Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI Tray Tools 1.0.1.500
Evo i nove verzije. Novo je: Added Support for last Radeon models Experimental support for Windows XP 64bit/ 2003 64bit Improved TV/Display support, updated "Default Single Display" profile Updated Display information All registry operation for Catalyst settings are moved to low level driver Added new utility "Low Level Driver Installation" Improved 3D Renderer Added option to set minimum allowed artifacts count Added new options in 3D rendered Update artifact scanning procedure Updated System Information module Updated "High precision" overclocking mode Added hot key to reset display driver Added new module "Monitor Graphs", at this moment you can control speed of GPU/Memory, Added "Hardware Monitoring" module Added option to dump current Video BIOS to file (experimental mode) Added option to show current assigned hotkeys in "General Settings" dialog box for Audio Recorder and ScreenShot maker Added FAN Control to "Overclocking Module" Added 2 new hot keys to operate with FAN Speed Changes in Overclocking Window Now if you close ATT manually default clocks for GPU/Mem will be applied Added confirmation message to "Save icon positions" Fixed bug with OpenGL MipMap and LODBias settings when both of them after reinstallation of Catalyst driver were reset to High Speed instead of High Quality Fixed some interface bugs Fixed MMC applications detection routine Fixed bug with Display profiles when Overscan mode were no saved to profile Fixed bug when ScreenShot system unable to make screen shot with Primary Monitor attached to second DVI port http://fileforum.betanews.com/download/1086738656/1 |
Lokacija: VG
Postovi: 1,128
Fala, fala :clap: :clap: |
