Povratak   PC Ekspert Forum > Računala > Software > Web dizajn, programiranje i ostalo
Staro 19.02.2011., 16:33   #1
svebee
Lokacija: /
Postovi: 2,053
Arrow [HITNO] Prebacivanje Pythona u PHP
Dakle imam slijedeći kod kojeg HITNO trebam prebaciti iz Pythona u PHP. Nadam se da onome ko poznaje Python (i PHP) ovo neće biti problem (nema baš nešto puno koda) . Unaprijed zahvaljujem Plaćam ako treba, ali valjda ima još dobrih kolega
Code:
def find_best_run (first_array, *argv):
    # initialize data structures.
    this_array_best_run = {}
    for x in first_array:
        this_array_best_run[x] = (1, (1,), (x,))
    for this_array in argv:
        # find the best runs ending at each value in this_array
        last_array_best_run = this_array_best_run
        for x in this_array:
            for (y, pattern) in last_array_best_run.iteritems():
                (distinct_count, lengths, elements) = pattern
                if x == y:
                    lengths = tuple(lengths[:-1] + (lengths[-1] + 1,))
                else :
                    distinct_count += 1
                    lengths = tuple(lengths + (1,))
                    elements = tuple(elements + (x,))
                if x not in this_array_best_run:
                    this_array_best_run[x] = (distinct_count, lengths, elements)
                else:
                    (prev_count, prev_lengths, prev_elements) = this_array_best_run[x]
                    if distinct_count < prev_count or prev_lengths < lengths:
    # find the best overall run
    best_count = len(argv) + 10 # Needs to be bigger than any possible answer.
    for (distinct_count, lengths, elements) in this_array_best_run.itervalues():
        if distinct_count < best_count:
            best_count = distinct_count
            best_lengths = lengths
            best_elements = elements
        elif distinct_count == best_count and best_lengths < lengths:
    # convert it into a more normal representation.
    answer = []
    for (length, element) in zip(best_lengths, elements):
        answer.extend([element] * length)
    return answer
# example
print find_best_run(
    [1,4,8,10],
    [1,2,3,4,11,15],
    [2,4,20,21],
    [2,30]) # prints [4, 4, 4, 30]
svebee je offline   Reply With Quote
Staro 20.02.2011., 11:13   #2
svebee
Lokacija: /
Postovi: 2,053
Pa zar nitko? :/
Staro 20.02.2011., 13:18   #3
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,753
Autor svebee Pregled postova
Pa zar nitko? :/
Zasto s konja na magarca?
BTW, vidim da su ti "zahtijevi" sve veci, pa ces definitivno morati ili izbudjetirati programere, ili naci vise vremena.
Programer
