Staro 26.01.2011., 13:57   #61
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
EVGA Introduces Duo of GeForce GTX 560 Ti Graphics Cards
EVGA kicked off its GeForce GTX 560 Ti offer with two models: a base model (01G-P3-1561-AR), and a SuperClocked model (01G-P3-1563-AR). Both cards stick to NVIDIA's reference board design (PCB and cooler). The base model comes with "Free Performance Boost", it's slightly overclocked out of the box, while being priced on par with graphics cards that stick to NVIDIA reference speeds. The base model is clocked at 850/1700/1026 (4104) MHz (core/CUDA cores/memory actual (effective)), vs. reference speeds of 820/1640/1000 MHz. It is priced at US $249.99.
The SuperClocked model, on the other hand, features significantly increased clock speeds (over reference) of 900 MHz core, 1800 MHz CUDA cores, and 1053 MHz (4212 MHz effective). This variant is priced at $269.99. Both cards claim to be superior over non-reference design implementations that use PCBs with lesser number of layers, and lesser number of GPU electrical phases.
http://www.techpowerup.com/139210/EV...ics-Cards.html
Nakon Gigabyte SOC verzije i iz Evge stiže tvornički nabrijana GZX-ica.
C L O W N I N G A R O U N D
Staro 27.01.2011., 12:38   #62
brunex
brunex's Avatar
Lokacija: Osijek City
Postovi: 97
Autor MAGARAC Pregled postova
Ovaj score od 5135 u 3d11 sa naklokanom 560 mi se cini los..
posebno kad vidiš na kojem CPU je testirano.
stavi je na neki prosječni quad nećeš imati ni 4000
moraš imati bar dobro clocknuti i5 da dobiješ score kao i 6870.
brunex je offline   Reply With Quote
Staro 27.01.2011., 20:31   #63
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,826
Sa cijenom od 2.350-2.600 kn ne čini mi se baš toliko bolja kupnja u odnosu na GTX 460/470 seriju. U odnosu na GTX 460 je preskup, 1 Gb ima po 1.400 kn hrpa modela, a u odnosu na GTX 470 kojih ima po 1.900 kn je premala razlika u performansama. Sad će ispasti da se u srednjoj klasi nalazi hrpa kartica, od GTX 460 768 Mb model kao donja srednja klasa pa sve do GTX 560 kao gornja srednja klasa. A razlika ono, par desetaka kuna/par FPS-a...
Staro 27.01.2011., 21:59   #64
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Dvije GTX 460 1Gb u SLIu pojedu jednu 570(vjerovatno i 560) prema nekim testovima i jos ispadne jeftine uzet dvije grafe serije 4 neg jednu serije 5 ..
cijene
http://www.pc4u.hr/proizvod/ASUS-90-...it--55212.aspx
http://www.adria-computers.hr/index....oduct_id=57287
viper je offline   Reply With Quote
Staro 27.01.2011., 22:07   #65
Astral
Postovi: 2,523
siguran sam da ce se cijene malo korigirat tokom slijedecih dana
Astral je offline   Reply With Quote
Staro 27.01.2011., 22:14   #66
MAGARAC
MAGARAC's Avatar
Postovi: 5,990
Morat ce jer se za 200kn vise dobije mocnija gtx 570. Ja sam mislil da bu cijena ko gtx470. 1900 do 2000kn ili cak malo manje. Da ne spominjaem da svaka gtx 460 ima slicne pref. bez mnogo muke.
Staro 27.01.2011., 22:18   #67
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Grafa GTX 560 Ti bi trebala napasti segment Ati-a 6870 i 6950 1GB,470 GTX kako performansama tako i cijenom znaći ispod 2.000kn u suprotnom fail jer ako 6950 2GB dođe manje od 2.200kn onda 560 Ti nema što tražiti s tom cijenom u tom tržišnom segmentu.Naravno sve zavisi koja će cijena biti 6950 1GB.Uglavnom jako gusto oko 2.000kn glede kupnje i izbora.
NVIDIA GeForce GTX 560 Ti 1GB Review - Page 20
Staro 27.01.2011., 22:19   #68
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Cijena definitivno previsoka, pogotovo jer se za tu cijenu mogu naći HD6950 2GB pokraj kojih ova nema što raditi.
Nadam se price cutu, iako sam pomalo razočaran karticom.
fran123456 je offline   Reply With Quote
Staro 27.01.2011., 22:31   #69
MAGARAC
MAGARAC's Avatar
Postovi: 5,990
Kako ne, pogledaj review od Gigabyte 560 SOC grafe. Prakticki je ista kao i 6970 i jos ima 50+ mhz lufta na GPU. 69xx sa 2gb imaju pravu prednost na 2560 x 1600 sa aa a sve nize od toga je isti vrag.
