Staro 19.01.2011., 10:37   #6991
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Cyc, prokleti exploiter.Puuu!
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 19.01.2011., 17:36   #6992
Moshus
Moshus's Avatar
Datum registracije: Nov 2010
Postovi: 180
jel se isplati kupovati rabljenu igru? tj, dali će me banat sa servera zbog toga što se spajam sa istim serijskim sa druge IP adrese?
Moshus je offline   Reply With Quote
Staro 19.01.2011., 17:41   #6993
RaWeN
RaWeN's Avatar
Datum registracije: Aug 2009
Postovi: 637
Autor Moshus Pregled postova
Isplati se i neće te banat.
RaWeN je offline   Reply With Quote
Staro 19.01.2011., 18:22   #6994
Dottore
Dottore's Avatar
Postovi: 7,696
Čini mi se da je riješen problem zadnji driveri od Nvidie. Nema više nestanka slike na nekoj sekundi.. Ide dosta stabilno s 8800 GTS 320.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 19.01.2011., 18:44   #6995
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Nova je 120kn pa se po meni baš i ne isplati.
Veki-os je online   Reply With Quote
Staro 19.01.2011., 18:50   #6996
Moshus
Moshus's Avatar
Postovi: 180
gdje? ako je online, neda mi se s tim zaje...., a ova rabljena je 80kn tak da ono... i to rabljena tako da je samo single player isproban.
Staro 19.01.2011., 19:43   #6997
Rudy
Rudy's Avatar
Postovi: 169
svaki dan ti se mijenja IP adresa...kud bi dosli da banaju ako ne spajas konstantno sa iste IP adrese
Rudy je offline   Reply With Quote
Staro 19.01.2011., 19:54   #6998
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
Meni taj deal malo smrdi...
Ko bi kupio origigi boxanu igru i probao samo single player?
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 20.01.2011., 10:36   #6999
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Možeš frende sve, ovdje ni čitere ne benaju.
Staro 20.01.2011., 16:03   #7000
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Isuse Bože.Pogledajte ovog Kobashi-ja iz mog i Jurbasovog squada.Partija od prije dvije minute.
Staro 20.01.2011., 16:04   #7001
Neo-ST
Neo-ST's Avatar
Postovi: 8,532
Haha, ovaj je cheater, ali obrnuti !
Jesi mu napisao "l2p" ?
Staro 20.01.2011., 16:07   #7002
roflcopter000
roflcopter000's Avatar
Lokacija: Vukovar
Postovi: 54
Autor Mansky Hunt Pregled postova
a ja mislio da sam ja loš, no aj mozda je imo zajefrknuti dan....
Small words from a small mind. The even now your demons think of nothing but how best to cook you when you have outlived your usefulness. You are a fool among untold numbers of fools. The Imperium will show you no mercy, only death Heretic.
roflcopter000 je offline   Reply With Quote
Staro 20.01.2011., 17:50   #7003
ezz
ezz's Avatar
Datum registracije: Feb 2010
Postovi: 297
za kobashija postoji sam jedan put
start/control panel/add remove programs/bad company 2
ezz je offline   Reply With Quote
Staro 21.01.2011., 14:33   #7004
Thund3rman
Thund3rman's Avatar
Datum registracije: Dec 2010
Postovi: 104
Kako bi si mogao vidjeti statse na bfbc2?
Registrirao sam se i idem na update i nista, pise samo Update (Queue is full at 5000 Try again!) i tako vec 5 dana...
Thund3rman je offline   Reply With Quote
Staro 21.01.2011., 14:39   #7005
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor Thund3rman Pregled postova
probaj na :
http://www.bfbc2.eu
ili na:
http://bfbc2.statsverse.com/
DeadMan+ je offline   Reply With Quote
Staro 21.01.2011., 16:11   #7006
Thund3rman
Thund3rman's Avatar
Postovi: 104
Hvala Deadman+... regao sam se i sad mi je jedino cekat....
Staro 21.01.2011., 16:14   #7007
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Sta se imas regat :S bfbc2.eu upises svoje ime sacekas par min i to je to
Staro 21.01.2011., 16:34   #7008
Thund3rman
Thund3rman's Avatar
Postovi: 104
ma kako god, sad mi radi... sve 5
Staro 21.01.2011., 18:53   #7009
BojanZD
BojanZD's Avatar
Postovi: 1,398
Neki dan, igram heavy metal i lik se skampa negdje u grmlje u blizini naše baze i samo čeka da netko sjedne u heli-odmah ga skine.
U životu nisam toliko psovao...da mi je bilo uhvatit malog švabu mamicu mu..
Još se kao pravi glup,ne špreha engleski..o čem ja pričam...al mislim da me razumio?!
BojanZD je offline   Reply With Quote
Staro 21.01.2011., 21:24   #7010
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
moj najdrazi zaposlenik u DICE-u (bez sarkazma) se oglasio u vezi statsa:
MikaelKalms: The stats system - a performance perspective
btw.
