Staro 07.01.2011., 15:39   #1
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Corsair Obsidian Series 650D
Corsair Announces Obsidian 650D Mid-Tower Case
Corsair, a worldwide designer and supplier of high-performance components to the PC gaming hardware market, today announced the Corsair Obsidian Series 650D case, the latest addition to its highly-acclaimed Obsidian Series. With a number of innovative features, the first Obsidian Series case—the 800D—garnered worldwide recognition as one of the most builder-friendly cases available, and quickly became a favorite among water-cooling enthusiasts and case modders alike.
The new Obsidian Series 650D brings many of the favorite features of the Obsidian Series—simple, clean design; an innovative cable routing system; room for water cooling; and ample space for even the most complex systems—to a mid-tower case. The 650D also incorporates the same high-quality construction and materials the Obsidian Series is known for, including a rugged steel skeleton and stylish brushed aluminum faceplate.
“As soon as the original Obsidian Series 800D full-tower case was launched, we began to receive an unbelievable number of requests for a smaller, mid-tower version. The rich feature set of the 650D is the result of the direct communication we have with our customers,” said Ruben Mookerjee, VP and General Manager for Components at Corsair. “We are pleased to be able to work with such passionate customers, and equally enthusiastic engineers, to bring high-quality products like the 650D to market.”
In addition to the features already described, the Corsair Obsidian Series 650D includes a windowed side panel, 200mm front-mounted intake and top-mounted exhaust fans with external fan speed control, eight PCI expansions slots, room for both 1x120 and 2x120mm radiators, as well as an external SATA 6Gbps (SATA Revision 3.0) hot-swap dock. The 650D also features a generous CPU cutout to make installing a CPU cooler simpler, easy-to-open side panels, and tool-free 5.25” and 3.5” drive bays, making the 650D just as builder-friendly as its full-tower predecessor. It has ample room to fit even the longest graphics cards, and the SSD-ready 3.5” drive bays can be reconfigured easily for even more room or improved airflow. And finally, with plenty of space behind the motherboard tray, your cable routing will always be neat and tidy with minimal effort.
The Corsair Obsidian Series 650D is expected to be available in April, 2011, from Corsair's worldwide network of authorized distributors and resellers. It has a Manufacturer’s Suggested Retail Price of $199.99 and is supplied with a 2-year warranty. Like all Corsair products, the Obsidian Series 650D is backed by Corsair’s highly regarded customer service and technical support.
C L O W N I N G A R O U N D
Zadnje izmijenjeno od: Doink the Clown. 07.01.2011. u 16:26. Razlog: linkić dodan
Staro 07.01.2011., 16:04   #2
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
nevalja ništ ...al opet min. 1500kn :S
SetH je offline   Reply With Quote
Staro 07.01.2011., 18:21   #3
prt scr
Datum registracije: Jan 2011
Lokacija: wild west
Postovi: 321
nice,sa prozorom
prt scr je offline   Reply With Quote
Staro 07.01.2011., 19:34   #4
Doink the Clown
Postovi: 6,214
Malo više slika i podataka na službenom linku:
http://www.corsair.com/cases/obsidia...ries-650d.html
Staro 07.01.2011., 19:56   #5
gunther
Postovi: 1,367
Original Obsidian mi je djelovao malo preglomazno, ovaj djeluje sasvim pristojno...
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 07.01.2011., 20:31   #6
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
dostojna zamjena stackera?hm..
Staro 07.01.2011., 20:33   #7
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Ako kućišta budu dolazila ovim tempom, nećemo ga dočkat prije 6. mjeseca.
fran123456 je offline   Reply With Quote
Staro 07.01.2011., 20:38   #8
gunther
Postovi: 1,367
Autor SetH Pregled postova
A cuj, trenutno imam Stackera i dva Anteca 300, pa sto nebi imo i jednog Obsidiana
Staro 07.01.2011., 20:42   #9
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
Autor gunther Pregled postova
ako nestane u corsaira gajba pive kao u stackera...neznam onda
Staro 07.01.2011., 20:51   #10
gunther
Postovi: 1,367
Evo malo surfam i vidim da se naprijed moze stavit iskljucivo 200 mm vent, nema podrske za 120/140 mm
Grozno
Staro 07.01.2011., 20:57   #11
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
danas ih ima di očeš tako da to nije problem
Staro 07.01.2011., 21:01   #12
gunther
Postovi: 1,367
120 mm na 500/600 rpm mi je dovoljno...
tise nego 200 mm na 500/600
I nema razloga ogranicavat mogucnost izbora...