384sp nije malo na Fermiju a kad dela na 1000mhz je jako brzo i dobici su veliki u odnosu na ref grafu jer shaderi u odnosu 1:2. Ta grafa sa taktom bez problema kompenzira 100njak sp manje u odnosu na 570 i vidim da se moze pribliziti i 580tki.
Mene isto na prvu malo razocarala ali sto vise citam reviewju to mi se vise svida i kad bi cijenu spustili na 2000, nebi uopce bilo dvojbe.
Zadnje izmijenjeno od: MAGARAC. 27.01.2011. u 22:45.
Staro 27.01.2011., 22:44   #70
ECHO
Postovi: 2,354
Da ukoliko bi cijena tih nereferentnih grafa bila cca 2.200kn onda OK, ali referentna grafa nevrijedi tu cijenu s obzirom što nudi barem glede testiranja na linku koji sam dao jer su performanse podjednake sa jeftinijim modelima konkurencije 6870/6950 1GB/470 GTX pa čak je cijenom ista sa 6950 2GB, naravno sve se one daju clockati u nebesa i podižu performanse ali ukoliko gledamo uloženo/dobiveno onda to baš i nije tako glede 560 GTX.Ukoliko cijena padne ispod ili oko 2.000kn onda bi to bila dobra kupnja.Valjda će cijena malo pasti to ide svima u korist
Staro 27.01.2011., 23:21   #71
Sinac
Sinac's Avatar
Postovi: 2,826
Pa ako su prvi modeli već po 2.250 kn, mogli bi slijedeći modeli biti i jeftiniji. Naravno da je ovo malo nabrijani Asusov model sa boljim taktovima i hladnjakom, cijena mi se čini opravdana ako će "vulgaris" modeli biti ispod 2.000 kn. Sve u svemu, mislim da nisam pogriješio kada sam u 11. mjesecu ulovio MSI Hawk Talon za 1.450 kn, mislim da sam sada iduće dvije godine miran što se grafike tiče, GTX 275 je bila taman, da nisam imao prilike dobro je udomiti u jedno rabljeno računalo bila bi i danas u pogonu. Mislim da je sada ciklus od neke dvije godine nekako OK za zamjenu grafičke, ne skačem za svakim novim modelom kada se neki pojavi. Ionako bi GTX 600 mogao iskočiti negdje pred idući Božić...
Staro 28.01.2011., 00:16   #72
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor viper Pregled postova
cijene
ovo su cijene u shopovima u kojima ne bi kupio ni pastu za cooler, a kamoli nesto za 2k kn
cijena ce sigurno biti ispod 2000 kn
DeadMan+ je offline   Reply With Quote
Staro 28.01.2011., 01:06   #73
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Ovo je strasno, vani su ispod 220€
Kakav fail nasih trgovina, za nepovjerovat
Staro 28.01.2011., 15:05   #74
Overhaul
Overhaul's Avatar
Postovi: 517
Dvije gtx 460 1gb sli? Pa ono sto sam ja mjerio kod mene, jace su i od gtx580, ili u egalu.
Okej, nemam bas stock gtx460tke, ali gotovo da i nema stock gtx460tki u ponudi kad se daju lako i za potrosnju i grijanje bezbolno ubrzati iznad podcjenjenih frekvencija. Mene u biti nije toliko impresionirala gtx560... ne zato jer kiselim susjedovo grozdje, nego jer je, budimo realni, gtx460 bila osjetnije osvjezenje kad je izasla. Kao sto je netko rekao, prevelik je postao raspon cijena za premalo razlike u performansama u ovoj klasi.
No ajmo vidit kolko ce u nas traziti novaca u normalnim ducanima,
ipak se prema tome sve ravna.
Zadnje izmijenjeno od: Overhaul. 28.01.2011. u 15:12.
Overhaul je offline   Reply With Quote
Staro 28.01.2011., 16:47   #75
T0X1C
n00b
T0X1C's Avatar
Postovi: 246
A vidi, nVidia je ispeglala Fermi koliko je mogla, GTX460 jest bila stvarno osvjezenje (pogotovo kad se sjetim kako je bilo popularno srati po Fermiju kad je tek izasao) ali nakon nje nece tu bit opet nekih velikih pomaka jer Fermi je dosao na ono sto je trebao i bit prije...
Sad je samo pitanje cijene, spusti li se to ispod 2000kn, 560 postaje sasvim ok izbor...