Downtime for BFBC2 PC,360,PS3 sometime during next week (Jan 25th-28th)
We will take down the backend a couple of hours for maintenance work on all platforms. The purpose is to improve performance of the stats system, to reduce/eliminate stats outages.
Zh1nt0 will get back to you with a more accurate timing for the downtime on Monday.
If you have a lot of time to kill, this thread contains some background info.
Staro 22.01.2011., 01:56   #7011
2 die 4
2 die 4's Avatar
Postovi: 2,276
Autor BojanZD Pregled postova
Da nisam to bio ja,
Jednu sam večer našao server sa tom mapom i 1000ticketa po rundi a samo se ta mapa vrti gore, e predobra zabava za mene i moj stil igre, kada se hoću sčilat od strke i panike onda odem na tu mapu!
Isto tako sam jedno 10 minuta rejpao nekog snajperistu koji je uporno bio glup i spawnao se tu a ja sam ga uporno svaki put sašio i dakako svakoga tko je pomislio ući u heliće
RedGreenBlue
Staro 22.01.2011., 09:56   #7012
Red Dwarf
Bajker s AMD-om na dresu
Red Dwarf's Avatar
Postovi: 960
Autor DeadMan+ Pregled postova
bolje bi bilo da je purpose optimizacija igre...je*e mi se za statse ako mi igra šteka -.-
samo jedno malo pitanje : brončani, srebrni i zlatni dogtagsi : kako se dobivaju. Mislim znam kako se dobivaju dogtagsi, ali o čemu ovisi brončani, srebrni ili zlazni. Je ima neka podjela na levele ili?
Red Dwarf je offline   Reply With Quote
Staro 22.01.2011., 10:09   #7013
white.banana
Lokacija: Kroejša
Postovi: 107
Autor Red Dwarf Pregled postova
Iznad 40-tog levela ti je zlatni, ostali su vjerojatno ispod
white.banana je offline   Reply With Quote
Staro 22.01.2011., 15:47   #7014
BojanZD
BojanZD's Avatar
Postovi: 1,398
Autor 2 die 4 Pregled postova
Da nisam to bio ja,
Nadam se da nisi, u tom trenu sam imao napade ludila kao što mansky zna imat na TS-u, znaš kak to zvuči!!
Staro 23.01.2011., 18:56   #7015
B@re
B@re's Avatar
Lokacija: Split,Hrvatska(Croatia)
Postovi: 313
Iman jedno pitanje.... posudia mi je prijatelj svoj EA account sa original BFBC2 naravno, na kojem ima svoja dva lika koja inace igra.. e sad.. problem je sta ja nemam original instalaciju i naravno mora san skinit onu "drugu" , i uglavnom, ja normalno sve patcham udjem u igru ulogiram se uredno na account vidim statse, vidim likove, ALI nemogu niti jedan server naći niti se mogu joinat igdi kad stisnen play now, samo mi kaze no available games, zašto?
B@re je offline   Reply With Quote
Staro 23.01.2011., 19:15   #7016
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor B@re Pregled postova
play now ne radi, a osim toga i kad slucajno proradi spoji te na server u Australiji ili negdje jos dalje
odi u server browser i tamo se spoji na neki europski server
btw. ne moras igrati s njegovim likovima, mozes napraviti novog, ali svi ce biti vezani za jedan EA account
Staro 23.01.2011., 19:19   #7017
PointDexter
Lokacija: Éire
Postovi: 1,812
zašto?
Kod instalacije na svoj komp si koristio njegov game key?
Staro 23.01.2011., 19:44   #7018
B@re
B@re's Avatar
Postovi: 313
Nisam koristia njegov key(kupia ga je preko neta i otkad je rega sebi account nema blage veze di mu je key),nego sam kreka.., update sam napravia normalno... i normalno mi se uloga na account njegov i vidin sve charactere i statse (znam da mogu napravit svog lika al mi to nije bitno).....prije mi je radilo normalno bez obzira na crack... a sad nece neznan zasto ....
btw server browser mi ne nalazi nijedan server...
Zadnje izmijenjeno od: B@re. 23.01.2011. u 20:04.
Staro 23.01.2011., 19:57   #7019
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Dok te netko od modova još nije vidio makni ovaj dio kraj skidrow (za svoj acc to učini)
a i ako se logiraš preko njegovo acca zar nije logično da si instalirao preko njegova keya ? :S
54' / 74' / 90' / 2014
Zadnje izmijenjeno od: panda505. 23.01.2011. u 20:14.
Staro 23.01.2011., 19:59   #7020
CyCl0p$
a ti si ga mudro citirao tako i ako editira opet ostaje
inace, mora se koristiti origigi cd key prilikom instalacije inace nema nista od igranja online.
