Datum registracije: Jan 2011
Postovi: 79
Problem s kamerom
Molim malu pomoć, Naime kći ima asus k50ip nedavno kupljen dakle ima garanciju. Problem je u kameri koja daje sliku naopako, pa ako netko zna što i kako da napravim da se slika okrene u normalu a da ne idem zbog toga u servis ako nemoram. Hvala unaprijed. |
Lokacija: slavonac
Postovi: 495
Kako naopako? Naglavačke ili kao odraz u zrcalu? Pogledaj u opcijama kamere .
he,he |
Ekspert iz sjene ...
Lokacija: New Eden
Postovi: 3,801
Čini se da je problem u driveru. Nakon 7 sekundi Google-a. i'm using a K40IN and it used to have the same problem. Current OS is Windows 7 Ultimate 64bit. here's what i did. 1. download the latest Chicony (or Suyin) driver for Windows 7. 2. extract contents to desktop. 3. click the ORB button. right-click on Computer and select Properties. 4. select Device Manager. 5. click on Imaging Devices to show the name of the webcam. 6. right-click on the name of the webcam and select Properties. 7. go to the Driver tab. click on Update Driver. a new window should pop-up. 8. click 'Browse my computer for driver software'. select 'Let me pick from a list of device drivers on my computer'. 9. on the next window, it'll give you the current driver. click 'Have Disk'. click Browse. Browse to the desktop and select lastest driver that you've downloaded. it'll be then added to the list of drivers. select the new driver and click Next. Just follow the prompts so that it'll install the new driver. that should solve the problem. http://vip.asus.com/forum/view.aspx?...Language=en-us Sretno. |
Postovi: 12,607
A i vise puta na forumu receno za taj problem. Lockam ovo.