T0X1C je offline   Reply With Quote
Staro 28.01.2011., 17:18   #76
Overhaul
Overhaul's Avatar
Postovi: 517
Tako je... ali budimo realni, prekratko je ovo razdoblje (koliko, prije 6 mjeseci izašle gtx460 ?) da bi se iznjedrile bitne promjene u potrošnji i performansama, to su samo tweakovi sa Nvidiji uobičajenim
rename-anjima serija...
-makar su dosta ove 560tke kasnile za flagship 580/570, to je valjda više bilo čekanje konkurencije i čišćenja ormara punih gtx470 i sličnih, a manje zbog rekonfiguriranja chipseta, kao što je to onomad bilo sa gf104 u odnosu na gf100... Aj, fora mi je povratak "titanium" sufixa, to ce valjda znaciti da će izići i "obične", jeftinije 560tke sa recimo 768 mb rama?
Ništa, valjda je to to na ovom 40nm proizvodnom procesu. Ako se ne polakome pa renameaju iste kartice za 6 mjeseci.
Staro 28.01.2011., 19:11   #77
ECHO
Postovi: 2,354
U Diskont24 grafa 6950 1GB 1.950kn(bogme gusto u tom segmentu modela i razlika cca 150kn jeftinija od 2GB modela) ukoliko toliko bude i 560 Ti onda bi mogla doći u obzir kupnja iste zasada preskupa, valjda će sljedeći tjedan doći u naše trgovine u nabavljivim količinama, a ne samo na cijenik(trenutno nedostupne)
Staro 30.01.2011., 13:33   #78
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,855
po meni cjena mora past na 1800kn.
Staro 31.01.2011., 09:04   #79
Nick7
Lokacija: Velika Gorica
Postovi: 1,524
... treba prvo rasprodati zalihe GTX460 i sl....
Staro 31.01.2011., 12:38   #80
MAGARAC
MAGARAC's Avatar
Postovi: 5,990
Ovo je vec puno bolje i izgleda sasvim ok..
http://217.14.221.177/StartEU.ashx?_...R6BKzQSNPnGX9Y
Staro 31.01.2011., 13:04   #81
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
prt scr je offline   Reply With Quote
Staro 31.01.2011., 13:12   #82
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
1800 kn je bilo za ocekivati, ta cijena je sasvim prihvatljiva
Staro 31.01.2011., 13:32   #83
T0X1C
n00b
T0X1C's Avatar
Postovi: 246
Pa ovo je super vijest, fino fino, nVidia grize i dalje, mogla bi i jedna GTX560 uletit s novim kompom, ovaj je dosta dugo sluzio.
Staro 31.01.2011., 13:40   #84
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,355
IQ zadria piše da ima 128bita :S
Staro 31.01.2011., 13:45   #85
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
to ne postoji, gtx 560 ti imaju samo sa 256 bitnom sabirnicom
Staro 31.01.2011., 13:49   #86
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,355
pa znam zato i gledam wtf
Staro 31.01.2011., 14:06   #87
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Uf jel se to samo meni cini ili ova kartica ubi bilo kakvu isplativost gtx470, hd6870 i hd6950 2gb modela? Pitanje je jedino jel bu toliko kostala kad dodje na skladiste. I ak bude ta cijena, hoce li biti jos jeftinijih referentnih modela. Jer ovo je OC kartica s Windforce hladnjakom, najs!
tole_ je offline   Reply With Quote
Staro 31.01.2011., 17:22   #88
stipe1771
stipe1771's Avatar
Lokacija: split
Postovi: 233
stipe1771 je offline   Reply With Quote
Staro 31.01.2011., 17:58   #89
ECHO
Postovi: 2,354
http://tweaktown.com/cgi-bin/dada/ma.../364626054708/
Evo ovakva grafa je bila na stanju trgovine PC4U i neko mi ju uzeo ispred nosa isto zvijer od grafe cijena 2.200kn
Staro 31.01.2011., 18:35   #90
MAGARAC
MAGARAC's Avatar
Postovi: 5,990
99% sam siguran da ce se uskoro pojavit MSI 560 Twinfrozr2 i da nece bit preskupa kao ni Gigabyteovi modeli koje uvozi Microline. Tak da ti i nije neka steta jer je po mnogima TF2 trenutno najbolji cooler i mislim da nema potrebe dalje trazit. Inace sa Gainwardicama sa hladnjacima u tom stilu nemam bas dobrih iskustva, puno buke nizasto. 2200 kn je previse. Rade se malo strpi i pricekaj da stigne vise modela. Ja bi osobno isao ili na SOC ili TF2. Prvu jer je ultra brza a drugu zbog hladnjaka.
