Staro 10.02.2011., 01:32   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
SAPPHIRE launches Xtend TV Graphics Card
Leading graphics card supplier, SAPPHIRE Technology has just launched a new TV tuner card with a difference - the SAPPHIRE HD 5570 XtendTV card.
The SAPPHIRE HD 5570 XtendTV card is a single slot PCI-Express graphics card with 1GB of GDDR5 memory and HDMI and DVI outputs – and a built in programmable TV tuner. Connected to a standard TV antenna signal, it will receive and decode all of the local free to air TV and radio stations*. Just as with a regular TV tuner, the user can watch TV on the host PC using Media Center – record, save and playback programs at will.
But XtendTV does more. Installing the FlexiStream software on the PC in which the card is installed enables the PC as a streaming server and users can watch all of their home TV programmes anywhere in the world using the XtendTV client on a remote PC or laptop**.
Based on FlexiTV and FlexiStream technologies from Mirics, the SAPPHIRE XtendTV solution uses the Accelerated Parallel Processing (stream processing) capability of the on-board HD 5570 graphics chip to decode the TV signals smoothly and to compress the stream for viewing over the internet.
No licence or IP issues !
With SAPPHIRE Xtend TV you are watching programmes on your own PC – streamed to you over the internet on a one-to-one basis – so there are no blocks on the availability of programmes wherever you may be – and no additional licence required.
SAPPHIRE HD 5570
The HD 5570 is a member of the SAPPHIRE HD 5000 series which is supported by AMD's Catalyst DirectX 11 WHQL certified graphics driver. This generation of hardware delivers support for all of the key Microsoft DirectX 11 level features including DirectCompute 11 instructions, hardware Tessellation and multi-threaded communications with the system CPU. It also supports Accelerated Parallel Processing, accelerating supported applications such as video transcoding and rendering tasks by executing instructions on the GPU architecture rather than the system CPU.
Ideal for media applications, all members of the SAPPHIRE HD 5570 series have an on board hardware UVD (Unified Video Decoder) considerably reducing CPU load and delivering smooth decoding of Blu-ray™ and HD DVD content for both VC-1 and H.264 codecs, as well as Mpeg files. In the SAPPHIRE HD 5000 series the UVD has been enhanced to be able simultaneously to decode two 1080p HD video streams and to be able to display HD video in high quality with Windows Aero mode enabled. It supports HDMI 1.3a with Dolby TrueHD and DTS-HD Master Audio.
About Mirics technology
Mirics FlexiTV is a multi-standard broadcast TV receiver for personal computer and portable processor-based devices. Using the PC’s processor for demodulation, any digital TV and radio standard can be received, resulting in a highly optimized multi-standard receiver platform. This allows maximum standards flexibility, and a single hardware design for worldwide terrestrial TV and radio reception.
FlexiStream™ is an innovative extension to the FlexiTV platform. FlexiStream utilizes a FlexiTV-enabled home-server (such as a desktop PC) for local reception, viewing and recording of live broadcast content. The FlexiStream server software then provides real-time re-formatting and IP-streaming of the live or previously recorded TV to a portable device featuring the FlexiStream client software - anywhere in the world.
Note* - DVB-T only at launch.
Note** - Other portable apps in development.
Staro 10.02.2011., 01:45   #2
Mad_Duke
Bilo je i vrijeme.
Samo tri zamjerke.
1. Mogli su temeljiti rađe na 6xxx seriji pošto još manje troši (iako je ovo hladno do ibera)
2. Mogli bi biti low profile
3. Bilo bi super da je dual-dvb-t.
Iako mi se sviđa mnogo jer je idealna za HTPC. Puno sam veći fan dedicated grafa + neka najjeftinija matx ili mitx matična od integriranih rješenja. Low profile ne bi uopće smetao veličini jer bi u takvu konfiguraciju stavio interni hard skup sa kučište
Anywayl Bilo je i vrijeme!
Staro 10.02.2011., 06:21   #3
Charmander
Ultrapiretik
Charmander's Avatar
Postovi: 903
izgleda da se vracaju na AIW modele.
Moja trgovanja: 1, 2, 3, 4, 5, 6, 7, 8
Picoin invite: bass999 // minepi.com/bass999
Charmander je offline   Reply With Quote
Staro 10.02.2011., 18:26   #4
Minox
Minox's Avatar
Postovi: 565
to je najbolja serija od atia bila,steta kaje vise neproizvode
Minox je offline   Reply With Quote
Staro 11.02.2011., 13:52   #5
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,142
Autor Jelc Pregled postova
Eh, novi TV wonder mi radi savrseno i ovo me bas previse ne dira. Jedino, volio bih uvijek imati kartu manje i vratiti se na AIW onboard pricu. Ali ovo je po izlazima jos gore od proslog HD AIW-a
Ispravak, ovo su identicni izlazi AIW HD-a!
Bas primarno za HTPC. Kako to da se Sapphire šepuri s ovim tuneriranjima samostalno? Hoce li to reci da ATI isto izbacuje nesto onboardtasticno?
Staro 11.02.2011., 14:47   #6
Jelc
Super Moderators
Postovi: 17,485
Bilo bi lijepo da je low-profile barem
Staro 11.02.2011., 14:52   #7
windfucker
Ili da je barem pasivno, kada već nije low profile...
Staro 11.02.2011., 15:42   #8
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,142
Istina, za HTPC bi niska pasivka bila pozeljnija.
Ali ne koristi nikakav poznati termin ATI MM kucnih naziva. XtendTV je koliko vidim nekakvo vlastito kombiniranje u prosirenje MM ponude?
Staro 11.02.2011., 15:45   #9
syss
syss's Avatar
Postovi: 10,805
da je dual dvb, mam je maznem
Staro 11.02.2011., 17:22   #10
domis
Lokacija: Hrvatistan
Postovi: 4,164
ako budu izbacili graficku srednjeg segmenta (hd*600 ili hd*800 serije) s tv tjunerom i da na nju moze pasivno twinturbo, kupujem
Staro 21.02.2011., 12:50   #11
Jelc
Super Moderators
Postovi: 17,485
Baš me obavjestil jedan endivijaš da ih ima i kod nas
http://www.adm.hr/product_info.php?products_id=9759
