#6991 |
Addicted to music.
Postovi: 1,782
Cyc, prokleti exploiter.Puuu!
All you have is your fire and the place you need to reach. Don't you ever tame your demons, always keep them on a leash. |
#6993 |
Datum registracije: Aug 2009
Postovi: 637
#6995 |
Datum registracije: Jun 2004
Postovi: 3,996
#6998 |
Lokacija: Éire
Postovi: 1,810
#6999 |
Addicted to music.
Postovi: 1,782
Možeš frende sve, ovdje ni čitere ne benaju.
#7000 |
Addicted to music.
Postovi: 1,782
#7002 |
Lokacija: Vukovar
Postovi: 54
Small words from a small mind. The even now your demons think of nothing but how best to cook you when you have outlived your usefulness. You are a fool among untold numbers of fools. The Imperium will show you no mercy, only death Heretic. ![]() |
#7005 | |
LateralusX
Postovi: 1,788
http://www.bfbc2.eu ili na: http://bfbc2.statsverse.com/ |
#7009 |
Postovi: 1,398
Neki dan, igram heavy metal i lik se skampa negdje u grmlje u blizini naše baze i samo čeka da netko sjedne u heli-odmah ga skine. U životu nisam toliko psovao...da mi je bilo uhvatit malog švabu mamicu mu.. Još se kao pravi glup,ne špreha engleski..o čem ja pričam...al mislim da me razumio?! |
#7010 |
LateralusX
Postovi: 1,788
moj najdrazi zaposlenik u DICE-u (bez sarkazma) se oglasio u vezi statsa: MikaelKalms: The stats system - a performance perspective btw. Downtime for BFBC2 PC,360,PS3 sometime during next week (Jan 25th-28th) We will take down the backend a couple of hours for maintenance work on all platforms. The purpose is to improve performance of the stats system, to reduce/eliminate stats outages. Zh1nt0 will get back to you with a more accurate timing for the downtime on Monday. If you have a lot of time to kill, this thread contains some background info. |
#7011 | |
Postovi: 2,241
![]() Jednu sam večer našao server sa tom mapom i 1000ticketa po rundi a samo se ta mapa vrti gore, e predobra zabava za mene i moj stil igre, kada se hoću sčilat od strke i panike onda odem na tu mapu! Isto tako sam jedno 10 minuta rejpao nekog snajperistu koji je uporno bio glup i spawnao se tu a ja sam ga uporno svaki put sašio i dakako svakoga tko je pomislio ući u heliće ![]() ![]()
![]() RedGreenBlue |
#7012 | |
Bajker s AMD-om na dresu
Postovi: 960
samo jedno malo pitanje : brončani, srebrni i zlatni dogtagsi : kako se dobivaju. Mislim znam kako se dobivaju dogtagsi, ali o čemu ovisi brončani, srebrni ili zlazni. Je ima neka podjela na levele ili? |
#7013 | |
Lokacija: Kroejša
Postovi: 107
#7014 | |
Postovi: 1,398
#7015 |
Lokacija: Split,Hrvatska(Croatia)
Postovi: 313
Iman jedno pitanje.... posudia mi je prijatelj svoj EA account sa original BFBC2 naravno, na kojem ima svoja dva lika koja inace igra.. e sad.. problem je sta ja nemam original instalaciju i naravno mora san skinit onu "drugu" , i uglavnom, ja normalno sve patcham udjem u igru ulogiram se uredno na account vidim statse, vidim likove, ALI nemogu niti jedan server naći niti se mogu joinat igdi kad stisnen play now, samo mi kaze no available games, zašto? ![]() |
#7016 | |
LateralusX
Postovi: 1,788
![]() odi u server browser i tamo se spoji na neki europski server btw. ne moras igrati s njegovim likovima, mozes napraviti novog, ali svi ce biti vezani za jedan EA account ![]() |
#7018 |
Postovi: 313
Nisam koristia njegov key(kupia ga je preko neta i otkad je rega sebi account nema blage veze di mu je key),nego sam kreka.., update sam napravia normalno... i normalno mi se uloga na account njegov i vidin sve charactere i statse (znam da mogu napravit svog lika al mi to nije bitno).....prije mi je radilo normalno bez obzira na crack... a sad nece neznan zasto ![]() btw server browser mi ne nalazi nijedan server... Zadnje izmijenjeno od: B@re. 23.01.2011. u 19:04. |
#7019 |
Lokacija: Beertopia
Postovi: 2,013
Dok te netko od modova još nije vidio makni ovaj dio kraj skidrow (za svoj acc to učini) a i ako se logiraš preko njegovo acca zar nije logično da si instalirao preko njegova keya ? :S
54' / 74' / 90' / 2014
I'm only here to see how the story unfolds. Any self-respecting leading man would do the same. Zadnje izmijenjeno od: panda505. 23.01.2011. u 19:14. |
#7020 |
a ti si ga mudro citirao tako i ako editira opet ostaje ![]() inace, mora se koristiti origigi cd key prilikom instalacije inace nema nista od igranja online. |
