam slijedeći kod kojeg HITNO trebam prebaciti iz Pythona u PHP. Nadam se da onome ko poznaje Python (i PHP) ovo neće biti problem (nema baš nešto puno koda) ![]() ![]() ![]() Code:
def find_best_run (first_array, *argv): # initialize data structures. this_array_best_run = {} for x in first_array: this_array_best_run[x] = (1, (1,), (x,)) for this_array in argv: # find the best runs ending at each value in this_array last_array_best_run = this_array_best_run this_array_best_run = {} for x in this_array: for (y, pattern) in last_array_best_run.iteritems(): (distinct_count, lengths, elements) = pattern if x == y: lengths = tuple(lengths[:-1] + (lengths[-1] + 1,)) else : distinct_count += 1 lengths = tuple(lengths + (1,)) elements = tuple(elements + (x,)) if x not in this_array_best_run: this_array_best_run[x] = (distinct_count, lengths, elements) else: (prev_count, prev_lengths, prev_elements) = this_array_best_run[x] if distinct_count < prev_count or prev_lengths < lengths: this_array_best_run[x] = (distinct_count, lengths, elements) # find the best overall run best_count = len(argv) + 10 # Needs to be bigger than any possible answer. for (distinct_count, lengths, elements) in this_array_best_run.itervalues(): if distinct_count < best_count: best_count = distinct_count best_lengths = lengths best_elements = elements elif distinct_count == best_count and best_lengths < lengths: best_count = distinct_count best_lengths = lengths best_elements = elements # convert it into a more normal representation. answer = [] for (length, element) in zip(best_lengths, elements): answer.extend([element] * length) return answer # example print find_best_run( [1,4,8,10], [1,2,3,4,11,15], [2,4,20,21], [2,30]) # prints [4, 4, 4, 30] |
Lokacija: /
Postovi: 2,053
Pa zar nitko? :/ |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,748