...mene je recimo ovaj podatak malo ohladio
Staro 08.01.2011., 01:11   #13
alengrosevic
alengrosevic's Avatar
Postovi: 3,781
slazem se u potpunosti. dobar case mora biti i velik. nije da je ovaj los, vjerojatno je jako dobar, ali imati malo kuciste, to jednostavno nije to.
Inace je lijepo da je corsair poceo misliti i na ljude kojima treba mid kuciste, samo da ne zeznu kao sa novom cx serijom napajanja...
Staro 08.01.2011., 23:41   #14
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Kućište je kao monolit puno ljepše nego veliki brat 800D.
No i dalje mi nije jasno kako svi proizvođači guraju ovoliko rupa za kablove na vidljivim mjestima?
Stavite rupe pod matičnu ploču! Ako je gužva s kablovima, ne stanu, predebeli su pa smetaju matičnoj, bočna stranica se ne može zatvoriti, pa pobogu imate računala, projektirajte nešto sa većim distancerima i sa više mjesta iza mobo traya.
Spoiler alert!
Staro 09.01.2011., 00:25   #15
Thundercool
Plebium
Thundercool's Avatar
Lokacija: Sisak
Postovi: 156
Sve super sve 5 ali sto ici na toga Obsidijena kad 600T vec drzi midi tower dio trzista.
600T ima estetiku na svojoj strani i sve prednosti ovoga Obsidijena.
CX serija napanjanja ima svoje kupce ali ovaj Obsidijen nece imati ako izadje 600T edicija s prozorom(iako je i bez prozora cisti win), jer tko bi pobogu uzeo bilo sta osim 600T(po meni najbolje MID kuciste "in the world").
Thundercool je offline   Reply With Quote
Staro 09.01.2011., 00:31   #16
Doink the Clown
Postovi: 6,214
Autor Thundercool Pregled postova
A čuj, zašto ne bi izbacili više od jednog mid tower kućišta?
Nekome će se više svidjeti kako izgleda 600T nekome 650D, još i bolje da šire ponudu pa da za svaki ukus bude ponešto kad već nema baš za svaki džep.
Staro 09.01.2011., 00:41   #17
Thundercool
Plebium
Lokacija: Sisak
Postovi: 156
Da u pravu si i sve dalje je raspravljanje o ukusima.
Ali ako nekoga bas zanima: "
Obsidian 800D je Velicina i "Monolith Effect" sto se gubi kad se prelazi u MIDI range,"
Zadnje izmijenjeno od: Thundercool. 09.01.2011. u 00:42. Razlog: 800D
Staro 05.03.2011., 15:33   #18
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Staro 05.03.2011., 15:43   #19
dzeneral
Valar morghulis
dzeneral's Avatar
Postovi: 280
Jesu mogli naći još većeg kretena za video?
"The objective of war is not to die for your country, but to make the other bastard die for his."
dzeneral je offline   Reply With Quote
Staro 05.03.2011., 15:47   #20
Postovi: 8,223
Meni je ovo kućište ljepše nego 600T, baca mi na LianLi a to je win odmah, plus prozor. Jedino što mi se nesviđa su ove kopče na toj bočnoj stranici.
Staro 05.03.2011., 15:55   #21
Postovi: 34,029
Meni bi bez plexija bio ljepši. btw, na neweggu je 200$.
