Povratak   PC Ekspert Forum > Računala > Overclocking > Memorije
Staro 29.12.2010., 11:45   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Koliko je sporija kombinacija 3x4GB od 2x4GB/4x4GB DDR3?
Dilema;
Imam potrebu za 12GB DDR3. Dakle 3X4GB.
To će ići u konfu baziranoj na 880G Extreme3 + Phenom X6 sa umjerenim OCem.
Ako stavim 3 keksa, to vjerojatno znači da ne radi dual-channel. Koliki je gubitak performansi zbog toga u praksi? Isplati li se uzimati još i 4. keks?
Hvala,
Pozdrav
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 29.12.2010., 11:51   #2
Momir
Momir's Avatar
Postovi: 1,011
A cuj, ako imas potrebu za 12GB memorije, onda nema smisla uzimati tocno 12GB. Uvjek ce biti jos neka sitnica koja ce tu i tamo pojesti jos nesto.
Ako zaista imas potrebu za tolikim ramom i ako mozes si to priustiti, onda nema razloga da neuzmes 4*4GB.
Momir je offline   Reply With Quote
Staro 29.12.2010., 11:55   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Trebam nešto više od 8Gb. Recimo 8-10. I nije luksuz nego potreba, zbog posla.
Imam razloga za ne uzeti 16. Lova, naravno. Kod mene je još uvijek recesija.
Ali da sad izostavimo polemiku oko love i potreba, može li odgovor na moje pitanje;
Hoće li uopće, i koliko sporije će biti 3X4GB DDR3 u odnosu na 2X4 ili 4X4GB?
U praksi, naravno.
Zadaća konfiguracije; render mašina za 24h full load.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 29.12.2010., 13:10   #4
krzljavi
Lokacija: Križ
Postovi: 87
mislim da je bolje da su 4x3gb tako da oba rade u dual channelu ako već treba toliko rama...
krzljavi je offline   Reply With Quote
Staro 29.12.2010., 13:22   #5
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Pitanje je; koliko je efikasno sporije bez Dual Channela!?
EDIT:
Wiki kaže:
There have been varying reports as to the performance increase of dual-channel configurations, with some tests citing significant performance gains while others suggest almost no gain.
Tom's Hardware found little significant difference between single-channel and dual-channel configurations in synthetic and gaming benchmarks (using a "modern" system setup). In its tests, dual channel gave at best a 5% speed increase in memory-intensive tasks.[3] Another comparison by laptoplogic.com resulted in a similar conclusion for integrated graphics.[4] The test results published by Tom's Hardware had a discrete graphics comparison.
The difference can be far more significant in applications that manipulate large amounts of data in memory. A comparison by TechConnect Magazine demonstrated considerable gains for dual-channel in tasks using block sizes greater than 4 MB, and during stream processing by the CPU
Pretpostavljam da mi ni ovdje nitko neće preciznije odgovoriti.
4X4 onda.
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 29.12.2010. u 17:56.