http://www.newegg.com/Product/Produc...-004-_-Product
Staro 05.03.2011., 16:19   #22
GetRight
GetRight's Avatar
Datum registracije: Apr 2009
Lokacija: Frkjevci
Postovi: 344
Autor dzeneral Pregled postova
Ma lik je legenda
CPU: Phenom II x4 960T@Phenom II x6 1605T
MBO: ASRock 880G Extreme 3
RAM: 2x4GB DDR3 Corsair Vengeance Red
HDD: Hitachi 320GB
VGA: VTX3D Radeon HD 6850
PSU: Coolermaster 600w Silent Pro
Monitor: Samsung SM 2233BW
OS: Windows 7 Ultimate
Ostalo: CM 690 II Advanced,ROCCAT Kone[+]
CPU: Phenom II X2 555 BE@Phenom II X4 B55
MBO: ASRock M3N78D
RAM: 2x2GB DDR3 Corsair XMS3-1600
HDD: WD 320GB,Hitachi 160GB SATA
VGA: Sapphire Radeon 5670 512MB DDR5
PSU: XFX Core Edition 450W
Monitor: 17 "Dell E173FP
OS: XP Pro SP3
Ostalo: Thermaltake VC3000BWS
GetRight je offline   Reply With Quote
Staro 05.03.2011., 16:42   #23
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
kaj fali linusu? lik je baš ok
da, otkad su izašla corsair kučišta, najljepši su mi, predobar je ovaj 650D, za moju kantu bi bio fenomenalan
sviđa mi se crno, kockasto kučište ravne prednje strane bez ikakvih izbočina..
samo kaj moram dić kredit da si ga kupim
T0mB1ll je offline   Reply With Quote
Staro 05.03.2011., 16:44   #24
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Izgleda da su pomaknuli gumene rupe za vodeno sa vrha na sredinu stražnjeg dijela, kao na 600T. Ako sam dobro vidio gore ipak ima rupa gdje se mogu provuć prednji USB 3.0 kablovi da se ne moraju vuć preko matične kao na 600T jer su prekratki (na 600T barem).
Ovo je hibrid između 600T sa zakrivljenim linijama i Obsidian "monolith" serije, moram reć da mi nije nešto iako pretpostavljam da ima popravljene neke nedostatke nad prethodna 3 modela. Ali to je moje subjektivno mišljenje.
Linus je ok, pogledaj više njegovih filmića i vidjet ćeš. Vjeruj mi, daleko najmanje iritantan lik (uz TTL-a sa OC3D) od većine review-era na YT.
Zadnje izmijenjeno od: T}{OR. 05.03.2011. u 18:06.
Staro 05.03.2011., 18:17   #25
GetRight
GetRight's Avatar
Lokacija: Frkjevci
Postovi: 344
Autor coconut Pregled postova
Stvar ukusa,meni osobno taj plexi razbija monotiniju "obične" stranice.Kao ovo,samo primjer(model 700).
http://www.corsair.com/media/catalog...top-angled.png
HDD: Hitachi 320GB
MBO: ASRock M3N78D
OS: XP Pro SP3
Staro 05.03.2011., 19:49   #26
Bluzer
Bluzer's Avatar
Lokacija: localhost
Postovi: 1,073
Autor GetRight Pregled postova
Stvar u tome je šta taj plexi izgleda kao jeftini aftermarket kit sa tim ružnim debelim rubom, moglo se to i puno ljepše napraviti. Ovako je samo
Staro 05.03.2011., 20:13   #27
BojanZD
BojanZD's Avatar
Postovi: 1,398
Meni puuuno bolje od 600T...pa nije valjda da će bit 1500kn..smrc!!
Za 600T stalno imam neki dojam da je unutra vruće,hebat ga?!
Vjerovatno nije, al sumnja ostaje.
BojanZD je offline   Reply With Quote
Staro 05.03.2011., 21:52   #28
Doink the Clown
Postovi: 6,214
Autor BojanZD Pregled postova
A i ti svašta znaš napisati
Čemu sad ovo?
Staro 05.03.2011., 21:58   #29
Postovi: 8,223
Omg, ona 2 ogromna venta i vruće. Mislim znam da je tebi sad slabo sve što se nezove delta, al netreba pretjerivat
Staro 05.03.2011., 22:26   #30
GetRight
GetRight's Avatar
Lokacija: Frkjevci
Postovi: 344
Autor Bluzer Pregled postova
Ko što sam i rekao stvar je ukusa,a o ukusima se ne raspravlja.Sad da li su mogli poraditi na tom rubu,dalo bi se pričati.Ali opet estetski mi je prihvatljivije od monotone pune stranice.
HDD: Hitachi 320GB
MBO: ASRock M3N78D
OS: XP Pro SP3
